Results 1 to 4 of 4
Thread: MOSFET for teensy 3.2?
    May 2020
    London
    2
    Can anyone recommend a MOSFET to use on a teensy 3.2 board bearing in mind its 3.3v limitation on the MOSFET gate. I wish to switch on a small string of 12V lcd's with PWM capability. TIA Len
    Apr 2020
    7
    I'm using these
    with a Teensy 4 and 24V LEDs.
    Dec 2016
    Montreal, Canada
    3,319
    RFP30N06
    Logic level mosfets
    May 2020
    London
    2
    Thanks Keith. What value resistor would you suggest from gate to ground bearing in mind I will have 3.3v signal?
