Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 51
Thread: Targeting Teensy 4.1 uses 5x as much dynamic memory as Teensy 3.6
    Oct 2018
    8
    This is only a curiosity at this point. I have been working on a project using the Teensy 3.6 and decided it would be interesting to see if it would even compile when targeting the Teensy 4.1. I switched from using TeensyDelay for the timers, to using TeensyTimerTool in order to get it to compile without error. I am using Teensyduino 1.52 / Arduino 1.8.12. The 5X increase in dynamic memory strikes me as being a bit unusual, so I am only interested in knowing if this could possibly be expected.
    This is memory usage when compiled for the Teensy 4.1:
    Sketch uses 114272 bytes (1%) of program storage space. Maximum is 8126464 bytes.
    Global variables use 139956 bytes (26%) of dynamic memory, leaving 384332 bytes for local variables. Maximum is 524288 bytes.
    This is memory usage when compiled for the Teensy 3.6:
    Sketch uses 107216 bytes (10%) of program storage space. Maximum is 1048576 bytes.
    Global variables use 25484 bytes (9%) of dynamic memory, leaving 236660 bytes for local variables. Maximum is 262144 bytes.
    The project uses the following libraries:
    Using library ILI9341_t3 at version 1.0
    Using library SPI at version 1.0
    Using library ADC at version 8.0
    Using library SdFat-beta-master at version 2.0.0-beta.6
    Using library USBHost_t36 at version 0.1
    Using library TeensyTimerTool-master at version 0.1.9
    Using library Encoder at version 1.4.1
    Using library XPT2046_Touchscreen at version 1.3
    I would like to see if I can move my project to the Teensy 4.1 without major breadboard changes. That is what prompted me to do this comparison, without knowing how practical it might be to make the change.
    Thanks,
    Chuck
    Oct 2015
    Roma (IT, EU)
    357
    With the "Blink" example it's even worse: using "Faster" (1.8.12 + 1.52)
    BLINK
    T3.6:
    Sketch uses 10724 bytes (1%) of program storage space. Maximum is 1048576 bytes.
    Global variables use 3828 bytes (1%) of dynamic memory, leaving 258316 bytes for local variables. Maximum is 262144 bytes.
    T4.1:
    Sketch uses 14688 bytes (0%) of program storage space. Maximum is 8126464 bytes.
    Global variables use 41660 bytes (7%) of dynamic memory, leaving 482628 bytes for local variables. Maximum is 524288 bytes
    Oct 2018
    8
    Interesting, thanks for that information. I never thought about trying the simple case.
    8,904
    My guess it is something like, differences in some of the buffers, like USB. And of course you do have the other 256KB of DMAMEM available to you as well.
    24,021
    On Teensy 4.x, the main 512K RAM1 bank is divided into ITCM and DTCM, where I=Instructions and D=Data. ITCM is used by default for functions, unless you add "FLASHMEM" to them. The FlexRAM hardware supports memory partitioning in 32K chunks, so even if you have only 1 small function in ITCM, a minimum of 32K must be allocated. Most of that memory usage Arduino is reporting is one 32K chunk dedicated to ITCM.
    ITCM is basically zero wait memory with a wide 64 bit bus directly to the M7 processor. Code runs extremely fast from ITCM. Caching is never used with ITCM because it's as fast as the M7 caches, so you also get very consistent & deterministic speed.
    All code not in ITCM shares a 32K cache. Usually that gives excellent performance for normal code, though cache misses are quite slow if the code is executing from the flash chip (what "FLASHMEM" does). Normally FLASHMEM is used with startup code. But if your program becomes large, you would probably want to start using FLASHMEM on functions where performance is less important.
    Oct 2018
    8
    KurtE and Paul: Thanks, sounds like it is to be expected. The 4.1 has more than enough memory for me even with this, so it is good to know nothing bad is going on. I am new to all of this, so it is great to have this forum as a resource. I will go ahead and order a 4.1 to experiment with in parallel with my several 3.6 modules while continuing to work on the project.
    Thanks again.
    Oct 2015
    Roma (IT, EU)
    357
    Excellent explanation Paul, thanks.
    To be honest there were already bits of explanations across the various 4.x topics, but this message should really be in the T4.x web pages, IMHO.
    13,784
    This product page has lots of 4.0 details that generally apply to 4.1 as well for the 1062 aspects:: pjrc.com/store/teensy40.html
    It gives a larger explanation of memory on the 1062 processor
    8,230
    Yup.
    quote. "Teensy 4.0 is the latest Teensy, "
    "Teensy 3.6Teensy 3.6 with Pins – The Most Powerful Teensy"
    I'll take a break.
    13,784
    Teensy 4.0 is the latest Teensy, offering the fastest microcontroller and powerful peripherals in the Teensy 1.4 by 0.7 inch form factor
    too picky Frank ... full context:
    Teensy 4.0 is the latest Teensy ... in the Teensy 1.4 by 0.7 inch form factor
    And to update for the T_4.1::
    Teensy 4.1 is the latest Teensy ... in the Teensy 2.4 by 0.7 inch form factor
    Good to see updates on the PJRC website
    8,230
    Interrupt Service Routine Syntax
    To use interrupts, you must include the AVR interrupt header.
    #include <avr/io.h>
    #include <avr/interrupt.h>
    --etc
    For debug:
    #include <usb_debug_only.h>
    --etc
    Oct 2015
    Roma (IT, EU)
    357
    A user reads this (Teensy 4.0):
    https://www.pjrc.com/store/teensy40.html
    "1024K RAM (512K is tightly coupled)
    2048K Flash (64K reserved for recovery & EEPROM emulation) "
    And this (Teensy 3.6):
    https://www.pjrc.com/teensy/techspecs.html
    "256K RAM
    1024K flash"
    and should figure out by himself that actually there are cases where his sketches could fit the 3.6 but not the 4.x?
    I humbly think this is asking too much.
    8,230
    There could be a very simple fix for this which would make the T4.x more compatible to the older models by optionally switching to a different linkage.
    But this has not found much love I don't know why. ... which reminds me, I still have to close the PR.
    13,784
    Referring to this work Frank? - just posted on similar thread :: T4-0-Memory-trying-to-make-sense-of-the-different-regions
    8,230
    yes.
    For the history: This is the now closed pull request (without the boards.txt - did not know where to do a PR for it.)
    https://github.com/PaulStoffregen/cores/pull/440
    3,127
    That is why I use Makefiles for projects that do not need to be Arduino compatible, or where the word Arduino has a bad taste.
    8,230
    Since the weather is getting better now and I have other hobbies and will move, I will leave this forum again for a while.
    @all: Stay healthy. Keep the distance.
    Best wishes,
    Frank.
    Oct 2015
    Roma (IT, EU)
    357
    Indeed it would be an excellent solution.
    For example, it could have been called automatically by the toolchain when the user selects "Smallest Code" (which means it has memory occupation issues).
    13,784
    Best wishes,
    Frank.
    Moving? A new residence - or getting out for exercise moving?
    Stay well, looking forward to your next posts.
    8,230
    A new residence.
    @WMXZ, why not do a step more and switch to MBED or MCUxpresso?
    I'll use the time off to think about it.
    8,230
    Quote Originally Posted by johanbilen View Post
    I agree with this.
    I recently ported my project (designed and printed out new PCBs, bought the new Audio Adaptor for 4.1) from T3.5 (96% Dynamic Memory) to T4.1 and found out that my brand new 4.1 doesn't have enough memory :-(
    I thought that moving over to 4.1 would enable me to add more functions to my project, instead I have to remove features...
    "data section exceeds available space in board".
    Yes, have you asked NXP about this? What is their excuse? What do they say?
    A bit more serious: There are several issues that may play a role.
    Easiest: The printed sizes that you can see at the end of the compilation are just wrong. I'd say it would be better without them..but..ok..
    For T4.x, it prints too high RAM usage, too low FLASH usage. The latter will be fixed with TD 1.54 release.
    T4 copies the code from FLASH to RAM. This way, it executes faster.
    Obviously: the larger your code is, the less usable RAM you'll have.
    There are at least three ways to "fix" this:
    a) use the FLASHMEM keyword (Macro) - esp. for functions that are not speed-sensitive.
    Example: FLASHMEM void foo() {...}
    This way, it gets not copied to RAM. (Note: RAM for code gets allocated in 32KB Blocks.)
    b) use the HEAP. It is located in the 2nd big RAM area -> Use getMem() and new().
    c) modify the linker file. It's possible to link in a way that all the code stays in FLASH. I've shown such files for a earlier Teensyduino version, but its unlikeley that they still work and they'll need some attention to update them.
    Edit:
    And use the PROGMEM macro for const arrays:
    PROGMEM const int xyz[12345] = {...
    8,230
    Can you show one of them? Maybe there is an easy fix. And pls. see my answer #21 to your deleted post.
    The "not enough memory" issue disappears when I disable this code:
    // ACTIONS PERFORMED WHEN GATE 1 IS HIGH/LOW
    void actionsReadGate1(int state){
      switchGate(1,state);
      if(state){
        switch(parameterStructure[sample1Select].value){
          case 0:playSample1.play(bpb606bd04);break;
          case 1:playSample1.play(bpb606ch01);break;
          case 2:playSample1.play(bpb606ch02);break;
          case 3:playSample1.play(bpb606ch11);break;
          case 4:playSample1.play(bpb606ch12);break;
          case 5:playSample1.play(bpb606oh01);break;
          case 6:playSample1.play(bpb606sd02);break;
          case 7:playSample1.play(bpb606sd04);break;
          case 8:playSample1.play(bpb606sd07);break;
          case 9:playSample1.play(bpb606sd09);break;
          case 10:playSample1.play(bpb909bd01);break;
          case 11:playSample1.play(bpb909bd09);break;
          case 12:playSample1.play(bpb909cp02);break;
          case 13:playSample1.play(bpb909hh01);break;
          case 14:playSample1.play(bpb909oh01);break;
          case 15:playSample1.play(bpb909sd01);break;
          case 16:playSample1.play(bpb909sd10);break;
          case 17:playSample1.play(dreamingofmebd);break;
          case 18:playSample1.play(justcantbd);break;
          case 19:playSample1.play(whatsyourbd);break;
          case 20:playSample1.play(dreamingofmesd);break;
          case 21:playSample1.play(justcantsd);break;
          case 22:playSample1.play(themeaningsd);break;
          case 23:playSample1.play(whatsyoursd);break;
          case 24:playSample1.play(justcantperc);break;
          case 25:playSample1.play(casiobd);break;
          case 26:playSample1.play(casiosd);break;
          case 27:playSample1.play(casiohh);break;
  24. #24
    8,230
    SHow
    bpb606bd04
    for example.
    Or just add PROGMEM to all samples: Like here: https://github.com/PaulStoffregen/Au...egister.cpp#L6
  25. #25
    SHow
    bpb606bd04
    for example.
    // Audio data converted from WAV file by wav2sketch
    #include "bpb606bd04.h"
    // Converted from bpb606bd04.wav, using 44100 Hz, u-law encoding
    const unsigned int bpb606bd04[10561] = {
    0x0100A484,0x87840082,0x7D6E481A,0x7E7F7F7F,0x7E7E7E7E,0x7D7D7E7E,0x7D7D7D7D,0x7C7C7C7D,
    0x7C7C7C7C,0x7B7B7B7C,0x7B7B7B7B,0x7A7A7B7B,0x75797A7A,0x6D6F7172,0x66686A6B,0x61626365,
    0x585A5D5F,0x4E515355,0x38404549,0xA2951B2F,0xC8C3B9AA,0xD5D2D0CD,0xDDDBD9D7,0xE3E2E0DF,
    0xE7E6E5E4,0xEBEAE9E8,0xEEEDECEB,0xF1F0F0EF,0xF2F2F1F1,0xF4F3F3F3,0xF5F5F4F4,0xF6F6F6F5,
    0xF7F7F7F7,0xF8F8F8F8,0xF9F9F9F9,0xFAFAFAF9,0xFBFBFAFA,0xFBFBFBFB,0xFCFCFBFB,0xFCFCFCFC,
    0xFBFBFCFC,0xFBFBFBFB,0xFAFAFAFB,0xFAFAFAFA,0xF9F9FAFA,0xF9F9F9F9,0xF8F9F9F9,0xF8F8F8F8,
    0xF8F8F8F8,0xF7F7F7F8,0xF7F7F7F7,0xF6F7F7F7,0xF6F6F6F6,0xF6F6F6F6,0xF5F5F6F6,0xF4F4F5F5,
    0xF3F3F3F4,0xF2F2F2F2,0xF0F1F1F1,0xEEEEEFF0,0xEAEBECED,0xE7E8E9EA,0xE3E4E5E6,0xDFE0E1E2,
    0xD7D9DBDD,0xCDD1D3D5,0xB7C0C4C9,0x301E96AD,0x4B464139,0x5754524F,0x5E5D5B59,0x64636260,
    0x69686766,0x6D6C6B6A,0x70706F6E,0x72727171,0x74737373,0x75757574,0x77767676,0x78787777,
    0x77787878,0x77777777,0x77777777,0x76777777,0x76767676,0x76767676,0x76767676,0x75757575,
    0x75757575,0x75757575,0x74747475,0x74747474,0x74747474,0x74747474,0x73737373,0x73737373,
    0x73737373,0x73737373,0x72727272,0x72727272,0x72727272,0x71717171,0x6F707070,0x6D6D6E6F,
    0x6B6B6C6C,0x6869696A,0x66676768,0x64646565,0x61626263,0x5E5F6061,0x595A5C5D,0x54555758,
    0x4F515253,0x46484A4D,0x383D4143,0x19252F34,0xAA968009,0xC1BEB9B4,0xCAC7C5C3,0xD1D0CECC,
    0xD5D4D3D2,0xD9D8D7D6,0xDDDCDBDA,0xE0E0DFDE,0xE2E2E1E1,0xE4E4E3E3,0xE6E6E5E5,0xE8E7E7E6,
    0xE9E9E8E8,0xEBEAEAEA,0xECECECEB,0xEEEDEDED,0xEFEEEEEE,0xF0F0EFEF,0xF0F0F0F0,0xF1F0F0F0,
    0xF1F1F1F1,0xF1F1F1F1,0xF1F1F1F1,0xF2F2F2F1,0xF2F2F2F2,0xF2F2F2F2,0xF2F2F2F2,0xF2F2F2F2,
    0xF2F2F2F2,0xF1F1F2F2,0xF1F1F1F1,0xF1F1F1F1,0xF1F1F1F1,0xF0F0F0F0,0xF0F0F0F0,0xEFEFEFF0,
    0xEEEEEEEE,0xECECEDED,0xEBEBEBEC,0xE9E9EAEA,0xE7E8E8E9,0xE5E6E6E7,0xE3E4E4E5,0xE1E2E2E3,
    0xDEDFE0E1,0xD9DADCDD,0xD4D5D7D8,0xCDD0D1D3,0xC2C5C8CB,0xAAB3B9BF,0x2D21059D,0x43403934,
    0x504D4946,0x56545351,0x5B595857,0x61605F5E,0x64636262,0x67666565,0x6A696868,0x6C6C6B6A,
    0x6F6E6E6D,0x7070706F,0x71717171,0x72727272,0x73737372,0x73737373,0x73737373,0x73737373,
    0x73737373,0x72727373,0x72727272,0x72727272,0x72727272,0x72727272,0x71717171,0x71717171,
    0x71717171,0x71717171,0x71717171,0x70707070,0x70707070,0x70707070,0x70707070,0x70707070,
    0x6E6F6F70,0x6D6D6E6E,0x6B6B6C6C,0x696A6A6B,0x68686869,0x66666767,0x64646565,0x62636364,
    0x61616162,0x5E5F6060,0x5A5B5C5D,0x5758595A,0x53545556,0x50515152,0x494A4C4E,0x41434547,
    0x35383C40,0x1B242C31,0x9C99900A,0xB9B5AFA3,0xC3C2C0BD,0xCAC9C7C5,0xD0D0CECC,0xD4D3D2D1,
    0xD7D6D5D5,0xDAD9D9D8,0xDDDCDCDB,0xE0DFDFDE,0xE1E1E1E0,0xE3E2E2E2,0xE4E4E3E3,0xE5E5E5E4,
    0xE6E6E6E6,0xE8E7E7E7,0xE9E8E8E8,0xEAE9E9E9,0xEAEAEAEA,0xEBEBEBEB,0xECECECEB,0xEDECECEC,
    0xEDEDEDED,0xEEEEEDED,0xEEEEEEEE,0xEEEEEEEE,0xEFEFEFEE,0xEFEFEFEF,0xEFEFEFEF,0xEFEFEFEF,
    0xEFEFEFEF,0xEEEEEFEF,0xEEEEEEEE,0xEEEEEEEE,0xEDEDEEEE,0xEDEDEDED,0xECECECED,0xEBECECEC,
    0xEBEBEBEB,0xEAEAEAEA,0xE9E9E9E9,0xE8E8E8E8,0xE6E7E7E7,0xE5E5E6E6,0xE4E4E4E5,0xE2E2E3E3,
    0xE0E1E1E2,0xDEDEDFE0,0xDADBDCDD,0xD6D7D8D9,0xD1D2D4D5,0xCACDCFD0,0xC1C4C6C8,0xB1B5BABF,
    0x18859EA8,0x39332E26,0x4644413E,0x504E4B49,0x54535251,0x5A585655,0x5F5E5C5B,0x62616060,
    0x64636362,0x66666564,0x68686767,0x6A6A6969,0x6C6C6B6B,0x6E6E6D6D,0x6F6F6F6E,0x70707070,
    0x71717070,0x71717171,0x72727171,0x72727272,0x72727272,0x72727272,0x71717172,0x71717171,
    0x6F6F7070,0x6F6F6F6F,0x6D6E6E6E,0x6C6D6D6D,0x6B6B6C6C,0x6A6A6A6B,0x68696969,0x67676868,
    0x65666667,0x64646565,0x63636364,0x61626262,0x60606161,0x5D5E5F5F,0x5A5B5C5C,0x57585959,
    0x54555656,0x51525354,0x4D4E5050,0x47484A4B,0x41424445,0x35383B3E,0x22282F32,0x9A8E0A19,
    0xABA9A7A3,0xBEBBB7B1,0xC4C3C2C0,0xCBC9C8C6,0xD0CFCDCC,0xD3D2D1D1,0xD5D5D4D3,0xD8D7D7D6,
    0xDBDAD9D9,0xDDDCDCDB,0xE0DFDEDE,0xE1E0E0E0,0xE2E2E1E1,0xE3E3E2E2,0xE4E4E3E3,0xE5E5E5E4,
    0xE6E6E5E5,0xE7E7E6E6,0xE8E7E7E7,0xE8E8E8E8,0xE9E9E9E9,0xEAEAE9E9,0xEAEAEAEA,0xEBEBEBEA,
    0xEBEBEBEB,0xECECEBEB,0xECECECEC,0xECECECEC,0xECECECEC,0xECECECEC,0xECECECEC,0xECECECEC,
    0xECECECEC,0xECECECEC,0xECECECEC,0xECECECEC,0xEBECECEC,0xEBEBEBEB,0xEAEBEBEB,0xEAEAEAEA,
    0xE9E9E9EA,0xE8E9E9E9,0xE8E8E8E8,0xE7E7E7E7,0xE6E6E6E6,0xE5E5E5E5,0xE3E4E4E4,0xE2E3E3E3,
    0xE1E2E2E2,0xE0E0E1E1,0xDDDEDFE0,0xDADBDCDD,0xD7D8D9DA,0xD4D5D6D6,0xD0D1D2D3,0xCACCCECF,
    0xC2C4C6C8,0xB5B9BDC0,0x96A3ABB1,0x2B241A03,0x3F3B3632,0x47454341,0x504E4C4A,0x53535251,
    0x58565454,0x5C5B5A59,0x605F5E5D,0x62616160,0x64636362,0x65656464,0x67676666,0x69686867,
    0x6A6A6969,0x6C6B6B6B,0x6D6C6C6C,0x6E6E6D6D,0x6F6F6E6E,0x706F6F6F,0x70707070,0x70707070,
    0x70707070,0x70707070,0x71717171,0x71717171,0x70717171,0x70707070,0x70707070,0x70707070,
    0x70707070,0x6F707070,0x6F6F6F6F,0x6E6E6E6F,0x6D6D6E6E,0x6C6D6D6D,0x6B6C6C6C,0x6A6B6B6B,
    0x696A6A6A,0x68686969,0x67676868,0x66666767,0x65656566,0x64646465,0x62636363,0x61626262,
    0x60606161,0x5E5F5F60,0x5B5C5D5D,0x595A5A5B,0x56575858,0x54545556,0x51525353,0x4E4F5051,
    0x494A4B4D,0x44454648,0x3E404142,0x3336383B,0x21272C30,0x95870D19,0xAEAAA59F,0xB7B2B0B0,
