khoih-prog
HI @shawn
I opened an issue in the library as QNEthernet and NativeEthernet staticIP not working with WS Server #39
Please check there for more detailed debug terminal output
Basically
1. DHCP is working OK with QNEthernet
2. Static IP is not working OK with QNEthernet
Basically
Starting Teensy41_Client on TEENSY 4.1 using QNEthernet
WebSockets2_Generic v1.10.1
=========== USE_QN_ETHERNET ===========
Initialize Ethernet using DHCP => Connected! IP address:192.168.2.107
[WS] WebsocketsClient::doestStartsWith: str = ws://192.168.2.30:8080
[WS] WebsocketsClient::doestStartsWith: prefix = ws://
[WS] WebsocketsClient::connect: step 1
[WS] WebsocketsClient::generateHandshake: base64Authorization =
[WS] WebsocketsClient::generateHandshake: handshake = GET / HTTP/1.1
Host: 192.168.2.30
Sec-WebSocket-Key: MDEyMzQ1Njc4OWFiY2RlZg==
Upgrade: websocket
Connection: Upgrade
Sec-WebSocket-Version: 13
User-Agent: TinyWebsockets Client
Authorization: Basic
Origin: https://github.com/khoih-prog/Websockets2_Generic
[WS] WebsocketsClient::connect: base64Authorization =
[WS] WebsocketsClient::connect: step 2
[WS] WebsocketsClient::connect: step 3
[WS] WebsocketsClient::connect: step 4
[WS] WebsocketsClient::doestStartsWith: str = HTTP/1.1 101 Switching Protocols
[WS] WebsocketsClient::doestStartsWith: prefix = HTTP/1.1 101
[WS] WebsocketsClient::connect: step 5
[WS] WebsocketsClient::connect: step 6
[WS] WebsocketsClient::generateHandshake: key = Upgrade
[WS] WebsocketsClient::generateHandshake: value = websocket
[WS] WebsocketsClient::generateHandshake: key = Connection
[WS] WebsocketsClient::generateHandshake: value = Upgrade
[WS] WebsocketsClient::generateHandshake: key = Sec-WebSocket-Accept
[WS] WebsocketsClient::generateHandshake: value = BACScCJPNqyz+UBoqMH89VmURoA=
[WS] WebsocketsClient::generateHandshake: key = Origin
[WS] WebsocketsClient::generateHandshake: value = https://github.com/khoih-prog/Websockets2_Generic
[WS] WebsocketsClient::connect: step 7
Connected to server : ws://192.168.2.30:8080
Got Message: Hello Server
Initialize Ethernet using static IP => Connected! IP address:192.168.2.222
[WS] WebsocketsClient::connect: not _connectionOpen, host = 192.168.2.30 , port = 8080
Couldn't connect to server : ws://192.168.2.30:8080
