Does the input have already a Schmitt-Trigger?
Figure 10-5 in the ATMEGA32U4 datasheet seems to say all the digital inputs have schmitt trigger.
Why do you ask? The reason I ask is because what you are asking may not be important to what you need to do.
Can you explain what you are trying to do?
I feed a teensy 2.0 with a external clock of an old device. Some of the devices have a dirty clock signal, so I have to set the low pass filter of the clock lower. This helps on most devices, but on some not.
I notice that, if I change the filter only, get an DC offset of 0.5V and maybe this is too short on the threshold and in some cases it does not work.
I have no idea where the input switch to high and back to low.
If you are looking for an exact value, I think it is somewhat arbitrary by nature.
The problem is that the Schmitt-Trigger is defined internally to the chip, not some dedicated manufactured part.
If you need to know, and it's not in the chip's data sheet, then I would put in a request with technical support at NXP. Even then, they may not have a definitive answer, but that is the best you can do.
Otherwise, you can look up a number of different Schmitt-Trigger chips and take the average, but that is only an educated guess.
Of course, but a sample size of one isn't very telling, statistically speaking.
There may be other factors that could cause that empirical value to change under different conditions, too. That might be a bigger problem if the operation becomes intermittent.
I am guessing it may be better to condition the signal externally than to rely on unpublished functionality. That, and to the best of my knowledge a Schmitt-Trigger only deals with level hysteresis, and that may not help with ringing of a signal.
Sure, but then the OP was talking about a single T2.0 and asking if it was Schmidt Triggered.