    0xC2C1BFBC,0xC7C6C4C3,0xCCCBC9C8,0xD0D0CECD,0xD3D2D1D1,0xD5D4D4D3,0xD7D7D6D6,0xDAD9D9D8,
    0xDCDBDBDA,0xDEDEDDDC,0xE0E0DFDF,0xE1E1E0E0,0xE2E2E1E1,0xE3E2E2E2,0xE4E3E3E3,0xE4E4E4E4,
    0xE5E5E5E5,0xE6E6E6E5,0xE7E6E6E6,0xE7E7E7E7,0xE8E8E8E7,0xE8E8E8E8,0xE9E9E9E9,0xE9E9E9E9,
    0xEAEAEAE9,0xEAEAEAEA,0xEAEAEAEA,0xEBEBEBEA,0xEBEBEBEB,0xEBEBEBEB,0xEBEBEBEB,0xEBEBEBEB,
    0xEBEBEBEB,0xEBEBEBEB,0xEBEBEBEB,0xEBEBEBEB,0xEAEAEAEB,0xEAEAEAEA,0xEAEAEAEA,0xE9E9E9EA,
    0xE9E9E9E9,0xE8E8E8E9,0xE8E8E8E8,0xE7E7E7E7,0xE6E6E6E7,0xE5E5E6E6,0xE4E5E5E5,0xE3E4E4E4,
    0xE3E3E3E3,0xE2E2E2E2,0xE1E1E1E1,0xDFE0E0E0,0xDDDEDEDF,0xDBDBDCDD,0xD8D9D9DA,0xD5D6D7D7,
    0xD3D3D4D5,0xD0D0D1D2,0xCACBCDCE,0xC4C5C7C8,0xBBBEC0C2,0xACB1B4B8,0x0B8F9DA5,0x3028231B,
    0x3F3B3834,0x46444341,0x4D4B4A48,0x5251504F,0x54545352,0x59585755,0x5C5B5A5A,0x5F5F5E5D,
    0x61616060,0x63626261,0x64646363,0x65656564,0x67666666,0x68686767,0x69696968,0x6A6A6A69,
    0x6B6B6B6A,0x6C6C6B6B,0x6D6C6C6C,0x6D6D6D6D,0x6E6E6E6D,0x6E6E6E6E,0x6E6E6E6E,0x6F6F6F6F,
    0x6F6F6F6F,0x6F6F6F6F,0x6F6F6F6F,0x6F6F6F6F,0x6E6E6F6F,0x6E6E6E6E,0x6E6E6E6E,0x6D6D6D6E,
    0x6D6D6D6D,0x6C6C6C6D,0x6B6C6C6C,0x6B6B6B6B,0x6A6A6A6A,0x69696A6A,0x68686969,0x67686868,
    0x66676767,0x66666666,0x65656565,0x64646464,0x63636363,0x61626262,0x60616161,0x5F606060,
    0x5D5E5E5F,0x5B5B5C5D,0x59595A5A,0x57575858,0x54555556,0x52535354,0x50505151,0x4B4C4E4F,
    0x4748494A,0x42434445,0x3B3E4041,0x32353739,0x23282C30,0x8908151E,0xA8A49F96,0xB1B1B0AD,
    0xBEBBB6B2,0xC3C2C1C0,0xC8C7C6C4,0xCCCBCAC8,0xD0CFCECD,0xD2D1D1D0,0xD4D3D3D2,0xD6D5D5D4,
    0xD8D7D7D6,0xDAD9D9D8,0xDCDBDBDA,0xDDDDDDDC,0xDFDFDEDE,0xE0E0E0E0,0xE1E1E1E0,0xE2E2E1E1,
    0xE3E2E2E2,0xE3E3E3E3,0xE4E4E4E4,0xE5E5E4E4,0xE5E5E5E5,0xE6E6E6E6,0xE7E6E6E6,0xE7E7E7E7,
    0xE7E7E7E7,0xE8E8E8E8,0xE8E8E8E8,0xE8E8E8E8,0xE9E9E9E8,0xE9E9E9E9,0xE9E9E9E9,0xE9E9E9E9,
    0xE9E9E9E9,0xE9E9E9E9,0xE9E9E9E9,0xE9E9E9E9,0xE9E9E9E9,0xE9E9E9E9,0xE9E9E9E9,0xE9E9E9E9,
    0xE8E8E9E9,0xE8E8E8E8,0xE8E8E8E8,0xE7E7E8E8,0xE7E7E7E7,0xE6E7E7E7,0xE6E6E6E6,0xE5E6E6E6,
    0xE5E5E5E5,0xE4E4E5E5,0xE4E4E4E4,0xE3E3E3E3,0xE2E2E2E3,0xE1E2E2E2,0xE0E1E1E1,0xE0E0E0E0,
    0xDEDFDFDF,0xDCDDDDDE,0xDADBDBDC,0xD8D9D9DA,0xD6D7D7D8,0xD4D4D5D6,0xD2D2D3D3,0xCFD0D0D1,
    0xCACBCCCE,0xC5C6C7C8,0xBFC0C2C3,0xB4B6B9BC,0xA1A7ADB1,0x190C8A98,0x322D2521,0x3D3A3734,
    0x44434140,0x4A484746,0x504E4D4B,0x52525150,0x54545453,0x58585755,0x5B5A5A59,0x5E5D5D5C,
    0x60605F5F,0x61616160,0x63626262,0x64636363,0x65656464,0x66666565,0x67676666,0x68686767,
    0x69696868,0x69696969,0x6A6A6A6A,0x6B6B6A6A,0x6B6B6B6B,0x6C6B6B6B,0x6C6C6C6C,0x6C6C6C6C,
    0x6C6C6C6C,0x6C6C6C6C,0x6C6C6C6C,0x6C6C6C6C,0x6C6C6C6C,0x6C6C6C6C,0x6C6C6C6C,0x6C6C6C6C,
    0x6B6B6C6C,0x6B6B6B6B,0x6B6B6B6B,0x6A6A6A6B,0x6A6A6A6A,0x69696969,0x68696969,0x68686868,
    0x67676768,0x66676767,0x66666666,0x65656565,0x64646465,0x63636464,0x62636363,0x62626262,
    0x61616161,0x60606060,0x5E5F5F60,0x5C5D5D5E,0x5B5B5B5C,0x59595A5A,0x57575858,0x55555656,
    0x53535454,0x51515252,0x4E4F5050,0x4A4B4C4D,0x46474849,0x42434445,0x3C3E4041,0x3537393B,
    0x2A2E3133,0x151D2226,0x9991830C,0xACA8A4A0,0xB1B1B0AF,0xBDBAB6B3,0xC2C1C0BF,0xC6C5C4C3,
    0xC9C9C8C7,0xCECDCCCA,0xD0D0CFCE,0xD2D2D1D1,0xD4D4D3D3,0xD6D5D5D4,0xD7D7D7D6,0xD9D9D8D8,
    0xDBDADAD9,0xDCDCDBDB,0xDEDDDDDD,0xDFDFDEDE,0xE0E0E0E0,0xE1E1E0E0,0xE1E1E1E1,0xE2E2E2E2,
    0xE3E3E2E2,0xE3E3E3E3,0xE4E4E4E3,0xE4E4E4E4,0xE5E5E5E4,0xE5E5E5E5,0xE6E6E5E5,0xE6E6E6E6,
    0xE6E6E6E6,0xE7E7E6E6,0xE7E7E7E7,0xE7E7E7E7,0xE7E7E7E7,0xE7E7E7E7,0xE8E8E7E7,0xE8E8E8E8,
    0xE8E8E8E8,0xE8E8E8E8,0xE8E8E8E8,0xE8E8E8E8,0xE8E8E8E8,0xE8E8E8E8,0xE7E7E7E8,0xE7E7E7E7,
    0xE7E7E7E7,0xE7E7E7E7,0xE7E7E7E7,0xE6E6E6E6,0xE6E6E6E6,0xE5E6E6E6,0xE5E5E5E5,0xE5E5E5E5,
    0xE4E4E4E5,0xE4E4E4E4,0xE3E3E3E4,0xE3E3E3E3,0xE2E2E2E2,0xE1E2E2E2,0xE1E1E1E1,0xE0E0E0E1,
    0xDFDFE0E0,0xDEDEDEDF,0xDCDDDDDD,0xDBDBDBDC,0xD9D9DADA,0xD7D8D8D9,0xD5D6D6D7,0xD4D4D5D5,
    0xD2D2D3D3,0xD0D0D1D1,0xCCCDCECF,0xC7C8CACB,0xC3C4C5C6,0xBEC0C1C2,0xB4B7B9BB,0xA7ABB0B2,
    0x83929CA2,0x231E190F,0x34312F29,0x3D3B3836,0x4342413F,0x47464544,0x4C4B4A49,0x504F4E4D,
    0x52525150,0x54545353,0x55555554,0x59585756,0x5B5A5A59,0x5D5C5C5B,0x5F5E5E5D,0x6060605F,
    0x61616160,0x62626261,0x63636262,0x64646363,0x65646464,0x65656565,0x66666666,0x67676666,
    0x67676767,0x68686867,0x68686868,0x69696968,0x69696969,0x69696969,0x6A6A6A6A,0x6A6A6A6A,
    0x6A6A6A6A,0x6A6A6A6A,0x6A6A6A6A,0x6A6A6A6A,0x6A6A6A6A,0x6A6A6A6A,0x6A6A6A6A,0x6A6A6A6A,
    0x69696969,0x69696969,0x69696969,0x68686969,0x68686868,0x67686868,0x67676767,0x66676767,
    0x66666666,0x65656666,0x65656565,0x64646465,0x63646464,0x63636363,0x62626263,0x61626262,
    0x61616161,0x60606061,0x5F606060,0x5E5E5E5F,0x5C5D5D5D,0x5B5B5C5C,0x595A5A5B,0x58585959,
    0x56575757,0x55555656,0x53535454,0x51525253,0x50505151,0x4D4D4E4F,0x494A4B4C,0x46464748,
    0x42434445,0x3E3F4041,0x37393A3C,0x30323335,0x2226292D,0x0210171E,0xA19B948B,0xADABA8A4,
    0xB2B0AEAF,0xBDBBB8B5,0xC2C1C0BF,0xC5C4C3C2,0xC8C7C6C6,0xCBCAC9C9,0xCECDCCCB,0xD0D0D0CF,
    0xD2D1D1D1,0xD3D3D3D2,0xD5D5D4D4,0xD6D6D6D5,0xD8D8D7D7,0xD9D9D9D8,0xDBDADADA,0xDCDCDBDB,
    0xDDDDDDDC,0xDFDEDEDE,0xE0DFDFDF,0xE0E0E0E0,0xE1E1E0E0,0xE1E1E1E1,0xE2E2E2E1,0xE2E2E2E2,
    0xE3E3E2E2,0xE3E3E3E3,0xE3E3E3E3,0xE4E4E4E4,0xE4E4E4E4,0xE5E4E4E4,0xE5E5E5E5,0xE5E5E5E5,
    0xE5E5E5E5,0xE6E6E6E5,0xE6E6E6E6,0xE6E6E6E6,0xE6E6E6E6,0xE6E6E6E6,0xE6E6E6E6,0xE6E6E6E6,
    0xE6E6E6E6,0xE6E6E6E6,0xE6E6E6E6,0xE6E6E6E6,0xE6E6E6E6,0xE6E6E6E6,0xE6E6E6E6,0xE5E6E6E6,
    0xE5E5E5E5,0xE5E5E5E5,0xE5E5E5E5,0xE4E4E5E5,0xE4E4E4E4,0xE4E4E4E4,0xE3E3E4E4,0xE3E3E3E3,
    0xE3E3E3E3,0xE2E2E2E2,0xE2E2E2E2,0xE1E1E1E2,0xE1E1E1E1,0xE0E0E0E1,0xE0E0E0E0,0xDFDFDFE0,
    0xDEDEDEDF,0xDDDDDDDE,0xDCDCDCDC,0xDADBDBDB,0xD9DADADA,0xD8D8D9D9,0xD7D7D7D8,0xD5D6D6D6,
    0xD4D4D5D5,0xD2D3D3D4,0xD1D1D2D2,0xCFD0D0D0,0xCCCDCDCE,0xC9C9CACB,0xC5C6C7C8,0xC2C3C4C4,
    0xBDBFC0C1,0xB7B8BABC,0xB0B1B3B5,0xA2A6A9AC,0x8390979E,0x1E17140B,0x2F2C2824,0x37353331,
    0x3E3C3A38,0x42414040,0x46454443,0x49484847,0x4D4C4B4A,0x504F4F4E,0x52515150,0x53535352,
    0x55545454,0x56565655,0x59585856,0x5A5A5959,0x5C5C5B5B,0x5D5D5D5C,0x5F5F5E5E,0x6060605F,
    0x61616060,0x61616161,0x62626262,0x63636262,0x63636363,0x64646463,0x64646464,0x65656564,
    0x65656565,0x66666565,0x66666666,0x66666666,0x67676766,0x67676767,0x67676767,0x67676767,
    0x67676767,0x68686867,0x68686868,0x68686868,0x68686868,0x68686868,0x67676768,0x67676767,
    0x67676767,0x67676767,0x67676767,0x67676767,0x66666666,0x66666666,0x66666666,0x65656566,
    0x65656565,0x65656565,0x64646464,0x64646464,0x63636464,0x63636363,0x62626363,0x62626262,
    0x61616262,0x61616161,0x60606061,0x60606060,0x5F5F5F5F,0x5D5E5E5E,0x5C5D5D5D,0x5B5B5C5C,
    0x5A5A5A5B,0x5959595A,0x57585858,0x56565757,0x55555656,0x54545455,0x52525353,0x51515152,
    0x4F505050,0x4C4D4E4E,0x494A4B4C,0x46474849,0x43444546,0x41414243,0x3C3D3F40,0x3638393A,
    0x30323335,0x26292B2E,0x151B2023,0x90860410,0xA3A09C96,0xAAAAA8A6,0xB2B0ABAA,0xBAB9B7B5,
    0xC0BFBDBC,0xC3C2C1C0,0xC5C5C4C3,0xC8C7C7C6,0xCBCACAC9,0xCDCCCCCB,0xD0CFCFCE,0xD1D1D0D0,
    0xD2D2D2D1,0xD4D3D3D3,0xD5D5D4D4,0xD6D6D5D5,0xD7D7D7D6,0xD8D8D8D7,0xDAD9D9D9,0xDBDADADA,
    0xDCDBDBDB,0xDDDDDCDC,0xDEDEDDDD,0xDFDFDEDE,0xE0DFDFDF,0xE0E0E0E0,0xE0E0E0E0,0xE1E1E1E1,
    0xE1E1E1E1,0xE2E1E1E1,0xE2E2E2E2,0xE2E2E2E2,0xE3E3E2E2,0xE3E3E3E3,0xE3E3E3E3,0xE3E3E3E3,
    0xE4E4E4E4,0xE4E4E4E4,0xE4E4E4E4,0xE4E4E4E4,0xE4E4E4E4,0xE4E4E4E4,0xE5E4E4E4,0xE5E5E5E5,
    0xE5E5E5E5,0xE5E5E5E5,0xE5E5E5E5,0xE5E5E5E5,0xE5E5E5E5,0xE5E5E5E5,0xE4E5E5E5,0xE4E4E4E4,
    0xE4E4E4E4,0xE4E4E4E4,0xE4E4E4E4,0xE4E4E4E4,0xE3E3E3E4,0xE3E3E3E3,0xE3E3E3E3,0xE3E3E3E3,
    0xE2E2E2E2,0xE2E2E2E2,0xE2E2E2E2,0xE1E1E1E2,0xE1E1E1E1,0xE1E1E1E1,0xE0E0E0E1,0xE0E0E0E0,
    0xDFE0E0E0,0xDEDFDFDF,0xDDDEDEDE,0xDDDDDDDD,0xDCDCDCDC,0xDBDBDBDB,0xDADADADA,0xD9D9D9D9,
    0xD8D8D8D8,0xD7D7D7D7,0xD6D6D6D6,0xD4D5D5D5,0xD3D4D4D4,0xD2D2D3D3,0xD1D1D1D2,0xD0D0D0D1,
    0xCDCECFCF,0xCBCBCCCD,0xC8C9CACA,0xC6C6C7C8,0xC3C4C4C5,0xC1C1C2C2,0xBCBEBFC0,0xB7B8BABB,
    0xB2B3B4B6,0xAAACAFB0,0x9EA2A4A7,0x838E9499,0x1B130A05,0x29262320,0x32302E2B,0x37363433,
    0x3D3B3A38,0x4140403E,0x44434242,0x47464545,0x49494847,0x4C4B4B4A,0x4F4E4E4D,0x51505050,
    0x52525151,0x53535352,0x54545454,0x56555555,0x56565656,0x58585756,0x59595959,0x5A5A5A5A,
    0x5C5B5B5B,0x5D5C5C5C,0x5E5D5D5D,0x5E5E5E5E,0x5F5F5F5F,0x60606060,0x60606060,0x61616160,
    0x61616161,0x62616161,0x62626262,0x62626262,0x63626262,0x63636363,0x63636363,0x63636363,
    0x64646363,0x64646464,0x64646464,0x64646464,0x64646464,0x64646464,0x65656564,0x65656565,
    0x65656565,0x65656565,0x65656565,0x65656565,0x65656565,0x65656565,0x64646465,0x64646464,
    0x64646464,0x64646464,0x64646464,0x64646464,0x63636364,0x63636363,0x63636363,0x63636363,
    0x62626263,0x62626262,0x62626262,0x61626262,0x61616161,0x61616161,0x60616161,0x60606060,
    0x60606060,0x5F5F5F60,0x5E5E5F5F,0x5D5D5E5E,0x5C5D5D5D,0x5B5C5C5C,0x5A5B5B5B,0x5A5A5A5A,
    0x59595959,0x58585858,0x57575757,0x56565656,0x54555555,0x53545454,0x52535353,0x51515252,
    0x50505151,0x4E4F4F50,0x4C4D4D4E,0x4A4A4B4B,0x47484849,0x45454647,0x42434444,0x40414142,
    0x3C3D3E40,0x37393A3B,0x33343536,0x2D2F3032,0x2326282A,0x15191E21,0x89800810,0x9F9A9691,
    0xA5A5A3A1,0xADA8A6A5,0xB6B4B2B0,0xBBBAB8B7,0xC0BEBDBC,0xC2C1C1C0,0xC4C4C3C3,0xC7C6C6C5,
    0xC9C9C8C7,0xCBCBCACA,0xCDCDCCCC,0xD0CFCECE,0xD1D0D0D0,0xD2D1D1D1,0xD3D2D2D2,0xD4D3D3D3,
    0xD4D4D4D4,0xD5D5D5D5,0xD6D6D6D6,0xD7D7D7D7,0xD8D8D8D8,0xD9D9D9D8,0xDADAD9D9,0xDBDADADA,
    0xDBDBDBDB,0xDCDCDCDC,0xDDDDDDDC,0xDEDDDDDD,0xDEDEDEDE,0xDFDFDFDE,0xE0DFDFDF,0xE0E0E0E0,
    0xE0E0E0E0,0xE0E0E0E0,0xE1E1E1E1,0xE1E1E1E1,0xE1E1E1E1,0xE1E1E1E1,0xE2E2E2E2,0xE2E2E2E2,
    0xE2E2E2E2,0xE2E2E2E2,0xE2E2E2E2,0xE3E3E2E2,0xE3E3E3E3,0xE3E3E3E3,0xE3E3E3E3,0xE3E3E3E3,
    0xE3E3E3E3,0xE3E3E3E3,0xE3E3E3E3,0xE3E3E3E3,0xE3E3E3E3,0xE3E3E3E3,0xE3E3E3E3,0xE3E3E3E3,
    0xE3E3E3E3,0xE2E3E3E3,0xE2E2E2E2,0xE2E2E2E2,0xE2E2E2E2,0xE2E2E2E2,0xE2E2E2E2,0xE1E2E2E2,
    0xE1E1E1E1,0xE1E1E1E1,0xE1E1E1E1,0xE0E1E1E1,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xDFDFDFE0,
    0xDEDFDFDF,0xDEDEDEDE,0xDDDDDDDE,0xDCDCDDDD,0xDBDCDCDC,0xDBDBDBDB,0xDADADADA,0xD9D9D9DA,
    0xD8D8D9D9,0xD7D8D8D8,0xD6D7D7D7,0xD6D6D6D6,0xD5D5D5D5,0xD4D4D4D4,0xD3D3D3D3,0xD2D2D2D3,
    0xD1D1D1D2,0xD0D0D0D1,0xCECFCFD0,0xCCCDCDCE,0xCACBCBCC,0xC8C9C9CA,0xC6C6C7C7,0xC4C4C5C5,
    0xC2C2C3C3,0xC0C0C1C1,0xBCBDBEBF,0xB8B9BABB,0xB4B5B6B7,0xB0B1B2B3,0xA7A9ABAE,0x9DA1A3A5,
    0x91929599,0x15100884,0x23211E19,0x2C2A2825,0x3231302E,0x37353433,0x3B3A3938,0x3F3E3D3C,
    0x42414140,0x44434342,0x46454544,0x48474746,0x4A494948,0x4C4B4B4A,0x4E4D4D4C,0x504F4F4E,
    0x51505050,0x52515151,0x53525252,0x54535353,0x55545454,0x55555555,0x56565656,0x56565656,
    0x58585857,0x59595959,0x5A5A5A59,0x5B5A5A5A,0x5B5B5B5B,0x5C5C5C5B,0x5D5C5C5C,0x5D5D5D5D,
    0x5E5E5E5D,0x5E5E5E5E,0x5F5F5F5F,0x605F5F5F,0x60606060,0x60606060,0x60606060,0x60606060,
    0x61616161,0x61616161,0x61616161,0x61616161,0x61616161,0x62626161,0x62626262,0x62626262,
    0x62626262,0x62626262,0x62626262,0x62626262,0x62626262,0x62626262,0x62626262,0x62626262,
    0x62626262,0x62626262,0x62626262,0x62626262,0x62626262,0x62626262,0x61616262,0x61616161,
    0x61616161,0x61616161,0x61616161,0x61616161,0x60606061,0x60606060,0x60606060,0x60606060,
    0x5F606060,0x5F5F5F5F,0x5E5F5F5F,0x5E5E5E5E,0x5D5D5E5E,0x5D5D5D5D,0x5C5C5C5D,0x5B5C5C5C,
    0x5B5B5B5B,0x5A5A5A5B,0x595A5A5A,0x59595959,0x58585859,0x57575858,0x56575757,0x56565656,
    0x55555555,0x54545455,0x53535454,0x52525353,0x51525252,0x51515151,0x50505050,0x4E4F4F4F,
    0x4C4D4D4E,0x4B4B4B4C,0x49494A4A,0x47474848,0x45464647,0x43444445,0x42424343,0x40404141,
    0x3D3D3E3F,0x393A3B3C,0x35363738,0x31323334,0x2B2D2F30,0x23252729,0x171B1F21,0x81060E13,
    0x98959089,0x9D9D9C9B,0xAAA6A29D,0xB2B1B0AD,0xB6B5B4B3,0xBAB9B8B7,0xBEBDBCBB,0xC1C0C0BF,
    0xC3C2C2C1,0xC5C4C4C3,0xC6C6C6C5,0xC8C8C7C7,0xCACAC9C9,0xCCCCCBCB,0xCECDCDCC,0xCFCFCFCE,
    0xD0D0D0CF,0xD1D1D1D1,0xD2D2D2D1,0xD3D3D3D2,0xD4D4D3D3,0xD5D4D4D4,0xD6D5D5D5,0xD6D6D6D6,
    0xD7D7D7D7,0xD8D8D8D7,0xD9D9D8D8,0xDAD9D9D9,0xDADADADA,0xDBDBDBDB,0xDCDCDBDB,0xDCDCDCDC,
    0xDDDDDDDD,0xDEDDDDDD,0xDEDEDEDE,0xDFDFDEDE,0xDFDFDFDF,0xE0DFDFDF,0xE0E0E0E0,0xE0E0E0E0,
    0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xE1E1E1E0,0xE1E1E1E1,0xE1E1E1E1,0xE1E1E1E1,0xE1E1E1E1,
    0xE1E1E1E1,0xE1E1E1E1,0xE1E1E1E1,0xE1E1E1E1,0xE1E1E1E1,0xE1E1E1E1,0xE1E1E1E1,0xE1E1E1E1,
    0xE1E1E1E1,0xE1E1E1E1,0xE1E1E1E1,0xE1E1E1E1,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,
    0xDFDFE0E0,0xDFDFDFDF,0xDEDEDFDF,0xDEDEDEDE,0xDDDDDDDD,0xDCDDDDDD,0xDCDCDCDC,0xDBDBDBDC,
    0xDBDBDBDB,0xDADADADA,0xD9D9DADA,0xD9D9D9D9,0xD8D8D8D9,0xD7D8D8D8,0xD7D7D7D7,0xD6D6D6D7,
    0xD5D6D6D6,0xD5D5D5D5,0xD4D4D4D5,0xD3D3D4D4,0xD3D3D3D3,0xD2D2D2D2,0xD1D1D1D2,0xD0D0D1D1,
    0xCFCFD0D0,0xCDCECECF,0xCCCCCCCD,0xCACACBCB,0xC8C8C9C9,0xC6C6C7C7,0xC4C5C5C6,0xC2C3C3C4,
    0xC1C1C1C2,0xBEBFC0C0,0xBBBBBCBD,0xB7B8B9BA,0xB4B5B5B6,0xB0B1B2B3,0xAAACAEB0,0xA3A5A7A9,
    0x9BA0A1A2,0x858D9295,0x15110A02,0x22201D19,0x2A282624,0x31302E2C,0x35343332,0x39383736,
    0x3D3C3B3A,0x40403F3E,0x42424141,0x44444343,0x46454545,0x48474746,0x4A494948,0x4B4B4B4A,
    0x4D4D4C4C,0x4F4F4E4E,0x50505050,0x51515150,0x52525251,0x53535252,0x54535353,0x54545454,
    0x55555554,0x56555555,0x56565656,0x56565656,0x58585757,0x58585858,0x59595958,0x59595959,
    0x5A5A5A5A,0x5B5A5A5A,0x5B5B5B5B,0x5C5C5B5B,0x5C5C5C5C,0x5D5D5D5C,0x5D5D5D5D,0x5E5E5E5D,
    0x5E5E5E5E,0x5F5F5F5E,0x5F5F5F5F,0x605F5F5F,0x60606060,0x60606060,0x60606060,0x60606060,
    0x60606060,0x60606060,0x60606060,0x60606060,0x60606060,0x61616060,0x61616161,0x61616161,
    0x61616161,0x61616161,0x61616161,0x61616161,0x61616161,0x60606161,0x60606060,0x60606060,
    0x60606060,0x60606060,0x60606060,0x60606060,0x60606060,0x60606060,0x5F5F5F60,0x5F5F5F5F,
    0x5F5F5F5F,0x5E5E5E5E,0x5E5E5E5E,0x5D5D5E5E,0x5D5D5D5D,0x5C5D5D5D,0x5C5C5C5C,0x5B5C5C5C,
    0x5B5B5B5B,0x5A5A5B5B,0x5A5A5A5A,0x5959595A,0x59595959,0x58585858,0x57575858,0x57575757,
    0x56565656,0x55555656,0x55555555,0x54545454,0x53535454,0x52535353,0x52525252,0x51515152,
    0x50505151,0x4F505050,0x4E4E4F4F,0x4C4D4D4D,0x4B4B4B4C,0x49494A4A,0x47484849,0x46464647,
    0x44444545,0x42434344,0x41414142,0x3E3F4040,0x3B3C3C3D,0x3738393A,0x33343536,0x30313232,
    0x292B2C2E,0x21232527,0x15181C20,0x02060C11,0x81000000,0xA19E978C,0xAAA8A6A4,0xB1B0AEAC,
    0xB4B3B2B1,0xB8B7B6B5,0xBBBAB9B8,0xBEBEBDBC,0xC1C0C0BF,0xC2C2C2C1,0xC4C4C3C3,0xC6C6C5C5,
    0xC8C7C7C6,0xC9C9C9C8,0xCBCBCACA,0xCDCCCCCB,0xCECECDCD,0xD0CFCFCF,0xD1D0D0D0,0xD1D1D1D1,
    0xD2D2D2D2,0xD3D3D3D2,0xD4D4D3D3,0xD4D4D4D4,0xD5D5D5D5,0xD6D6D5D5,0xD6D6D6D6,0xD7D7D7D7,
    0xD8D7D7D7,0xD8D8D8D8,0xD9D9D9D8,0xD9D9D9D9,0xDADADADA,0xDADADADA,0xDBDBDBDB,0xDBDBDBDB,
    0xDCDCDCDC,0xDCDCDCDC,0xDDDDDDDD,0xDDDDDDDD,0xDEDEDEDD,0xDEDEDEDE,0xDFDEDEDE,0xDFDFDFDF,
    0xDFDFDFDF,0xDFDFDFDF,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,
    0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,
    0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xE0E0E0E0,0xDFDFE0E0,0xDFDFDFDF,0xDFDFDFDF,
    0xDFDFDFDF,0xDEDEDEDF,0xDEDEDEDE,0xDEDEDEDE,0xDDDDDDDE,0xDDDDDDDD,0xDCDDDDDD,0xDCDCDCDC,
    0xDCDCDCDC,0xDBDBDBDB,0xDBDBDBDB,0xDADADADB,0xDADADADA,0xD9D9DADA,0xD9D9D9D9,0xD8D8D8D9,
    0xD7D8D8D8,0xD7D7D7D7,0xD6D6D7D7,0xD6D6D6D6,0xD5D5D5D5,0xD4D4D5D5,0xD4D4D4D4,0xD3D3D3D3,
    0xD2D2D3D3,0xD2D2D2D2,0xD1D1D1D2,0xD0D0D1D1,0xD0D0D0D0,0xCECFCFCF,0xCDCDCDCE,0xCBCBCCCC,
    0xC9CACACB,0xC8C8C8C9,0xC6C6C7C7,0xC4C5C5C5,0xC2C3C3C4,0xC1C1C1C2,0xBEBFC0C0,0xBBBCBDBE,
    0xB8B9B9BA,0xB4B5B6B7,0xB1B2B3B3,0xACADAFB0,0xA5A8AAAA,0x9DA0A2A3,0x8E929699,0x0D068087,
    0x1C181511,0x2523211F,0x2B2A2826,0x31302F2D,0x34343332,0x38373635,0x3B3A3A39,0x3F3E3D3C,
    0x4140403F,0x42424241,0x44444343,0x46454545,0x48474746,0x49494848,0x4B4B4A4A,0x4D4C4C4B,
    0x4E4E4D4D,0x504F4F4F,0x50505050,0x51515151,0x52525151,0x53525252,0x53535353,0x54545353,
    0x54545454,0x55555554,0x55555555,0x56555555,0x57575756,0x57575757,0x58585858,0x58585858,
    0x59595959,0x59595959,0x5A5A5A59,0x5A5A5A5A,0x5B5B5A5A,0x5B5B5B5B,0x5B5B5B5B,0x5C5C5C5B,
    0x5C5C5C5C,0x5C5C5C5C,0x5D5D5D5D,0x5D5D5D5D,0x5D5D5D5D,0x5E5D5D5D,0x5E5E5E5E,0x5E5E5E5E,
    0x5E5E5E5E,0x5E5E5E5E,0x5F5F5E5E,0x5F5F5F5F,0x5F5F5F5F,0x5F5F5F5F,0x5F5F5F5F,0x5F5F5F5F,
    0x5F5F5F5F,0x5F5F5F5F,0x5F5F5F5F,0x5F5F5F5F,0x5F5F5F5F,0x5E5E5E5E,0x5E5E5E5E,0x5E5E5E5E,
    0x5E5E5E5E,0x5E5E5E5E,0x5D5D5D5E,0x5D5D5D5D,0x5D5D5D5D,0x5D5D5D5D,0x5C5C5C5C,0x5C5C5C5C,
    0x5B5C5C5C,0x5B5B5B5B,0x5B5B5B5B,0x5A5A5A5A,0x5A5A5A5A,0x5959595A,0x59595959,0x58585858,
