Hello all,
I want the PWM waveforms from FTM0 and FTM3 to be toggled between two values each in period. I have set up the initializations of the timers and synchronized them with each other. Also, I have a separate function that does the PWM update by writing new values to the CnV registers of both FTMs. The issue I have is that between 2 specific values, the update does not occur for 1 FTM but occurs for the other. If I toggle between other values, the update works perfectly.
I don't understand the problem since some times the update happen and some times it does not.
I have the code below: [Note: MOD has the value of 599.]
FTM0:
void initFTM0(void) {
  SIM_SCGC6    |= 0x01000000;
  SIM_SCGC5    |= 0x3E00;
  FTM0_SC       = 0x00;
  FTM0_CONF     = 0xC0;
  FTM0_FMS      = 0x00;
  FTM0_MODE    |= 0x05;
  FTM0_C0SC     = 0x28;
  FTM0_C1SC     = 0x28;
  FTM0_C2SC     = 0x28;
  FTM0_C3SC     = 0x28;
  FTM0_COMBINE  = 0x0303;
  FTM0_COMBINE |= 0x1010;
  FTM0_COMBINE |= 0x2020;
  FTM0_DEADTIME = 0x3;
  FTM0_CNT      = 0x00;
  FTM0_CNTIN    = 0x00;
  FTM0_MOD      = MOD;
  FTM0_SYNC     = 0x02;
  PORTC_PCR1    = 0x400;
  PORTC_PCR2    = 0x400;
  PORTC_PCR3    = 0x400;
  PORTC_PCR4    = 0x400;
  FTM0_C0V      = (MOD+1)/2;
  FTM0_C1V      = (MOD+1);
  FTM0_C2V      = 0;
  FTM0_C3V      = (MOD+1)/2;
FTM3:
void initFTM3(void) {
  SIM_SCGC3    |= 0x02000000;
  FTM3_SC       = 0x00;
  FTM3_CONF     = 0xC0;
  FTM3_FMS      = 0x00;
  FTM3_MODE    |= 0x05;
  FTM3_C0SC     = 0x28;
  FTM3_C1SC     = 0x28;
  FTM3_C2SC     = 0x28;
  FTM3_C3SC     = 0x28;
  FTM3_C4SC     = 0x68;
  FTM3_C5SC     = 0x28;
  FTM3_COMBINE  = 0x030303;
  FTM3_COMBINE |= 0x1010;
  FTM3_COMBINE |= 0x202020;
  FTM3_DEADTIME = 0x00;
  FTM3_CNT      = 0x00;
  FTM3_CNTIN    = 0x00;
  FTM3_MOD      = MOD;
  FTM3_SYNC     = 0x02;
  PORTD_PCR0    = 0x400;
  PORTD_PCR1    = 0x400;
  PORTD_PCR2    = 0x400;
  PORTD_PCR3    = 0x400;
  PORTC_PCR8    = 0x300;
  PORTC_PCR9    = 0x300;
  FTM3_C0V      = (MOD+1)/2;
  FTM3_C1V      = (MOD+1)/2;
  FTM3_C2V      = 0;
  FTM3_C3V      = (MOD+1);
  FTM3_C4V      = (MOD+1)/2 - 8;
  FTM3_C5V      = (2*(MOD+1))/2 - 8;
FTM syncing:
void syncFTMs(void) {
  FTM0_CONF |= 0x200;
  FTM3_CONF |= 0x200;
  FTM0_SYNCONF |= 0x80;
  FTM3_SYNCONF |= 0x80;
  FTM0_SC = 0x48;
  FTM3_SC = 0x08;
  FTM0_CONF |= 0x400;
Register update:
void phase_modulator(void) {
  //toggle is a global variable with initial value of false
  if (!toggle) {
    Phi = 270;
    toggle = !toggle;
  else if (toggle) {
    Phi = 240;
    toggle = !toggle;
  FTM0_C0V   = (MOD+1)/2 - Phi;
  FTM0_C1V   = (MOD+1)   - Phi;
  FTM0_C2V   = 0;
  FTM3_C0V   = (MOD+1)/2 - Phi;
  FTM3_C2V   = 0;
  FTM3_C3V   = (MOD+1)   - Phi;
  FTM3_C4V   = ((MOD+1) - Phi)/2 - 8;
  FTM3_C5V   = (2*(MOD+1) - Phi)/2 - 8;
  FTM0_PWMLOAD |= 0x20F;
  FTM3_PWMLOAD |= 0x20F;
ISR of FTM0:
void ftm0_isr(void) {
  phase_modulator();
  asm("nop");
In the function phase_modulator(), if I use any value other than Phi=270, sometimes only FTM0 gets the update, other times only FTM3.
This is a weird issue really and I don't know if anyone can reproduce it because it happens to me occasionally.
Does anyone know why this happens? I followed the PWM synchronization guidelines in the manual.
Thanks in advance.
