Page 2 of 2 FirstFirst 1 2
Results 26 to 36 of 36
Thread: triangle & sawtooth oscillators : how to deal with aliasing ?
  1. #26
    Jul 2020
    398
    Triangle waves don't behave as badly as the discontinuity is 2nd-order, pulse type I've not looked at. It may be an easy
    generalization of square wave or not, hopefully the former.
  2. #27
    Apr 2019
    110
    Yes, triangles sound fine. The variable triangle wave can be varied to a sawtooth and reverse sawtooth, I imagine trying to band-limit at just those points is a pain. The square and sawtooth are a fantastic improvement that people have been requesting for several years.
  3. #28
    Jul 2020
    398
    And the latest changes to the branch support WAVEFORM_BANDLIMIT_PULSE !
    My sanity was restored by finding an online midi file of Toccata and Fugue in D-minor to replace the William Tell score array
    in the PlaySynthMusic example BTW!
  4. #29
    Apr 2019
    110
    Great! I'll test. Yes, I was reminded of Walter/Wendy Carlos and Clockwork Orange while listening to it...
  5. #30
    Jul 2020
    398
    Released another change, sets the WAVEFORM_BANDWIDTH_PULSE DC offset to match the duty cycle to greatly reduce pumping effect on note attach/release.
    It might cause issues with rapidly modulated pulse widths though as its not sophisticated! Compare it to the original PULSE to see what I mean.
    Because of the shift in offset the amplitude necessarily has to be a lot lower than the existing PULSE waveform.
  6. #31
    Apr 2019
    110
    Hello Mark. Square and sawtooth are great, the pulse wave is fine until there's any sort of modulation, even around 0.5Hz. There's digital noise that isn't regular but often. Can it be improved? Many thanks for all your work on the Audio Library.
    Manual adjustment and then lfo:
    pulsewave.wav
    // demonstrate pulse with slow changes in pulse width
    const float NOTEFREQS[128] = {8.176, 8.662, 9.177, 9.723, 10.301, 10.913, 11.562, 12.25, 12.978, 13.75, 14.568, 15.434, 16.352, 17.324, 18.354, 19.445, 20.602, 21.827, 23.125, 24.5, 25.957, 27.5, 29.135, 30.868, 32.703, 34.648, 36.708, 38.891, 41.203, 43.654, 46.249, 48.999, 51.913, 55, 58.27, 61.735, 65.406, 69.296, 73.416, 77.782, 82.407, 87.307, 92.499, 97.999, 103.826, 110, 116.541, 123.471, 130.813, 138.591, 146.832, 155.563, 164.814, 174.614, 184.997, 195.998, 207.652, 220, 233.082, 246.942, 261.626, 277.183, 293.665, 311.127, 329.628, 349.228, 369.994, 391.995, 415.305, 440, 466.164, 493.883, 523.251, 554.365, 587.33, 622.254, 659.255, 698.456, 739.989, 783.991, 830.609, 880, 932.328, 987.767, 1046.502, 1108.731, 1174.659, 1244.508, 1318.51, 1396.913, 1479.978, 1567.982, 1661.219, 1760, 1864.655, 1975.533, 2093.005, 2217.461, 2349.318, 2489.016, 2637.02, 2793.826, 2959.955, 3135.963, 3322.438, 3520, 3729.31, 3951.066, 4186.009, 4434.922, 4698.636, 4978.032, 5274.041, 5587.652, 5919.911, 6271.927, 6644.875, 7040, 7458.62, 7902.133, 8372.018, 8869.844, 9397.273, 9956.063, 10548.08, 11175.3, 11839.82, 12543.85};
    AudioOutputUSB           usbAudio;       //xy=2356,593
    AudioSynthWaveformModulated       waveform1;      //xy=188,240
    AudioSynthWaveform       pwmWave;      //xy=188,240
    AudioEffectEnvelope      envelope1;      //xy=371,237
    AudioOutputI2S           i2s1;           //xy=565,241
    AudioConnection          patchCord1(pwmWave, 0, waveform1, 1);
    AudioConnection          patchCord6t(waveform1, envelope1);
    AudioConnection          patchCord2(envelope1, 0, i2s1, 0);
    AudioConnection          patchCord3(envelope1, 0, i2s1, 1);
    AudioConnection          patchCord4(envelope1, 0, usbAudio, 0);
    AudioConnection          patchCord5(envelope1, 0, usbAudio, 1);
    AudioControlSGTL5000     audioShield;     //xy=586,175
    void setup(void) {
      // Set up
      AudioMemory(8);
      audioShield.enable();
      audioShield.volume(0.40);
      pwmWave.begin(0.8f, 0.5f, WAVEFORM_SINE);
      // waveform1.begin(0.4, 220, WAVEFORM_PULSE);
      waveform1.begin(0.4, 220, WAVEFORM_BANDLIMIT_PULSE);
      envelope1.attack(50);
      envelope1.decay(50);
      envelope1.release(250);
      usbMIDI.setHandleNoteOff(myNoteOff);
      usbMIDI.setHandleNoteOn(myNoteOn);
    void myNoteOn(byte channel, byte note, byte velocity) {
      waveform1.frequency(NOTEFREQS[note]);
      envelope1.noteOn();
    void myNoteOff(byte channel, byte note, byte velocity) {
      envelope1.noteOff();
      usbMIDI.read(); //USB Client MIDI
  7. #32
    Jul 2020
    398
    Quote Originally Posted by UHF View Post
    Thanks for testing - and I've reworked the pulse code to be much better - it should have fixed modulation issues and I've
    improved the generality by allows arbitrarily fine pulses and fixed the DC-offset compensation to actually be scaled
    correctly (so the modulation frequency shouldn't generate a hum component, upto a point).
    The pulse shape modulation is now sampled at the rising edge of the pulse waveform so its no longer a moving target while
    processing samples (its hard enough when just the phase increment is arbitrary!). I've not run your code but have been
    using simultaneous FM and pulse modulation a fair bit with pulse modulation at full amplitude.
    [ Scope shot: Click image for larger version.
  8. #33
    Apr 2019
    110
    Beautiful! Thanks...
  9. #34
    Oct 2019
    16
    Seems like different people are working in parallel at the same problems
    I recently created a polyBLEP oscillator, you might have a look at it (https://forum.pjrc.com/threads/62240...ited-hard-sync)
    Apparently i was too fast with opening a new thread as there are already posts on bandlimited waveforms!
  10. #35
    Apr 2019
    110
    Hard sync! Great, I'll have play.
  11. #36
    Jul 2020
    398
    Had a play with my spectrum analyzer today (it rolls off below 9kHz so not great for audio, but has a resolution bw down to 1Hz so it can
    pick up a lot).
    Audio lib's standard sawtooth spectrum:
    And my band-limited version:
    Which shows the power of a bandlimited step of reasonable resolution...
    The cutoff is below the SGTL5000's in-built filtering point, and much stronger,
    completely knocking out the 5th harmonic at 20kHz
    I must try this out on flo's PolyBLOB too.