    0x57585858,0x57575757,0x56565757,0x56565656,0x55555656,0x55555555,0x54545455,0x54545454,
    0x53535353,0x52535353,0x52525252,0x51515152,0x50515151,0x50505050,0x4F4F4F50,0x4D4D4E4E,
    0x4C4C4C4D,0x4A4B4B4B,0x4949494A,0x47484848,0x46464647,0x44444545,0x42434344,0x41414242,
    0x3F3F4040,0x3B3C3D3E,0x38393A3A,0x34353637,0x31323334,0x2C2D2F30,0x2527282A,0x1F202223,
    0x1D1D1D1E,0x8209151C,0x9995918B,0xA3A2A09C,0xAAA8A6A5,0xB0AFADAB,0xB3B2B1B1,0xB6B6B5B4,
    0xBAB9B8B7,0xBDBCBBBA,0xC0BFBEBE,0xC1C1C1C0,0xC3C3C2C2,0xC5C4C4C3,0xC6C6C5C5,0xC8C7C7C6,
    0xC9C9C8C8,0xCBCACAC9,0xCCCCCBCB,0xCDCDCDCC,0xCFCECECE,0xD0CFCFCF,0xD0D0D0D0,0xD1D1D1D1,
    0xD2D2D1D1,0xD2D2D2D2,0xD3D3D3D3,0xD4D4D3D3,0xD4D4D4D4,0xD5D5D5D5,0xD6D5D5D5,0xD6D6D6D6,
    0xD7D7D6D6,0xD7D7D7D7,0xD8D8D7D7,0xD8D8D8D8,0xD9D9D8D8,0xD9D9D9D9,0xDAD9D9D9,0xDADADADA,
    0xDADADADA,0xDBDBDBDB,0xDBDBDBDB,0xDCDBDBDB,0xDCDCDCDC,0xDCDCDCDC,0xDDDCDCDC,0xDDDDDDDD,
    0xDDDDDDDD,0xDDDDDDDD,0xDDDDDDDD,0xDDDDDDDD,0xDEDEDDDD,0xDEDEDEDE,0xDEDEDEDE,0xDEDEDEDE,
    0xDEDEDEDE,0xDEDEDEDE,0xDEDEDEDE,0xDEDEDEDE,0xDEDEDEDE,0xDEDEDEDE,0xDEDEDEDE,0xDEDEDEDE,
    0xDEDEDEDE,0xDDDEDEDE,0xDDDDDDDD,0xDDDDDDDD,0xDDDDDDDD,0xDDDDDDDD,0xDDDDDDDD,0xDCDCDCDC,
    0xDCDCDCDC,0xDCDCDCDC,0xDBDBDBDC,0xDBDBDBDB,0xDBDBDBDB,0xDADADADA,0xDADADADA,0xD9DADADA,
    0xD9D9D9D9,0xD9D9D9D9,0xD8D8D8D8,0xD8D8D8D8,0xD7D7D7D7,0xD6D7D7D7,0xD6D6D6D6,0xD5D5D6D6,
    0xD5D5D5D5,0xD4D4D4D5,0xD4D4D4D4,0xD3D3D3D3,0xD2D2D3D3,0xD2D2D2D2,0xD1D1D1D1,0xD0D0D1D1,
    0xD0D0D0D0,0xCECFCFCF,0xCDCDCECE,0xCCCCCCCD,0xCACBCBCB,0xC9C9C9CA,0xC7C8C8C8,0xC6C6C6C7,
    0xC4C5C5C5,0xC3C3C3C4,0xC1C1C2C2,0xBFC0C0C1,0xBCBDBEBF,0xB9BABBBC,0xB6B7B8B8,0xB3B4B5B5,
    0xB1B1B2B2,0xABACAEB0,0xA5A7A8A9,0x9EA0A2A3,0x9295989B,0x0482888F,0x1613100A,0x21201D19,
    0x28262423,0x2E2D2B29,0x32313030,0x35343433,0x38383736,0x3C3B3A39,0x3F3E3D3C,0x4140403F,
    0x42424141,0x43434342,0x45454444,0x46464645,0x48474747,0x49494948,0x4B4A4A4A,0x4C4C4B4B,
    0x4E4D4D4D,0x4F4F4E4E,0x5050504F,0x50505050,0x51515151,0x52525151,0x52525252,0x53535352,
    0x53535353,0x54545454,0x54545454,0x55545454,0x56565655,0x56565656,0x57575756,0x57575757,
    0x58585757,0x58585858,0x58585858,0x59595958,0x59595959,0x59595959,0x5A5A5A59,0x5A5A5A5A,
    0x5A5A5A5A,0x5A5A5A5A,0x5B5B5B5B,0x5B5B5B5B,0x5B5B5B5B,0x5B5B5B5B,0x5C5C5B5B,0x5C5C5C5C,
    0x5C5C5C5C,0x5C5C5C5C,0x5C5C5C5C,0x5C5C5C5C,0x5C5C5C5C,0x5C5C5C5C,0x5C5C5C5C,0x5C5C5C5C,
    0x5C5C5C5C,0x5C5C5C5C,0x5C5C5C5C,0x5B5C5C5C,0x5B5B5B5B,0x5B5B5B5B,0x5B5B5B5B,0x5B5B5B5B,
    0x5A5A5B5B,0x5A5A5A5A,0x5A5A5A5A,0x5A5A5A5A,0x59595959,0x59595959,0x59595959,0x58585858,
    0x58585858,0x58585858,0x57575757,0x57575757,0x56565657,0x56565656,0x55555656,0x55555555,
    0x54555555,0x54545454,0x53535454,0x53535353,0x52525353,0x52525252,0x51515152,0x51515151,
    0x50505050,0x4F505050,0x4E4E4F4F,0x4D4D4E4E,0x4C4C4C4D,0x4A4B4B4B,0x494A4A4A,0x48484949,
    0x47474748,0x45454646,0x44444445,0x42434343,0x41414242,0x3F404041,0x3C3D3E3F,0x3A3A3B3C,
    0x37373839,0x34353536,0x31323233,0x2D2E3030,0x29292A2B,0x28292929,0x171C2025,0x030A1014,
    0x93908A83,0xA09D9A97,0xA6A4A3A1,0xACAAA9A7,0xB1B0AFAD,0xB4B3B2B2,0xB7B6B5B5,0xBAB9B9B8,
    0xBDBCBCBB,0xC0C0BFBE,0xC1C1C1C0,0xC3C2C2C2,0xC4C4C4C3,0xC6C5C5C5,0xC7C7C6C6,0xC8C8C8C7,
    0xCAC9C9C9,0xCBCBCACA,0xCCCCCCCB,0xCDCDCDCC,0xCFCECECE,0xD0CFCFCF,0xD0D0D0D0,0xD1D1D1D0,
    0xD1D1D1D1,0xD2D2D2D2,0xD3D2D2D2,0xD3D3D3D3,0xD4D4D3D3,0xD4D4D4D4,0xD5D5D4D4,0xD5D5D5D5,
    0xD6D6D5D5,0xD6D6D6D6,0xD7D7D6D6,0xD7D7D7D7,0xD7D7D7D7,0xD8D8D8D8,0xD8D8D8D8,0xD9D8D8D8,
    0xD9D9D9D9,0xD9D9D9D9,0xD9D9D9D9,0xDADADADA,0xDADADADA,0xDADADADA,0xDADADADA,0xDBDBDBDB,
    0xDBDBDBDB,0xDBDBDBDB,0xDBDBDBDB,0xDBDBDBDB,0xDBDBDBDB,0xDBDBDBDB,0xDBDBDBDB,0xDBDBDBDB,
    0xDADBDBDB,0xDADADADA,0xDADADADA,0xDADADADA,0xDADADADA,0xD9D9D9D9,0xD9D9D9D9,0xD9D9D9D9,
    0xD9D9D9D9,0xD8D8D8D8,0xD8D8D8D8,0xD8D8D8D8,0xD7D7D7D8,0xD7D7D7D7,0xD7D7D7D7,0xD6D6D6D6,
    0xD6D6D6D6,0xD5D5D6D6,0xD5D5D5D5,0xD4D5D5D5,0xD4D4D4D4,0xD3D4D4D4,0xD3D3D3D3,0xD2D3D3D3,
    0xD2D2D2D2,0xD1D1D2D2,0xD1D1D1D1,0xD0D0D1D1,0xD0D0D0D0,0xCFCFCFD0,0xCDCECECE,0xCCCDCDCD,
    0xCBCBCCCC,0xCACACACB,0xC8C9C9C9,0xC7C7C8C8,0xC6C6C6C7,0xC4C5C5C5,0xC3C3C4C4,0xC1C2C2C3,
    0xC0C0C1C1,0xBDBEBFC0,0xBBBBBCBD,0xB8B8B9BA,0xB5B5B6B7,0xB2B3B4B5,0xAEB0B0B1,0xA8AAABAD,
    0xA3A4A6A7,0x9B9EA0A1,0x8F929598,0x07018389,0x1714110D,0x21201D1A,0x27262423,0x2D2C2A29,
    0x3130302F,0x34333332,0x37363635,0x3A393838,0x3D3C3B3A,0x3F3F3E3D,0x41404040,0x42424141,
    0x43434342,0x44444444,0x46454545,0x47474646,0x48484747,0x49494948,0x4A4A4A49,0x4B4B4B4B,
    0x4D4C4C4C,0x4E4D4D4D,0x4F4F4E4E,0x50504F4F,0x50505050,0x51515150,0x51515151,0x52525251,
    0x52525252,0x53535352,0x53535353,0x53535353,0x54545353,0x55555554,0x55555555,0x56565555,
    0x56565656,0x56565656,0x57565656,0x57575757,0x57575757,0x57575757,0x58585858,0x58585858,
    0x58585858,0x58585858,0x59595858,0x59595959,0x59595959,0x59595959,0x59595959,0x59595959,
    0x59595959,0x59595959,0x59595959,0x59595959,0x59595959,0x59595959,0x59595959,0x59595959,
    0x59595959,0x59595959,0x59595959,0x59595959,0x58595959,0x58585858,0x58585858,0x58585858,
    0x58585858,0x57575758,0x57575757,0x57575757,0x57575757,0x56565656,0x56565656,0x55565656,
    0x55555555,0x55555555,0x54545455,0x54545454,0x53535454,0x53535353,0x52535353,0x52525252,
    0x51525252,0x51515151,0x50515151,0x50505050,0x4F4F5050,0x4E4E4F4F,0x4D4D4E4E,0x4C4C4D4D,
    0x4B4B4C4C,0x4A4A4B4B,0x4949494A,0x48484849,0x47474747,0x45464646,0x44444545,0x43434344,
    0x42424242,0x40414141,0x3F3F4040,0x3C3D3D3E,0x393A3B3B,0x37373839,0x34353536,0x32323333,
    0x31313232,0x2A2D3031,0x23242628,0x1A1D2021,0x0C111416,0x89830107,0x9794918E,0xA19F9C99,
    0xA5A4A3A2,0xABA9A8A7,0xB0AFADAC,0xB2B2B1B0,0xB5B4B4B3,0xB8B7B6B6,0xBAB9B9B8,0xBDBCBBBB,
    0xBFBFBEBD,0xC1C0C0C0,0xC2C2C1C1,0xC3C3C3C2,0xC4C4C4C3,0xC6C5C5C5,0xC7C7C6C6,0xC8C8C7C7,
    0xC9C9C9C8,0xCACACAC9,0xCBCBCBCB,0xCDCCCCCC,0xCECDCDCD,0xCFCECECE,0xD0D0CFCF,0xD0D0D0D0,
    0xD1D1D0D0,0xD1D1D1D1,0xD2D2D1D1,0xD2D2D2D2,0xD3D3D2D2,0xD3D3D3D3,0xD4D4D3D3,0xD4D4D4D4,
    0xD4D4D4D4,0xD5D5D5D5,0xD5D5D5D5,0xD6D6D5D5,0xD6D6D6D6,0xD6D6D6D6,0xD6D6D6D6,0xD7D7D7D7,
    0xD7D7D7D7,0xD7D7D7D7,0xD7D7D7D7,0xD8D8D8D7,0xD8D8D8D8,0xD8D8D8D8,0xD8D8D8D8,0xD8D8D8D8,
    0xD8D8D8D8,0xD8D8D8D8,0xD8D8D8D8,0xD8D8D8D8,0xD9D8D8D8,0xD9D9D9D9,0xD9D9D9D9,0xD9D9D9D9,
    0xD8D8D9D9,0xD8D8D8D8,0xD8D8D8D8,0xD8D8D8D8,0xD8D8D8D8,0xD8D8D8D8,0xD8D8D8D8,0xD8D8D8D8,
    0xD8D8D8D8,0xD8D8D8D8,0xD7D7D7D8,0xD7D7D7D7,0xD7D7D7D7,0xD7D7D7D7,0xD6D6D7D7,0xD6D6D6D6,
    0xD6D6D6D6,0xD5D6D6D6,0xD5D5D5D5,0xD5D5D5D5,0xD4D5D5D5,0xD4D4D4D4,0xD4D4D4D4,0xD3D3D4D4,
    0xD3D3D3D3,0xD2D3D3D3,0xD2D2D2D2,0xD2D2D2D2,0xD1D1D1D2,0xD1D1D1D1,0xD0D0D0D1,0xD0D0D0D0,
    0xCFCFCFD0,0xCECECECE,0xCDCDCDCD,0xCBCCCCCC,0xCACBCBCB,0xC9CACACA,0xC8C8C9C9,0xC7C7C8C8,
    0xC6C6C6C7,0xC5C5C5C6,0xC3C4C4C4,0xC2C3C3C3,0xC1C1C2C2,0xC0C0C0C1,0xBDBEBFBF,0xBBBCBCBD,
    0xB8B9BABA,0xB6B7B7B8,0xB3B4B4B5,0xB0B1B2B2,0xACAEAFB0,0xA7A8AAAB,0xA2A3A5A6,0x9B9DA0A1,
    0x91939698,0x0183888D,0x13100B06,0x1D1A1815,0x24222120,0x29282625,0x2E2D2C2A,0x31313030,
    0x34333332,0x37363535,0x39383837,0x3C3B3A3A,0x3E3D3D3C,0x40403F3F,0x41414140,0x42424241,
    0x44434343,0x45444444,0x46464545,0x47474646,0x48484847,0x49494948,0x4A4A4A49,0x4B4B4B4A,
    0x4C4C4C4C,0x4D4D4D4D,0x4E4E4E4E,0x4F4F4F4E,0x5050504F,0x50505050,0x51515050,0x51515151,
    0x51515151,0x52525252,0x52525252,0x52525252,0x52525252,0x53535352,0x54545453,0x54545454,
    0x54545454,0x54545454,0x55555555,0x55555555,0x55555555,0x55555555,0x55555555,0x56565656,
    0x56565656,0x56565656,0x56565656,0x56565656,0x56565656,0x57565656,0x57575757,0x57575757,
    0x57575757,0x57575757,0x57575757,0x57575757,0x57575757,0x57575757,0x56575757,0x56565656,
    0x56565656,0x56565656,0x56565656,0x56565656,0x56565656,0x55555556,0x55555555,0x55555555,
    0x55555555,0x54555555,0x54545454,0x54545454,0x54545454,0x53535354,0x53535353,0x53535353,
    0x52525253,0x52525252,0x52525252,0x51515151,0x51515151,0x50505151,0x50505050,0x4F505050,
    0x4F4F4F4F,0x4E4E4E4E,0x4D4D4D4D,0x4C4C4C4C,0x4B4B4B4C,0x4A4A4A4B,0x4949494A,0x48484849,
    0x47474748,0x46464647,0x45454545,0x43444444,0x42434343,0x41414242,0x40404141,0x3E3F3F40,
    0x3C3C3D3E,0x393A3B3B,0x37383839,0x37373737,0x34363637,0x30313133,0x2B2C2E2F,0x2628292A,
    0x21222425,0x191B1E20,0x0F121417,0x8400050A,0x93918E89,0x9D9B9896,0xA3A2A19F,0xA8A7A5A4,
    0xACABAAA9,0xB0B0AFAE,0xB3B2B2B1,0xB5B4B4B3,0xB7B7B6B6,0xBAB9B8B8,0xBCBBBBBA,0xBEBEBDBC,
    0xC0C0BFBF,0xC1C1C1C0,0xC2C2C2C1,0xC3C3C3C3,0xC5C4C4C4,0xC6C5C5C5,0xC7C6C6C6,0xC8C8C7C7,
    0xC9C9C8C8,0xCACAC9C9,0xCBCBCACA,0xCCCCCCCB,0xCDCDCDCC,0xCECECDCD,0xCFCFCECE,0xD0D0CFCF,
    0xD0D0D0D0,0xD0D0D0D0,0xD1D1D1D1,0xD1D1D1D1,0xD2D2D1D1,0xD2D2D2D2,0xD2D2D2D2,0xD3D3D2D2,
    0xD3D3D3D3,0xD3D3D3D3,0xD4D3D3D3,0xD4D4D4D4,0xD4D4D4D4,0xD4D4D4D4,0xD5D5D4D4,0xD5D5D5D5,
    0xD5D5D5D5,0xD5D5D5D5,0xD5D5D5D5,0xD6D6D5D5,0xD6D6D6D6,0xD6D6D6D6,0xD6D6D6D6,0xD6D6D6D6,
    0xD6D6D6D6,0xD6D6D6D6,0xD6D6D6D6,0xD6D6D6D6,0xD6D6D6D6,0xD6D6D6D6,0xD6D6D6D6,0xD6D6D6D6,
    0xD6D6D6D6,0xD6D6D6D6,0xD6D6D6D6,0xD6D6D6D6,0xD6D6D6D6,0xD5D5D5D6,0xD5D5D5D5,0xD5D5D5D5,
    0xD5D5D5D5,0xD5D5D5D5,0xD5D5D5D5,0xD4D4D4D4,0xD4D4D4D4,0xD4D4D4D4,0xD3D4D4D4,0xD3D3D3D3,
    0xD3D3D3D3,0xD3D3D3D3,0xD2D2D2D2,0xD2D2D2D2,0xD2D2D2D2,0xD1D1D1D1,0xD1D1D1D1,0xD0D1D1D1,
    0xD0D0D0D0,0xD0D0D0D0,0xCFCFD0D0,0xCECECFCF,0xCDCECECE,0xCCCDCDCD,0xCCCCCCCC,0xCBCBCBCB,
    0xCACACACA,0xC9C9C9C9,0xC8C8C8C8,0xC7C7C7C7,0xC6C6C6C6,0xC5C5C5C5,0xC3C4C4C4,0xC2C3C3C3,
    0xC1C2C2C2,0xC0C1C1C1,0xBFC0C0C0,0xBDBDBEBE,0xBBBBBCBC,0xB9BABABA,0xB6B7B7B8,0xB4B5B5B6,
    0xB2B2B3B3,0xAFB0B0B1,0xAAABACAE,0xA5A7A8A9,0xA1A2A3A4,0x999B9EA0,0x90929497,0x0282878B,
    0x12100B07,0x1B191714,0x2221201E,0x27262423,0x2B2A2928,0x302F2E2C,0x32313130,0x34343332,
    0x36363535,0x38383737,0x3B3A3A39,0x3D3C3C3B,0x3F3E3E3D,0x4040403F,0x41414140,0x42424242,
    0x43434343,0x44444444,0x45454545,0x46464646,0x47474747,0x48484848,0x49494948,0x4A4A4A49,
    0x4B4B4A4A,0x4C4C4B4B,0x4D4C4C4C,0x4D4D4D4D,0x4E4E4E4E,0x4F4F4F4E,0x504F4F4F,0x50505050,
    0x50505050,0x51515050,0x51515151,0x51515151,0x52515151,0x51515252,0x52515151,0x52525252,
    0x53535353,0x53535353,0x53535353,0x53535353,0x53535353,0x54545353,0x54545454,0x54545454,
    0x54545454,0x54545454,0x54545454,0x54545454,0x54545454,0x54545454,0x54545454,0x54545454,
    0x54545454,0x54545454,0x54545454,0x53535354,0x53535353,0x53535353,0x53535353,0x53535353,
    0x52525252,0x52525252,0x52525252,0x51515252,0x51515151,0x51515151,0x50515151,0x50505050,
    0x50505050,0x4F505050,0x4F4F4F4F,0x4E4E4E4E,0x4D4D4E4E,0x4C4D4D4D,0x4C4C4C4C,0x4B4B4B4B,
    0x4A4A4A4B,0x49494A4A,0x48484949,0x47484848,0x46474747,0x45464646,0x44454545,0x43444444,
    0x42434343,0x41424242,0x40414141,0x3F404040,0x3D3E3E3F,0x3C3C3C3D,0x3C3C3C3C,0x37393A3B,
    0x35353637,0x33333434,0x31313232,0x2D2E2F30,0x292A2B2C,0x24252627,0x20212223,0x171A1C1E,
    0x0E111315,0x8201050A,0x918F8B87,0x9B989694,0xA1A09F9D,0xA6A5A4A3,0xAAA9A8A7,0xAEADACAB,
    0xB1B1B0B0,0xB3B3B2B2,0xB5B5B4B4,0xB7B7B6B6,0xBAB9B9B8,0xBCBBBBBA,0xBEBDBDBC,0xC0BFBFBE,
    0xC1C0C0C0,0xC2C1C1C1,0xC3C2C2C2,0xC3C3C3C3,0xC4C4C4C4,0xC5C5C5C5,0xC6C6C6C6,0xC7C7C7C6,
    0xC8C8C8C7,0xC9C9C8C8,0xCAC9C9C9,0xCACACACA,0xCBCBCBCB,0xCCCCCCCB,0xCDCDCCCC,0xCECDCDCD,
    0xCECECECE,0xCFCFCFCF,0xD0D0CFCF,0xD0D0D0D0,0xD0D0D0D0,0xD1D1D0D0,0xD1D1D1D1,0xD1D1D1D1,
    0xD1D1D1D1,0xD2D2D2D1,0xD2D2D2D2,0xD2D2D2D2,0xD2D2D2D2,0xD2D2D2D2,0xD3D3D3D3,0xD3D3D3D3,
    0xD3D3D3D3,0xD3D3D3D3,0xD3D3D3D3,0xD3D3D3D3,0xD3D3D3D3,0xD3D3D3D3,0xD4D4D4D3,0xD4D4D4D4,
    0xD4D4D4D4,0xD4D4D4D4,0xD4D4D4D4,0xD4D4D4D4,0xD4D4D4D4,0xD4D4D4D4,0xD4D4D4D4,0xD4D4D4D4,
    0xD3D4D4D4,0xD3D3D3D3,0xD3D3D3D3,0xD3D3D3D3,0xD3D3D3D3,0xD3D3D3D3,0xD3D3D3D3,0xD3D3D3D3,
    0xD2D2D3D3,0xD2D2D2D2,0xD2D2D2D2,0xD2D2D2D2,0xD2D2D2D2,0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,
    0xD0D1D1D1,0xD0D0D0D0,0xD0D0D0D0,0xD0D0D0D0,0xCFCFCFCF,0xCECECFCF,0xCECECECE,0xCDCDCDCD,
    0xCCCCCCCD,0xCBCBCCCC,0xCACBCBCB,0xCACACACA,0xC9C9C9C9,0xC8C8C8C9,0xC7C7C8C8,0xC6C7C7C7,
    0xC5C6C6C6,0xC4C5C5C5,0xC4C4C4C4,0xC3C3C3C3,0xC2C2C2C2,0xC1C1C1C1,0xC0C0C0C0,0xBEBEBFBF,
    0xBCBCBDBD,0xBABABBBC,0xB8B8B9B9,0xB6B6B7B7,0xB3B4B5B5,0xB1B2B2B3,0xAFB0B0B1,0xABACADAE,
    0xA7A8A9AA,0xA2A4A5A6,0x9D9FA0A1,0x9597999B,0x8A8E9193,0x06028186,0x13110E0A,0x1B191715,
    0x21201F1D,0x25242322,0x29282726,0x2D2C2B2A,0x30302F2E,0x32323131,0x34343333,0x36363535,
    0x38383737,0x3A3A3939,0x3C3C3B3B,0x3E3D3D3C,0x403F3F3E,0x41404040,0x42414141,0x43424242,
    0x43434343,0x44444444,0x45454545,0x46464645,0x47474646,0x48474747,0x48484848,0x49494949,
    0x4A4A4949,0x4A4A4A4A,0x4B4B4B4B,0x4C4C4B4B,0x4C4C4C4C,0x4D4D4D4D,0x4E4D4D4D,0x4E4E4E4E,
    0x4F4F4E4E,0x4F4F4F4F,0x5050504F,0x50505050,0x50505050,0x50505050,0x51515151,0x51515151,
    0x51505050,0x51515151,0x52515151,0x52525252,0x52525252,0x52525252,0x52525252,0x52525252,
    0x52525252,0x52525252,0x52525252,0x52525252,0x52525252,0x52525252,0x52525252,0x52525252,
    0x51515151,0x51515151,0x51515151,0x51515151,0x51515151,0x50515151,0x50505050,0x50505050,
    0x50505050,0x50505050,0x4F4F4F4F,0x4E4F4F4F,0x4E4E4E4E,0x4D4D4E4E,0x4D4D4D4D,0x4C4C4C4C,
    0x4B4B4C4C,0x4B4B4B4B,0x4A4A4A4B,0x49494A4A,0x49494949,0x48484848,0x47474848,0x46474747,
    0x46464646,0x45454545,0x44444545,0x43444444,0x42434343,0x42424242,0x41414141,0x40404041,
    0x40404040,0x3F404040,0x3B3C3C3D,0x393A3A3B,0x37383839,0x35363637,0x33343435,0x31323233,
    0x30303131,0x2C2D2E2F,0x28292A2B,0x24252627,0x20212223,0x191B1D1F,0x11131517,0x03070B0F,
    0x8B878300,0x9593918F,0x9D9B9997,0xA2A1A09F,0xA6A5A4A3,0xAAA9A8A7,0xAEADACAB,0xB1B0B0AF,
    0xB3B2B2B1,0xB5B4B4B3,0xB7B6B6B5,0xB9B8B7B7,0xBABAB9B9,0xBCBCBBBB,0xBEBEBDBD,0xC0C0BFBF,
    0xC1C0C0C0,0xC2C1C1C1,0xC2C2C2C2,0xC3C3C3C3,0xC4C4C4C4,0xC5C5C5C4,0xC6C6C5C5,0xC6C6C6C6,
    0xC7C7C7C7,0xC8C8C8C7,0xC9C8C8C8,0xC9C9C9C9,0xCACACAC9,0xCBCACACA,0xCBCBCBCB,0xCCCCCCCB,
    0xCDCCCCCC,0xCDCDCDCD,0xCECDCDCD,0xCECECECE,0xCFCFCECE,0xCFCFCFCF,0xCFCFCFCF,0xD0D0D0D0,
    0xD0D0D0D0,0xD0D0D0D0,0xD0D0D0D0,0xD0D0D0D0,0xD1D0D0D0,0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,
    0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,
    0xD1D1D1D1,0xD2D2D1D1,0xD2D1D1D2,0xD1D1D1D2,0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,
    0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,0xD1D1D1D1,0xD0D0D0D0,0xD0D0D0D0,
    0xD0D0D0D0,0xD0D0D0D0,0xD0D0D0D0,0xCFCFCFCF,0xCFCFCFCF,0xCECECECF,0xCECECECE,0xCDCDCDCE,
    0xCDCDCDCD,0xCCCCCCCC,0xCBCBCCCC,0xCBCBCBCB,0xCACACACB,0xC9CACACA,0xC9C9C9C9,0xC8C8C8C9,
    0xC7C8C8C8,0xC7C7C7C7,0xC6C6C6C6,0xC5C5C6C6,0xC4C5C5C5,0xC4C4C4C4,0xC3C3C3C4,0xC2C2C3C3,
    0xC1C2C2C2,0xC1C1C1C1,0xC0C0C0C0,0xBFBFBFC0,0xBDBEBEBE,0xBBBBBCBC,0xB9BABABA,0xB7B8B8B9,
    0xB5B6B6B7,0xB3B4B4B5,0xB2B2B2B3,0xB0B0B1B1,0xACADAEAF,0xA9A9AAAB,0xA5A6A7A8,0xA1A2A3A4,
    0x9B9D9FA0,0x94969799,0x898D9092,0x06028185,0x12100D09,0x19181614,0x201F1D1B,0x24232221,
    0x27272625,0x2B2A2928,0x2E2E2D2C,0x3130302F,0x33323231,0x34343333,0x36363535,0x38373736,
    0x39393938,0x3B3B3A3A,0x3D3C3C3B,0x3E3E3D3D,0x403F3F3F,0x40404040,0x41414141,0x42424241,
    0x43434242,0x44434343,0x44444444,0x45454544,0x46464545,0x46464646,0x47474747,0x48484747,
    0x48484848,0x49494948,0x49494949,0x4A4A4A4A,0x4B4A4A4A,0x4B4B4B4B,0x4C4C4B4B,0x4C4C4C4C,
    0x4D4D4C4C,0x4D4D4D4D,0x4D4D4D4D,0x4E4E4E4E,0x4E4E4E4E,0x4F4E4E4E,0x4F4F4F4F,0x4F4F4F4F,
    0x4F4F4F4F,0x50505050,0x50505050,0x4F4F5050,0x504F4F4F,0x50505050,0x50505050,0x50505050,
    0x50505050,0x50505050,0x50505050,0x50505050,0x50505050,0x50505050,0x50505050,0x50505050,
    0x50505050,0x50505050,0x50505050,0x50505050,0x50505050,0x50505050,0x50505050,0x4F4F5050,
    0x4F4F4F4F,0x4F4F4F4F,0x4E4F4F4F,0x4E4E4E4E,0x4E4E4E4E,0x4D4D4D4E,0x4D4D4D4D,0x4C4C4D4D,
    0x4C4C4C4C,0x4B4C4C4C,0x4B4B4B4B,0x4A4A4B4B,0x4A4A4A4A,0x4949494A,0x49494949,0x48484848,
    0x47484848,0x47474747,0x46464647,0x45464646,0x45454545,0x44444445,0x43444444,0x43434343,
    0x42424343,0x42424242,0x41424242,0x40404041,0x3E3F3F40,0x3D3D3E3E,0x3B3C3C3C,0x3A3A3A3B,
    0x38383939,0x36363737,0x34353535,0x32333334,0x31313232,0x2E2F3030,0x2B2C2D2E,0x2829292A,
    0x24252627,0x21222324,0x1C1D1F20,0x1517181A,0x0C101113,0x80020609,0x8F8B8784,0x96949291,
    0x9C9B9997,0xA2A1A09E,0xA5A4A3A2,0xA9A8A7A6,0xACABAAA9,0xB0AFAEAD,0xB1B1B0B0,0xB3B3B2B2,
    0xB5B4B4B3,0xB6B6B5B5,0xB8B7B7B6,0xB9B9B8B8,0xBBBABAB9,0xBCBCBBBB,0xBDBDBDBC,0xBFBEBEBE,
    0xC0C0C0BF,0xC1C0C0C0,0xC1C1C1C1,0xC2C2C2C1,0xC3C3C2C2,0xC3C3C3C3,0xC4C4C4C4,0xC5C5C4C4,
    0xC5C5C5C5,0xC6C6C6C6,0xC7C7C6C6,0xC7C7C7C7,0xC8C8C8C8,0xC9C8C8C8,0xC9C9C9C9,0xCAC9C9C9,
