Results 1 to 5 of 5
Thread: Teensy 4.1 Cannot access Internal SD card
    May 2020
    North Carolina
    7
    I am an experienced Arduino user making the switch to Teensy and finding it painful. I recently got the full featured 4.1 with built in SD card, but can find no way to access it.
    Arduino's SD library won't work
    SdFat won't work
    Examples sketches from forums using older boards won't work
    My card is a brand new SanDisk 32 gig, formatted Fat32. My PC reads/writes it perfectly.
    Don't bother asking for my source code, it's all garbage anyway.
    What I need is a GREATLY SIMPLIFIED set of tested examples of how to:
    1. #include the SD library, where in the sketch, and which library actually works in 4.1
    2. Syntax for begin, including CS pin is any - is the CS pin now selected by the 4.1 board for SD?
    3. Syntax for exists and !exists
    4. Syntax for file establishment, file open and file close.
    Something on the order of the way books are written on Arduino would be wonderful.
    I have done all this successfully on Arduino MEGA and built substantial projects using SD, memories, etc., but
    cannot get to first base with Teensy.
    Please keep it simple.
    22,101
    Use SD.begin(BUILTIN_SDCARD) to cause the SD library to access the SD socket on Teensy 4.1.
    The comments in all the SD library examples mention this only for Teensy 3.5 and 3.6. I've committed an update to also mention Teensy 4.1 in those comments.
    https://github.com/PaulStoffregen/SD...9f246b20be1282
    May 2020
    North Carolina
    7
    Adding to the list of things that DONT work, I talked to Paul and he said you have to put in a statement "chipSelect=BUILTIN_SDCARD
    in code for the 4.1, after which the usual SD libraries from Arduino should work. Below is my code for a simple test, only testing if the SD is functioning:
    int chipSelect = BUILTIN_SDCARD;
    if (!SD.begin()) Serial.println ("NO LUCK");
    else Serial.println ("SD WORKS!");
    The statement "NO LUCK" is repeated every time.
    Any and all help is appreciated.
    May 2020
    North Carolina
    7
    MANY THANX, PAUL! One line of written code is worth 1000 verbal descriptions! You can see from my code above that I misinterpreted the verbal info!
    I can get SD to open now, and now I'll mess with read/write tests.
    FYI this is for a fully programmable percussion sequencer or "Drum Machine" used for performance. It currently exists in Arduino format, with
    520 available rhythm patterns, capable of playing about 8 instruments at any given instant, a total palate of about 100. It is programmed via MIDI
    from Cakewalk, and outputs MIDI to the sound source of your choice. It has breaks, fills, intros, endings, drum cadenzas, and lots of other fun stuff.
    I currently have the first one built in the console of my theater organ, the Teensy version will be a portable.
    22,101
    If you're familiar with serial MIDI on Arduino Mega, one minor detail that commonly comes up is the need for different resistors with 3.3V signals. Details here:
    https://www.pjrc.com/teensy/td_libs_MIDI.html
    You might also be interested to know Teensy can do USB MIDI, both device and host modes. For USB device MIDI, this page has info:
    https://www.pjrc.com/teensy/td_midi.html
    For USB host MIDI, see the examples in the USBHost_t36 library. Usually host mode is used for connecting musical instruments that send MIDI, so perhaps not so useful for a sequencer that primarily transmits MIDI.
