Results 1 to 4 of 4
Thread: >1Mohm impedance on Teensy 3.2 analog inputs?
    Sep 2019
    17
    The datasheets for these resistive position sensors say that impedance needs to be >1Mohm for accurate performance:
    https://www.murata.com/~/media/webre...tion/r51e.ashx
    https://industrial.panasonic.com/cdb.../ARE0000C1.pdf
    Do I need to add anything to the connection from position sensor to Teensy 3.2 analog input pin to achieve >1Mohm impedance? Capacitors, resistors, inductors?
    If it makes a difference, the wire lengths from position sensor to Teensy will be 5-20cm.
    Thanks.
    Oct 2012
    Portland OR
    689
    What resolution and sample rate or bandwidth do you need? You could simply put a 1M resistor in series, that would make your sensor happy, but the Teensy ADC unhappy (either extremely high noise, and/or slow response with a filter capacitor, due to RC time constant). Normally with such a high impedance requirement you would use an active device, like a buffer opamp between the sensor output and the ADC input.
    Germany NRW
    6,906
    It's more in the range of 100k.
    Sep 2019
    17
    Thanks for mentioning opamps. With that hint I found this article which goes into more detail about the tradeoffs involved in driving an MCU ADU with a resistive voltage divider:
    https://www.embeddedrelated.com/showarticle/110.php