    0xCACACACA,0xCBCBCACA,0xCBCBCBCB,0xCBCBCBCB,0xCCCCCCCC,0xCCCCCCCC,0xCDCDCCCC,0xCDCDCDCD,
    0xCDCDCDCD,0xCECECECD,0xCECECECE,0xCECECECE,0xCFCFCECE,0xCFCFCFCF,0xCFCFCFCF,0xCFCFCFCF,
    0xCFCFCFCF,0xCFCFCFCF,0xCFCFCFCF,0xCFCFCFCF,0xCFCFCFCF,0xD0CFCFCF,0xD0D0D0D0,0xD0D0D0D0,
    0xD0D0D0D0,0xD0D0D0D0,0xCFCFD0D0,0xCFCFCFCF,0xCFCFCFCF,0xCFCFCFCF,0xCFCFCFCF,0xCFCFCFCF,
    0xCFCFCFCF,0xCECFCFCF,0xCECECECE,0xCECECECE,0xCECECECE,0xCDCDCDCE,0xCDCDCDCD,0xCDCDCDCD,
    0xCCCCCCCC,0xCCCCCCCC,0xCBCBCCCC,0xCBCBCBCB,0xCACBCBCB,0xCACACACA,0xC9CACACA,0xC9C9C9C9,
    0xC8C9C9C9,0xC8C8C8C8,0xC7C7C8C8,0xC7C7C7C7,0xC6C6C6C6,0xC5C6C6C6,0xC5C5C5C5,0xC4C4C4C5,
    0xC3C4C4C4,0xC3C3C3C3,0xC2C2C2C3,0xC1C2C2C2,0xC1C1C1C1,0xC0C0C0C1,0xC0C0C0C0,0xBEBEBEBF,
    0xBCBDBDBD,0xBBBBBBBC,0xB9BABABA,0xB8B8B8B9,0xB6B6B7B7,0xB4B5B5B6,0xB3B3B4B4,0xB1B2B2B2,
    0xB0B0B1B1,0xADADAEAF,0xA9AAABAC,0xA6A7A8A9,0xA3A3A4A5,0x9FA0A1A2,0x989A9C9D,0x92939596,
    0x868A8D90,0x06038083,0x11100D09,0x18161513,0x1E1D1B1A,0x22212120,0x25252423,0x29282726,
    0x2C2B2A29,0x2F2E2D2D,0x31303030,0x32323231,0x34343333,0x35353534,0x37373636,0x38383837,
    0x3A393939,0x3B3B3B3A,0x3D3C3C3C,0x3E3E3D3D,0x3F3F3F3E,0x40404040,0x41414040,0x41414141,
    0x42424242,0x43434242,0x43434343,0x44444444,0x45444444,0x45454545,0x46464545,0x46464646,
    0x47474746,0x47474747,0x48484847,0x48484848,0x49494848,0x49494949,0x49494949,0x4A4A4A4A,
    0x4A4A4A4A,0x4A4A4A4A,0x4B4B4B4A,0x4B4B4B4B,0x4B4B4B4B,0x4C4C4B4B,0x4C4C4C4C,0x4C4C4C4C,
    0x4C4C4C4C,0x4D4C4C4C,0x4D4D4D4D,0x4D4D4D4D,0x4D4D4D4D,0x4D4D4D4D,0x4D4D4D4D,0x4D4D4D4D,
    0x4D4D4D4D,0x4D4D4D4D,0x4D4D4D4D,0x4D4D4C4D,0x4D4D4D4D,0x4D4D4D4D,0x4D4D4D4D,0x4D4D4D4D,
    0x4D4D4D4D,0x4D4D4D4D,0x4D4D4D4D,0x4C4C4D4D,0x4C4C4C4C,0x4C4C4C4C,0x4C4C4C4C,0x4B4C4C4C,
    0x4B4B4B4B,0x4B4B4B4B,0x4B4B4B4B,0x4A4A4A4A,0x4A4A4A4A,0x494A4A4A,0x49494949,0x49494949,
    0x48484848,0x48484848,0x47474748,0x47474747,0x46464647,0x46464646,0x45454546,0x45454545,
    0x45454545,0x44454545,0x43434344,0x42424343,0x42424242,0x41414141,0x40414141,0x40404040,
    0x3F3F3F40,0x3D3D3E3E,0x3C3C3C3D,0x3A3B3B3B,0x3939393A,0x37383838,0x36363737,0x34353535,
    0x33333434,0x31323232,0x30303031,0x2D2E2E2F,0x2A2A2B2C,0x27272829,0x23242526,0x20212223,
    0x1A1C1E1F,0x14161719,0x0C0F1113,0x80030609,0x8C898683,0x9492918F,0x9A999796,0xA09F9D9C,
    0xA3A2A1A1,0xA6A5A4A4,0xA9A8A7A6,0xACABAAA9,0xAEAEADAC,0xB0B0B0AF,0xB2B1B1B1,0xB3B3B3B2,
    0xB5B4B4B4,0xB6B6B5B5,0xB8B7B7B7,0xB9B9B8B8,0xBABABAB9,0xBCBCBBBB,0xBDBDBDBC,0xBFBEBEBE,
    0xC0C0BFBF,0xC0C0C0C0,0xC1C1C1C1,0xC2C1C1C1,0xC2C2C2C2,0xC3C3C3C2,0xC3C3C3C3,0xC4C4C4C4,
    0xC4C4C4C4,0xC5C5C5C5,0xC6C5C5C5,0xC6C6C6C6,0xC6C6C6C6,0xC7C7C7C7,0xC7C7C7C7,0xC8C8C8C7,
    0xC8C8C8C8,0xC8C8C8C8,0xC9C8C8C8,0xC9C9C9C9,0xCAC9C9C9,0xCACACACA,0xCACACACA,0xCACACACA,
    0xCBCBCACA,0xCBCBCBCB,0xCBCBCBCB,0xCBCBCBCB,0xCBCBCBCB,0xCBCBCBCB,0xCCCCCBCB,0xCCCCCCCC,
    0xCCCCCCCC,0xCCCCCCCC,0xCCCCCCCC,0xCCCCCCCC,0xCCCCCCCC,0xCCCCCCCC,0xCCCCCCCC,0xCCCCCCCC,
    0xCCCCCCCC,0xCCCCCCCC,0xCCCCCCCC,0xCCCCCCCC,0xCBCCCCCC,0xCBCBCBCB,0xCBCBCBCB,0xCBCBCBCB,
    0xCBCBCBCB,0xCBCBCBCB,0xCACACACA,0xCACACACA,0xCACACACA,0xC9C9C9CA,0xC9C9C9C9,0xC9C9C9C9,
    0xC8C8C8C8,0xC8C8C8C8,0xC7C8C8C8,0xC7C7C7C7,0xC7C7C7C7,0xC6C6C6C6,0xC6C6C6C6,0xC5C5C5C6,
    0xC5C5C5C5,0xC4C4C4C5,0xC4C4C4C4,0xC3C3C3C3,0xC2C3C3C3,0xC2C2C2C2,0xC1C1C2C2,0xC1C1C1C1,
    0xC0C1C1C1,0xC0C0C0C0,0xBFBFBFBF,0xBDBEBEBE,0xBCBCBDBD,0xBBBBBCBC,0xBABABABB,0xB8B8B9B9,
    0xB7B7B7B8,0xB5B6B6B6,0xB4B4B5B5,0xB2B3B3B3,0xB1B1B2B2,0xB0B0B0B1,0xADADAEAF,0xAAAAABAC,
    0xA7A7A8A9,0xA4A4A5A6,0xA1A1A2A3,0x9C9D9FA0,0x9698999B,0x90929394,0x85888B8E,0x06030082,
    0x110F0C09,0x17151412,0x1C1B1918,0x21201F1E,0x24232222,0x27262524,0x2A292827,0x2C2C2B2A,
    0x2F2E2E2D,0x31303030,0x32323131,0x33333332,0x35343434,0x36363535,0x37373736,0x38383837,
    0x3A393939,0x3B3B3A3A,0x3C3C3C3B,0x3D3D3D3C,0x3F3E3E3E,0x403F3F3F,0x40404040,0x41414140,
    0x41414141,0x42424241,0x42424242,0x43434343,0x43434343,0x44444444,0x44444444,0x45454544,
    0x45454545,0x46464545,0x46464646,0x46464646,0x47474746,0x47474747,0x47474747,0x48484847,
    0x48484848,0x48484848,0x49484848,0x49494949,0x49494949,0x49494949,0x49494949,0x4A4A4A49,
    0x4A4A4A4A,0x4A4A4A4A,0x4A4A4A4A,0x4A4A4A4A,0x4A4A4A4A,0x4A4A4A4A,0x4A4A4A4A,0x4A4A4A4A,
    0x4A4A4A4A,0x4949494A,0x49494949,0x49494949,0x49494949,0x48484949,0x48484848,0x48484848,
    0x48484848,0x47474747,0x47474747,0x47474747,0x46464646,0x46464646,0x45464646,0x45454545,
    0x45454545,0x44444445,0x44444444,0x43434444,0x43434343,0x42434343,0x42424242,0x41414242,
    0x41414141,0x40404141,0x40404040,0x3F3F3F40,0x3D3E3E3E,0x3C3D3D3D,0x3B3B3C3C,0x3A3A3A3B,
    0x38393939,0x37373838,0x36363637,0x34353535,0x33333434,0x32323233,0x31313131,0x2F303030,
    0x2C2D2E2E,0x2A2A2B2C,0x27282829,0x24252626,0x22232324,0x1F202121,0x1A1B1C1E,0x14161718,
    0x0F101213,0x0507090C,0x87848101,0x918F8D8A,0x96959392,0x9C9A9997,0xA09F9E9D,0xA3A2A2A1,
    0xA6A5A4A4,0xA8A8A7A6,0xABAAAAA9,0xAEADACAC,0xB0B0AFAE,0xB1B1B1B0,0xB2B2B2B2,0xB4B3B3B3,
    0xB5B5B4B4,0xB6B6B6B5,0xB7B7B7B6,0xB9B8B8B8,0xBAB9B9B9,0xBBBBBABA,0xBCBCBBBB,0xBDBDBDBC,
    0xBEBEBEBD,0xBFBFBFBF,0xC0C0C0C0,0xC0C0C0C0,0xC1C1C1C1,0xC1C1C1C1,0xC2C2C2C2,0xC2C2C2C2,
    0xC3C3C3C3,0xC3C3C3C3,0xC4C4C4C3,0xC4C4C4C4,0xC5C4C4C4,0xC5C5C5C5,0xC5C5C5C5,0xC6C5C5C5,
    0xC6C6C6C6,0xC6C6C6C6,0xC7C6C6C6,0xC7C7C7C7,0xC7C7C7C7,0xC7C7C7C7,0xC7C7C7C7,0xC8C8C8C8,
    0xC8C8C8C8,0xC8C8C8C8,0xC8C8C8C8,0xC8C8C8C8,0xC9C9C8C8,0xC9C9C9C9,0xC9C9C9C9,0xC9C9C9C9,
    0xC9C9C9C9,0xC9C9C9C9,0xC9C9C9C9,0xC9C9C9C9,0xC9C9C9C9,0xC9C9C9C9,0xC9C9C9C9,0xC9C9C9C9,
    0xC9C9C9C9,0xC9C9C9C9,0xC8C8C8C9,0xC8C8C8C8,0xC8C8C8C8,0xC8C8C8C8,0xC8C8C8C8,0xC8C8C8C8,
    0xC7C7C8C8,0xC7C7C7C7,0xC7C7C7C7,0xC7C7C7C7,0xC6C6C6C7,0xC6C6C6C6,0xC6C6C6C6,0xC5C5C5C6,
    0xC5C5C5C5,0xC5C5C5C5,0xC4C4C4C4,0xC4C4C4C4,0xC3C3C3C4,0xC3C3C3C3,0xC2C2C2C3,0xC2C2C2C2,
    0xC1C2C2C2,0xC1C1C1C1,0xC0C0C0C1,0xC0C0C0C0,0xBFBFBFC0,0xBEBEBEBF,0xBDBDBDBE,0xBCBCBCBD,
    0xBBBBBBBB,0xBABABABA,0xB8B9B9B9,0xB7B8B8B8,0xB6B7B7B7,0xB5B5B6B6,0xB4B4B4B5,0xB3B3B3B4,
    0xB1B2B2B2,0xB0B1B1B1,0xAFAFB0B0,0xACADADAE,0xAAAAABAB,0xA7A8A8A9,0xA5A5A6A6,0xA2A3A3A4,
    0x9FA0A1A1,0x9A9B9C9E,0x95969799,0x8F919293,0x85878A8C,0x05020082,0x0F0D0A08,0x15131211,
    0x1A181716,0x1F1E1C1B,0x22212020,0x24242322,0x27262525,0x29292827,0x2C2B2A2A,0x2E2D2D2C,
    0x30302F2F,0x31313130,0x32323231,0x33333333,0x35343434,0x36353535,0x37363636,0x38383737,
    0x39393838,0x3A3A3A39,0x3B3B3B3A,0x3C3C3C3C,0x3D3D3D3D,0x3E3E3E3E,0x3F3F3F3F,0x40404040,
    0x40404040,0x41414141,0x41414141,0x42424241,0x42424242,0x43424242,0x43434343,0x43434343,
    0x44444343,0x44444444,0x44444444,0x45444444,0x45454545,0x45454545,0x45454545,0x46464545,
    0x46464646,0x46464646,0x46464646,0x46464646,0x46464646,0x47474746,0x47474747,0x47474747,
    0x47474747,0x47474747,0x47474747,0x47474747,0x47474747,0x47474747,0x47474747,0x47474747,
    0x46474747,0x46464646,0x46464646,0x46464646,0x46464646,0x45464646,0x45454545,0x45454545,
    0x45454545,0x44444445,0x44444444,0x44444444,0x43434344,0x43434343,0x42434343,0x42424242,
    0x42424242,0x41414141,0x41414141,0x40404141,0x40404040,0x3F404040,0x3F3F3F3F,0x3E3E3E3E,
    0x3D3D3D3D,0x3C3C3C3C,0x3B3B3B3B,0x3A3A3A3A,0x39393939,0x38383838,0x36373737,0x35363636,
    0x34353535,0x33333434,0x32323233,0x31313132,0x30303030,0x2D2E2E2F,0x2B2B2C2D,0x2829292A,
    0x26262728,0x23242425,0x21212223,0x1D1E2020,0x18191B1C,0x13141617,0x0D0F1112,0x0306080B,
    0x86838101,0x908D8B88,0x94939291,0x99989795,0x9E9D9B9A,0xA1A0A09F,0xA3A3A2A2,0xA6A5A5A4,
    0xA8A7A7A6,0xAAAAA9A9,0xADACACAB,0xAFAEAEAD,0xB0B0B0AF,0xB1B1B1B1,0xB3B2B2B2,0xB4B3B3B3,
    0xB5B5B4B4,0xB6B6B5B5,0xB7B7B6B6,0xB8B8B7B7,0xB9B9B9B8,0xBABABAB9,0xBBBBBBBA,0xBCBCBCBB,
    0xBDBDBDBC,0xBEBEBDBD,0xBFBFBEBE,0xC0C0BFBF,0xC0C0C0C0,0xC0C0C0C0,0xC1C1C1C1,0xC1C1C1C1,
    0xC2C2C1C1,0xC2C2C2C2,0xC2C2C2C2,0xC3C3C3C2,0xC3C3C3C3,0xC3C3C3C3,0xC4C3C3C3,0xC4C4C4C4,
    0xC4C4C4C4,0xC4C4C4C4,0xC4C4C4C4,0xC5C5C5C5,0xC5C5C5C5,0xC5C5C5C5,0xC5C5C5C5,0xC5C5C5C5,
    0xC6C6C5C5,0xC6C6C6C6,0xC6C6C6C6,0xC6C6C6C6,0xC6C6C6C6,0xC6C6C6C6,0xC6C6C6C6,0xC6C6C6C6,
    0xC6C6C6C6,0xC6C6C6C6,0xC6C6C6C6,0xC6C6C6C6,0xC6C6C6C6,0xC6C6C6C6,0xC6C6C6C6,0xC6C6C6C6,
    0xC6C6C6C6,0xC6C6C6C6,0xC5C5C5C6,0xC5C5C5C5,0xC5C5C5C5,0xC5C5C5C5,0xC5C5C5C5,0xC4C4C5C5,
    0xC4C4C4C4,0xC4C4C4C4,0xC4C4C4C4,0xC3C3C4C4,0xC3C3C3C3,0xC3C3C3C3,0xC2C3C3C3,0xC2C2C2C2,
    0xC2C2C2C2,0xC1C1C2C2,0xC1C1C1C1,0xC1C1C1C1,0xC0C0C0C1,0xC0C0C0C0,0xBFC0C0C0,0xBFBFBFBF,
    0xBEBEBEBE,0xBDBDBDBE,0xBCBCBCBD,0xBBBBBBBC,0xBABABABB,0xB9B9B9BA,0xB8B8B9B9,0xB7B7B8B8,
    0xB6B6B6B7,0xB5B5B5B6,0xB4B4B4B5,0xB3B3B3B4,0xB2B2B2B2,0xB1B1B1B1,0xAFB0B0B0,0xADAEAEAF,
    0xABACACAD,0xA9A9AAAA,0xA7A7A8A8,0xA4A5A5A6,0xA2A3A3A4,0xA0A0A1A2,0x9B9D9E9F,0x9798999A,
    0x92939596,0x8B8E9091,0x82848789,0x06040280,0x100D0B09,0x14131211,0x18171615,0x1D1C1B1A,
    0x20201F1E,0x23222121,0x25242423,0x27262625,0x29292828,0x2B2B2A2A,0x2E2D2C2C,0x302F2F2E,
    0x31303030,0x32313131,0x33323232,0x34343333,0x35353434,0x36363535,0x37363636,0x38373737,
    0x39383838,0x39393939,0x3A3A3A3A,0x3B3B3B3B,0x3C3C3C3B,0x3D3D3D3C,0x3E3E3D3D,0x3F3E3E3E,
    0x3F3F3F3F,0x4040403F,0x40404040,0x40404040,0x41414141,0x41414141,0x41414141,0x42424242,
    0x42424242,0x42424242,0x43424242,0x43434343,0x43434343,0x43434343,0x44434343,0x44444444,
    0x44444444,0x44444444,0x44444444,0x44444444,0x44444444,0x45454545,0x45454545,0x45454545,
    0x45454545,0x45454545,0x45454545,0x45454545,0x45454545,0x45454545,0x45454545,0x45454545,
    0x45454545,0x45454545,0x44444445,0x44444444,0x44444444,0x44444444,0x44444444,0x44444444,
    0x44444444,0x43434344,0x43434343,0x43434343,0x43434343,0x42434343,0x42424242,0x42424242,
    0x42424242,0x41414142,0x41414141,0x41414141,0x40404041,0x40404040,0x40404040,0x3F3F3F40,
    0x3E3F3F3F,0x3E3E3E3E,0x3D3D3D3D,0x3C3C3C3D,0x3B3B3C3C,0x3A3B3B3B,0x393A3A3A,0x38393939,
    0x38383838,0x37373737,0x36363636,0x35353535,0x34343434,0x33333333,0x32323232,0x31313131,
    0x30303030,0x2E2F2F30,0x2C2C2D2E,0x2A2A2B2B,0x28282929,0x26262727,0x24242525,0x21222323,
    0x1F202021,0x1B1C1D1E,0x1617191A,0x12131415,0x0C0E1011,0x0304070A,0x84828001,0x8D8A8986,
    0x9392918F,0x97969594,0x9C9A9998,0xA09F9E9D,0xA2A1A1A0,0xA4A3A3A2,0xA6A5A5A4,0xA8A7A7A6,
    0xAAA9A9A8,0xACABABAA,0xAEADADAC,0xB0AFAFAE,0xB1B0B0B0,0xB2B1B1B1,0xB2B2B2B2,0xB3B3B3B3,
    0xB4B4B4B4,0xB5B5B5B5,0xB6B6B6B5,0xB7B7B7B6,0xB8B8B7B7,0xB9B9B8B8,0xBAB9B9B9,0xBABABABA,
    0xBBBBBBBB,0xBCBCBBBB,0xBDBDBCBC,0xBDBDBDBD,0xBEBEBEBE,0xBFBFBFBE,0xC0BFBFBF,0xC0C0C0C0,
    0xC0C0C0C0,0xC1C0C0C0,0xC1C1C1C1,0xC1C1C1C1,0xC1C1C1C1,0xC2C2C2C1,0xC2C2C2C2,0xC2C2C2C2,
    0xC2C2C2C2,0xC2C2C2C2,0xC3C3C3C2,0xC3C3C3C3,0xC3C3C3C3,0xC3C3C3C3,0xC3C3C3C3,0xC3C3C3C3,
    0xC3C3C3C3,0xC3C3C3C3,0xC3C3C3C3,0xC4C3C3C3,0xC4C4C3C4,0xC4C4C4C4,0xC4C4C4C4,0xC4C4C4C4,
    0xC4C4C4C4,0xC3C3C4C4,0xC3C3C3C3,0xC3C3C3C3,0xC3C3C3C3,0xC3C3C3C3,0xC3C3C3C3,0xC3C3C3C3,
    0xC3C3C3C3,0xC3C3C3C3,0xC3C3C3C3,0xC2C2C2C3,0xC2C2C2C2,0xC2C2C2C2,0xC2C2C2C2,0xC2C2C2C2,
    0xC1C1C1C2,0xC1C1C1C1,0xC1C1C1C1,0xC1C1C1C1,0xC0C0C0C0,0xC0C0C0C0,0xC0C0C0C0,0xBFBFBFC0,
    0xBFBFBFBF,0xBEBEBEBE,0xBDBDBEBE,0xBCBDBDBD,0xBCBCBCBC,0xBBBBBBBC,0xBABABBBB,0xB9BABABA,
    0xB9B9B9B9,0xB8B8B8B8,0xB7B7B7B8,0xB6B6B7B7,0xB5B6B6B6,0xB4B5B5B5,0xB4B4B4B4,0xB3B3B3B3,
    0xB2B2B2B2,0xB1B1B1B1,0xB0B0B0B1,0xAEAFAFB0,0xACADADAE,0xAAABABAC,0xA8A9A9AA,0xA6A7A7A8,
    0xA4A5A5A6,0xA2A3A3A4,0xA0A1A1A2,0x9D9E9FA0,0x999A9B9C,0x95969798,0x91929394,0x8C8D8F90,
    0x8485878A,0x04020082,0x0C0A0806,0x1211100E,0x16151413,0x1B1A1817,0x1F1E1D1C,0x21212020,
    0x23232222,0x25252424,0x27272626,0x29292828,0x2B2B2A2A,0x2D2D2C2C,0x2F2F2E2E,0x30303030,
    0x31313130,0x32323231,0x33333232,0x34333333,0x35343434,0x35353535,0x36363636,0x37373636,
    0x38373737,0x38383838,0x39393939,0x3A3A3A39,0x3B3A3A3A,0x3B3B3B3B,0x3C3C3C3B,0x3D3C3C3C,
    0x3D3D3D3D,0x3E3E3E3D,0x3E3E3E3E,0x3F3F3F3F,0x403F3F3F,0x40404040,0x40404040,0x40404040,
    0x41404040,0x41414141,0x41414141,0x41414141,0x41414141,0x42414141,0x42424242,0x42424242,
    0x42424242,0x42424242,0x42424242,0x42424242,0x42424242,0x42424242,0x42424242,0x42424242,
    0x42424242,0x43424242,0x42424343,0x42424242,0x42424242,0x42424242,0x42424242,0x42424242,
    0x42424242,0x42424242,0x42424242,0x42424242,0x42424242,0x42424242,0x41414142,0x41414141,
    0x41414141,0x41414141,0x41414141,0x40404141,0x40404040,0x40404040,0x40404040,0x3F3F4040,
    0x3F3F3F3F,0x3E3E3E3F,0x3E3E3E3E,0x3D3D3D3D,0x3C3C3D3D,0x3C3C3C3C,0x3B3B3B3C,0x3A3A3B3B,
    0x3A3A3A3A,0x39393939,0x38383839,0x37383838,0x37373737,0x36363636,0x35353536,0x34343535,
    0x33343434,0x33333333,0x32323232,0x31313132,0x30303031,0x2F2F3030,0x2D2D2E2E,0x2B2C2C2D,
    0x292A2A2B,0x27282829,0x26262727,0x24242525,0x22222323,0x20202121,0x1C1D1E1F,0x191A1B1C,
    0x15161718,0x11121314,0x0A0C0E10,0x02040609,0x84828001,0x8C8A8886,0x9291908E,0x96959493,
    0x99989897,0x9D9C9B9B,0xA0A09F9E,0xA2A2A1A1,0xA4A3A3A2,0xA6A5A5A4,0xA7A7A6A6,0xA9A9A8A8,
    0xABABAAAA,0xADACACAB,0xAEAEAEAD,0xB0B0AFAF,0xB1B0B0B0,0xB1B1B1B1,0xB2B2B2B2,0xB3B3B3B2,
    0xB4B4B3B3,0xB5B4B4B4,0xB5B5B5B5,0xB6B6B6B6,0xB7B7B6B6,0xB8B7B7B7,0xB8B8B8B8,0xB9B9B9B8,
    0xB9B9B9B9,0xBABABABA,0xBBBBBABA,0xBBBBBBBB,0xBCBCBCBB,0xBCBCBCBC,0xBDBDBDBC,0xBDBDBDBD,
    0xBEBEBEBD,0xBEBEBEBE,0xBFBFBFBE,0xBFBFBFBF,0xC0C0BFBF,0xC0C0C0C0,0xC0C0C0C0,0xC0C0C0C0,
    0xC0C0C0C0,0xC1C0C0C0,0xC1C1C1C1,0xC1C1C1C1,0xC1C1C1C1,0xC1C1C1C1,0xC1C1C1C1,0xC1C1C1C1,
    0xC1C1C1C1,0xC1C1C1C1,0xC1C1C1C1,0xC1C1C1C1,0xC1C1C1C1,0xC1C1C1C1,0xC1C1C1C1,0xC1C1C1C1,
    0xC0C0C1C1,0xC0C0C0C0,0xC0C0C0C0,0xC0C0C0C0,0xC0C0C0C0,0xC0C0C0C0,0xBFBFBFC0,0xBFBFBFBF,
    0xBEBFBFBF,0xBEBEBEBE,0xBDBEBEBE,0xBDBDBDBD,0xBCBDBDBD,0xBCBCBCBC,0xBBBBBCBC,0xBBBBBBBB,
    0xBABABABB,0xB9BABABA,0xB9B9B9B9,0xB8B8B8B9,0xB7B8B8B8,0xB7B7B7B7,0xB6B6B6B7,0xB5B6B6B6,
    0xB5B5B5B5,0xB4B4B4B4,0xB3B3B3B4,0xB2B2B3B3,0xB1B2B2B2,0xB1B1B1B1,0xB0B0B0B0,0xAEAFAFB0,
    0xADADADAE,0xABABACAC,0xA9AAAAAA,0xA7A8A8A9,0xA6A6A7A7,0xA4A4A5A5,0xA2A3A3A4,0xA1A1A1A2,
    0x9E9FA0A0,0x9A9B9C9D,0x9798999A,0x93949596,0x90919292,0x898B8D8E,0x83848688,0x04020081,
    0x0C0A0705,0x11100F0D,0x15141312,0x18171616,0x1C1B1A19,0x201F1E1D,0x21212120,0x23232222,
    0x25252424,0x27262625,0x28282827,0x2A2A2929,0x2C2B2B2B,0x2D2D2D2C,0x2F2F2E2E,0x3030302F,
    0x31313030,0x32313131,0x32323232,0x33333332,0x34333333,0x34343434,0x35353535,0x36363535,
    0x36363636,0x37373737,0x38383737,0x38383838,0x39393938,0x39393939,0x3A3A3A3A,0x3B3A3A3A,
    0x3B3B3B3B,0x3C3B3B3B,0x3C3C3C3C,0x3D3C3C3C,0x3D3D3D3D,0x3D3D3D3D,0x3E3E3E3E,0x3E3E3E3E,
    0x3F3F3E3E,0x3F3F3F3F,0x3F3F3F3F,0x40403F3F,0x40404040,0x40404040,0x40404040,0x40404040,
    0x40404040,0x40404040,0x40404040,0x40404040,0x40404040,0x40404040,0x40404040,0x40404040,
    0x40404040,0x40404040,0x40404040,0x40404040,0x40404040,0x3F3F3F40,0x3F3F3F3F,0x3F3F3F3F,
    0x3E3E3E3E,0x3E3E3E3E,0x3D3D3E3E,0x3D3D3D3D,0x3C3D3D3D,0x3C3C3C3C,0x3C3C3C3C,0x3B3B3B3B,
    0x3B3B3B3B,0x3A3A3A3A,0x393A3A3A,0x39393939,0x38383939,0x38383838,0x37373737,0x36363737,
    0x36363636,0x35353535,0x34343535,0x34343434,0x33333333,0x32323233,0x31323232,0x31313131,
    0x30303030,0x2F2F3030,0x2D2E2E2E,0x2C2C2D2D,0x2A2B2B2B,0x2929292A,0x27272828,0x25262627,
    0x24242525,0x22222323,0x20212122,0x1E1F2020,0x1A1B1C1D,0x1718191A,0x14151516,0x10111213,
    0x0B0C0E10,0x04060709,0x82800002,0x88878583,0x8F8D8C8A,0x93929190,0x96959493,0x99989797,
    0x9C9C9B9A,0xA09F9E9D,0xA1A1A0A0,0xA3A2A2A2,0xA4A4A4A3,0xA6A6A5A5,0xA8A7A7A7,0xA9A9A8A8,
    0xABAAAAAA,0xACACACAB,0xAEADADAD,0xAFAFAEAE,0xB0B0B0B0,0xB1B1B0B0,0xB2B1B1B1,0xB2B2B2B2,
    0xB3B3B3B2,0xB4B3B3B3,0xB4B4B4B4,0xB5B5B5B4,0xB6B5B5B5,0xB6B6B6B6,0xB7B7B6B6,0xB7B7B7B7,
    0xB8B8B8B7,0xB8B8B8B8,0xB9B9B9B9,0xB9B9B9B9,0xBABABABA,0xBABABABA,0xBBBBBBBA,0xBBBBBBBB,
    0xBCBCBBBB,0xBCBCBCBC,0xBCBCBCBC,0xBDBDBDBC,0xBDBDBDBD,0xBDBDBDBD,0xBEBEBDBD,0xBEBEBEBE,
    0xBEBEBEBE,0xBEBEBEBE,0xBFBFBEBE,0xBFBFBFBF,0xBFBFBFBF,0xBFBFBFBF,0xBFBFBFBF,0xBFBFBFBF,
    0xBFBFBFBF,0xBFBFBFBF,0xBFBFBFBF,0xBFBFBFBF,0xBFBFBFBF,0xBFBFBFBF,0xBFBFBFBF,0xBFBFBFBF,
    0xBFBFBFBF,0xBFBFBFBF,0xBFBFBFBF,0xBEBEBFBF,0xBEBEBEBE,0xBEBEBEBE,0xBEBEBEBE,0xBDBEBEBE,
    0xBDBDBDBD,0xBDBDBDBD,0xBDBDBDBD,0xBCBCBCBC,0xBCBCBCBC,0xBBBCBCBC,0xBBBBBBBB,0xBBBBBBBB,
    0xBABABABB,0xBABABABA,0xB9B9BABA,0xB9B9B9B9,0xB8B8B9B9,0xB8B8B8B8,0xB7B7B8B8,0xB7B7B7B7,
    0xB6B6B6B7,0xB6B6B6B6,0xB5B5B5B5,0xB4B5B5B5,0xB4B4B4B4,0xB3B3B3B4,0xB2B3B3B3,0xB2B2B2B2,
    0xB1B1B1B2,0xB0B1B1B1,0xB0B0B0B0,0xAEAFAFB0,0xADADAEAE,0xACACACAD,0xAAAAABAB,0xA9A9A9AA,
    0xA7A7A8A8,0xA5A6A6A7,0xA4A4A5A5,0xA2A3A3A3,0xA1A1A1A2,0x9E9FA0A0,0x9B9C9D9D,0x98999A9A,
