Results 1 to 3 of 3
Thread: Teensy 4.0 RTC
    May 2020
    3
    Teensy 4.0 RTC
    Iím using the Teensy 4.0 RTC, and I have some strange issue, with keeping the time, the problem is as follows: Iím setting the time using the serial interface (view code), and the Teensy is displaying it correctly, up until now everything is okÖ. But as Iím disconnecting the power from the Teensy and reconnecting it, it is losing one hour, the minutes and the seconds are ok, it is only the hour segment that is missing the time, and it is always losing one hour. Does anyone have any idea?
Name:	Teensy 4.0 rtc.jpg
    Arduino code:
    #include <TimeLib.h> //Teensy time lib
    #define led 14
    #define display Serial1 // nextion display
    int long blink_time; // blinking led
    int long time_display_cycle;
    Serial.begin(115200); Serial.setTimeout(50);
    display.begin(115200);
    pinMode(led, OUTPUT);
    Serial.println("- = Program Starts = - ");
    led_blink(100); // blinking the LED connected on pin 14
    display_clock();
    set_clock();
    time_t getTeensy3Time() {
    return Teensy3Clock.get();
    void led_blink(int t) {
    if (millis() - blink_time >= t) {
    digitalWrite(led, !digitalRead(led));
    blink_time = millis();
    void set_clock() { //setting the time using the serial interface, typ 1 for entering time setting mode
    if (Serial.available() > 0) {
    int data_type;
    data_type = Serial.parseInt();
    if (data_type == 1) {// 1-->clock setting
    Serial.println(Serial.parseInt());
    Serial.println(" -= Time Setting =- ");
    Serial.print("Enter Hour :.....");
    while (Serial.available() == 0) {
    int Hour = int (Serial.parseInt());
    Serial.println(Hour);
    Serial.print("Enter Minutes:.....");
    int Minute = int (Serial.parseInt());
    Serial.println(Minute);
    Serial.print("Day Of Month :.....");
    int Day_month = int (Serial.parseInt());
    Serial.println(Day_month);
    Serial.print("Month :.....");
    int Month = int (Serial.parseInt());
    Serial.println(Month);
    Serial.print("Year :.....");
    int Year = int (Serial.parseInt());
    Serial.println(Year);
    // hours, minutes, seconds, days, months, years
    setTime(Hour, Minute, 0, Day_month, Month, Year);
    else {
    Serial.println("");
    Serial.println("- = Unknown data type = -");
    Serial.println("================================== ==");
    time_display_cycle = 0;
    display_clock();
    void display_clock() {
    if (millis() - time_display_cycle >= 1000) { // display the time once a second
    String _minute;
    String _second;
    String Day;
    if (second() < 10) {
    _second = "0" + String(second());
    else {
    _second = String(second());
    if (minute() < 10) {
    _minute = "0" + String(minute());
    else {
    _minute = String(minute());
    switch (weekday()) {
    case 1:
    Day = "Sun";
    case 2:
    Day = "Mon";
    case 3:
    Day = "Tue";
    case 4:
    Day = "Wed";
    case 5:
    Day = "Thu";
    case 6:
    Day = "Fri";
    case 7:
    Day = "Sat";
    String txt = String(day()) + "/" + String(month()) + "/" + String(year()) + " " +
    String(hour()) + ":" + _minute + " " + Day;
    Serial.println(txt);
    String txt_hmi = String(hour()) + ":" + _minute + ":" + _second;
    display.print("t0.txt="); // update nextion display
    display.write(0x22);
    display.print(txt_hmi);
    display.write(0xff);
    time_display_cycle = millis();
    22,107
    Which version of Teensy Loader are you using. In the small Teensy window, click Help > About (or Teensy > About if using Macintosh) to see the version.
    A bug with daylight savings time was fixed in version 1.52. If you have an older version, update to 1.52.
    May 2020
    3
    That was super quick, I updated to the 1.52, and it runs perfect, thanks.
