Results 1 to 5 of 5
Thread: Serial monitor output unexpectedly stops
    When outputting a substantial amount of text to the Serial Monitor I've been experiencing an issue where the output will just truncate and stop appearing. Here's a super simple sketch that generates the problem (I'm running this on a new Teensy 4.1, with the CPU speed set to 396MHz, and Optimize set to "Fast")...
      for (int i = 0; i < 500; i++) {
        Serial.print("Another number: ");
        Serial.println(i);
    After the expected output appears in the Serial Monitor for a few hundred lines, it just dies. Here's the end of the output...
    Another number: 386
    Another number: 387
    Another number: 388
    Another number: 389
    Another number: 390
    Another number: 391
    Another number: 392
    Another number: 393
    Another number: 394
    Another
    There are no errors during compilation (not surprising, considering how simple the sketch is). Anyone have any idea what's going on? THANKS!
    11,800
    Putting that on a currently active Teensy LC works fine. The T_4.1 at 480 Mbps is way faster than that at 12 Mbps.
    The change below - waits for Serial before printing. Without that the T_4.1 here showed nothing of the prints 0-499.
      while (!Serial && millis() < 2000) ; // wait
        Serial.println(i);
    22,110
    Are you using Mac, Linux or Windows. Which version? If Linux, double check you have the latest udev rules (they were updated months ago for a new ModemManger bug).
        Serial.println(i);
    Thanks, I'll try that!
    I'm on Mac. Thanks!
