Results 1 to 4 of 4
Thread: Teensy 4.0/4.1, USB Type option "No USB" not present?
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    179
    In the Arduino IDE, for Teensy 3.1/3.2 there is a USB Type option "No USB". For the newer Teensy 4.0/4.1 there is not.
    I searched this forum ofcourse but it would not let me search on "No USB" specifically. It's probably discussed somewhere in the long Teensy-4-0-First-Beta-Test thread...
    I recall reading an answer from Paul on deleting the "All of the above" option, but I don't recall reading on the "No USB" option.
    Does anyone of you know about removing the "No USB' option? And why?
    Related question: is the "RawHID" option identical to the "No USB" option?
    Running Arduino 1.8.12, Teensyduino 1.52, Windows 7.
    Thanks,
    Paul
    6,927
    I am not sure how well the support for No USB is implemented (or not).
    But if you look in the boards.txt file you will see lines like:
    #teensy40.menu.usb.disable=No USB
    #teensy40.menu.usb.disable.build.usbtype=USB_DISABLED
    Which shows they are commented out.
    Have no idea what would happen if you un-comment them.
    I do see a few places in the Teensy4 sources that check for USB_DISABLED
    Apr 2015
    Netherlands
    179
    Thanks Kurt.
    I guess Paul must have had a good reason to uncomment the "No USB" option.
    On my related question: "No USB" really means no USB, not even a HID device. I checked on a T3.2. When active as a "No USB" device, you have to push the program button on the Teensy to get it reprogrammed. The Teensy Loader won't program automatically.
    Addition: it looks like a fresh Teensy 4.1 arrives from the factory as a RawHID device.
    Paul
    11,792
    IIRC - T_4.0 beta started without No_USB by design to assure the 480Mbps stack was tested and working to build the other USB types.
    Uncommenting that may be low priority - or perhaps a reason?
