Results 1 to 7 of 7
Thread: Teensy 4.1 WiFi (Howto)
    Apr 2020
    Germany, NRW
    86
    Hi all,
    today my new parts arrived including an Adafruit Airlift Feather so i decided to connect the Teensy 4.1 to my WLAN.
    (I think this would also work with Teensy 4.0)
    Here is a bit of an advanced howto, proceed at your own risk, soldering skills are required!
    Hardware needed:
    AirLift FeatherWing ESP32
    https://www.adafruit.com/product/4264
    Teensy Feather Adapter
    https://www.adafruit.com/product/3200
    Stacking Headers for the Teensy/Airlift, or what i used:
    FeatherWing Doubler - Prototyping Add-on For All Feather Boards
    https://www.adafruit.com/product/2890
    (Also available from other suppliers)
    The prepared parts will look like this:
    Note: On the AirLift you might need to solder the pads near ESPGPIO0.
    I did not get it working without soldering the pads but it might be worthwhile to try without first.
    You need this Library:
    https://github.com/adafruit/WiFiNINA
    I used version 1.3.0 of this library.
    If you use Teensyduino i think following the instructions on
    https://learn.adafruit.com/adafruit-...or-featherwing
    should be helpful. I used PlatformIO, where you have to add this line to the file platformio.ini in your project dir:
    lib_deps = https://github.com/adafruit/WiFiNINA/#1.3.0
    You need to apply this patch to the Adafruit WiFiNINA library to make it work with Teensy4:
    diff --git a/src/utility/spi_drv.cpp b/src/utility/spi_drv.cpp
    index ff89d41..3884f30 100644
    --- a/src/utility/spi_drv.cpp
    +++ b/src/utility/spi_drv.cpp
    @@ -81,6 +81,14 @@ void SpiDrv::begin()
           SLAVERESET = (uint8_t)SPIWIFI_RESET;
    +#ifdef ARDUINO_TEENSY41
    +#define SLAVESELECT  5
    +#define SLAVERESET   6
    +#define SLAVEREADY   9
    +#define NINA_GPIO0  10
    +#endif
    +#ifndef ARDUINO_TEENSY41
     #ifdef ARDUINO_SAMD_MKRVIDOR4000
           inverted_reset = false;
     #else
    @@ -88,6 +96,7 @@ void SpiDrv::begin()
             inverted_reset = true;
             SLAVERESET = ~SLAVERESET;
    +#endif
    Then you should be able to compile and upload this sketch:
    #define SPIWIFI        SPI  // The SPI port
    #include <Arduino.h>
    #include <WiFiNINA.h>
    const char *ssid = "YOUR_SSID_HERE";
    const char *pass= "YOUR_PASSWORD";
    int status = WL_IDLE_STATUS;     // the Wifi radio's status
    void printMacAddress(byte mac[]) {
      for (int i = 5; i >= 0; i--) {
        if (mac[i] < 16) {
          Serial.print("0");
        Serial.print(mac[i], HEX);
        if (i > 0) {
          Serial.print(":");
    void printWifiData() {
      // print your board's IP address:
      IPAddress ip = WiFi.localIP();
      Serial.print("IP Address: ");
      Serial.println(ip);
      Serial.println(ip);
      // print your MAC address:
      byte mac[6];
      WiFi.macAddress(mac);
      Serial.print("MAC address: ");
      printMacAddress(mac);
    void printCurrentNet() {
      // print the SSID of the network you're attached to:
      Serial.print("SSID: ");
      Serial.println(WiFi.SSID());
      // print the MAC address of the router you're attached to:
      byte bssid[6];
      WiFi.BSSID(bssid);
      Serial.print("BSSID: ");
      printMacAddress(bssid);
      // print the received signal strength:
      long rssi = WiFi.RSSI();
      Serial.print("signal strength (RSSI):");
      Serial.println(rssi);
      // print the encryption type:
      byte encryption = WiFi.encryptionType();
      Serial.print("Encryption Type:");
      Serial.println(encryption, HEX);
      //Initialize serial and wait for port to open:
      while (!Serial) {
        ; // wait for serial port to connect. Needed for native USB port only
      SPI.begin();
      // check for the WiFi module:
      if (WiFi.status() == WL_NO_MODULE) {
        Serial.println("Communication with WiFi module failed!");
        // don't continue
        while (true);
      String fv = WiFi.firmwareVersion();
      if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
        Serial.println("Please upgrade the firmware!");
      // attempt to connect to Wifi network:
      while (status != WL_CONNECTED) {
