Results 1 to 4 of 4
Thread: Which pin is OUT1A on Teensy 4.1?
    Dec 2014
    311
    I see both pin 39 and pin 7 marked as OUT1A, with neither of them being dimmed (secondary.)
    Is it still pin 7, like on the Teensy 4.0, or did it move to pin 39 on the 4.1?
    15,089
    In order to work with Audio Board it would share the #7 common pin.
    25,077
    Use pin 7.
    Pin 39 is the alternate which should have been printed in gray. I will fix that on future versions of the Teensy 4.1 pinout card.
    Dec 2014
    311
    Thanks both of you!
