Results 1 to 5 of 5
Thread: It won't compile to a Teensy 3.5
    Jun 2020
    2
    Error asks me to add the Teensy 3.5 to the Boards Library.
    My friend has been able to compile and run this sketch without issues.
    I've gone as far as loading everything onto a recently acquired and clean computer but I'm getting the same errors.
    I'm lost!!
    Please have a look.
    Thanks.
    Alex
    Arduino: 1.8.11 (Windows 8.1), TD: 1.52, Board: "Teensy 3.5, Serial + MIDI, 120 MHz, Faster, US English"
    In file included from C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playgroun d/utility/CP_Firmata.h:17:0,
    from C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playgroun d/Adafruit_Circuit_Playground.h:25,
    from C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playgroun d/Adafruit_CircuitPlayground.h:3,
    from C:\Hurdy Gurdy\Digi Gurdy\Teensy\DGcodeV77newScreenNewSong\DGcodeV77ne wScreenNewSong.ino:1:
    C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playgroun d/utility/CP_Boards.h:746:2: error: #error "Please edit CP_Boards.h with a hardware abstraction for this board"
    Multiple libraries were found for "Adafruit_GFX.h"
    Used: C:\Program
    Not used: C:\Users\Alex\Documents\Arduino\libraries\Adafruit _GFX_Library
    Error compiling for board Teensy 3.5.
    1,357
    Which board did your friend compile the code for?
    CP_Boards.h doesn't appear to know about the Teensy 3.5. It only has Teensys up to T3.2.
    Pete
    Jun 2020
    2
    I watched him compile/ load to a Teensy 3.5.
    However, since posting my question, I have tried a slightly older sketch and it WORKS!
    Now to figure out where the difference (glitch) is.
    Sorry to not have tried this before (4 days ago when all this trouble began).
    This is my first Arduino project though I have actually built (very early) computers years ago.
    Thanks for your input, Pete.
    Alex
    1,357
    There is an oddity in the output here:
    Used: C:\Program
    This implies that you have a copy of the file Adafruit_GFX.h in C:\Program instead of in your C:\Program Files (x86)\Arduino\libraries directory. Is it supposed to be in C:\Program ?
    Pete
    22,101
    Why are you using CP_Firmata.h rather than regular Firmata.h ?