    0x95959697,0x91929394,0x8D8E9091,0x87888A8B,0x80828385,0x05040201,0x0C0A0907,0x11100F0D,
    0x14131212,0x17161615,0x1A191918,0x1D1D1C1B,0x20201F1E,0x21212120,0x23232222,0x25242423,
    0x26262525,0x27272726,0x29292828,0x2A2A2A29,0x2C2B2B2B,0x2D2D2C2C,0x2F2E2E2E,0x30302F2F,
    0x30303030,0x31313131,0x32313131,0x32323232,0x33333332,0x33333333,0x34343434,0x35343434,
    0x35353535,0x36363535,0x36363636,0x37373736,0x37373737,0x38383837,0x38383838,0x39393938,
    0x39393939,0x3A3A3939,0x3A3A3A3A,0x3A3A3A3A,0x3B3B3B3B,0x3B3B3B3B,0x3C3B3B3B,0x3C3C3C3C,
    0x3C3C3C3C,0x3C3C3C3C,0x3D3D3C3C,0x3D3D3D3D,0x3D3D3D3D,0x3D3D3D3D,0x3D3D3D3D,0x3D3D3D3D,
    0x3E3E3E3D,0x3E3E3E3E,0x3E3E3E3E,0x3E3E3E3E,0x3E3E3E3E,0x3E3E3E3E,0x3E3E3E3E,0x3E3E3E3E,
    0x3E3E3E3E,0x3E3E3E3E,0x3E3E3E3E,0x3E3E3E3E,0x3D3E3E3E,0x3D3D3D3D,0x3D3D3D3D,0x3D3D3D3D,
    0x3D3D3D3D,0x3C3D3D3D,0x3C3C3C3C,0x3C3C3C3C,0x3C3C3C3C,0x3B3C3C3C,0x3B3B3B3B,0x3B3B3B3B,
    0x3A3A3B3B,0x3A3A3A3A,0x3A3A3A3A,0x39393939,0x39393939,0x38383939,0x38383838,0x37373838,
    0x37373737,0x36363737,0x36363636,0x35353536,0x35353535,0x34343434,0x33343434,0x33333333,
    0x32323333,0x32323232,0x31313131,0x30313131,0x30303030,0x2F2F2F30,0x2D2E2E2E,0x2C2C2C2D,
    0x2A2B2B2C,0x29292A2A,0x28282829,0x26272727,0x25252626,0x23242424,0x22222323,0x21212122,
    0x1F1F2020,0x1C1C1D1E,0x191A1A1B,0x16171718,0x13141515,0x10111212,0x0A0C0D0F,0x05060809,
    0x81000103,0x87858482,0x8D8B8A88,0x9190908E,0x94939392,0x97969695,0x9A999998,0x9D9C9C9B,
    0xA09F9F9E,0xA1A1A1A0,0xA3A2A2A2,0xA4A4A3A3,0xA6A5A5A4,0xA7A7A6A6,0xA8A8A8A7,0xAAA9A9A9,
    0xABABAAAA,0xACACACAB,0xAEADADAD,0xAFAFAEAE,0xB0B0AFAF,0xB0B0B0B0,0xB1B1B1B1,0xB2B1B1B1,
    0xB2B2B2B2,0xB3B3B2B2,0xB3B3B3B3,0xB4B4B3B3,0xB4B4B4B4,0xB5B5B4B4,0xB5B5B5B5,0xB6B6B5B5,
    0xB6B6B6B6,0xB7B6B6B6,0xB7B7B7B7,0xB7B7B7B7,0xB8B8B8B8,0xB8B8B8B8,0xB9B8B8B8,0xB9B9B9B9,
    0xB9B9B9B9,0xBAB9B9B9,0xBABABABA,0xBABABABA,0xBABABABA,0xBABABABA,0xBBBBBBBB,0xBBBBBBBB,
    0xBBBBBBBB,0xBBBBBBBB,0xBBBBBBBB,0xBCBCBCBB,0xBCBCBCBC,0xBCBCBCBC,0xBCBCBCBC,0xBCBCBCBC,
    0xBCBCBCBC,0xBCBCBCBC,0xBCBCBCBC,0xBCBCBCBC,0xBCBCBCBC,0xBCBCBCBC,0xBCBCBCBC,0xBBBBBBBB,
    0xBBBBBBBB,0xBBBBBBBB,0xBBBBBBBB,0xBBBBBBBB,0xBABBBBBB,0xBABABABA,0xBABABABA,0xBABABABA,
    0xB9BABABA,0xB9B9B9B9,0xB9B9B9B9,0xB8B9B9B9,0xB8B8B8B8,0xB8B8B8B8,0xB7B7B8B8,0xB7B7B7B7,
    0xB6B7B7B7,0xB6B6B6B6,0xB6B6B6B6,0xB5B5B5B5,0xB5B5B5B5,0xB4B4B4B4,0xB4B4B4B4,0xB3B3B3B4,
    0xB3B3B3B3,0xB2B2B2B2,0xB1B2B2B2,0xB1B1B1B1,0xB0B0B1B1,0xB0B0B0B0,0xAFAFAFB0,0xADAEAEAE,
    0xACADADAD,0xABABACAC,0xAAAAAAAB,0xA8A9A9A9,0xA7A7A8A8,0xA6A6A6A7,0xA4A5A5A5,0xA3A3A4A4,
    0xA2A2A2A3,0xA0A1A1A1,0x9F9FA0A0,0x9C9D9D9E,0x999A9B9B,0x96979899,0x94949596,0x91919293,
    0x8C8E8F90,0x8788898B,0x81828485,0x05030100,0x0A090706,0x100F0D0C,0x13121110,0x15151413,
    0x18181716,0x1B1A1919,0x1E1D1C1B,0x20201F1E,0x21212120,0x23222222,0x24242323,0x25252524,
    0x27262626,0x28282727,0x29292828,0x2A2A2A2A,0x2C2B2B2B,0x2D2D2C2C,0x2E2E2E2D,0x2F2F2F2E,
    0x30303030,0x30303030,0x31313131,0x32313131,0x32323232,0x33323232,0x33333333,0x34333333,
    0x34343434,0x34343434,0x35353535,0x35353535,0x36363635,0x36363636,0x37363636,0x37373737,
    0x37373737,0x38373737,0x38383838,0x38383838,0x38383838,0x39393939,0x39393939,0x39393939,
    0x39393939,0x3A3A3A39,0x3A3A3A3A,0x3A3A3A3A,0x3A3A3A3A,0x3A3A3A3A,0x3A3A3A3A,0x3A3A3A3A,
    0x3B3B3B3A,0x3B3B3B3B,0x3B3B3B3B,0x3B3B3B3B,0x3B3B3B3B,0x3B3B3B3B,0x3B3B3B3B,0x3B3B3B3B,
    0x3A3B3B3B,0x3A3A3A3A,0x3A3A3A3A,0x3A3A3A3A,0x3A3A3A3A,0x3A3A3A3A,0x3A3A3A3A,0x3939393A,
    0x39393939,0x39393939,0x39393939,0x38383839,0x38383838,0x38383838,0x37383838,0x37373737,
    0x37373737,0x36363737,0x36363636,0x36363636,0x35353536,0x35353535,0x34343535,0x34343434,
    0x33343434,0x33333333,0x32333333,0x32323232,0x31323232,0x31313131,0x30303131,0x30303030,
    0x2F2F2F30,0x2E2E2E2F,0x2D2D2D2D,0x2B2C2C2C,0x2A2A2B2B,0x29292A2A,0x28282829,0x26272727,
    0x25262626,0x24242425,0x23232324,0x21222222,0x20202121,0x1E1F1F20,0x1C1C1D1D,0x19191A1B,
    0x16171818,0x14151516,0x11121313,0x0E0F1011,0x090A0B0C,0x03050607,0x81000102,0x86858382,
    0x8C8A8987,0x908F8E8D,0x93929191,0x95959493,0x98979796,0x9B9A9999,0x9D9D9C9B,0xA09F9E9E,
    0xA1A1A0A0,0xA2A2A2A1,0xA3A3A3A2,0xA5A4A4A4,0xA6A5A5A5,0xA7A7A6A6,0xA8A8A8A7,0xA9A9A9A8,
    0xABAAAAAA,0xACABABAB,0xADACACAC,0xAEAEADAD,0xAFAFAEAE,0xB0B0AFAF,0xB0B0B0B0,0xB1B1B0B0,
    0xB1B1B1B1,0xB2B2B1B1,0xB2B2B2B2,0xB3B3B2B2,0xB3B3B3B3,0xB3B3B3B3,0xB4B4B4B4,0xB4B4B4B4,
    0xB5B5B4B4,0xB5B5B5B5,0xB5B5B5B5,0xB6B6B6B5,0xB6B6B6B6,0xB6B6B6B6,0xB7B6B6B6,0xB7B7B7B7,
    0xB7B7B7B7,0xB7B7B7B7,0xB7B7B7B7,0xB8B8B8B7,0xB8B8B8B8,0xB8B8B8B8,0xB8B8B8B8,0xB8B8B8B8,
    0xB8B8B8B8,0xB8B8B8B8,0xB9B8B8B8,0xB9B9B9B9,0xB9B9B9B9,0xB9B9B9B9,0xB9B9B9B9,0xB9B9B9B9,
    0xB9B9B9B9,0xB9B9B9B9,0xB9B9B9B9,0xB8B9B9B9,0xB8B8B8B8,0xB8B8B8B8,0xB8B8B8B8,0xB8B8B8B8,
    0xB8B8B8B8,0xB8B8B8B8,0xB7B8B8B8,0xB7B7B7B7,0xB7B7B7B7,0xB7B7B7B7,0xB7B7B7B7,0xB6B6B6B7,
    0xB6B6B6B6,0xB6B6B6B6,0xB5B5B6B6,0xB5B5B5B5,0xB5B5B5B5,0xB4B4B5B5,0xB4B4B4B4,0xB4B4B4B4,
    0xB3B3B3B3,0xB3B3B3B3,0xB2B2B3B3,0xB2B2B2B2,0xB1B2B2B2,0xB1B1B1B1,0xB0B1B1B1,0xB0B0B0B0,
    0xB0B0B0B0,0xAFAFAFAF,0xADAEAEAE,0xACADADAD,0xABACACAC,0xAAAAABAB,0xA9A9AAAA,0xA8A8A9A9,
    0xA7A7A7A8,0xA6A6A6A7,0xA5A5A5A5,0xA3A4A4A4,0xA2A3A3A3,0xA1A1A2A2,0xA0A0A0A1,0x9E9E9FA0,
    0x9B9C9D9D,0x99999A9B,0x97979898,0x94959596,0x91929394,0x8F909091,0x8A8B8C8E,0x85868789,
    0x80818284,0x05030200,0x09080706,0x0F0D0C0B,0x12111010,0x14141312,0x17161515,0x19181817,
    0x1B1B1A1A,0x1E1D1D1C,0x20201F1E,0x21212020,0x22222221,0x23232322,0x24242424,0x26252525,
    0x27262626,0x28282727,0x29292828,0x2A2A2929,0x2B2B2B2A,0x2C2C2C2B,0x2D2D2D2C,0x2E2E2E2D,
    0x2F2F2F2E,0x3030302F,0x30303030,0x31313030,0x31313131,0x31313131,0x32323232,0x32323232,
    0x33333232,0x33333333,0x33333333,0x34343433,0x34343434,0x34343434,0x35353535,0x35353535,
    0x35353535,0x36363635,0x36363636,0x36363636,0x36363636,0x37373736,0x37373737,0x37373737,
    0x37373737,0x37373737,0x37373737,0x37373737,0x37373737,0x38383838,0x38383838,0x38383838,
    0x38383838,0x38383838,0x38383838,0x38383838,0x38383838,0x38383838,0x38383838,0x37383838,
    0x37373737,0x37373737,0x37373737,0x37373737,0x37373737,0x37373737,0x36373737,0x36363636,
    0x36363636,0x36363636,0x35363636,0x35353535,0x35353535,0x35353535,0x34343435,0x34343434,
    0x34343434,0x33333333,0x33333333,0x32333333,0x32323232,0x32323232,0x31313132,0x31313131,
    0x30313131,0x30303030,0x2F303030,0x2F2F2F2F,0x2E2E2E2E,0x2D2D2D2D,0x2C2C2C2C,0x2B2B2B2B,
    0x2A2A2A2A,0x29292929,0x28282828,0x27272727,0x25262626,0x24252525,0x23242424,0x22222323,
    0x21212222,0x20202021,0x1E1F1F20,0x1C1C1D1D,0x191A1B1B,0x17181819,0x15151617,0x13131414,
    0x10111112,0x0D0E0F10,0x08090A0B,0x03040507,0x81000102,0x85848382,0x8A898887,0x908E8D8C,
    0x92919090,0x94939292,0x96959594,0x98989797,0x9B9A9999,0x9D9C9B9B,0x9F9E9E9D,0xA0A0A09F,
    0xA1A1A1A0,0xA2A2A2A2,0xA3A3A3A3,0xA4A4A4A4,0xA5A5A5A5,0xA7A6A6A6,0xA8A7A7A7,0xA8A8A8A8,
    0xA9A9A9A9,0xAAAAAAAA,0xABABABAB,0xACACACAC,0xADADADAD,0xAEAEAEAD,0xAFAFAEAE,0xB0AFAFAF,
    0xB0B0B0B0,0xB0B0B0B0,0xB1B1B1B0,0xB1B1B1B1,0xB1B1B1B1,0xB2B2B2B2,0xB2B2B2B2,0xB3B2B2B2,
    0xB3B3B3B3,0xB3B3B3B3,0xB3B3B3B3,0xB4B4B4B4,0xB4B4B4B4,0xB4B4B4B4,0xB4B4B4B4,0xB5B5B4B4,
    0xB5B5B5B5,0xB5B5B5B5,0xB5B5B5B5,0xB5B5B5B5,0xB5B5B5B5,0xB6B6B6B5,0xB6B6B6B6,0xB6B6B6B6,
    0xB6B6B6B6,0xB6B6B6B6,0xB6B6B6B6,0xB6B6B6B6,0xB6B6B6B6,0xB6B6B6B6,0xB6B6B6B6,0xB6B6B6B6,
    0xB6B6B6B6,0xB6B6B6B6,0xB6B6B6B6,0xB6B6B6B6,0xB6B6B6B6,0xB5B5B5B6,0xB5B5B5B5,0xB5B5B5B5,
    0xB5B5B5B5,0xB5B5B5B5,0xB5B5B5B5,0xB4B4B5B5,0xB4B4B4B4,0xB4B4B4B4,0xB4B4B4B4,0xB3B3B4B4,
    0xB3B3B3B3,0xB3B3B3B3,0xB2B3B3B3,0xB2B2B2B2,0xB2B2B2B2,0xB1B2B2B2,0xB1B1B1B1,0xB1B1B1B1,
    0xB0B0B1B1,0xB0B0B0B0,0xB0B0B0B0,0xAFAFAFAF,0xAEAEAEAF,0xADADAEAE,0xACADADAD,0xACACACAC,
    0xABABABAB,0xAAAAAAAA,0xA9A9A9A9,0xA8A8A8A8,0xA7A7A7A7,0xA6A6A6A7,0xA5A5A5A6,0xA4A4A4A5,
    0xA3A3A3A3,0xA2A2A2A2,0xA0A1A1A1,0x9FA0A0A0,0x9D9E9E9F,0x9B9C9C9D,0x999A9A9B,0x97979899,
    0x95959696,0x93939494,0x90919292,0x8D8F9090,0x898A8B8C,0x85868788,0x80828383,0x03020100,
    0x08060504,0x0C0B0A09,0x100F0F0D,0x13121111,0x15141313,0x17161615,0x19191817,0x1B1B1A19,
    0x1D1D1C1C,0x1F1F1E1E,0x20202020,0x21212121,0x22222222,0x23232323,0x24242423,0x25252525,
    0x26262625,0x27272726,0x28282827,0x29282828,0x2A2A2929,0x2B2B2A2A,0x2C2B2B2B,0x2D2C2C2C,
    0x2D2D2D2D,0x2E2E2E2E,0x2F2F2F2E,0x30302F2F,0x30303030,0x30303030,0x31313130,0x31313131,
    0x31313131,0x32323231,0x32323232,0x32323232,0x33333232,0x33333333,0x33333333,0x33333333,
    0x34343333,0x34343434,0x34343434,0x34343434,0x34343434,0x34343434,0x35353434,0x35353535,
    0x35353535,0x35353535,0x35353535,0x35353535,0x35353535,0x35353535,0x35353535,0x35353535,
    0x35353535,0x34353535,0x34343434,0x34343434,0x34343434,0x34343434,0x34343434,0x33343434,
    0x33333333,0x33333333,0x33333333,0x33333333,0x32323232,0x32323232,0x32323232,0x31313232,
    0x31313131,0x31313131,0x30303031,0x30303030,0x30303030,0x2F2F2F30,0x2E2E2F2F,0x2D2E2E2E,
    0x2D2D2D2D,0x2C2C2C2C,0x2B2B2B2C,0x2A2A2B2B,0x292A2A2A,0x28292929,0x28282828,0x27272727,
    0x26262626,0x25252525,0x24242424,0x23232324,0x22222223,0x21212122,0x20202021,0x1E1F1F20,
    0x1C1D1D1D,0x1A1A1B1B,0x18191919,0x16161717,0x14141515,0x12121313,0x10101111,0x0B0D0F10,
    0x0708090A,0x03040506,0x80000102,0x84838281,0x88888685,0x8D8C8B89,0x90908F8E,0x92929191,
    0x94949393,0x96969595,0x98989797,0x9A9A9999,0x9C9C9B9B,0x9E9E9D9D,0xA09F9F9F,0xA1A0A0A0,
    0xA2A1A1A1,0xA2A2A2A2,0xA3A3A3A3,0xA4A4A4A4,0xA5A5A5A4,0xA6A6A6A5,0xA7A7A6A6,0xA8A8A7A7,
    0xA9A8A8A8,0xA9A9A9A9,0xAAAAAAAA,0xABABABAA,0xACACABAB,0xACACACAC,0xADADADAD,0xAEAEADAD,
    0xAFAEAEAE,0xAFAFAFAF,0xB0B0B0AF,0xB0B0B0B0,0xB0B0B0B0,0xB1B0B0B0,0xB1B1B1B1,0xB1B1B1B1,
    0xB1B1B1B1,0xB2B1B1B1,0xB2B2B2B2,0xB2B2B2B2,0xB2B2B2B2,0xB2B2B2B2,0xB3B3B3B2,0xB3B3B3B3,
    0xB3B3B3B3,0xB3B3B3B3,0xB3B3B3B3,0xB3B3B3B3,0xB3B3B3B3,0xB3B3B3B3,0xB4B3B3B3,0xB4B4B4B4,
    0xB4B4B4B4,0xB4B4B4B4,0xB4B4B4B4,0xB4B4B4B4,0xB4B4B4B4,0xB4B4B4B4,0xB4B4B4B4,0xB4B4B4B4,
    0xB3B3B4B4,0xB3B3B3B3,0xB3B3B3B3,0xB3B3B3B3,0xB3B3B3B3,0xB3B3B3B3,0xB3B3B3B3,0xB3B3B3B3,
    0xB2B2B2B3,0xB2B2B2B2,0xB2B2B2B2,0xB2B2B2B2,0xB2B2B2B2,0xB1B1B1B1,0xB1B1B1B1,0xB1B1B1B1,
    0xB1B1B1B1,0xB0B0B0B1,0xB0B0B0B0,0xB0B0B0B0,0xAFAFB0B0,0xAFAFAFAF,0xAEAEAEAE,0xADADAEAE,
    0xADADADAD,0xACACACAC,0xABABABAC,0xAAABABAB,0xA9AAAAAA,0xA9A9A9A9,0xA8A8A8A9,0xA7A7A8A8,
    0xA6A7A7A7,0xA6A6A6A6,0xA5A5A5A5,0xA4A4A4A4,0xA3A3A3A4,0xA2A2A2A3,0xA1A1A2A2,0xA0A0A1A1,
    0x9FA0A0A0,0x9D9E9E9F,0x9B9C9C9D,0x999A9A9B,0x97989899,0x96969697,0x94949595,0x92929393,
    0x90909191,0x8C8D8E8F,0x88898A8B,0x85868788,0x81818284,0x02010180,0x06050403,0x0A090807,
    0x0E0D0C0B,0x1110100F,0x13121211,0x15141413,0x17161615,0x18181817,0x1A1A1919,0x1C1C1B1B,
    0x1E1E1D1D,0x201F1F1E,0x21202020,0x21212121,0x22222222,0x23232322,0x24242323,0x25252424,
    0x26252525,0x27262626,0x27272727,0x28282828,0x29292928,0x2A2A2929,0x2B2A2A2A,0x2B2B2B2B,
    0x2C2C2C2C,0x2D2D2C2C,0x2D2D2D2D,0x2E2E2E2E,0x2F2E2E2E,0x2F2F2F2F,0x30302F2F,0x30303030,
    0x30303030,0x30303030,0x31313130,0x31313131,0x31313131,0x31313131,0x32323131,0x32323232,
    0x32323232,0x32323232,0x32323232,0x32323232,0x33323232,0x33333333,0x33333333,0x33333333,
    0x33333333,0x33333333,0x33333333,0x33333333,0x33333333,0x33333333,0x33333333,0x33333333,
    0x33333333,0x33333333,0x33333333,0x33333333,0x33333333,0x33333333,0x33333333,0x32323233,
    0x32323232,0x32323232,0x32323232,0x32323232,0x32323232,0x31323232,0x31313131,0x31313131,
    0x31313131,0x31313131,0x30303031,0x30303030,0x30303030,0x30303030,0x2F2F2F30,0x2F2F2F2F,
    0x2E2E2E2E,0x2D2D2E2E,0x2D2D2D2D,0x2C2C2C2D,0x2B2B2C2C,0x2B2B2B2B,0x2A2A2A2A,0x29292A2A,
    0x28292929,0x28282828,0x27272727,0x26262727,0x25262626,0x25252525,0x24242424,0x23232323,
    0x22222223,0x21212122,0x20202121,0x1F202020,0x1D1E1E1F,0x1B1C1C1D,0x1A1A1A1B,0x17181919,
    0x16161717,0x14151515,0x12131314,0x10111112,0x0E0E0F10,0x0A0B0C0D,0x06070809,0x03040405,
    0x80000102,0x84838281,0x88878685,0x8B8A8989,0x8F8E8D8C,0x91919090,0x93929291,0x95949493,
    0x96969695,0x98989797,0x9A9A9999,0x9C9B9B9A,0x9D9D9C9C,0x9F9F9E9E,0xA0A0A09F,0xA1A1A1A0,
    0xA2A1A1A1,0xA3A2A2A2,0xA3A3A3A3,0xA4A4A4A3,0xA5A5A4A4,0xA5A5A5A5,0xA6A6A6A6,0xA7A7A7A6,
    0xA8A8A7A7,0xA8A8A8A8,0xA9A9A9A9,0xAAAAA9A9,0xAAAAAAAA,0xABABABAA,0xACABABAB,0xACACACAC,
    0xADADACAC,0xADADADAD,0xAEAEAEAD,0xAEAEAEAE,0xAFAFAFAE,0xAFAFAFAF,0xB0B0AFAF,0xB0B0B0B0,
    0xB0B0B0B0,0xB0B0B0B0,0xB0B0B0B0,0xB1B1B1B0,0xB1B1B1B1,0xB1B1B1B1,0xB1B1B1B1,0xB1B1B1B1,
    0xB1B1B1B1,0xB1B1B1B1,0xB1B1B1B1,0xB1B1B1B1,0xB2B2B1B1,0xB2B2B2B2,0xB2B2B2B2,0xB2B2B2B2,
    0xB2B2B2B2,0xB2B2B2B2,0xB2B2B2B2,0xB2B2B2B2,0xB2B2B2B2,0xB2B2B2B2,0xB1B1B1B1,0xB1B1B1B1,
    0xB1B1B1B1,0xB1B1B1B1,0xB1B1B1B1,0xB1B1B1B1,0xB1B1B1B1,0xB1B1B1B1,0xB0B1B1B1,0xB0B0B0B0,
    0xB0B0B0B0,0xB0B0B0B0,0xB0B0B0B0,0xAFB0B0B0,0xAFAFAFAF,0xAFAFAFAF,0xAEAEAEAE,0xAEAEAEAE,
    0xADADADAE,0xADADADAD,0xACACADAD,0xABACACAC,0xABABABAB,0xAAAAABAB,0xAAAAAAAA,0xA9A9A9A9,
    0xA8A8A9A9,0xA8A8A8A8,0xA7A7A7A8,0xA6A6A7A7,0xA6A6A6A6,0xA5A5A5A5,0xA4A4A5A5,0xA3A3A4A4,
    0xA3A3A3A3,0xA2A2A2A2,0xA1A1A1A2,0xA0A0A1A1,0x9FA0A0A0,0x9E9E9F9F,0x9C9D9D9D,0x9A9B9B9C,
    0x99999A9A,0x97989898,0x95969697,0x94949595,0x92929393,0x90919192,0x8D8E8F90,0x8A8B8C8D,
    0x86878889,0x83848585,0x00808182,0x03020101,0x07060504,0x0A090908,0x0E0D0C0B,0x10100F0E,
    0x12121111,0x14131312,0x15151414,0x17171616,0x19181817,0x1A1A1A19,0x1C1C1B1B,0x1E1D1D1D,
    0x1F1F1E1E,0x20202020,0x21212120,0x22212121,0x22222222,0x23232323,0x24242323,0x24242424,
    0x25252525,0x26262625,0x27262626,0x27272727,0x28282827,0x29282828,0x29292929,0x2A292929,
    0x2A2A2A2A,0x2B2B2B2A,0x2C2B2B2B,0x2C2C2C2C,0x2D2C2C2C,0x2D2D2D2D,0x2E2D2D2D,0x2E2E2E2E,
    0x2E2E2E2E,0x2F2F2F2F,0x2F2F2F2F,0x302F2F2F,0x30303030,0x30303030,0x30303030,0x30303030,
    0x30303030,0x30303030,0x31313131,0x31313131,0x31313131,0x31313131,0x31313131,0x31313131,
    0x31313131,0x31313131,0x31313131,0x31313131,0x31313131,0x31313131,0x31313131,0x31313131,
    0x31313131,0x31313131,0x31313131,0x31313131,0x31313131,0x30303131,0x30303030,0x30303030,
    0x30303030,0x30303030,0x30303030,0x30303030,0x2F2F2F30,0x2F2F2F2F,0x2F2F2F2F,0x2E2E2E2E,
    0x2E2E2E2E,0x2D2D2D2E,0x2D2D2D2D,0x2C2C2D2D,0x2C2C2C2C,0x2B2C2C2C,0x2B2B2B2B,0x2A2A2B2B,
    0x2A2A2A2A,0x2929292A,0x29292929,0x28282828,0x27272828,0x27272727,0x26262626,0x25252526,
    0x24252525,0x24242424,0x23232323,0x22222323,0x21222222,0x21212121,0x20202021,0x1F1F2020,
    0x1D1E1E1E,0x1C1C1D1D,0x1A1B1B1C,0x1919191A,0x17171818,0x16161617,0x14141515,0x12131314,
    0x11111112,0x0F101010,0x0B0C0D0E,0x0809090A,0x05060707,0x02030405,0x81800001,0x84838382,
    0x88878685,0x8A898988,0x8D8D8C8B,0x90908F8E,0x92919190,0x93939292,0x95949494,0x96969595,
    0x98989797,0x99999998,0x9B9B9A9A,0x9D9C9C9B,0x9E9E9D9D,0x9F9F9F9E,0xA0A0A0A0,0xA1A1A1A0,
    0xA2A1A1A1,0xA2A2A2A2,0xA3A3A3A2,0xA4A3A3A3,0xA4A4A4A4,0xA5A5A5A4,0xA5A5A5A5,0xA6A6A6A6,
    0xA7A6A6A6,0xA7A7A7A7,0xA8A8A8A7,0xA8A8A8A8,0xA9A9A9A9,0xA9A9A9A9,0xAAAAAAAA,0xAAAAAAAA,
    0xABABABAA,0xABABABAB,0xACACABAB,0xACACACAC,0xACACACAC,0xADADADAC,0xADADADAD,0xADADADAD,
    0xAEAEAEAD,0xAEAEAEAE,0xAEAEAEAE,0xAEAEAEAE,0xAFAFAFAE,0xAFAFAFAF,0xAFAFAFAF,0xAFAFAFAF,
    0xAFAFAFAF,0xAFAFAFAF,0xB0B0B0B0,0xB0B0B0B0,0xB0B0B0B0,0xB0B0B0B0,0xB0B0B0B0,0xB0B0B0B0,
    0xB0B0B0B0,0xB0B0B0B0,0xB0B0B0B0,0xAFB0B0B0,0xAFAFAFAF,0xAFAFAFAF,0xAFAFAFAF,0xAFAFAFAF,
    0xAFAFAFAF,0xAFAFAFAF,0xAEAEAFAF,0xAEAEAEAE,0xAEAEAEAE,0xAEAEAEAE,0xADADADAD,0xADADADAD,
    0xADADADAD,0xACACACAC,0xACACACAC,0xABABACAC,0xABABABAB,0xAAABABAB,0xAAAAAAAA,0xA9AAAAAA,
    0xA9A9A9A9,0xA8A9A9A9,0xA8A8A8A8,0xA8A8A8A8,0xA7A7A7A7,0xA6A7A7A7,0xA6A6A6A6,0xA5A5A6A6,
    0xA5A5A5A5,0xA4A4A4A4,0xA3A4A4A4,0xA3A3A3A3,0xA2A2A2A2,0xA1A2A2A2,0xA1A1A1A1,0xA0A0A0A1,
    0x9FA0A0A0,0x9E9E9E9F,0x9C9D9D9D,0x9B9B9C9C,0x9A9A9A9B,0x98989999,0x97979798,0x95959696,
    0x94949495,0x92929393,0x91919192,0x8F8F9090,0x8B8C8D8E,0x88898A8A,0x85868788,0x82838384,
    0x00808182,0x03020201,0x06060504,0x09080807,0x0C0B0B0A,0x0F0E0D0D,0x11101010,0x12111111,
    0x14131212,0x15151414,0x16161615,0x18171717,0x1A191918,0x1B1B1A1A,0x1C1C1C1B,0x1E1E1D1D,
    0x1F1F1E1E,0x20202020,0x21212020,0x21212121,0x22222222,0x23232222,0x23232323,0x24242423,
    0x24242424,0x25252525,0x26252525,0x26262626,0x27272626,0x27272727,0x28282727,0x28282828,
    0x29292828,0x29292929,0x2A292929,0x2A2A2A2A,0x2B2A2A2A,0x2B2B2B2B,0x2B2B2B2B,0x2C2C2B2B,
    0x2C2C2C2C,0x2C2C2C2C,0x2D2C2C2C,0x2D2D2D2D,0x2D2D2D2D,0x2D2D2D2D,0x2E2E2D2D,0x2E2E2E2E,
