I've a compiling error with teensy4_i2c library (https://github.com/Richard-Gemmell/teensy4_i2c).
I did a simple code to be sure of it, to do no mistake about it.
About the library, i added it in the libraries directory for teensy and i restarted my arduino IDE. Of course, I didn't modify any files of the original teensy4_i2c library.
After some tests and some tests, and some ..., it's certainly simple but I don't understand why i have this error.
The final purpose is to exchange data between ESP8266 (huzzah 8266 adafruit) and Teensy 4.0.
Need help, please.
Thanks .
Source code
Error
Need help, please.
Thanks .
Source code
#include <Arduino.h>
#include <i2c_driver_wire.h> //not need to add #include <i2c_driver.h> because already include in i2c_driver_wire.h file, and if I include it here, it doesn't change anything for the error compiling
Wire.begin();
Wire.beginTransmission(9);
Wire.write("HELP");
Wire.endTransmission();
Error
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\frv\\AppData\\Local\\Temp\\arduino_build_39783/i2c.ino.elf" "C:\\Users\\frv\\AppData\\Local\\Temp\\arduino_build_39783\\sketch\\i2c.ino.cpp.o" "C:\\Users\\frv\\AppData\\Local\\Temp\\arduino_build_39783\\libraries\\i2c_t4\\i2c_driver_wire.cpp.o" "C:\\Users\\frv\\AppData\\Local\\Temp\\arduino_build_39783\\libraries\\i2c_t4\\i2c_register_slave.cpp.o" "C:\\Users\\frv\\AppData\\Local\\Temp\\arduino_build_39783/..\\arduino_cache_967020\\core\\core_cbcf98d7353d8ae0f0fec04c01711548.a" "-LC:\\Users\\frv\\AppData\\Local\\Temp\\arduino_build_39783" -larm_cortexM7lfsp_math -lm -lstdc++
C:\Users\frv\AppData\Local\Temp\arduino_build_39783\libraries\i2c_t4\i2c_driver_wire.cpp.o: In function `I2CDriverWire::I2CDriverWire(I2CMaster&, I2CSlave&)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\i2c_t4/i2c_driver_wire.cpp:15: undefined reference to `Master'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\i2c_t4/i2c_driver_wire.cpp:15: undefined reference to `Slave'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\i2c_t4/i2c_driver_wire.cpp:15: undefined reference to `Slave1'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\i2c_t4/i2c_driver_wire.cpp:15: undefined reference to `Slave2'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\i2c_t4/i2c_driver_wire.cpp:15: undefined reference to `Master1'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\i2c_t4/i2c_driver_wire.cpp:15: undefined reference to `Master2'
Using library i2c_t4 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\i2c_t4 (legacy)
Error compiling for board Teensy 4.0.
