Results 1 to 12 of 12
Thread: Acquiring/Sending JPG Snapshot from IP camera using Teensy 4.1
    I am very excited to hear of the speed and memory of the Teensy 4.1
    I have been trying to do this for a while, namely take a snapshot (1920 x 1000 jpg) from an IP camera and send the image byte array via Ethernet to another computer. I do not have a need to store the image on disk. So basically take a snapshot using the camera CGI command, then send the image byte array via Ethernet to another computer in a time not exceeding a few seconds.
    Can the Teensy 4.1 do that? Is there any sample code?
    Thanks in advance to the community.
    11,853
    IP camera? Wired ethernet?
    May 2020
    14
    cgi seems to mean that you want todo an HTTP request ? get that response..extract the image and then send it out via tcp again..?
    Yes, correct. But could also be wireless.
    Yes @maxman. This is exactly what I am trying to do ...
    May 2020
    14
    using a teeny/arduino board aims for solving problems at a lower level...
    means things you wanna accomplish are quite difficult compared to a 20$ openwrt router with linux and some bash script.
    so you might wanna thing about how you want to solve your task.
    this is completly doable with a teensy, but involves quite some low level knowledge and experience...
    Quote Originally Posted by maxman View Post
    Thank you @maxman. Indeed it can be done with a wrt router or a PI but my knowledge of Linux is very basic. On the other hand, the combination of a Teensy 4.1 and the Tennsy 4.1 Ethernet board seems to be very promising from a hardware standpoint.
    Oct 2015
    Roma (IT, EU)
    336
    Quote Originally Posted by jimmie View Post
    What you ask is more typical work for a Linux Single-Board Computer (i.e. Raspberry Pi and the likes) than for a microcontroller.
    It can still be done, but it involves quite more work.
    Basically you need to write an HTTP(S) client, manage the reply in chunks to fit an appropriate FIFO / circular buffer, create and send Ethernet packets.
    Not the easiest of tasks; I'm not sure any code base exists to do HTTP over the Teensy Ethernet, which is quite new itself.
    Now, if you wanted to acquire frames from a directly-attached parallel camera (say OV7670, OV7725) and send them over Ethernet, that would be more typical work for an MCU.
    Thank you @XFer for explaining the steps.
    I thought there are some HTTP client libraries available (https://github.com/arduino-libraries/ArduinoHttpClient), so is the bottleneck still memory? The Teensy 4.1 can have more memory added (below the board). Is that still not enough?
    Oct 2015
    Roma (IT, EU)
    336
    I'm not sure they are compatible with Teensy Ethernet; they seem to rely upon an underlying TCP stack (for example by WiFi101, ESP8266 etc.).
    Anyway there is an example for T4.1 Ethernet, it's called "WebClient": you may want to start studying it. It is installed by the latest Teeensyduino setup (v1.52). Remember to select Teensy 4.1 as a board to have access to the example from the IDE.
    Memory can be a problem, yes, because a FullHD image can be larger than the max contiguous byte array a Teensy can hold:
    https://www.pjrc.com/store/teensy4_memory.png
    You may want to manage the HTTP request in chunks with a circular buffer, or you may try adding a PSRAM chip to the Teensy (or even 2, for 16 MB total). But the PSRAM support is still in its early phase; there are more infos about that in the "Teensy 4.1 beta" thread.
    May 2020
    14
    also have a look at these example network stuff: https://github.com/vjmuzik/NativeEth...aster/examples
    thats code for the teensy 4.1
    Thank you for helping. There is a lot of useful info in your post which will guide me to the areas I need to concentrate on.
