timing problem (midi note On/Off)
Qcontinuum
New member
Goodmorning everyone.
I am writing to find a pious soul to help me with this problem (I state that I have been researching for days).
I have a code that is almost fully functional to create a step sequencer (16 steps that are activated with a time calculated in bpm and functional).
I use a bpm calculation that is entered via a "tap tempo" and two buttons, one that increases and one that decreases the tempo in 1 bpm steps.
My problem is the following:
I state that I am using, for the midi, the "control_surface" library and a teensy 3.5 card that natively uses the midi via usb (although everything also works with an arduino with the modified firmware).
For each step I send a MidiNoteOn and a MidiNoteOff that go to drive my video software (I also need the noteoff to release the clips I'm going to triggherare).
For the NoteOn there are no problems, it is sent correctly, however, obviously sending an on and off signal are consecutively sent at the same time, I would need to understand how to insert a delay (without DELAY) in each step so that the all send "NoteON - Delay - NoteOff".
if (!played) {
      midi.update();
    if (stepNum == 0 && state1 == 1) {
      Serial.print("  primo_step  ");
      midi.sendNoteOn(noteAddress0, velocity);
      midi.sendNoteOff(noteAddress0, velocity);
    played = true;
    if (stepNum == 1 && state2 == 1 ) {
     Serial.print("  secondo_step  ");
      midi.sendNoteOn(noteAddress1, velocity);
      midi.sendNoteOff(noteAddress1, velocity);
    played = true;
   if (stepNum == 2 && state3 == 1) {
      Serial.print("  terzo_step  ");
      midi.sendNoteOn(noteAddress2, velocity);
      midi.sendNoteOff(noteAddress2, velocity);
    played = true;
    if (stepNum == 3 && state4 == 1) {
      Serial.print("  quarto_step  ");
      midi.sendNoteOn(noteAddress3, velocity);
      midi.sendNoteOff(noteAddress3, velocity);
    played = true;
 if (stepNum == 4 && state5 == 1) {
      Serial.print("  quinto_step  ");
      midi.sendNoteOn(noteAddress4, velocity);
      midi.sendNoteOff(noteAddress4, velocity);
    played = true;
    if (stepNum == 5 && state6 == 1) {
      Serial.print("  sesto_step  ");
      midi.sendNoteOn(noteAddress5, velocity);
      midi.sendNoteOff(noteAddress5, velocity);
    played = true;
    if (stepNum == 6 && state7 == 1) {
      Serial.print("  settimo_step  ");
      midi.sendNoteOn(noteAddress6, velocity);
      midi.sendNoteOff(noteAddress6, velocity);
    played = true;
   if (stepNum == 7 && state8 == 1) {
      Serial.print("  ottavo_step  ");
      midi.sendNoteOn(noteAddress7, velocity);
      midi.sendNoteOff(noteAddress7, velocity);
    played = true;
       if (stepNum == 8 && state9 == 1) {
      Serial.print("  nono_step  ");
      midi.sendNoteOn(noteAddress8, velocity);
      midi.sendNoteOff(noteAddress8, velocity);
    played = true;
    if (stepNum == 9 && state10 == 1 ) {
     Serial.print("  drcimo_step  ");
      midi.sendNoteOn(noteAddress9, velocity);
      midi.sendNoteOff(noteAddress9, velocity);
    played = true;
 if (stepNum == 10 && state11 == 1) {
      Serial.print("  undicesimo_step  ");
      midi.sendNoteOn(noteAddress10, velocity);
      midi.sendNoteOff(noteAddress10, velocity);
    played = true;
    if (stepNum == 11 && state12 == 1) {
      Serial.print("  dodicesimo_step  ");
      midi.sendNoteOn(noteAddress11, velocity);
      midi.sendNoteOff(noteAddress11, velocity);
    played = true;
 if (stepNum == 12 && state13 == 1) {
      Serial.print("  tredicesimo_step  ");
      midi.sendNoteOn(noteAddress12, velocity);
      midi.sendNoteOff(noteAddress12, velocity);
    played = true;
    if (stepNum == 13 && state14 == 1) {
      Serial.print("  quattordicesimo_step  ");
      midi.sendNoteOn(noteAddress13, velocity);
      midi.sendNoteOff(noteAddress13, velocity);
    played = true;
    if (stepNum == 14 && state15 == 1) {
      Serial.print("  quindicesimo_step  ");
      midi.sendNoteOn(noteAddress14, velocity);
      midi.sendNoteOff(noteAddress14, velocity);
    played = true;
   if (stepNum == 15 && state16 == 1) {
      Serial.print("  sedicesimo_step  ");
      midi.sendNoteOn(noteAddress15, velocity);
      midi.sendNoteOff(noteAddress15, velocity);
    played = true;
This is the part that sends the midi notes at each step:
stepNum is the step number
played is a bool that says the step has been performed
state is put in &&, I send notes only if the button for the step has been pressed and brought state from 0 to 1.
Serial.println is only for debugging on the serial monitor.
I will give you an example:
Setting the bpm to 60 (therefore one step every second), the reading of the millis at each step increases by 1000 ms, I need to understand the mechanism by which I can tell him: the step has started, send MidiNoteOn, wait for total ms and send MidiNoteOff. (I can't put the note off in the next step before the note on because it would get me all wrong).
If anyone wants to lose 10 minutes I'm here, if you need other code or explanations, write as well.
Another little question: it would be better if you use the native midi commands in teensy or if using an external library does not cause problems?
I hope to be able to make a nice post with a 100% working step sequencer as soon as possible, this is the last game to overcome.
Thank you all.
Without seeing all your code it is hard to know what is happening but *after* each if statement you set played = true. But this sets played to true whether or not you sent the note on and off. Each if statement should presumably look like this:
      played = true;
Pete
Played is referred to step, not to note.
I have 16 buttons, every button pressed sets state(in your case 1) to 1 and only if state is 1 sends note on and note off.
I'm trying to figure out how delay note on and note off, not with "delay" because I have a timing to follow.
Entire step sequencer is work in progress, code is a bit confused but working... I try to post it tomorrow
