Results 1 to 2 of 2
Thread: Teensy 4 Audio Library with ASIO4ALL for Low-Latency Playback
    I'm testing my new DAC, and opened Ableton Live 10 Suite to see if I can use the DAC with it. I was hoping ASIO4ALL would work but I'm getting the following error.
Name:	abelton live teensy error.png
    Live does not support 11025 as a sample rate for the device ASIO4ALL v2. I was searching forums for this problem and I came across the "ASIO4ALL Off-line Settings" and I know it's only the Teensy enabled.
Name:	ASIO4ALL teensy audio off-line settings.png
    Has anyone else used Ableton Live with Teensy? With ASIO4ALL? Any advice would be appreciated.
    Jay
    Dec 2014
    291
    How do you set up the USB audio-in endpoint? Are you using the audio library / setup?
    I don't see code in the USB library to set up 11 kHz (it all sets up at 44 kHz) but maybe you changed something?
    What DAC are you using, and how do you set that up?
