Results 1 to 11 of 11
Thread: Is there a way to increase the audio lib buffer?
    I would really love to be able to add some buffer in the audio library to prevent pops and clicks. if i have a couple of wavs playing then i get pops and clicks when i open envelopes. its fine with just one wav playing. is there a way to do this? I realise it would be at the expense of latency.
    I have had a look at AudioPlayMemory and AudioRecordMemory but presumably the library has its own buffer, is it possible to adjust this?
    regards,
    Al.
    May 2020
    14
    isnt AudioMemory for increasing buffer size?
    https://github.com/PaulStoffregen/Au...e_Test.ino#L37
    it makes more memory available but doesn't fill it with buffer which is what i would like to do : )
    Member houtson's Avatar
    Aug 2015
    Scotland
    92
    @alrj can you post some sample code that reproduces your problem, it makes it a lot easier to help that way, cheer Paul
    So this code shows part of the problem. triggering the sample that is already playing should result in a click but there is a bit of distortion in there as well that you can "tune" by adjusting the AUDIO_BLOCK_SAMPLES. the smaller number the higher pitched the artifact. this makes it impossible to trigger a wav that is already playing from the start, i have similar issues triggering a wav straight after one has just finished.
    AudioPlaySdWav           playSdWav1;     //xy=314,214
    AudioOutputI2S           i2s1;           //xy=587,192
    AudioConnection          patchCord1(playSdWav1, 0, i2s1, 0);
    AudioConnection          patchCord2(playSdWav1, 1, i2s1, 1);
    //#define SDCARD_CS_PIN    10
    //#define SDCARD_MOSI_PIN  7
    //#define SDCARD_SCK_PIN   14
    #define SDCARD_CS_PIN    BUILTIN_SDCARD
    #define SDCARD_MOSI_PIN  11  // not actually used
    #define SDCARD_SCK_PIN   13  // not actually used
    // Use these for the SD+Wiz820 or other adaptors
    //#define SDCARD_CS_PIN    4
    //#define SDCARD_MOSI_PIN  11
    //#define SDCARD_SCK_PIN   13
    int inByte = 0;
    byte  newDATAin = 1;
      AudioMemory(100);
      SPI.setMOSI(SDCARD_MOSI_PIN);
      SPI.setSCK(SDCARD_SCK_PIN);
        // stop here, but print a message repetitively
        while (1) {
    switch (Serial.read()) {
       case 's': {
        Serial.println("s");
       // envelope1.noteOff();
       // envelope2.noteOff();
       playSdWav1.stop();
       //playSdWav2.stop();
       //playSdWav3.stop();
       //playSdWav4.stop();
    //   playSdWav5.stop();
      // playSdWav6.stop();
     //  playSdWav7.stop();
     //  playSdWav8.stop();
     case 't': {
      playSdWav1.play("10BAB1.WAV");
     delay(5);
     // playSdWav2.play("10BAB2.WAV");
      //playSdWav3.play("10BAB3.WAV");
      //playSdWav4.play("10BAB4.WAV");
    Here are the wav files for the test...
    http://donjohnstonmusic.co.uk/tr/sinewavs.zip
    Here is what the click should sound like without the artefact..
    https://soundcloud.com/donjohnston/s.../s-S49FSTnUxvs
    I get similar artefacts trying to launch several wavs at the same time, or actuating an envelope on a wav with more than 2 other wavs playing.
    Regards,
    Al.
    I think I just need a way to buffer the audio but as wavs only play at realtime I am not sure how to go about it. I was hoping to increase AUDIO_BLOCK_SAMPLES to make the lib more robust to clicks as the latency is super low anyway i would happily swap some latency to get rid of these artefacts.
    No issues with SD read speed...
    SD Card Test
    SD card is connected :-)
    Card type is SDHC
    File system space is 63848.94 Mbytes.
    SD library is able to access the filesystem
    Unable to find SDTEST1.WAV on this card
    [Disconnected]
    [Connected]
    SD Card Test
    Card type is SDHC
    Reading SDTEST1.WAV:
      Overall speed = 1.73 Mbyte/sec
      Worst block time = 0.55 ms
        18.85% of audio frame time
    Reading SDTEST1.WAV & SDTEST2.WAV:
      Overall speed = 1.85 Mbyte/sec
      Worst block time = 0.59 ms
        20.34% of audio frame time
    Reading SDTEST1.WAV & SDTEST2.WAV staggered:
        20.30% of audio frame time
    Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV:
      Overall speed = 1.89 Mbyte/sec
      Worst block time = 0.85 ms
        29.19% of audio frame time
    Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV staggered:
        29.23% of audio frame time
    Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV, SDTEST4.WAV:
      Overall speed = 1.91 Mbyte/sec
      Worst block time = 1.60 ms
        55.32% of audio frame time
    Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV, SDTEST4.WAV staggered:
      Worst block time = 1.36 ms
        46.81% of audio frame time
    This demonstrates the issue even more clearly. 4 WAVs launched at the same time creates the drop out i am talking about if you trigger it a couple of times..
    AudioPlaySdWav           playSdWav2;     //xy=411,434
    AudioPlaySdWav           playSdWav3;     //xy=428,498
    AudioPlaySdWav           playSdWav1;     //xy=439,351
    AudioPlaySdWav           playSdWav4;     //xy=460,575
    AudioOutputI2S           i2s1;           //xy=712,329
    int inByte = 0;
    byte  newDATAin = 1;
      AudioMemory(100);
        while (1) {
       case 's': {
       // envelope2.noteOff();tttttttttttt
       playSdWav1.stop();
       playSdWav2.stop();
       playSdWav3.stop();
       playSdWav4.stop();
       //playSdWav5.stop();
       //playSdWav6.stop();
       //playSdWav7.stop();
       //playSdWav8.stop();
     case 't': {
     delay(5);
    Dec 2014
    304
    The problem is with the SDCard FAT library. It is quite inefficient in how it reads blocks, and how it scans directories for files.
    If you can add a multi-threaded runtime into the Teensy runtime, and let it run at a lower priority than the main Teensy loop, then you could do this without more buffering.
    Another option would be to copy the code for the SDCard FAT reader, and write your own, that's either more efficient, or splits the work into multiple iterations using a state machine approach.
    That is great info thank you. I have been working through this with a friend who is a much better programmer than me and he said a similar thing about having a multi-threaded runtime. I wouldn't be able to implement that but he can for sure.
    I managed to get the teensy to compile with the Bill's SDfat.h and using that all the pops and clicks were gone but every time audio was triggered the system would hang and you would loose control for up to 4 seconds. I might go back down this route and post in the SDfat thread to see if anyone has a solution.
    I have asked the in the SDfat SDIO T4 thread if there is a solution to the hangs caused when playing multiple wavs and provided example code...
    https://forum.pjrc.com/threads/57669...l=1#post241181
