MY SETUP ( FM SYNTHESIZER )
HARDWARE :
POT ---> MULTIPLEXER 4067 ---> TEENSY 4.0 + AUDIO SHIELD ---> HEADPHONE ---> MY EARS
SOFTWARE :
What I have been try to proved by my self by research old thread.
Hardware :
1. USB Power Source issue Because Pot and Teensy using the same source ---> Separate Vcc ---> 100nf | 1uf | 10uf coupling between Vcc&Gnd ---> No Change
2. Ground loop ---> I probe at USB power pin and 3.3v pin with AC coupling mode | 50mv div ---> 1mhz - 3mhz noise ---> Probe Lineout --> noisy sin wave
3. Poor Mechanical pot ---> try difference pot ----> Connect Pot directly to teensy without Mux ---> No Change
4. Change Audio Shield ----> No Change
Software :
1. Try to use ResposiveAnalogRead library ---> No Change
2. Try to make Hysteresis or dead band ---> No Change
3. Try to use example from audio library --> Do More While Playing ---> Playing .wav file from sd card ---> Change Amplitude ---> Didn't hear clicking
I'm not sure it's no clicking because Music are louder than clicking and having a lot of detail or Teensy tell me something here ?.
After this I need your help - I like to learn and make a mistake
Tomorrow Plan :
1. In Pure Data if you send Control Signal directly to amplify the output , you will hear the same kind of clicking that I founded in this project. So the solution in Pure Data is [line~] object or Ramp generator, by passing 2 parameter 1. target value 2. ramp_duration and then it will smooth your changing without noise.
So, In Teensy Audio System have an object like Fade but it only have ramp_duration , I have been try it already and again No Change.
My question is :
1. Do you think my Tomorrow Plan will help me from this problem ?
2. Like title Do you think My problem ( Clicking noise coming from hardware or software ?
Ps. Sorry for my English. if you read this message I think you know already please forgive me
HARDWARE :
SOFTWARE :
#define s0 3
#define s1 4
#define s2 9
#define s3 5
AudioSynthWaveformModulated OscA; //xy=1675.8333282470703,313.21425437927246
AudioOutputI2S i2s1; //xy=1899.9999923706055,312.1428861618042
AudioConnection patchCord1(OscA, 0, i2s1, 0);
AudioConnection patchCord2(OscA, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=1851.3332061767578,404.47619438171387
AudioMemory(40);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
OscA.begin(0.5,220,WAVEFORM_SINE);
// SET MULTIPLEXER ADDRESS
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
// no scan to make sure that clicking issure didn't coming form scan rate
digitalWrite(s0, HIGH);
digitalWrite(s1, LOW);
digitalWrite(s2, HIGH);
digitalWrite(s3, LOW);
float vol = (float)analogRead(A10) / 1280 ;
AudioNoInterrupts();
OscA.amplitude(vol);
AudioInterrupts();
Hardware :
Software :
Tomorrow Plan :
My question is :
