Results 1 to 3 of 3
Thread: Teensy 4.0 multiple I2C devices question
    May 2020
    2
    Hi all.
    I'm working on a project with a Teensy 4.0, BMP280, and BNO055 and am starting my code with some initial checks. I want the code to attempt to connect to the devices and then serial print a message if they are successful or not. I have the code working with the BNO055 but the BMP280 is giving me problems. The BNO055 works as intended and reports depending if it's connected or not but the BNO055 will always report back saying it's connected even if it isn't. If someone could help me diagnose and solve the issue that would be great! Thanks!
    Heres my code:
    #include <Wire.h> //libs
    #include <Adafruit_Sensor.h>
    #include <Adafruit_BNO055.h>
    #include <Adafruit_BMP280.h>
    #include <utility/imumaths.h>
    #include <Servo.h>
    Adafruit_BMP280 bmp; //Puts BMP280 into I2C communication
    Adafruit_Sensor *bmp_temp = bmp.getTemperatureSensor(); //gets temp
    Adafruit_Sensor *bmp_pressure = bmp.getPressureSensor(); //gets pressure
    Adafruit_BNO055 bno = Adafruit_BNO055(55); //defines bno as the BNO055 sensor
    int ledred = 14;    // Red LED connected to digital pin 14
    int ledblu = 15;    // Blue LED connected to digital pin 15
    int ledgrn = 16;    // Green LED connected to digital pin 16
      pinMode(ledred, OUTPUT);
      pinMode(ledblu, OUTPUT);
      pinMode(ledgrn, OUTPUT);
      Serial.begin(9600); //attempt to establish a serial connection
      if(!bno.begin()){ //attempts to establish connection with BNO055 on 0x28
        error("BNO055 FAIL TO CONNECT");
      }else{
        Serial.println("BNO055 SUCESSFULL CONNECTION");
        digitalWrite(ledgrn, HIGH);
      if(!bmp.begin()){ //attempts to establish connection with BMP280 on 0x77
        error("BMP280 FAIL TO CONNECT");
      }else{
        Serial.println("BMP280 SUCESSFULL CONNECTION");
    int error(String err) {
      Serial.println("ERROR - " + err + " - Mission abort"); //prints the error to serial
      digitalWrite(ledred, HIGH);
      while(1); //stops the program until reset
    22,115
    As a quick check, try running the Wire library's Scanner example.
    Does it correctly detect when the BNO055 is disconnected?
    May 2020
    2
    Yup.
    BNO055 on 0x28
    BMP280 on 0x77
    With the scanner I can unplug and plug back in the sensors and they are detected perfectly.