    0x2E2E2E2E,0x2E2E2E2E,0x2E2E2E2E,0x2E2E2E2E,0x2F2E2E2E,0x2F2F2F2F,0x2F2F2F2F,0x2F2F2F2F,
    0x2F2F2F2F,0x2F2F2F2F,0x2F2F2F2F,0x2F2F2F2F,0x2F2F2F2F,0x2F2F2F2F,0x2E2E2E2F,0x2E2E2E2E,
    0x2E2E2E2E,0x2E2E2E2E,0x2E2E2E2E,0x2E2E2E2E,0x2E2E2E2E,0x2D2D2E2E,0x2D2D2D2D,0x2D2D2D2D,
    0x2D2D2D2D,0x2C2C2C2D,0x2C2C2C2C,0x2C2C2C2C,0x2B2B2B2C,0x2B2B2B2B,0x2A2B2B2B,0x2A2A2A2A,
    0x2A2A2A2A,0x2929292A,0x29292929,0x28282929,0x28282828,0x27272828,0x27272727,0x26272727,
    0x26262626,0x25252626,0x25252525,0x24242425,0x24242424,0x23232323,0x22232323,0x22222222,
    0x21212122,0x20202121,0x20202020,0x1F1F2020,0x1D1E1E1E,0x1C1D1D1D,0x1B1B1B1C,0x1A1A1A1B,
    0x18191919,0x17171818,0x15161616,0x14141515,0x13131314,0x11121212,0x10101111,0x0D0E0F0F,
    0x0B0B0C0D,0x0809090A,0x05060707,0x02030304,0x80000101,0x83828181,0x86858483,0x88888786,
    0x8B8A8A89,0x8E8D8D8C,0x90908F8E,0x91919190,0x93939292,0x94949393,0x95959595,0x97969696,
    0x98989897,0x9A999999,0x9B9B9A9A,0x9C9C9C9B,0x9E9D9D9C,0x9F9E9E9E,0xA0A09F9F,0xA0A0A0A0,
    0xA1A1A1A0,0xA1A1A1A1,0xA2A2A2A2,0xA3A3A2A2,0xA3A3A3A3,0xA4A4A4A3,0xA4A4A4A4,0xA5A5A5A4,
    0xA5A5A5A5,0xA6A6A6A5,0xA6A6A6A6,0xA7A7A6A6,0xA7A7A7A7,0xA8A7A7A7,0xA8A8A8A8,0xA8A8A8A8,
    0xA9A9A9A8,0xA9A9A9A9,0xA9A9A9A9,0xAAAAAAAA,0xAAAAAAAA,0xAAAAAAAA,0xABABAAAA,0xABABABAB,
    0xABABABAB,0xABABABAB,0xABABABAB,0xACACACAC,0xACACACAC,0xACACACAC,0xACACACAC,0xACACACAC,
    0xACACACAC,0xACACACAC,0xACACACAC,0xACACACAC,0xADACACAC,0xACACACAC,0xACACACAC,0xACACACAC,
    0xACACACAC,0xACACACAC,0xACACACAC,0xACACACAC,0xACACACAC,0xACACACAC,0xACACACAC,0xABABABAB,
    0xABABABAB,0xABABABAB,0xABABABAB,0xABABABAB,0xAAAAAAAA,0xAAAAAAAA,0xAAAAAAAA,0xA9A9A9AA,
    0xA9A9A9A9,0xA9A9A9A9,0xA8A8A8A8,0xA8A8A8A8,0xA7A7A8A8,0xA7A7A7A7,0xA6A7A7A7,0xA6A6A6A6,
    0xA6A6A6A6,0xA5A5A5A5,0xA5A5A5A5,0xA4A4A4A5,0xA4A4A4A4,0xA3A3A3A4,0xA3A3A3A3,0xA2A2A2A2,
    0xA2A2A2A2,0xA1A1A1A1,0xA0A0A1A1,0xA0A0A0A0,0x9F9FA0A0,0x9E9E9E9E,0x9C9D9D9D,0x9B9B9C9C,
    0x9A9A9B9B,0x9999999A,0x97989898,0x96969797,0x95959596,0x93949494,0x92929393,0x91919192,
    0x8F909090,0x8D8D8E8F,0x8A8B8B8C,0x87888889,0x85868686,0x82838384,0x80808181,0x02020100,
    0x05040303,0x07070605,0x0A0A0908,0x0D0C0B0B,0x0F0F0E0D,0x11101010,0x12121111,0x13131212,
    0x14141413,0x16151515,0x17171616,0x18181817,0x19191918,0x1B1A1A1A,0x1C1C1B1B,0x1D1D1D1C,
    0x1E1E1E1D,0x1F1F1F1F,0x20202020,0x21202020,0x21212121,0x22212121,0x22222222,0x23222222,
    0x23232323,0x24242323,0x24242424,0x25252424,0x25252525,0x26252525,0x26262626,0x26262626,
    0x27272727,0x27272727,0x28282727,0x28282828,0x28282828,0x29292828,0x29292929,0x29292929,
    0x29292929,0x2A2A2A2A,0x2A2A2A2A,0x2A2A2A2A,0x2A2A2A2A,0x2B2B2A2A,0x2B2B2B2B,0x2B2B2B2B,
    0x2B2B2B2B,0x2B2B2B2B,0x2B2B2B2B,0x2B2B2B2B,0x2B2B2B2B,0x2B2B2B2B,0x2C2C2C2B,0x2C2C2C2C,
    0x2C2C2C2C,0x2C2B2B2C,0x2B2C2C2C,0x2B2C2B2B,0x2B2B2B2B,0x2B2B2B2B,0x2B2B2B2B,0x2B2B2B2B,
    0x2B2B2B2B,0x2B2B2B2B,0x2B2B2B2B,0x2B2B2B2B,0x2A2A2A2A,0x2A2A2A2A,0x2A2A2A2A,0x2A2A2A2A,
    0x292A292A,0x29292929,0x29292929,0x28282929,0x28282828,0x28282828,0x27272828,0x27272727,
    0x27272727,0x26262626,0x26262626,0x25252626,0x25252525,0x24242525,0x24242424,0x23242424,
    0x23232323,0x22232323,0x22222222,0x21222222,0x21212121,0x20202121,0x20202020,0x1F1F1F20,
    0x1E1E1E1E,0x1C1D1D1D,0x1B1C1C1C,0x1A1A1B1B,0x1919191A,0x18181818,0x16171717,0x15161616,
    0x14141515,0x13131314,0x12121212,0x10111111,0x0F0F1010,0x0D0D0D0E,0x090A0B0C,0x07070809,
    0x04050506,0x02020304,0x80000001,0x82828181,0x85848483,0x87878686,0x8A898888,0x8C8B8B8A,
    0x8E8E8D8D,0x90908F8F,0x91919190,0x93929292,0x94939393,0x95959494,0x96969595,0x97979796,
    0x98989898,0x99999999,0x9B9A9A9A,0x9C9C9B9B,0x9D9D9C9C,0x9E9E9E9D,0x9F9F9F9E,0xA0A0A09F,
    0xA0A0A0A0,0xA1A1A1A0,0xA1A1A1A1,0xA2A2A1A1,0xA2A2A2A2,0xA3A3A2A2,0xA3A3A3A3,0xA4A3A3A3,
    0xA4A4A4A4,0xA4A4A4A4,0xA5A5A5A4,0xA5A5A5A5,0xA6A5A5A5,0xA6A6A6A6,0xA6A6A6A6,0xA6A6A6A6,
    0xA7A7A7A7,0xA7A7A7A7,0xA7A7A7A7,0xA8A8A8A7,0xA8A8A8A8,0xA8A8A8A8,0xA8A8A8A8,0xA9A9A8A8,
    0xA9A9A9A9,0xA9A9A9A9,0xA9A9A9A9,0xA9A9A9A9,0xA9A9A9A9,0xA9A9A9A9,0xA9A9A9A9,0xAAAAAAAA,
    0xAAAAAAAA,0xAAAAAAAA,0xAAAAAAAA,0xAAAAAAAA,0xAAAAAAAA,0xAAAAAAAA,0xAAAAAAAA,0xA9AAAAAA,
    0xA9A9A9A9,0xA9A9A9A9,0xA9A9A9A9,0xA9A9A9A9,0xA9A9A9A9,0xA9A9A9A9,0xA9A9A9A9,0xA8A8A8A9,
    0xA8A8A8A8,0xA8A8A8A8,0xA8A8A8A8,0xA8A8A8A8,0xA7A7A7A7,0xA7A7A7A7,0xA7A7A7A7,0xA6A6A7A7,
    0xA6A6A6A6,0xA6A6A6A6,0xA5A5A6A6,0xA5A5A5A5,0xA5A5A5A5,0xA4A4A4A5,0xA4A4A4A4,0xA3A3A4A4,
    0xA3A3A3A3,0xA2A3A3A3,0xA2A2A2A2,0xA1A2A2A2,0xA1A1A1A1,0xA1A1A1A1,0xA0A0A0A0,0xA0A0A0A0,
    0x9F9F9F9F,0x9E9E9E9E,0x9C9D9D9D,0x9B9C9C9C,0x9A9B9B9B,0x999A9A9A,0x98989999,0x97979898,
    0x96969797,0x95959596,0x94949494,0x92939393,0x91929292,0x90909191,0x8E8F8F90,0x8C8D8D8D,
    0x8A8A8B8B,0x87878889,0x84858686,0x82838384,0x80808181,0x02010100,0x04030302,0x06050504,
    0x09080707,0x0B0A0A09,0x0D0D0C0B,0x100F0E0E,0x11101010,0x12121111,0x13131212,0x14141413,
    0x15151514,0x16161616,0x17171717,0x19181818,0x1A1A1919,0x1B1B1A1A,0x1C1C1B1B,0x1D1D1C1C,
    0x1E1E1D1D,0x1F1F1F1E,0x20201F1F,0x20202020,0x21212020,0x21212121,0x22222121,0x22222222,
    0x22222222,0x23232323,0x23232323,0x24242323,0x24242424,0x24242424,0x25252525,0x25252525,
    0x25252525,0x26262626,0x26262626,0x26262626,0x27262626,0x27272727,0x27272727,0x27272727,
    0x28272727,0x28282828,0x28282828,0x28282828,0x28282828,0x28282828,0x29282828,0x29292929,
    0x29292929,0x29292929,0x29292929,0x29292929,0x29292929,0x29292929,0x29292929,0x29292929,
    0x29292929,0x29292929,0x29292929,0x29292929,0x29292929,0x29292829,0x28282829,0x28282828,
    0x28282828,0x28282828,0x28282828,0x27272828,0x27272727,0x27272727,0x27272727,0x27272727,
    0x26262627,0x26262626,0x26262626,0x25262626,0x25252525,0x25252525,0x24242525,0x24242424,
    0x24242424,0x23232324,0x23232323,0x23232323,0x22222222,0x22222222,0x21212122,0x21212121,
    0x20202121,0x20202020,0x1F202020,0x1E1F1F1F,0x1D1E1E1E,0x1C1D1D1D,0x1B1C1C1C,0x1A1B1B1B,
    0x191A1A1A,0x18191919,0x17181818,0x16161717,0x15151616,0x14141415,0x13131314,0x12121213,
    0x11111112,0x0F101010,0x0D0E0F0F,0x0B0B0C0D,0x09090A0A,0x06070808,0x04050506,0x02020304,
    0x00000101,0x82818180,0x84848382,0x86868585,0x89888887,0x8B8A8A8A,0x8D8D8C8C,0x908F8E8E,
    0x91909090,0x92929191,0x93929292,0x94939393,0x95949494,0x96959595,0x97979696,0x98989797,
    0x99999898,0x9A9A9999,0x9B9B9A9A,0x9C9C9B9B,0x9D9D9C9C,0x9E9E9D9D,0x9F9F9E9E,0xA09F9F9F,
    0xA0A0A0A0,0xA0A0A0A0,0xA1A1A1A1,0xA1A1A1A1,0xA2A1A1A1,0xA2A2A2A2,0xA2A2A2A2,0xA3A3A3A3,
    0xA3A3A3A3,0xA3A3A3A3,0xA4A4A4A4,0xA4A4A4A4,0xA4A4A4A4,0xA5A5A5A4,0xA5A5A5A5,0xA5A5A5A5,
    0xA5A5A5A5,0xA6A6A6A5,0xA6A6A6A6,0xA6A6A6A6,0xA6A6A6A6,0xA6A6A6A6,0xA7A7A6A6,0xA7A7A7A7,
    0xA7A7A7A7,0xA7A7A7A7,0xA7A7A7A7,0xA7A7A7A7,0xA7A7A7A7,0xA7A7A7A7,0xA7A7A7A7,0xA7A7A7A7,
    0xA7A7A7A7,0xA7A7A7A7,0xA7A7A7A7,0xA6A6A6A6,0xA6A6A6A6,0xA6A6A6A6,0xA6A6A6A6,0xA6A6A6A6,
    0xA5A5A5A5,0xA5A5A5A5,0xA5A5A5A5,0xA5A5A5A5,0xA4A4A4A5,0xA4A4A4A4,0xA4A4A4A4,0xA3A3A4A4,
    0xA3A3A3A3,0xA3A3A3A3,0xA2A3A3A3,0xA2A2A2A2,0xA2A2A2A2,0xA1A1A2A2,0xA1A1A1A1,0xA1A1A1A1,
    0xA0A0A0A0,0xA0A0A0A0,0x9F9FA0A0,0x9E9F9F9F,0x9D9E9E9E,0x9C9C9D9D,0x9C9C9C9C,0x9B9B9B9B,
    0x9A9A9A9A,0x9999999A,0x98989899,0x97979798,0x96969797,0x95959696,0x94949595,0x93939494,
    0x92929393,0x91919292,0x90909191,0x8E8F8F90,0x8C8D8D8E,0x8A8B8B8C,0x8888898A,0x86868788,
    0x83848585,0x81828383,0x00808181,0x02010100,0x04030302,0x06050504,0x08070706,0x0A090908,
    0x0C0C0B0B,0x0E0E0D0D,0x10100F0F,0x11111110,0x12121111,0x13131212,0x14141413,0x15151514,
    0x16161615,0x17171716,0x18181817,0x19191918,0x1A1A1919,0x1B1B1A1A,0x1C1B1B1B,0x1C1C1C1C,
    0x1D1D1D1D,0x1E1E1E1D,0x1F1F1F1E,0x2020201F,0x20202020,0x20202020,0x21212121,0x21212121,
    0x22212121,0x22222222,0x22222222,0x23232222,0x23232323,0x23232323,0x23232323,0x24242424,
    0x24242424,0x24242424,0x24242424,0x25252525,0x25252525,0x25252525,0x25252525,0x25252525,
    0x26262626,0x26262626,0x26262626,0x26262626,0x26262626,0x26262626,0x26262626,0x26262626,
    0x27262626,0x27272727,0x27272727,0x27272727,0x27272726,0x27272727,0x27272727,0x26262727,
    0x26272727,0x26262626,0x26262626,0x26262626,0x26262626,0x26262626,0x26262626,0x26262626,
    0x25252526,0x25252525,0x25252525,0x25252525,0x25252525,0x24242424,0x24242424,0x24242424,
    0x23242424,0x23232323,0x23232323,0x23232323,0x22222223,0x22222222,0x22222222,0x21212222,
    0x21212121,0x21212121,0x20202021,0x20202020,0x1F202020,0x1E1F1F1F,0x1E1E1E1E,0x1D1D1D1D,
    0x1C1C1C1D,0x1B1B1C1C,0x1A1A1B1B,0x191A1A1A,0x18191919,0x17181818,0x16171717,0x16161616,
    0x15151515,0x14141414,0x13131313,0x12121212,0x11111112,0x10101011,0x0E0F0F10,0x0C0D0D0E,
    0x0B0B0C0C,0x0808090A,0x07070808,0x05050606,0x03030405,0x01010202,0x81800000,0x83828281,
    0x84848383,0x86868585,0x88878787,0x8A8A8988,0x8C8B8B8A,0x8E8E8D8C,0x90908F8F,0x91919090,
    0x91919191,0x92929292,0x94939393,0x94949494,0x95959595,0x96969696,0x97979796,0x98989897,
    0x99989898,0x9A999999,0x9A9A9A9A,0x9B9B9B9A,0x9C9C9C9B,0x9C9C9C9C,0x9D9D9D9D,0x9E9E9E9E,
    0x9F9F9E9E,0xA0A09F9F,0xA0A0A0A0,0xA0A0A0A0,0xA1A0A0A0,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,
    0xA2A2A2A1,0xA2A2A2A2,0xA2A2A2A2,0xA2A2A2A2,0xA3A3A3A3,0xA3A3A3A3,0xA3A3A3A3,0xA3A3A3A3,
    0xA4A3A3A3,0xA4A4A4A4,0xA4A4A4A4,0xA4A4A4A4,0xA4A4A4A4,0xA4A4A4A4,0xA4A4A4A4,0xA4A4A4A4,
    0xA5A5A5A4,0xA5A5A5A5,0xA5A5A5A5,0xA5A5A5A5,0xA5A5A5A5,0xA5A5A5A5,0xA5A5A5A5,0xA5A5A5A5,
    0xA5A5A5A5,0xA5A5A5A5,0xA5A5A5A5,0xA5A5A5A5,0xA5A5A5A5,0xA5A5A5A5,0xA4A4A5A5,0xA4A4A4A4,
    0xA4A4A4A4,0xA4A4A4A4,0xA4A4A4A4,0xA4A4A4A4,0xA4A4A4A4,0xA4A4A4A4,0xA3A3A3A3,0xA3A3A3A3,
    0xA3A3A3A3,0xA3A3A3A3,0xA2A2A3A3,0xA2A2A2A2,0xA2A2A2A2,0xA2A2A2A2,0xA1A1A1A1,0xA1A1A1A1,
    0xA1A1A1A1,0xA0A0A1A1,0xA0A0A0A0,0xA0A0A0A0,0x9F9F9FA0,0x9E9E9E9E,0x9E9E9E9E,0x9D9D9E9E,
    0x9C9C9D9D,0x9C9C9C9C,0x9B9B9B9B,0x9A9A9A9A,0x9999999A,0x98999999,0x97989898,0x97979797,
    0x96969696,0x95959596,0x94949595,0x93939394,0x92929393,0x91929292,0x90919191,0x8F909090,
    0x8E8E8F8F,0x8C8C8D8D,0x8A8A8B8B,0x8889898A,0x86878788,0x84858586,0x83838484,0x81818282,
    0x00008080,0x02020101,0x04040303,0x06060504,0x08070706,0x09090908,0x0B0B0A0A,0x0D0C0C0C,
    0x0F0E0E0D,0x1010100F,0x11111110,0x12121111,0x13131212,0x14131313,0x15141414,0x16151515,
    0x16161616,0x17171717,0x18181717,0x19181818,0x19191919,0x1A1A1A19,0x1B1B1A1A,0x1C1B1B1B,
    0x1C1C1C1C,0x1D1D1C1C,0x1E1D1D1D,0x1E1E1E1E,0x1F1F1F1E,0x1F1F1F1F,0x20202020,0x20202020,
    0x20202020,0x21212120,0x21212121,0x21212121,0x21212121,0x22222222,0x22222222,0x22222222,
    0x22222222,0x23232222,0x23232323,0x23232323,0x23232323,0x23232323,0x23232323,0x23232323,
    0x24232323,0x24242424,0x24242424,0x24242424,0x24242424,0x24242424,0x24242424,0x24242424,
    0x24242424,0x24242424,0x24242424,0x24242424,0x24242424,0x24242424,0x24242424,0x24242424,
    0x24242424,0x24232424,0x24242424,0x24242424,0x24242424,0x23232323,0x23232323,0x23232323,
    0x23232323,0x23232323,0x22222323,0x22222222,0x22222222,0x22222222,0x22222222,0x21212121,
    0x21212121,0x21212121,0x20212121,0x20202020,0x20202020,0x20202020,0x1F1F2020,0x1F1F1F1F,
    0x1E1E1E1E,0x1D1D1E1E,0x1D1D1D1D,0x1C1C1C1D,0x1B1B1C1C,0x1B1B1B1B,0x1A1A1A1A,0x19191919,
    0x18181919,0x17181818,0x17171717,0x16161616,0x15151516,0x14151515,0x14141414,0x13131313,
    0x12121213,0x11111212,0x10101111,0x0F101010,0x0E0E0E0E,0x0B0C0C0D,0x0A0A0B0B,0x08080909,
    0x06070708,0x05050606,0x03030404,0x01010202,0x80000001,0x81818180,0x83838382,0x85848484,
    0x87868686,0x89888787,0x8A8A8989,0x8C8C8B8B,0x8E8D8D8D,0x908F8F8F,0x90909090,0x91919191,
    0x92929291,0x93939392,0x94949393,0x95949494,0x95959595,0x96969695,0x97979796,0x98979797,
    0x98989898,0x99999899,0x9A999999,0x9A9A9A9A,0x9B9B9B9B,0x9C9C9B9B,0x9C9C9C9C,0x9D9D9D9C,
    0x9E9D9D9D,0x9E9E9E9E,0x9F9F9E9E,0x9F9F9F9F,0xA0A09F9F,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,
    0xA1A1A0A0,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,0xA2A1A1A1,0xA2A2A2A2,0xA2A2A2A2,
    0xA2A2A2A2,0xA2A2A2A2,0xA2A2A2A2,0xA2A2A2A2,0xA3A3A2A2,0xA2A3A3A3,0xA3A3A3A3,0xA3A3A3A3,
    0xA3A3A3A3,0xA3A3A3A3,0xA3A3A3A3,0xA3A3A3A3,0xA3A3A3A3,0xA3A3A3A3,0xA3A3A3A3,0xA3A3A3A3,
    0xA3A3A3A3,0xA3A3A3A3,0xA2A3A3A3,0xA2A2A3A2,0xA2A2A2A2,0xA2A2A2A2,0xA2A2A2A2,0xA2A2A2A2,
    0xA2A2A2A2,0xA2A2A2A2,0xA2A2A2A2,0xA1A1A2A2,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,
    0xA1A1A1A1,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0x9F9F9F9F,0x9E9F9F9F,0x9E9E9E9E,
    0x9E9E9E9E,0x9D9D9D9D,0x9C9D9D9D,0x9C9C9C9C,0x9B9B9C9C,0x9B9B9B9B,0x9A9A9A9B,0x999A9A9A,
    0x99999999,0x98989899,0x97989898,0x97979797,0x96969697,0x95959696,0x94959595,0x94949494,
    0x93939394,0x92939393,0x92929292,0x91919191,0x90909090,0x8F8F9090,0x8D8E8E8E,0x8C8C8C8D,
    0x8A8B8B8B,0x8889898A,0x87878888,0x85868686,0x84848485,0x82838383,0x80818182,0x00008080,
    0x02020101,0x04030302,0x06050404,0x07060606,0x09080807,0x0A0A0909,0x0C0B0B0A,0x0D0D0D0C,
    0x0F0E0E0E,0x10100F0F,0x11111010,0x12111111,0x12121212,0x13131313,0x14141413,0x15141414,
    0x15151515,0x16161615,0x17171616,0x17171717,0x18181818,0x18181818,0x19191919,0x1A1A1919,
    0x1B1B1A1A,0x1B1B1B1B,0x1C1C1C1B,0x1C1C1C1C,0x1D1D1D1D,0x1E1D1D1D,0x1E1E1E1E,0x1F1F1E1E,
    0x1F1F1F1F,0x2020201F,0x20202020,0x20202020,0x20202020,0x21202020,0x21212121,0x21212121,
    0x21212121,0x21212121,0x21212121,0x22212121,0x22222222,0x22222222,0x22222222,0x22222222,
    0x22222222,0x22222222,0x22222222,0x22222222,0x22222222,0x22222222,0x22222222,0x22222222,
    0x22222222,0x22222222,0x22222222,0x22222222,0x22222222,0x21222121,0x21212121,0x21212121,
    0x21212121,0x21212121,0x20212121,0x20202020,0x20202020,0x20202020,0x20202020,0x1F1F1F20,
    0x1F1F1F1F,0x1E1E1E1E,0x1E1E1E1E,0x1D1D1D1D,0x1D1D1D1D,0x1C1C1C1C,0x1B1C1C1C,0x1B1B1B1B,
    0x1A1A1B1B,0x1A1A1A1A,0x19191A1A,0x19191919,0x18181818,0x17171718,0x16171717,0x16161616,
    0x15151516,0x14151515,0x14141414,0x13131313,0x12121313,0x12121212,0x11111111,0x10101011,
    0x0F101010,0x0E0E0F0F,0x0C0D0D0E,0x0B0C0C0C,0x0B0B0A0B,0x08080809,0x06060707,0x04040506,
    0x02030304,0x02020202,0x00000101,0x81818000,0x83828281,0x84848483,0x85858584,0x87878686,
    0x89888887,0x8A8A8989,0x8B8B8B8A,0x8C8C8C8C,0x8E8E8D8D,0x908F8F8F,0x90909090,0x91919191,
    0x92929191,0x92929292,0x93939393,0x94949393,0x95949494,0x95959595,0x96969595,0x96969696,
    0x97979796,0x97979797,0x98989898,0x99999898,0x99999999,0x9A9A9A99,0x9A9A9A9A,0x9B9B9B9A,
    0x9C9B9B9B,0x9C9C9C9C,0x9D9C9C9C,0x9D9D9D9D,0x9E9E9D9D,0x9E9E9E9E,0x9F9F9E9E,0x9F9F9F9F,
    0x9F9F9F9F,0x9F9F9F9F,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,
    0xA1A1A1A0,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,
    0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,0xA1A1A1A1,
    0xA0A0A0A1,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0x9FA0A0A0,0x9F9F9F9F,0x9F9F9F9F,
    0x9E9E9F9F,0x9E9E9E9E,0x9D9E9E9E,0x9D9D9D9D,0x9D9D9D9D,0x9C9C9C9C,0x9C9C9C9C,0x9B9B9B9C,
    0x9B9B9B9B,0x9A9A9B9B,0x999A9A9A,0x99999999,0x98999999,0x98989898,0x97979898,0x97979797,
    0x96969696,0x95959596,0x94959595,0x94949494,0x93939394,0x92939393,0x92929292,0x91919292,
    0x90919191,0x90909090,0x8F8F8F90,0x8D8E8E8E,0x8C8C8C8D,0x8A8B8B8C,0x89898A8A,0x87888889,
    0x86868787,0x84858585,0x82838484,0x81818282,0x80808081,0x01010000,0x02020201,0x04030303,
    0x05050404,0x07060605,0x08080707,0x09090908,0x0B0A0A0A,0x0C0C0C0B,0x0D0D0D0C,0x0F0F0E0E,
    0x1010100F,0x11101010,0x11111111,0x12121211,0x13121212,0x13131313,0x14141413,0x15141414,
    0x15151515,0x16161615,0x16161616,0x17171717,0x18181717,0x18181818,0x19191918,0x19191919,
    0x1A1A1A19,0x1A1A1A1A,0x1B1B1B1A,0x1B1B1B1B,0x1C1C1B1B,0x1C1C1C1C,0x1D1C1C1C,0x1D1D1D1D,
    0x1D1D1D1D,0x1E1E1E1D,0x1E1E1E1E,0x1E1E1E1E,0x1F1F1F1F,0x1F1F1F1F,0x1F1F1F1F,0x2020201F,
    0x20202020,0x20202020,0x20202020,0x20202020,0x20202020,0x20202020,0x20202020,0x20202020,
    0x21212120,0x21212121,0x21212121,0x21212121,0x21212121,0x21212121,0x21212121,0x21212121,
    0x21212121,0x21212121,0x21212121,0x20212121,0x20212120,0x20202020,0x20202020,0x20202020,
    0x20202020,0x20202020,0x20202020,0x20202020,0x20202020,0x1F202020,0x1F1F1F1F,0x1F1F1F1F,
    0x1F1F1F1F,0x1E1E1E1F,0x1E1E1E1E,0x1E1E1E1E,0x1D1D1D1E,0x1D1D1D1D,0x1C1D1D1D,0x1C1C1C1C,
    0x1B1C1C1C,0x1B1B1B1B,0x1B1B1B1B,0x1A1A1A1A,0x1A1A1A1A,0x19191919,0x18191919,0x18181818,
    0x17181818,0x17171717,0x16161717,0x16161616,0x15151516,0x14151515,0x14141414,0x13131414,
    0x13131313,0x12121212,0x11111212,0x10111111,0x10101010,0x0F0F1010,0x0E0E0E0F,0x0C0D0D0D,
