Trying to use a struct to simplify a function, please help
laptophead
Pardon my inexperience...
I got this robot consisting of 8 motors and I am able to send commands to each of them by this function:
HTML:
void Ev_GoTo_Pos (float M1, float M2, float M3,  float M11, float M12, float M13, float M5, float M6)
{ //Show_Encs();
  if (SendOnce == 0)
    GoTo_Pos (M1, 1);
    GoTo_Pos (M5 * 5, 5);//Neck Tilt
    GoTo_Pos (M11, 11);
    delay (4);  // MUST STAY AT 4 MS for long reply
    GoTo_Pos (M2 * 5, 2);
    GoTo_Pos (M6 * 6, 6);  //neck pan
    GoTo_Pos (M12 * 5, 12);
    delay (4);
    GoTo_Pos (M3 * 4, 3);
    //GoTo_Pos (M7 , 7);
    GoTo_Pos (-M13 * 4, 13);
    delay (4);
    SendOnce = 1;
  ReadENC_Master = 1;
I would like to simplify the 8 arguments by defining waypoints such as :
struct Way_Pt {
float M1;
float M2;
float M3;
float M11;
float M12;
float M13;
float M5;
float M6;
Way_Pt Squat = { -47.4, -103.7, 40.6, 75.2, 100.2, 17.2, 2.0, 0 };
Way_Pt Stand = { -57.9, -84.1, 32.2, 78.8, 80.6, 8.8, -3.9, 2.1};
then I would go
Ev_GoTo_Pos (Stand);
But it does not work, I get:
cannot convert 'Way_Pt' to 'float' for argument '1' to 'void Ev_GoTo_Pos(float, float, float, float, float, float, float, float)'
Ev_GoTo_Pos (Stand); // too fast
Is there smarter way to do this?
You cannot initalize a struct that way, it's not an array.
Also your declaration does not define a type.
This should work (untested):
typedef struct Way_Pt {
float M1;
float M2;
float M3;
float M11;
float M12;
float M13;
float M5;
float M6;
} Way_Pt;
Way_Pt Squat;
Squat.M1 = -47.4;
Squat.M2 = -103.7;
Squat.M3 = 40.6;
...etc...
Ok I tried this
float M1;
float M2;
float M3;
float M11;
float M12;
float M13;
float M5;
float M6;
} Way_Pt;
Way_Pt Squat;
float SquatVals [] = {-47.4, -103.7, 40.6, 75.2, 100.2, 17.2, 2.0, 0 };
Squat.M1 = SquatVals [0];
Squat.M2 = SquatVals [1];
Squat.M3 = SquatVals [2];
Squat.M11 = SquatVals [3];
Squat.M12 = SquatVals [4];
Squat.M13 = SquatVals [5];
Squat.M5 = SquatVals [6];
Squat.M6 = SquatVals [7];
void Ev_GoTo_Pos_Struct (Squat)
{ //Show_Encs();
  if (SendOnce == 0)
    GoTo_Pos (MotorValues.M1, 1);
    GoTo_Pos (MotorValues.M5 * 5, 5);//Neck Tilt
    GoTo_Pos (MotorValues.M11, 11);
    SendOnce = 1;
  ReadENC_Master = 1;
It would not compile
I get
Sw_Cse:28: error: variable or field 'Ev_GoTo_Pos_Struct' declared void
You can't declare an argument of a function like that.
Moreover, you declare Squat but in the function body use MotorValues instead.
Try:
void Ev_GoTo_Pos_Struct (Way_Pt MotorValues)
{ //Show_Encs();
  if (SendOnce == 0)
Actually I discovered that I can use float arrays as function arguments
Problem solved, forget structs
Thanks for your help.
Mitch
Yes, he can. C and C++ totally allows that.
The actual error is this:
He updated the code to pass a struct instead of a lot of floats, but he didn't update the receiving function to take a struct instead of a bunch of floats.
Illustrating with three variables;
struct Waypoint {
  float A;
  float B;
  float C;
void GoToPos(Waypoint const &wp) {
  SendCommand(wp.A, 1);
  SendCommand(wp.B, 2);
  SendCommand(wp.C, 3);
Waypoint wp1 = { 3.0, 4.0, 5.0 };
Waypoint wp2 = { 1.0, 6.0, -2.0 };
  GoToPos(wp1);
  GoToPos(wp2);
Assuming you have a SendCommand() this will work great.
The main thing is changing the function to take a `Waypoint const &` and then to change the uses of the values to use that struct with `wp.A` instead of just `A`.