        Serial.print("Attempting to connect to WPA SSID: ");
        Serial.println(ssid);
        // Connect to WPA/WPA2 network:
        status = WiFi.begin(ssid, pass);
        // wait 5 seconds for connection:
        delay(5000);
      // you're connected now, so print out the data:
      Serial.print("You're connected to the network.");
      printCurrentNet();
      printWifiData();
      // check the network connection once every 10 seconds:
      delay(10000);
      printCurrentNet();
    If it works it should look like this in the serial monitor:
    Attempting to connect to WPA SSID: bs_XXXXX
    You're connected to the network.SSID: bs_XXXXX
    BSSID: D0:03:4B:XX:XX:XX
    signal strength (RSSI):-62
    Encryption Type:4
    IP Address: 192.168.178.40
    192.168.178.40
    MAC address: A4:CF:12:XX:XX:XX
    SSID: bs_XXXXX
    Encryption Type:4
    In the terminal window:
    ms@braeburn:WiFiNINA #5009 22:28 :) ping 192.168.178.40
    PING 192.168.178.40 (192.168.178.40): 56 data bytes
    64 bytes from 192.168.178.40: icmp_seq=0 ttl=255 time=188.952 ms
    64 bytes from 192.168.178.40: icmp_seq=1 ttl=255 time=121.472 ms
    64 bytes from 192.168.178.40: icmp_seq=2 ttl=255 time=38.590 ms
    64 bytes from 192.168.178.40: icmp_seq=3 ttl=255 time=250.641 ms
    64 bytes from 192.168.178.40: icmp_seq=4 ttl=255 time=167.443 ms
    Caveat: Sometime it does not find the ESP32, i think it could benefit from some SPI pullup resistors, but i am not sure
    which values to use and where exactly. Did not look at Paul's SPI recommendation page today.
    Apr 2020
    Germany, NRW
    86
    PS:
    I think that issue with the SPI pullups might actually be true. I remembered that the FeatherWing Logger has pull-ups, so i stacked another module. It looks gross now but worked at the first try.
    Apr 2020
    Germany, NRW
    86
    I forked the lib fresh from master which looks better than the 1.3.0 version and applied a new patch to make it work out of the box.
    https://github.com/gounselor/WiFiNINA
    So please replace the github.com url in the first posting an report if it works for you.
    Apr 2020
    Germany, NRW
    86
    More investigation reveals, that you can in fact use the Adafruit library https://github.com/adafruit/WiFiNINA
    but you should use master and add this on top of the sketch:
    #if defined(TEENSYDUINO)
      #define SPIWIFI_SS     5   // Chip select pin
      #define ESP32_RESETN   6   // Reset pin
      #define SPIWIFI_ACK    9   // a.k.a BUSY or READY pin
      #define ESP32_GPIO0   -1
    And this in setup():
    WiFi.setPins(SPIWIFI_SS, SPIWIFI_ACK, ESP32_RESETN, ESP32_GPIO0, &SPIWIFI);
    Besides i still have the issue that it works only with the added AdaLogger feather even after adding two 10k pull-ups on CS and MOSI.
    Any clues?
    Jan 2021
    2
    Hiya, I wondered if anyone has had any more progress I this? I've run through all the steps and not having any joy (am currently waiting on delivery of an Adalogger) Can anyone give guidance on an alternative to using the logger?
    Jan 2021
    2
    Laptop USB power sufficient for this setup?
    Quote Originally Posted by Asteroider View Post
    Also I was wondering if the USB port on my laptop would provide sufficient power to run this setup? (given that the instructions here rely on response via the serial monitor)
    Or would it be prudent to add an aditional power supply?
    I'm a bit of a NOOB with this stuff. I've been tinkering with Arduino for 10 or 15 years with reasonabel success but this is a bit of stretch for me :-) so I'm grateful for any assistance
    Cheers
    Feb 2019
    6
    This seems like it would be an attractive solution, however, I'm still pretty confused as to the rationale behind the stacking configuration. If you line up the teensy 4.1 or 3.6 with the featherwing the pins as referenced for the airlift don't seem to match. In the original post, the pins that cut vertically across the teensy are at the edge while the feather adapter has them more centrally located?
    If this is the case, is the OP suggesting we use some other MISO/MOSI pin set? Or is this poor coupling due to the pull-ups?
    https://cdn-shop.adafruit.com/1200x900/3200-04.jpg
