MIMRT1062 Serial Downloader
john_c_kennedy
I've been reading the RM so I'm just curious, does anyone know:
Does Teensy4.x respond to the serial download protocol used by the on chip serial downloader described in section 9.9 pg. 268 of the RM?
If so, is this the protocol the the Teensy4.x loader uses? Or does the MKL02 take over on boot?
If not then I assume none of the NXP tools like blhost will work for downloading to Teensy4.x?
Thanks,
John
I have read some incorrect statements regarding the serial downloader on the forum.
The USB serial downloader is fully functionnal, only the UART variant is disabled in the fuses (not tested, I only use USB).
To enter in serial downloader mode, you have to put an invalid image in the flash memory. Writing 0x00000000 at the beginning is enough. You can build a dumb .hex file to load with teensy loader.
Once this image is flashed, the Teensy 4 board will always enter in USB downloader mode at power-up, unlike what I read on an other topic.
Then, you can use the sdphost utility (VID/PID: 0x1fc9/0x0135) to upload your application (IVT, code, data) in the TCM RAM, and jump to the IVT. For an unknown reason, you cannot write to the OCRAM region (0x20200000), neither to the first 32 bits word in ITCM (0x00000000) - error unexpected write response 0x89232389.
EDIT: I did not test to boot a Teensy/Arduino image, I build my firmware with the NXP SDK (and cmake).
Jory, thanks for the information, very helpful.
