Originally Posted by
defragster
That isn't a 'WARNING' to be concerned with - unless the one chosen is WRONG - more of informative feedback - actually added to the Arduino system by Paul@PJRC
Thanks. That is helpful.
I'm using PlatformIO 5.1.0 (+Visual Code) with a Teensy 4.1.
As you could probably guess from below, I'm trying to get ArduinoMenu going with SdFat (cards are small FAT16 for a reason) and a rotary encoder.
All libs and platform software are up-to-date.
I'm getting "'BUILTIN_SDCARD' was not declared in this scope"
Where is that symbol actually declared? what's its value on a Teensy 4.1?
Any help is appreciated!
PACKAGES:
- framework-arduinoteensy 1.153.0 (1.53)
- toolchain-gccarmnoneeabi 1.50401.190816 (5.4.1)
Dependency Graph
|-- <MIDI Library> 5.0.2
|-- <USBHost_t36> 0.1
|-- <Encoder>
|-- <Adafruit BusIO> 1.7.1
| |-- <Wire> 1.0
| |-- <SPI> 1.0
|-- <ArduinoMenu library> 4.21.3
| |-- <SdFat> 2.0.4
| | |-- <SPI> 1.0
| |-- <ClickEncoder> 0.0.0-alpha+sha.9337a0c46c
| |-- <Wire> 1.0
| |-- <Adafruit GFX Library> 1.10.5
| | | |-- <Wire> 1.0
| | | |-- <SPI> 1.0
| | |-- <Wire> 1.0
| | |-- <SPI> 1.0
|-- <SdFat> 2.0.4
| |-- <SPI> 1.0
|-- <SPI> 1.0
| | |-- <Wire> 1.0
| | |-- <SPI> 1.0
| |-- <Wire> 1.0
| |-- <SPI> 1.0
|-- <Adafruit SSD1306> 2.4.3
| | | |-- <Wire> 1.0
| | | |-- <SPI> 1.0
| | |-- <Wire> 1.0
| | |-- <SPI> 1.0
| |-- <SPI> 1.0
I have the answer to this now, thanks!
Hi.
I cannot get the Teensy 4.1 SD card reader to recognise any SD card. I have tried 2 different Teensy 4.1 modules and 8 different sizes and brands of SD card. I've even tried 2 different PC's and USB cables - clutching at straws, I know. I've used the BUILTIN_SDCARD in this and a number of other example programs, but they consistently find 'no card'. The fact that they compile correctly tells me that they are using the correct Teensy SD.h//SDFat.h etc.
The cards all format and read fine on my PC and via a Arduino Mega2560 card reader.
I have an ethernet Magjack wired to both Teensy modules; would this stop it recognising the SD card reader? There are no other peripherals connected.
Well, something must be wrong, because it works great, normally.
No the magjacks are no problem.
chrissaich
Hi.
Hi, I don't have any particular insight, but I've been using the SD reader for a while now and it does work.
Fairly obvious suggestions:
1.Format the SD cards with the official formatter:
https://www.sdcard.org/downloads/formatter/
2. Post pictures and code here. Usually someone gets back with suggestions pretty quickly.
3. Is it possible you damaged something installing the Magjack? Tiny board, hot iron.
Good luck.
Thanks for the replies. I did most of my testing with one SD card which seems to be faulty and when I tried other SD cards, it seems to have been with a program which used the wrong SD.h.
All now working with 7 out of 8 SD cards. The other one works perfectly on PC's but not Teensy.
All good to proceed, thanks for the help.
- You may not post replies
- You may not edit your posts
Forum Rules
