Results 1 to 12 of 12
Thread: Amiga emulation on Teensy 4.1
    May 2018
    111
    Happy to share the initial code and the video of the UAE Amiga emulator running on the Teensy 4.1 + PSRAM.
    2MB chip ram and 4 MB fast ram now mapped on the PSRAM.
    Impressive performance of the PSRAM without any memory tweak.
    https://youtu.be/LE4IWPG5z6g
    https://github.com/Jean-MarcHarvengt...ster/README.md
    22,279
    Awesome. I gave it a quick shout-out on Twitter.
    May 2018
    111
    Some updates of the UAE port to the teensy4.1...
    I restarted from a more compatible version of the source code.
    - Sound has been fixed
    - Most GFX problems too (no AGA support yet but ok)
    - Add support for Hard Disk (e.g. WHDload now working to launch demos and games from the HDD)
    - Moved to 68020 core (for better compatibility)
    Still runs on a 320x240 display.
    Anyone got the uVGA library working on the Teensy4.1?
    May 2018
    111
    I added 2 new videos to demo it...
    https://youtu.be/Ho8qZSCKdLg
    https://youtu.be/vuMYwylYqYs
    Apr 2020
    Germany, NRW
    85
    This is just amazing.
    Senior Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    129
    I have an observation and a question concerning the teensy 4.1 bottom psram pads and the code... in teensyuae41/iopins.h the psram is defined on pins34-37 and the 4.1 psram pads on bottom are different pins , 48-50 and 52-54.
    Should I change those defines, or... ?
    May 2018
    111
    Sorry, no need to change this for teensy4.1. I used to connect the psram my own way on the T4.0 but no need if you use teensyuae4.1...
    Amazing work! Wish I had one!
    Great work here! Love Amiga!
    May 2018
    111
    so for people who wants to try, most important using the teensyuae41 project:
    1) have the PSRAM soldered under the T4.1
    2) select the type of display in platform_config.h (ILI or ST)
    3) look at the display pinout in iopins.h (TFT_*) and Analog joystick pins/ADC (forget second joystick, SD and PSRAM pins)
    4) finally compile for smallest code...
    For the sound I use the MQSR output on pin 10, therefore CS is using pin 22. If you don't have sound, it is because the SPI still initialize the CS as pin10 (my workaround is adapting pins_arduino.h => PIN_SPI_SS= something else that 10)
    I have done some more fix past w-e around the floppy driver (some games as great gianna sister were not booting anymore from adf) and some GFX issue (battle squadron sprite that was corrupted)
    You might experiment some issue due to the PSRAM. Some games might freeze because of the PSRAM caching I guess. It is very random. Please share the issue you have especially around the PSRAM. I find it strange because sometimes recompilation or rebooting seems to move the problem somewhere else... But I think it will be hard to fix...
    Mar 2014
    New Ulm, Mn
    129
    Got it, thanks!
    Put your handheld up on tindie. Take my money!
