Results 1 to 3 of 3
Thread: Can't make OLED work SSD1311 controller with Teensy 3.6
    Jul 2019
    United Kingdom
    15
    Hi, I've been trying to get a Midas MCOB42005AX-EWP display to work with my Teensy 3.6 but can't get anything to display.
    http://www.midasdisplays.com/product...cob42005ax-ewp
    http://www.midasdisplays.com/getatta.../specification
    I've found this thread and the code in the example but it seems designed for a 1602 display not the 2004 I have: https://forum.pjrc.com/threads/42740...hlight=SSD1311
    My wiring is:
    Teensy........ OLED 16 pin interface
    41 SCL0.....7
    40 SDA0.....8
    1 GND........1
    15 3v3.......2
    I've also found various SSD1311 libraries but they are all for SPI or parallel interfaces - the Midas seems to only use I2C.
    Any help very gratefully received
    TIA
    3,743
    Quote Originally Posted by sw_hunt View Post
    My wiring is:
    41 SCL0.....7
    40 SDA0.....8
    1 GND........1
    15 3v3.......2
    TIA
    You want to use pin 19 (A5) to connect to SCL, and pin 18 (A4) to connect to SDA.
    You may or may not need pull-up resistors on the I2C bus (it depends on whether the device already has it own pull-up resistors). I and others put some information about connecting pull-up resistors to the I2C bus in the non-official Teensy wiki:
    Jul 2019
    United Kingdom
    15
    Thanks, I am using those pins. Each Teensy pin has two numbers! I quoted the physical pin numbers and I think you mean the pin names. Pin 41 SCL0 is called 19 so I think we're talking about the same thing.
    Good idea with the pullups; I just tried 10k from SDA and SCK to 3v3 but still no life
