Results 1 to 5 of 5
Thread: New Teensy 4.1 has [no_device] error on MacOS 10.14.6; Teensy 3.6 and 4.0 all work
    Oct 2018
    8
    I received my first Teensy 4.1 today. I always verify the "factory" Blink appears to be working for each new board and then program a different blink rate to verify that download works. When attempting to select the port in Teensyduino 1.8.12 it shows this:
    [no_device] Bootloader (Teensy 4.1)
    I tried this several times, disconnecting and reconnecting the USB cable. I then verified that the Teensy 3.6 I am currently using works, and then tried the one Teensy 4.0 that I have. It also works.
    Is there a chance that the "15 second" reset might fix this? I wanted to inquire before trying it.
    Can I provide any other information?
    13,791
    Not yet seen Harm from 15s Restore. It reloads a no USB Blink factory sketch.
    Then like new - the first upload takes a Button press to get to bootloader and facilitate upload as it comes as noted without USB.
    8,907
    What version of teensyduino is installed?
    Oct 2018
    8
    Teensyduino 1.52 is installed.
    But I finally got it working. The 15 second reset worked normally. I then stumbled through multiple iterations trying to get the load to work. It was probably a matter of my finger pressing the reset to get to the bootloader, I'm not sure what was going on, but I finally closed the Teensy loader and tried one more time and the loader opened back up and when I pressed reset one more time it started working.
    Thanks.
    24,023
    Glad it finally started working.
    The "[no device]" part means MacOS detected the USB device, but didn't load HID drivers and create a HID entry in the MacOS I/O Registry (or if it did, the teensy_ports program didn't get a notification about the change). Why that would happen is a mystery to me.
