I am trying to set up a simple project with a Teensy 4 and an ESP8266 that communicate over I2C to allow some LEDs to be controlled by the Teensy. The rough idea is something like this:
Where the two Teensy's at the end are controlling some LED strips via WS2812Serial based on the commands they receive. After failing to get anything working I broke the project down into the smallest test setup that I could and it looks like this (although a Teensy 4 instead of a Teensy 3.1):
In this configuration I am unable to get the two devices to talk to each other in either master/slave or slave/master configuration. If I set up one as a slave and then use the scanner I get back 0 devices. Curiously, if I replace the Teensy with an Arduino Uno OR I replace the ESP8266 with an Arduino Uno then they are able to communicate without any issues. At this point I feel like it must be related to the logic levels somehow but I'm confused about that.
I know that applying 5v to the Teensy or the ESP8266 can damage them so using the Uno for testing is a bit of a gamble but so far everything has held up ok. I've tried adding pullup resistors to both the SDA and SCL lines (I only had about 4 ~1k on hand so I used two on each without any difference in behavior). I also tried a 10k and that didn't seem to help either (but honestly I don't know enough to confidently say what values I should be using or how to tell if they are working).
I have a logic level converter on hand that I can use if anyone thinks it might help but I'm very confused about why the 3v signals between the Teensy and the ESP8266 wouldn't work on their own. I think since I'm not planning on using an Arduino for this project I shouldn't need to use the logic level shifter at all?
The code I'm using for my tests are just the basic Master_Sender and Slave_Receiver examples from the Wire library, nothing else fancy at the moment. Does anyone have any tips, suggestions or ideas about what I might be doing wrong here? Even just additional thoughts on what I can troubleshoot would be greatly appreciated. Thank you!
