Results 1 to 4 of 4
Thread: ICM-20948 Motion Sensor Library for Teensy (the newer+better MPU-9250)
    Dec 2018
    13
    I've written an Arduino library for the ICM-20948 motion sensor which uses the internal DMP (digital motion processor). I've tested it using a Teensy 4.1 and it seems to work well.
    Library can be found here:
    https://github.com/ZaneL/Teensy-ICM-20948
    Nodejs app which takes the quaternion output and rotates a 3D object in real time:
    https://github.com/ZaneL/quaternion_sensor_3d_nodejs
    Video demo: https://streamable.com/ivmgfz
ID:	20226Click image for larger version.
    New York
    5,348
    @Zane470 - very nice indeed. I have been using the Sparkfun library for the ICM-20948. Yours seems a bit more interesting
    Oct 2015
    Roma (IT, EU)
    336
    Hello, is there a calibration routine to be performed?
    I tried to work on a project for an underground orientation instrument, but stumbled upon unreliable devices (mag + gyro + compass), even after extensive calibrations.
    I would happily try again with your promising library, but I can't find how calibration works here..?
    Dec 2018
    13
    Quote Originally Posted by XFer View Post
    The datasheet claims that when using the DMP it does some sort of a continuous automatic calibration. After this weekend I'll look through the datasheet and code a bit more to see if that is actually running properly. I'll also look into adding a manual calibration routine.
