Results 1 to 11 of 11
Thread: Array handling in the audio tool.
    Dec 2019
    129
    Is array declaration on the roadmap for audio tool development? It would be of some use for more complicated designs, as currently you can't declare arrays of wavetables and fill that array with declared wavetables and have it work... the only workaround I have found is to manually instantiate the arrays and patch chords, which when you have hundreds of these connections can be quite tedious.
    Sep 2019
    Sevilla, Spain
    22
    the audio tool does not support arrays of objects, but you could manage anything done with the design tool making an array of pointers,
    AudioSynthSimpleDrum     drum0;          //xy=219,42
    AudioSynthSimpleDrum     drum1;          //xy=219,162
    AudioSynthSimpleDrum     drum2;          //xy=219,282
    AudioSynthSimpleDrum     drum3;          //xy=219,402
    AudioSynthSimpleDrum     drum4;          //xy=219,522
    AudioSynthSimpleDrum     drum5;          //xy=219,642
    AudioSynthSimpleDrum     drum6;          //xy=219,762
    AudioSynthSimpleDrum     drum7;          //xy=219,882
    AudioSynthSimpleDrum     *drum[8] = {
      &drum0, &drum1, &drum2, &drum3, &drum4, &drum5, &drum6, &drum7 };
    and then use it like this
      drum[x]->frequency( y );
      drum[x]->noteOn();
    does it help?
    Dec 2019
    129
    Yes, ty. I realized this the other day when I started working on my wavetable project again. It would be nice to add this info somewhere in the audio tool documentation because it seems a common issue. Given the processing power of the t4 4.1 platforms array support would be nice but the workarounds presented on the forum are helpful. IDK why I'm always asking the forum for things I could prob do my lazy self, lol. I imagine PJRC has their hands full with well designing teensy and writing large swathes of the library. Ty for your reply and cheers!
    Apr 2020
    Tucson
    135
    In the designer tool you can declare names like mixer[1] instead of mixer1, mixer2, etc. The design tool still sucks for this when copying and pasting, requiring you to manually go back and change all the mixer[0]1 (for example) to mixer[2] because the copy paste doesn't understand the notation. Aside form this limitation, the design tool will properly create all the wire connections and such. However, when I tried this I could not get it to work even after a MyControlArray* = new MyControlArray[n] declaration. If you could make a simple sketch that shows this working I can build a python script to handle the rest of the automation. Python and bash are my forte.
    Dec 2019
    129
    Quote Originally Posted by boxxofrobots View Post
    So like this:
    in audio tool you make mixer[1] mixer[2] mixer[3] mixer[4]
    comment out the auto gui declared mixer[1] mixer[2] mixer[3] mixer[4]
    do not comment out the patchchord connections, only the variable declarations
    then right below your */*/ block
    declare the pointer array like this: AudioMixer4* mixer = new AudioMixer4[4];
    it must have the same name as the dummy audio tool declarations.
    Hope that clarifies it!
    Dec 2019
    129
    if you still have difficulty pls post your code and I will help correct it
    May 2019
    Brisbane, QLD
    104
    Quote Originally Posted by RABB17 View Post
    There's nothing inherently different dealing with arrays inside vs outside audio library from my experience.
    I find it's easier to declare and initialize the array in the .cpp file of your audio object, and reference it outside with extern.
    i.e inside audio object .cpp;
    float variable1[16];
    outside;
    extern float variable1[];
    Dec 2019
    129
    extern? my god c++ is so ugly XD
    Dec 2019
    129
    frankenlanguage. idk whats worse, garbage syntax or garbage collectors
    Jun 2020
    Sweden
    62
    You can check my code at github https://github.com/manicken/teensy4.0polysynth
    It have 3 osc + wavetable player for each "voice" and also have one mixer in the class, note the pointer use for the Audioconnection, without this pointer-use the audio dont work.