    0x0B0B0B0C,0x090A0A0A,0x08080909,0x06070707,0x05050606,0x03040405,0x02020303,0x01010102,
    0x80800000,0x81818180,0x83828282,0x84848383,0x85858484,0x87868686,0x88888787,0x89898988,
    0x8B8A8A89,0x8C8C8B8B,0x8D8D8D8C,0x8F8E8E8E,0x908F8F8F,0x90909090,0x91919190,0x92929191,
    0x92929292,0x93939392,0x94939393,0x94949494,0x95959494,0x95959595,0x96969696,0x97969696,
    0x97979796,0x97979797,0x98989897,0x98989898,0x99999998,0x99999999,0x9A9A9999,0x9A9A9A9A,
    0x9B9B9A9A,0x9B9B9B9B,0x9B9B9B9B,0x9C9C9C9C,0x9C9C9C9C,0x9D9D9C9C,0x9D9D9D9D,0x9D9D9D9D,
    0x9E9E9D9D,0x9E9E9E9E,0x9E9E9E9E,0x9E9E9E9E,0x9F9E9F9E,0x9F9F9F9F,0x9F9F9F9F,0x9F9F9F9F,
    0x9F9F9F9F,0x9F9F9F9F,0xA0A09F9F,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,
    0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0xA0A0A0A0,0x9F9F9FA0,
    0x9F9F9F9F,0x9F9F9F9F,0x9F9F9F9F,0x9F9F9F9F,0x9E9F9F9F,0x9E9E9E9E,0x9E9E9E9E,0x9E9E9E9E,
    0x9D9D9E9E,0x9D9D9D9D,0x9D9D9D9D,0x9D9D9D9D,0x9C9C9C9C,0x9C9C9C9C,0x9C9C9C9C,0x9B9B9B9B,
    0x9B9B9B9B,0x9A9A9A9B,0x9A9A9A9A,0x99999A9A,0x99999999,0x99999999,0x98989898,0x98989898,
    0x97979898,0x97979797,0x96969797,0x96969696,0x95959596,0x95959595,0x94949494,0x94949494,
    0x93939393,0x92929393,0x92929292,0x91919192,0x91919191,0x90909090,0x8F8F9090,0x8E8E8F8F,
    0x8C8D8D8E,0x8B8C8C8C,0x8A8B8B8B,0x89898A8A,0x88888889,0x86878787,0x85858686,0x84848485,
    0x82838383,0x81818182,0x00008080,0x01010000,0x02020201,0x03030303,0x05040404,0x06060505,
    0x08070707,0x09080808,0x0A0A0909,0x0C0B0B0B,0x0D0C0C0C,0x0E0E0D0D,0x0F0F0F0E,0x1010100F,
    0x10101010,0x11111010,0x12111111,0x12121212,0x13131313,0x13131313,0x14141313,0x14141414,
    0x15151515,0x15151515,0x16161616,0x17161616,0x17171717,0x18171717,0x18181818,0x19181818,
    0x19191919,0x19191919,0x1A1A1A19,0x1A1A1A1A,0x1B1A1A1A,0x1B1B1B1B,0x1B1B1B1B,0x1C1B1B1B,
    0x1C1C1C1C,0x1C1C1C1C,0x1D1C1C1C,0x1D1D1D1D,0x1D1D1D1D,0x1D1D1D1D,0x1D1D1D1D,0x1E1E1E1E,
    0x1E1E1E1E,0x1E1E1E1E,0x1E1E1E1E,0x1F1E1E1E,0x1F1F1F1F,0x1F1F1F1F,0x1F1F1F1F,0x1F1F1F1F,
    0x1F1F1F1F,0x1F1F1F1F,0x1F1F1F1F,0x1F1F1F1F,0x1F1F1F1F,0x1F1F1F1F,0x1F1F1F1F,0x1F1F1F1F,
    0x1F1F1F1F,0x1F1F1F1F,0x1E1F1F1F,0x1E1E1E1E,0x1E1E1E1E,0x1E1E1E1E,0x1E1E1E1E,0x1E1E1E1E,
    0x1D1D1D1D,0x1D1D1D1D,0x1D1D1D1D,0x1D1D1D1D,0x1C1C1D1D,0x1C1C1C1C,0x1C1C1C1C,0x1C1C1C1C,
    0x1B1B1B1B,0x1B1B1B1B,0x1A1A1B1B,0x1A1A1A1A,0x1A1A1A1A,0x1919191A,0x19191919,0x18181919,
    0x18181818,0x17181818,0x17171717,0x17171717,0x16161616,0x16161616,0x15151515,0x15151515,
    0x14141415,0x14141414,0x13131313,0x13131313,0x12121212,0x11111212,0x11111111,0x10101111,
    0x10101010,0x0E0F0F0F,0x0D0D0E0E,0x0D0D0D0D,0x0B0B0B0C,0x0A0A0B0B,0x0909090A,0x08080808,
    0x06060608,0x06060606,0x05050506,0x03030404,0x02020303,0x00010101,0x80000000,0x81818080,
    0x82828281,0x84838383,0x85858484,0x86868585,0x87878786,0x88888888,0x8A898989,0x8B8B8A8A,
    0x8C8C8B8B,0x8D8D8C8C,0x8E8E8E8D,0x8F8F8E8E,0x9090908F,0x90909090,0x91919191,0x92919191,
    0x92929292,0x93929292,0x93939393,0x94939393,0x94949494,0x95949494,0x95959595,0x96959595,
    0x96969696,0x96969696,0x97979797,0x97979797,0x98989797,0x98989898,0x98989898,0x99999898,
    0x99999999,0x99999999,0x9A9A9A99,0x9A9A9A9A,0x9A9A9A9A,0x9B9B9B9B,0x9B9B9B9B,0x9B9B9B9B,
    0x9C9B9B9B,0x9C9C9C9C,0x9C9C9C9C,0x9C9C9C9C,0x9C9C9C9C,0x9C9C9C9C,0x9C9C9D9C,0x9D9C9D9D,
    0x9D9D9D9D,0x9D9D9D9D,0x9D9D9D9D,0x9D9D9D9D,0x9D9D9D9D,0x9D9D9D9D,0x9D9D9D9D,0x9D9D9D9D,
    0x9D9D9D9D,0x9D9D9D9D,0x9D9D9D9D,0x9D9D9D9D,0x9D9D9D9D,0x9C9D9D9D,0x9C9C9C9C,0x9C9C9C9C,
    0x9C9C9C9C,0x9C9C9C9C,0x9B9B9C9C,0x9B9B9B9C,0x9B9B9B9B,0x9B9B9B9B,0x9B9B9B9B,0x9B9B9B9B,
    0x9A9A9A9B,0x9A9A9A9A,0x9A9A9A9A,0x9A9A9A9A,0x9999999A,0x99999999,0x98999999,0x98989898,
    0x98989898,0x97979797,0x97979797,0x96979797,0x96969696,0x96969696,0x95959596,0x95959595,
    0x94949495,0x94949494,0x93939494,0x93939393,0x92939393,0x92929292,0x91919192,0x91919191,
    0x90909091,0x90909090,0x8F8F8F8F,0x8E8E8E8E,0x8D8D8D8D,0x8C8C8C8C,0x8A8A8B8B,0x89898A8A,
    0x88888989,0x87878788,0x86868687,0x85858586,0x84848484,0x83838383,0x82828282,0x81818181,
    0x00808080,0x01010000,0x02020201,0x03030302,0x04040303,0x05050504,0x06060606,0x07070706,
    0x08080808,0x0A0A0909,0x0B0A0A0A,0x0C0B0B0B,0x0D0C0C0C,0x0E0D0D0D,0x0F0F0F0E,0x10100F0F,
    0x10101010,0x11111010,0x11111111,0x11111111,0x12121212,0x13121212,0x13131313,0x13131313,
    0x14141413,0x14141414,0x15151514,0x15151515,0x16161515,0x16161616,0x16161616,0x17171716,
    0x17171717,0x17171717,0x18181717,0x18181818,0x18181818,0x19191918,0x19191919,0x19191919,
    0x1A1A1919,0x1A1A1A1A,0x1A1A1A1A,0x1A1A1A1A,0x1A1B1A1A,0x1B1B1B1A,0x1B1B1B1B,0x1B1B1B1B,
    0x1B1B1B1B,0x1B1B1B1B,0x1C1B1B1B,0x1C1C1C1C,0x1B1B1B1B,0x1C1B1B1B,0x1C1C1B1B,0x1C1C1C1C,
    0x1C1C1C1C,0x1C1C1C1C,0x1C1C1C1C,0x1C1C1C1C,0x1C1C1C1C,0x1C1C1C1C,0x1C1B1B1B,0x1C1C1C1C,
    0x1B1B1B1B,0x1B1B1B1C,0x1B1B1B1B,0x1B1B1B1B,0x1B1B1B1B,0x1B1B1B1B,0x1B1A1B1B,0x1A1A1A1A,
    0x1A1A1A1A,0x1A1A1A1A,0x1A1A1A1A,0x191A1A1A,0x19191919,0x19191919,0x19191919,0x18181919,
    0x18181818,0x18181818,0x18181818,0x17171718,0x17171717,0x16171717,0x16161616,0x16161616,
    0x15151616,0x15151515,0x14151515,0x14141414,0x14141414,0x13131313,0x13131313,0x12121213,
    0x12121212,0x11111212,0x11111111,0x10101011,0x10101010,0x0F0F0F10,0x0E0E0F0F,0x0D0D0E0E,
    0x0C0C0C0C,0x0B0B0C0C,0x0A0A0A0A,0x0909090A,0x08080808,0x07070708,0x06060607,0x05050506,
    0x04040404,0x03030303,0x01020202,0x01000101,0x80008000,0x81818180,0x82828281,0x83838382,
    0x84848484,0x85858585,0x86868685,0x88878787,0x88888888,0x89898989,0x8B8A8A8A,0x8B8B8B8B,
    0x8C8C8C8C,0x8D8D8D8D,0x8E8E8E8E,0x8F8F8F8F,0x90909090,0x90909090,0x91919190,0x91919191,
    0x92929191,0x92929292,0x92929292,0x93939292,0x93939393,0x94939393,0x94949494,0x95959494,
    0x95949595,0x95959595,0x95959595,0x96969696,0x96969696,0x96969696,0x97979797,0x97979797,
    0x97989797,0x98989897,0x98989898,0x98989898,0x99989898,0x99999999,0x99999999,0x99999999,
    0x99999999,0x99999999,0x99999999,0x9A999999,0x9A9A9999,0x9A9A9A9A,0x9A9A9A9A,0x9A9A9A9A,
    0x9A9A9A9A,0x9A9A9A9A,0x9A9A9A9A,0x9A9A9A9A,0x9A9A9A9A,0x9A9A9A9A,0x9A9A9A9A,0x9A9A9A9A,
    0x9A9A9A9A,0x9A9A9A9A,0x9A9A9A9A,0x9A9A9A9A,0x9A9A9A9A,0x9A9A9A9A,0x999A9999,0x99999999,
    0x99999999,0x99999999,0x99999999,0x99999999,0x98999999,0x98989898,0x98989898,0x98989898,
    0x98989898,0x97979898,0x97979797,0x97979797,0x96979797,0x96969696,0x96969696,0x95969696,
    0x95959595,0x95959595,0x94959595,0x94949494,0x94949494,0x94949494,0x93939394,0x93939393,
    0x92939293,0x92929292,0x92929292,0x91919191,0x91919191,0x90909091,0x90909090,0x8F8F8F90,
    0x8E8E8F8F,0x8D8D8E8E,0x8C8C8D8D,0x8B8C8C8C,0x8A8A8B8B,0x89898A8A,0x88898989,0x87888888,
    0x86878787,0x85868686,0x84858585,0x83848484,0x83838383,0x82828282,0x80818181,0x00808080,
    0x01000000,0x02020101,0x03030202,0x04040303,0x05050505,0x06060505,0x07070706,0x08080807,
    0x09080808,0x09090909,0x0B0A0A0A,0x0C0B0B0B,0x0C0C0C0C,0x0D0D0D0C,0x0E0E0E0E,0x0F0F0F0F,
    0x10100F0F,0x10101010,0x11111111,0x11111111,0x12121111,0x12121212,0x12121212,0x13131313,
    0x13131313,0x14141313,0x14141414,0x14141414,0x15151414,0x15151515,0x15151515,0x16161515,
    0x16161616,0x16161616,0x16161616,0x17171717,0x17171717,0x17171717,0x17171717,0x18181817,
    0x18181818,0x18181818,0x18181818,0x18181818,0x19191818,0x19191919,0x19191919,0x19191919,
    0x19191919,0x19191919,0x19191919,0x19191919,0x19191919,0x19191919,0x19191919,0x19191919,
    0x19191919,0x19191919,0x19191919,0x19191919,0x18191918,0x18181818,0x18181818,0x18181818,
    0x18181818,0x17181818,0x17171717,0x17171717,0x17171717,0x17171717,0x16161616,0x16161616,
    0x16161616,0x15151616,0x15151515,0x15151515,0x14151515,0x14141414,0x14141414,0x14141414,
    0x13131314,0x13131313,0x12121313,0x12121212,0x12121212,0x11111112,0x11111111,0x10111111,
    0x10101010,0x10101010,0x0F0F0F0F,0x0E0E0E0F,0x0D0D0D0E,0x0C0C0C0D,0x0B0B0B0C,0x0A0B0B0B,
    0x09090A0A,0x08090909,0x08080808,0x07080807,0x05060606,0x05050505,0x04040404,0x03030404,
    0x02030303,0x01020202,0x00000101,0x80000000,0x81818080,0x82818181,0x82828282,0x84838383,
    0x85848484,0x85858585,0x86868686,0x87878787,0x88888887,0x89888888,0x8A8A8989,0x8B8A8A8A,
    0x8C8B8B8B,0x8D8C8C8C,0x8D8D8D8D,0x8E8E8E8E,0x8F8F8E8E,0x90908F8F,0x90909090,0x90909090,
    0x91919190,0x91919191,0x92929191,0x92929292,0x93929292,0x93939393,0x93939393,0x94949393,
    0x94949494,0x94949494,0x94949494,0x95959595,0x95959595,0x95959595,0x96959595,0x96969696,
    0x96969696,0x96969696,0x96969696,0x97979797,0x97979797,0x97979797,0x97979797,0x97989797,
    0x98989897,0x98989897,0x98989898,0x98989898,0x98989898,0x98989898,0x98989898,0x98989898,
    0x98989898,0x98989898,0x98989898,0x98989898,0x98989898,0x98989898,0x98989898,0x98989898,
    0x98989898,0x98989898,0x98989898,0x98989898,0x98989898,0x98989898,0x98989898,0x97979797,
    0x97979797,0x97979797,0x97979797,0x97979797,0x96969797,0x96969696,0x96969696,0x96969696,
    0x96969696,0x95959595,0x95959595,0x95959595,0x95959595,0x94949494,0x94949494,0x94949494,
    0x93939394,0x93939393,0x93939393,0x92929292,0x92929292,0x92929292,0x91919191,0x91919191,
    0x90909091,0x90909090,0x8F909090,0x8F8F8F8F,0x8E8E8E8E,0x8D8D8E8E,0x8C8D8D8D,0x8C8C8C8C,
    0x8B8B8B8B,0x8A8A8A8B,0x89898A8A,0x88888989,0x87878888,0x87878787,0x86868686,0x85858585,
    0x84848484,0x83838383,0x82828283,0x81818282,0x80818181,0x00808080,0x01000000,0x01010101,
    0x02020202,0x03030302,0x04040303,0x05050404,0x06050505,0x06060606,0x07070706,0x08080808,
    0x09090909,0x0A0A0A09,0x0B0A0A0A,0x0C0B0B0B,0x0D0C0C0C,0x0E0D0D0D,0x0E0E0E0E,0x0F0F0F0E,
    0x100F0F0F,0x10101010,0x10101010,0x11111110,0x11111111,0x12111111,0x12121212,0x12121212,
    0x12121212,0x13131313,0x13131313,0x13131313,0x14141414,0x14141414,0x14141414,0x15151414,
    0x15151515,0x15151515,0x15151515,0x16151515,0x16161616,0x16161616,0x16161616,0x16161616,
    0x16161616,0x17171717,0x17171717,0x17171717,0x17171717,0x17171717,0x17171717,0x17171717,
    0x17171717,0x18181717,0x18181818,0x18181818,0x18181717,0x18181818,0x18181818,0x18181818,
    0x18181818,0x18181818,0x18181818,0x17181818,0x17171718,0x17171717,0x17171817,0x17171717,
    0x17171717,0x17171717,0x17171717,0x17171717,0x17171717,0x17171717,0x16161616,0x16161616,
    0x16161616,0x16161616,0x15151616,0x15151515,0x15151515,0x15151515,0x14141415,0x14141414,
    0x14141414,0x14141414,0x13131314,0x13131313,0x13131313,0x12121213,0x12121212,0x12121212,
    0x11111212,0x11111111,0x11111111,0x10101010,0x10101010,0x0F101010,0x0E0E0F0F,0x0E0E0E0E,
    0x0D0D0D0D,0x0C0C0C0D,0x0B0B0B0C,0x0A0A0B0B,0x090A0A0A,0x09090909,0x08080809,0x07070708,
    0x06070707,0x05060606,0x04050505,0x03040404,0x03030303,0x02020202,0x01010202,0x01000001,
    0x80000000,0x80808080,0x82818181,0x82828182,0x83838282,0x84848383,0x85848484,0x85858585,
    0x86868686,0x87878686,0x88878787,0x89888888,0x89898889,0x8A8A8989,0x8B8B8A8A,0x8C8C8C8B,
    0x8D8D8C8C,0x8D8D8D8D,0x8E8E8E8D,0x8F8F8F8E,0x908F8F8F,0x90909090,0x90909090,0x91909090,
    0x91919191,0x91919191,0x91919191,0x92929291,0x92929292,0x92929292,0x93929292,0x93939393,
    0x93939393,0x93939393,0x94949393,0x94949494,0x94949494,0x94949494,0x94959594,0x95959595,
    0x95959595,0x95959594,0x95959595,0x95959595,0x95959595,0x96969595,0x96969696,0x96969696,
    0x96969696,0x96969696,0x96969696,0x96969696,0x96969696,0x96969696,0x96969696,0x96969696,
    0x96969696,0x96969696,0x96969696,0x96969696,0x96969696,0x96969696,0x96969696,0x95959696,
    0x95959595,0x95959595,0x95959595,0x95959595,0x94959494,0x94949494,0x94949494,0x93949494,
    0x93939494,0x93939393,0x93939393,0x93939393,0x92939393,0x92929292,0x92929292,0x92929292,
    0x91919292,0x91919191,0x91919191,0x90919090,0x90909090,0x8F909090,0x8F8F8F90,0x8E8E8F8F,
    0x8D8E8E8E,0x8D8D8D8D,0x8C8C8C8C,0x8B8B8C8C,0x8B8B8B8B,0x8A8A8A8A,0x89898989,0x88898989,
    0x88888888,0x87878888,0x87878787,0x85868686,0x85858585,0x84848484,0x83838484,0x82828283,
    0x81818181,0x80818181,0x00808080,0x00000000,0x01010000,0x02020101,0x02020202,0x03030303,
    0x04040404,0x05050504,0x06060505,0x07060606,0x07070707,0x08080808,0x09090909,0x0A0A0A09,
    0x0B0B0A0A,0x0B0B0B0B,0x0D0C0C0C,0x0D0D0D0D,0x0D0D0D0D,0x0E0E0E0E,0x0F0F0F0E,0x10100F0F,
    0x10101010,0x10101010,0x10101010,0x11111111,0x11111111,0x11111111,0x12121111,0x12121212,
    0x12121212,0x12121212,0x13131313,0x13131313,0x13131313,0x13131313,0x14141413,0x14141414,
    0x14141414,0x14141414,0x14141414,0x14141514,0x14141414,0x15151514,0x15151515,0x15151515,
    0x15151515,0x15151515,0x15151515,0x15151515,0x15151515,0x15151515,0x16161515,0x15161616,
    0x16161616,0x16161616,0x16161616,0x16161616,0x15161616,0x15151515,0x15151515,0x15151515,
    0x15151515,0x15151515,0x15151515,0x15151515,0x15151515,0x15151515,0x15151515,0x15151515,
    0x15151515,0x15151515,0x15151515,0x14141415,0x14141414,0x14141414,0x14141414,0x14141414,
    0x13141414,0x13131313,0x13131313,0x13131313,0x12121213,0x12121312,0x12121212,0x12121212,
    0x12121212,0x11111112,0x11111111,0x11111111,0x10101011,0x10101010,0x10101010,0x0F0F0F10,
    0x0E0F0F0F,0x0E0E0E0E,0x0D0D0E0E,0x0D0D0D0D,0x0C0C0C0D,0x0B0B0C0C,0x0B0B0B0B,0x0A0A0A0B,
    0x09090A0A,0x0909090A,0x08090909,0x07070708,0x07070707,0x06060607,0x05060606,0x04040405,
    0x04040404,0x03040404,0x02020203,0x01010202,0x00000101,0x00000000,0x80808000,0x81818080,
    0x81818181,0x82828282,0x83838383,0x84848383,0x85848484,0x85858585,0x86868686,0x87878786,
    0x87878787,0x88888888,0x89898988,0x8A8A8989,0x8A8A8A8A,0x8B8B8B8A,0x8C8B8B8B,0x8C8C8C8C,
    0x8D8D8D8C,0x8D8E8D8D,0x8E8E8E8E,0x8F8F8E8E,0x8F8F8F8F,0x90908F8F,0x90909090,0x90909090,
    0x90909090,0x91919190,0x91919191,0x91919191,0x92919191,0x92929292,0x92929292,0x92929292,
    0x92939292,0x93939392,0x93939393,0x93939393,0x93939393,0x93939393,0x93939393,0x94939393,
    0x94949494,0x94949494,0x94949494,0x94949494,0x94949494,0x94949494,0x94949494,0x94949494,
    0x94949494,0x94949494,0x95949494,0x95959595,0x95959595,0x95959595,0x94949595,0x95959595,
    0x94949595,0x95959595,0x94949495,0x94949494,0x94949494,0x94949494,0x94949494,0x94949494,
    0x94949494,0x94949494,0x94949494,0x94949494,0x94949494,0x93939494,0x93939393,0x93939393,
    0x93939393,0x93939393,0x92929393,0x92929292,0x92929292,0x92929292,0x92929292,0x91929292,
    0x91919191,0x91919191,0x90919191,0x91919190,0x91919191,0x90909090,0x90909090,0x908F9090,
    0x8F8F8F8F,0x8E8E8F8F,0x8E8E8E8E,0x8D8D8D8E,0x8D8D8D8D,0x8C8C8C8D,0x8B8B8B8C,0x8B8B8B8B,
    0x8A8A8A8A,0x89898A8A,0x89898989,0x88898888,0x88888888,0x87878787,0x86868787,0x86868686,
    0x85858686,0x84858585,0x83848484,0x83838383,0x82828283,0x81828282,0x81818181,0x80808080,
    0x00000080,0x01000000,0x01010101,0x02020101,0x02020202,0x03030302,0x04040303,0x04040404,
    0x05050404,0x05050505,0x06060605,0x07070707,0x08070707,0x09080808,0x09090909,0x0A090909,
    0x0A0A0A0A,0x0B0B0A0A,0x0B0B0B0B,0x0C0C0B0B,0x0C0C0C0C,0x0D0D0D0C,0x0D0E0D0D,0x0E0E0E0E,
    0x0F0E0E0E,0x0F0F0F0F,0x100F0F0F,0x10101010,0x10101010,0x11111010,0x10101010,0x11111111,
    0x11111111,0x11111111,0x12121111,0x12121212,0x12121212,0x12121212,0x12121212,0x12121212,
    0x12121212,0x13121312,0x13131313,0x13131313,0x13131313,0x13131313,0x13131313,0x14131313,
    0x14141414,0x14141414,0x14141414,0x14141414,0x14141414,0x14141414,0x14141414,0x14141414,
    0x14141414,0x14141414,0x14141414,0x14141414,0x14141414,0x14141414,0x14141414,0x14141413,
    0x14141414,0x14141414,0x14141414,0x13131414,0x13131314,0x13131313,0x13131313,0x13131313,
    0x13131313,0x13131313,0x12121212,0x12121212,0x12121212,0x12121212,0x12121212,0x12121212,
    0x12121212,0x11111111,0x11111111,0x11111111,0x11111111,0x11111111,0x10101010,0x10101010,
    0x10101010,0x0F100F10,0x0F0F0F0F,0x0E0E0E0E,0x0E0E0E0E,0x0D0D0D0D,0x0C0D0D0D,0x0C0C0C0C,
    0x0B0C0C0C,0x0B0B0B0B,0x0B0B0B0B,0x0A0A0A0A,0x0A0A0A0A,0x09090909,0x08090909,0x08080808,
    0x07070708,0x07070707,0x06060607,0x05050506,0x04050505,0x04040404,0x03030304,0x03030303,
    0x02020202,0x01010202,0x01010101,0x00000000,0x00000000,0x80800080,0x81808080,0x81818181,
    0x82828282,0x83838382,0x83838383,0x84848483,0x84858484,0x85858585,0x86868686,0x87868686,
    0x87878787,0x88888888,0x89898888,0x89898989,0x8A898989,0x8A8A8A8A,0x8A8B8A8A,0x8B8B8A8A,
    0x8B8B8B8B,0x8C8C8B8B,0x8C8C8C8C,0x8D8D8D8D,0x8E8D8D8D,0x8E8E8E8E,0x8F8E8E8E,0x8F8F8F8F,
    0x8F8F8F8F,0x9090908F,0x90909090,0x90909090,0x90909090,0x90909090,0x91909190,0x91919191,
    0x91919191,0x91919191,0x91919191,0x91919191,0x92929292,0x92929292,0x92929292,0x92929292,
    0x92929292,0x92929292,0x92929292,0x92929292,0x93929292,0x93939393,0x93939393,0x93939393,
    0x93939393,0x93939393,0x93939393,0x93939393,0x93939393,0x93939393,0x93939393,0x93939393,
    0x93939393,0x93939393,0x93939393,0x93939393,0x93939393,0x93939393,0x92939393,0x93939292,
    0x92929292,0x92929292,0x92929292,0x92929292,0x92929292,0x92929292,0x92929292,0x91919292,
    0x91919191,0x91919191,0x91919191,0x91919191,0x91919191,0x90919091,0x90909090,0x90909090,
    0x90909090,0x90909090,0x8F909090,0x8F8F8F8F,0x8E8F8F8F,0x8E8E8E8E,0x8E8E8E8E,0x8D8D8D8D,
    0x8C8D8D8C,0x8C8C8C8C,0x8C8C8C8C,0x8B8B8C8C,0x8A8B8B8B,0x8A8A8A8A,0x8A8A8A8A,0x89898989,
    0x88888989,0x88888888,0x87878788,0x87878787,0x86868686,0x85868686,0x84858585,0x84848484,
    0x83848484,0x83838383,0x82838383,0x82828282,0x81818282,0x81818181,0x80808080,0x00000080,
    0x00000000,0x01010100,0x02020101,0x02020202,0x03030302,0x03030303,0x04040404,0x05040404,
    0x05050505,0x06060606,0x06060606,0x07070707,0x08080807,0x08080808,0x08080808,0x09090909,
    0x0A0A0A09,0x0A0A0A0A,0x0B0A0A0B,0x0B0B0B0B,0x0C0C0B0B,0x0C0C0C0C,0x0D0D0C0C,0x0D0D0D0D,
    0x0E0E0D0D,0x0E0E0E0E,0x0F0F0E0E,0x0F0F0F0F,0x0F0F0F0F,0x1010100F,0x10101010,0x10101010,
    0x10101010,0x10101010,0x10101010,0x11111110,0x11111111,0x11111111,0x11111111,0x11111111,
    0x11111111,0x11111111,0x11111111,0x12121212,0x12121212,0x12121212,0x12121212,0x12121212,
    0x12121212,0x12121212,0x12121212,0x12121212,0x12121212,0x12121212,0x12121212,0x12121212,
    0x12121212,0x12121212,0x12121212,0x12121212,0x12121212,0x12121313,0x12121212,0x12121212,
    0x11121212,0x11111111,0x11111111,0x11111111,0x11111111,0x11111111,0x11111111,0x10111111,
    0x10101110,0x10101010,0x10101010,0x10101010,0x10101010,0x0F101010,0x0F0F0F0F,0x0F0F0F0F,
    0x0E0E0E0F,0x0E0E0E0E,0x0D0D0D0D,0x0D0D0D0D,0x0C0C0C0C,0x0C0C0C0C,0x0B0B0C0C,0x0B0B0B0B,
    0x0A0B0B0B,0x0A0A0A0A,0x0A0A0A0A,0x09090909,0x08090909,0x08080808,0x07070707,0x07070707,
    0x06060606,0x05050506,0x05060605,0x04040404,0x03030303,0x03030303,0x02020202,0x02020202,
    0x01010102,0x01010101,0x00000001,0x80800000,0x80808080,0x81818181,0x82818181,0x82828282,
    0x83828282,0x83838383,0x84848484,0x85848484,0x85858585,0x86858585,0x86868686,0x87878786,
    0x87878787,0x88878787,0x88888888,0x89888888,0x89898989,0x8A898989,0x8A8A8A8A,0x8A8A8A8A,
    0x8B8B8B8B,0x8C8C8B8B,0x8C8C8C8C,0x8D8D8C8C,0x8D8D8D8D,0x8D8D8D8D,0x8E8E8E8D,0x8E8E8E8E,
    0x8F8E8E8E,0x8F8F8F8F,0x8F8F8F8F,0x908F8F8F,0x90908F90,0x90909090,0x90909090,0x90909090,
    0x90909090,0x91909090,0x91919191,0x91919191,0x91919191,0x91919191,0x91929291,0x91929191,
    0x91919191,0x91919191,0x91919191,0x92929191,0x92929292,0x92929192,0x92929292,0x92929292,
    0x92929292,0x92929292,0x92929292,0x92929292,0x92929292,0x92929292,0x92929292,0x92929292,
    0x92929292,0x92929292,0x92929292,0x92929292,0x92929292,0x91929292,0x91919291,0x91919191,
    0x91919191,0x91919191,0x91919191,0x91919191,0x91919191,0x91919191,0x90919191,0x90909090,
    0x90909090,0x90909090,0x90909090,0x90909090,0x90909090,0x8F8F8F90,0x8F90908F,0x8E8F8F8F,
    0x8D8E8E8E,0x8D8E8E8E,0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,0x8C8C8C8C,0x8C8C8C8C,0x8B8B8B8C,
    0x8B8B8B8B,0x8A8A8A8B,0x8A8A8A8A,0x898A8A8A,0x89898989,0x88898989,0x88888888,0x87878888,
    0x87878787,0x86868787,0x86868686,0x85858586,0x85858585,0x84848485,0x84848484,0x83838383,
    0x83838383,0x82828282,0x82828282,0x81818181,0x81818181,0x80808081,0x00008080,0x01000000,
    0x01010101,0x01010101,0x02020202,0x03030302,0x03030303,0x04040404,0x04040404,0x05050505,
    0x06060505,0x06060606,0x07070706,0x07070707,0x08080707,0x08080808,0x09080808,0x09080909,
    0x09090909,0x0B0A0909,0x0B0A0B0B,0x0B0B0B0B,0x0C0B0B0B,0x0C0C0C0C,0x0C0C0C0C,0x0D0D0C0D,
    0x0D0D0D0D,0x0D0D0E0D,0x0E0E0E0E,0x0E0E0E0E,0x0F0F0F0E,0x0F0F0F0F,0x0F0F0F0F,0x10101010,
    0x10101010,0x10101010,0x10101010,0x10101010,0x10101010,0x11111111,0x11111111,0x11111111,
    0x11111111,0x11111111,0x11111111,0x11111111,0x11111111,0x11111111,0x11111111,0x12121211,
    0x12111112,0x11121111,0x12121211,0x12121212,0x12121212,0x12121212,0x12121212,0x12121212,
    0x12121212,0x12121212,0x12121212,0x11121212,0x11111111,0x11111111,0x11121211,0x11111111,
    0x11111111,0x11111111,0x11111111,0x11111111,0x11111111,0x11111111,0x10101011,0x10101010,
    0x10101010,0x10101010,0x10101010,0x10101010,0x10101010,0x10101010,0x100F0F0F,0x0F0F0F0F,
    0x0F0F0F0F,0x0E0E0E0E,0x0E0E0E0E,0x0D0E0E0D,0x0D0D0D0D,0x0D0D0D0D,0x0C0C0C0D,0x0C0C0C0C,
    0x0C0C0B0B,0x0B0B0B0B,0x0A0B0B0B,0x0A0A0A0A,0x0A0A0A0A,0x09090A0A,0x09090909,0x09090909,
    0x08080808,0x08080808,0x07070808,0x07070707,0x06070707,0x06060606,0x05050606,0x05050505,
    0x04040404,0x03030304,0x02030303,0x02020303,0x02020202,0x01010102,0x01010101,0x00000000,
    0x00000000,0x80808000,0x81818080,0x81818181,0x81818181,0x82828282,0x83838282,0x83838383,
    0x84838383,0x84848484,0x85858484,0x85858585,0x86868585,0x86868585,0x87878686,0x87878787,
    0x87888887,0x88888888,0x88888888,0x89898988,0x89898989,0x8A898A8A,0x8A8A8A8A,0x8A8A8A8A,
    0x8B8B8B8A,0x8C8B8B8B,0x8C8C8C8C,0x8C8C8C8C,0x8D8D8D8C,0x8D8D8D8D,0x8D8D8D8D,0x8E8E8E8D,
    0x8E8E8E8E,0x8E8E8E8E,0x8E8E8E8E,0x8F8F8F8F,0x8F8F8F8F,0x8F8F8F8F,0x90909090,0x90909090,
    0x90909090,0x90909090,0x90909090,0x90909090,0x90909090,0x90919190,0x90909090,0x91919191,
    0x91919191,0x91919191,0x91919191,0x91919191,0x91919191,0x91919191,0x91919191,0x91919191,
    0x91919191,0x91919191,0x91919191,0x91919191,0x90909091,0x90909090,0x90909090,0x90909090,
    0x90909090,0x90909090,0x90909090,0x90909090,0x8F8F8F8F,0x8F8F8F8F,0x8F8F8F8F,0x8E8F8F8F,
    0x8E8E8E8F,0x8E8E8E8E,0x8E8E8E8E,0x8E8E8E8E,0x8D8D8E8E,0x8D8C8D8D,0x8C8D8D8D,0x8C8C8C8C,
    0x8B8C8C8B,0x8B8B8B8B,0x8A8B8B8A,0x8A8A8A8A,0x8A898A8A,0x8989898A,0x89898989,0x88888989,
    0x88888888,0x88888888,0x87878787,0x87878787,0x86868687,0x86868686,0x85858686,0x85858585,
    0x84858585,0x84848484,0x83838484,0x83838383,0x82828282,0x82828282,0x81818181,0x81818181,
    0x80808080,0x00008080,0x00000000,0x00000000,0x01010100,0x01010101,0x02020201,0x02020202,
    0x03030303,0x04030303,0x04040404,0x05040404,0x05050505,0x05050505,0x06060605,0x06060606,
    0x07070706,0x08080707,0x07070708,0x08070707,0x08080808,0x09090808,0x09090909,0x09090909,
    0x0A0A0A0A,0x0A0A0A0A,0x0A0A0A0A,0x0B0B0B0A,0x0B0B0B0B,0x0B0C0C0B,0x0C0C0C0B,0x0C0C0C0C,
    0x0D0D0D0D,0x0D0D0D0D,0x0D0D0D0D,0x0E0E0E0E,0x0E0E0E0E,0x0E0E0E0E,0x0E0E0E0E,0x0F0F0F0F,
    0x0F0F0F0F,0x0F0F0F0F,0x0F0F0F0F,0x100F0F0F,0x10101010,0x10101010,0x10101010,0x10101010,
    0x10101010,0x10101010,0x10101010,0x10101010,0x10101010,0x10101010,0x10101010,0x10111010,
    0x10101010,0x10101010,0x10101011,0x10101010,0x10101010,0x10101010,0x11111010,0x10101010,
    0x10101010,0x10101010,0x10101010,0x10101010,0x10101010,0x10101010,0x10101010,0x10101010,
    0x10101010,0x10101010,0x100F0F10,0x0F101010,0x0F0F0F0F,0x0F0F0F0F,0x0F0F0F0F,0x0F0F0F0F,
    0x0E0E0E0F,0x0E0E0E0E,0x0E0E0E0E,0x0E0E0E0E,0x0D0D0D0E,0x0D0D0D0D,0x0D0D0D0D,0x0D0D0D0D,
    0x0C0C0C0C,0x0C0C0C0C,0x0B0B0B0C,0x0B0B0B0B,0x0B0B0B0B,0x0A0A0A0A,0x0A0A0A0A,0x09090A0A,
    0x09090909,0x09090909,0x08080808,0x08080808,0x07070708,0x07070707,0x06060707,0x06060606,
    0x05050606,0x05050505,0x05050505,0x04040405,0x04040404,0x03030304,0x03030202,0x03030303,
    0x02020202,0x01010202,0x01010101,0x00000000,0x00000000,0x80808080,0x81808080,0x81818080,
    0x81818181,0x82828181,0x82828282,0x83838382,0x83838383,0x83838383,0x84848484,0x84848484,
    0x85858585,0x85858585,0x86868685,0x86868686,0x86868686,0x87878787,0x87878787,0x87878887,
    0x88888888,0x88888888,0x89888888,0x89898989,0x8A898989,0x8A8A8A8A,0x8A8A8A8A,0x8A8A8A8A,
    0x8B8B8B8B,0x8B8B8B8B,0x8B8B8B8B,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8D8D8D8C,0x8D8D8D8D,
    0x8E8E8D8D,0x8D8D8D8E,0x8D8D8D8D,0x8E8E8E8E,0x8E8E8E8E,0x8E8E8E8E,0x8E8E8E8E,0x8E8E8E8E,
    0x8E8F8F8F,0x8E8E8F8E,0x8F8E8F8F,0x8F8E8E8E,0x8F8F8F8F,0x8F8F8F8F,0x8F8F8F8F,0x8F8F8F8F,
    0x8F8F8F8F,0x8F8F8F8F,0x8F8F8F8F,0x8F8F8F8F,0x8F8F8F8F,0x8F8F8F8F,0x8F8F8F8F,0x8F8F8F8F,
    0x8E8E8E8F,0x8F8F8F8E,0x8E8F8F8F,0x8E8E8E8F,0x8E8E8E8E,0x8E8E8E8E,0x8E8E8E8E,0x8D8D8E8E,
    0x8E8E8E8E,0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,0x8C8C8C8D,0x8C8C8C8C,0x8C8C8C8C,
    0x8C8B8B8C,0x8B8B8B8C,0x8B8B8B8B,0x8B8B8B8B,0x8B8B8B8B,0x8A8A8B8B,0x8A8A8A8A,0x8A8A8A8A,
    0x8989898A,0x89898989,0x89898989,0x89888889,0x88888888,0x87878888,0x87878787,0x86878787,
    0x86868687,0x86868686,0x85858686,0x85858585,0x84848485,0x84848484,0x83848484,0x83838383,
    0x83838383,0x82828383,0x82828282,0x82828182,0x81818181,0x81818181,0x80808081,0x80808080,
    0x00000080,0x00000000,0x01010000,0x01010101,0x01010101,0x02020202,0x02020202,0x03030302,
    0x03030303,0x03030303,0x03030303,0x04040403,0x05040404,0x05050505,0x05050505,0x05050505,
    0x06060606,0x06060606,0x06060606,0x07070707,0x07070707,0x07070807,0x08080808,0x08080808,
    0x09090808,0x09090909,0x09090909,0x0A0A0A09,0x0A0A0A0A,0x0A0B0A0A,0x0A0A0A0A,0x0B0B0B0B,
    0x0B0B0B0B,0x0B0B0B0B,0x0C0C0C0C,0x0C0C0C0C,0x0C0C0C0C,0x0C0D0D0C,0x0D0D0D0C,0x0D0D0D0D,
    0x0D0D0D0D,0x0D0D0D0D,0x0D0D0D0D,0x0D0D0D0D,0x0D0D0D0D,0x0E0E0E0E,0x0E0E0E0E,0x0E0E0E0E,
    0x0E0E0E0E,0x0E0E0E0E,0x0E0E0E0E,0x0E0E0E0E,0x0E0E0E0E,0x0E0E0E0E,0x0E0E0E0E,0x0E0E0E0E,
    0x0E0E0F0E,0x0E0E0E0F,0x0E0E0E0E,0x0E0E0E0E,0x0E0E0F0E,0x0E0E0E0E,0x0E0E0E0E,0x0E0F0F0E,
    0x0E0E0E0E,0x0E0E0E0E,0x0E0E0D0E,0x0D0D0E0D,0x0D0D0D0D,0x0D0D0D0D,0x0D0D0D0D,0x0D0D0D0D,
    0x0D0D0D0D,0x0D0D0D0D,0x0D0D0D0D,0x0C0C0C0C,0x0C0D0D0C,0x0C0C0C0C,0x0C0C0C0C,0x0C0C0C0C,
    0x0C0C0C0C,0x0B0B0C0C,0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,0x0A0B0A0A,0x0A0A0A0A,0x0A0A0A0A,
    0x0A0A0A0A,0x09090909,0x09090909,0x09090909,0x08090909,0x08080908,0x08080808,0x08080808,
    0x07070708,0x07070707,0x06060707,0x06060606,0x06060606,0x05050606,0x05050505,0x05040505,
    0x04040404,0x04040404,0x04040404,0x03030404,0x03030303,0x03030303,0x02020203,0x02020202,
    0x02020202,0x01020201,0x01010201,0x01010101,0x00010101,0x00000000,0x00000000,0x80808000,
    0x81808080,0x81818181,0x81818181,0x82818181,0x82828282,0x82828282,0x83838383,0x83838383,
    0x83838483,0x84848484,0x84848484,0x84848484,0x85858584,0x85858585,0x86858585,0x86868686,
    0x86868686,0x87878786,0x87878787,0x88878787,0x88888888,0x88888888,0x88888888,0x88888988,
    0x89898989,0x89898989,0x89898989,0x898A8A89,0x8A8A8A89,0x8A8A8A8A,0x8A8A8A8A,0x8A8A8B8A,
    0x8B8B8B8A,0x8B8A8A8A,0x8C8C8B8B,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,
    0x8D8D8C8C,0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,
    0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,0x8D8E8E8D,0x8D8D8D8D,0x8D8D8D8D,
    0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,0x8D8D8D8D,0x8D8C8D8D,0x8C8C8D8D,0x8C8C8C8C,
    0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8B8C8C8C,0x8B8B8B8B,
    0x8B8C8C8B,0x8B8B8B8B,0x8B8B8B8B,0x8B8B8B8B,0x8B8A8B8B,0x8A8A8A8B,0x8A8A8A8A,0x8A8A8A8A,
    0x8A8A8A89,0x89898989,0x89898989,0x89898989,0x88888989,0x88888888,0x88888988,0x88888888,
    0x88888888,0x87878787,0x87878787,0x87878787,0x86868687,0x86868686,0x85868686,0x85858585,
    0x85858585,0x84848585,0x84848484,0x84848484,0x83838384,0x83838383,0x83838383,0x82838383,
    0x82828282,0x82828282,0x81828282,0x82828282,0x81818181,0x81818181,0x80808081,0x80808080,
    0x80000080,0x00000000,0x01000000,0x01010101,0x01010101,0x01020101,0x02020201,0x02020202,
    0x02020202,0x03030303,0x03030303,0x03030303,0x03030303,0x03030303,0x04040404,0x05050505,
    0x05040405,0x05050505,0x05050505,0x06060505,0x06060606,0x06060606,0x07070707,0x07070707,
    0x07070707,0x08080807,0x08080808,0x08080808,0x09080808,0x09090909,0x09090909,0x09090909,
    0x09090909,0x0A090909,0x0A0A0A0A,0x0A0A0A0A,0x0B0B0A0A,0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,
    0x0B0C0C0B,0x0C0C0B0B,0x0C0C0C0C,0x0C0C0C0C,0x0C0C0C0C,0x0C0C0C0C,0x0C0C0C0C,0x0C0C0C0C,
    0x0C0C0D0C,0x0C0D0C0C,0x0C0C0C0C,0x0C0C0C0C,0x0D0C0C0C,0x0D0D0D0D,0x0D0C0D0D,0x0D0D0D0D,
    0x0D0D0D0D,0x0D0D0C0C,0x0D0D0D0D,0x0D0D0D0D,0x0D0D0D0D,0x0D0D0D0D,0x0D0D0D0D,0x0D0D0D0D,
    0x0D0D0D0D,0x0D0C0D0D,0x0D0C0D0D,0x0D0C0C0D,0x0D0D0C0C,0x0C0C0C0D,0x0C0C0C0C,0x0C0C0C0C,
    0x0C0C0C0C,0x0C0C0C0C,0x0B0C0C0C,0x0C0C0C0B,0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,
    0x0A0A0B0B,0x0A0A0A0A,0x0A0A0A0A,0x0A0A0A0A,0x09090A0A,0x09090909,0x09090909,0x09090909,
    0x09090909,0x08080808,0x08080808,0x08080808,0x07070808,0x07070707,0x07070707,0x07070707,
    0x06060607,0x06060606,0x06050606,0x05050505,0x05050505,0x04040404,0x04040404,0x03030404,
    0x04030303,0x03030304,0x02030303,0x02020202,0x02020202,0x02020202,0x01010102,0x01010101,
    0x01010101,0x00000000,0x00000000,0x80800000,0x80808080,0x80808080,0x81818080,0x81818181,
    0x81818181,0x82828282,0x82828282,0x82828282,0x83838382,0x83838383,0x83838383,0x83838383,
    0x84848383,0x84848484,0x84848484,0x85858484,0x85858585,0x85858585,0x85858585,0x86868686,
    0x87868686,0x86868687,0x87878787,0x87878787,0x87878787,0x88888887,0x88888788,0x88888888,
    0x88888888,0x89898988,0x89898989,0x89898989,0x89898989,0x8A898989,0x8A8A8989,0x8A8A8A8A,
    0x8A8A8A8A,0x8A8A8A8A,0x8B8A8A8A,0x8B8B8A8B,0x8B8B8B8B,0x8B8B8B8B,0x8B8B8B8B,0x8B8B8B8B,
    0x8B8C8B8B,0x8B8C8B8B,0x8C8C8C8B,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,
    0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,
    0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8D8C,0x8C8C8C8C,0x8C8C8C8C,0x8C8C8C8C,
    0x8C8C8C8C,0x8C8C8C8C,0x8C8B8C8C,0x8B8B8B8C,0x8C8C8B8B,0x8B8B8C8C,0x8B8B8B8B,0x8B8B8B8B,
    0x8B8B8B8B,0x8B8B8B8B,0x8A8A8B8B,0x8A8A8A8A,0x8A8A8A8A,0x8A8A8A8A,0x89898A8A,0x89898989,
    0x89898989,0x89898989,0x89898989,0x88898989,0x88888888,0x88888888,0x88888888,0x87878787,
    0x87878787,0x87878787,0x86878787,0x86868686,0x86868686,0x85858586,0x85858585,0x85858585,
    0x84848485,0x84848484,0x83848484,0x84838383,0x83838383,0x83838383,0x82838383,0x82828282,
    0x82828282,0x82828282,0x81818282,0x81818181,0x80808181,0x80808080,0x00000080,0x00000000,
    0x00000000,0x01010000,0x01010100,0x01010101,0x02020201,0x02020202,0x02020202,0x03030202,
    0x03030303,0x03030303,0x04040403,0x04040404,0x05050404,0x05050505,0x05050505,0x05050505,
    0x06050505,0x06060606,0x06060606,0x07060606,0x07070707,0x07070707,0x07070707,0x08070707,
    0x08080808,0x08080808,0x08080808,0x08090909,0x09090909,0x09090909,0x09090909,0x09090909,
    0x090A0909,0x0A090909,0x0A0A0A0A,0x0A0A0A0A,0x0A0A0A0A,0x0A0A0A0A,0x0B0B0A0A,0x0B0B0A0A,
    0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,0x0C0B0B0B,0x0B0B0B0B,
    0x0C0C0B0B,0x0B0B0B0B,0x0C0C0B0C,0x0B0B0B0B,0x0C0B0C0B,0x0C0C0B0C,0x0C0C0B0B,0x0B0B0B0C,
    0x0D0C0B0B,0x0B0B0C0C,0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,0x0C0C0C0B,0x0C0C0C0C,0x0B0B0B0C,
    0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,0x0B0B0B0B,0x0B0A0A0B,
    0x0B0B0B0B,0x0A0A0B0B,0x0A0A0A0A,0x0A0A0A0A,0x0A0A0A0A,0x0A0A0A0A,0x0A0A0A09,0x0909090A,
    0x09090909,0x09090909,0x09090909,0x08080808,0x07080808,0x08080807,0x08080808,0x07070707,
    0x07070707,0x07070707,0x07070707,0x06060607,0x06060606,0x06060606,0x06060606,0x06060606,
    0x05050505,0x05050505,0x05050505,0x04040504,0x04040404,0x04030404,0x03030304,0x03030303,
    0x03020303,0x02020202,0x02020202,0x02010102,0x01010101,0x01010101,0x01010101,0x00000101,
    0x00000000,0x00000000,0x80808000,0x80808080,0x81808080,0x81818181,0x81818181,0x81818281,
    0x82828282,0x82828282,0x82828282,0x83838383,0x83838383,0x83838383,0x83838383,0x84838383,
    0x84848484,0x84848484,0x84848484,0x85858584,0x85858585,0x85858585,0x85858585,0x85858585,
    0x86868686,0x86868686,0x86868686,0x86868686,0x86868686,0x86868686,0x86868686,0x87868686,
    0x87878787,0x87868787,0x86878787,0x87878787,0x87878787,0x87878787,0x86868687,0x87868686,
    0x87878787,0x87878787,0x87878787,0x87878787,0x87868787,0x86868686,0x86868686,0x86868686,
    0x86868686,0x86868686,0x86868686,0x86868686,0x86868686,0x86868686,0x86868686,0x85858585,
    0x85858585,0x85858585,0x85858585,0x85858585,0x85858585,0x85858585,0x85858585,0x84858585,
    0x84848484,0x84848484,0x84848484,0x84848484,0x84848484,0x84848484,0x83838384,0x83838383,
    0x83838383,0x83838383,0x83838383,0x83838383,0x83838383,0x82828283,0x82828282,0x82828282,
    0x82828282,0x82828282,0x82828282,0x82818282,0x81818181,0x81818181,0x81818181,0x81818181,
    0x81818181,0x81818181,0x81818181,0x81818181,0x80808081,0x80808080,0x80808080,0x80808080,
    0x80808080,0x80808080,0x80808080,0x80808080,0x80808080,0x80808080,0x80808080,0x80808080,
    0x80808080,0x00808080,0x00000000,0x00000000,0x00000000,0x00000000,0x00000000,0x00000000,
    0x00000000,0x00000000,0x00000000,0x00000000,0x00000000,0x00000000,0x00000000,0x00000000,
    0x00000000,
