Hello, thanks for any help here. I have a IMU that I need to use and would like to run it on a Teensy 3.6.
I have a example that I found on GitHub. would someone be able to help me with converting it to be used on the teensy? I have alreaady successfully run this code on a Adafruit Feather nrf52840 board. i just need to use it on the teensy, bluetooth functionality is not necessary, I just need to get all the readings from the IMU (acceleration, angle, pitch, etc...) and be able to print them.
its attached to this post as a notepad file and as the arduino .ino file as well and copied below:
Code for BNO080 and nfr52 feather
IMU data are sentto Adafruit Bluefruit LE app
Copyright JP Schramel Jan 3 2019
MIT license, check LICENSE for more information
Text to be included in any redistribution
Based upon Adafruit bleuart example:
This is an example for our nRF52 based Bluefruit LE modules
Pick one up today in the adafruit shop!
products from Adafruit!
All text above, and the splash screen below must be included in
any redistribution.
Features
# Sends data from IMU BNO080 to Adafruit BLE connect app.
# Reports battery level
# BNO Calibrate by sending "c" via bleuart
# BNO Tare by sending "t" via bleuart
Connect BNO080 breakout to feather nrf52:
SDA --> SDA (4k7 pullup)
SCL--> SCL (4k7 pullup)
N_RST --> pin 6 (4k7 pullup)no pullup used to get working
3V3
GND
INCLUDES
#include <bluefruit.h>
DEFINITIONS
#define serial_out // serial out
//#define quaternions // bleuart out (uart)
//#define euler (uart)
#define plotter (plotter)
#define NAME "NRF52_BNO080" // devicename for advertising
#define BNO_ADDRESS (0x4A) // device address when SA0 Pin 17 = GND; 0x4B SA0 Pin 17 = VDD
#define QP (1.0f / (1 << n)) // 1 << n == 2^-n
#define radtodeg (180.0f / PI)
#define VBAT_PIN (A7)
#define VBAT_MV_PER_LSB (0.7324F) // 3.0V ADC range and 12-bit ADC resolution = 3000mV/4096
#define VBAT_DIVIDER (0.7128F) // 0.806M and 2M voltage divider factor
#define Led (17) // Led internal
#define N_RST (6) // N_RST pin of BNO080
const int serial_interval = 500; // serial interval in ms
const int ble_interval = 50; // BLE interval in ms
uint8_t cargo[23];
uint8_t readbuf = 0x00; // buffer to hold uart read data
float Q0,Q1,Q2,Q3, H_est;
uint8_t stat_; // Status (0-3)
float yaw,pitch,roll;
const uint8_t quat_report = 0x05; // defines kind of rotation vector (0x05), geomagnetic (0x09), AR/VR (0x28), // without magnetometer : game rotation vector (0x08), AR/VR Game (0x29)
const int reporting_frequency = 400; // reporting frequency in Hz // note that serial output strongly reduces data rate
const uint8_t B0_rate = 1000000 / reporting_frequency; //calculate LSB (byte 0)
const uint8_t B1_rate = B0_rate >> 8; //calculate byte 1
unsigned long timer_timeout = 0;
unsigned long timer_data = 0;
unsigned long timer_data1 = 0;
float battery_level = 4100; // battery level in mV
float battery_percent = 100; // battery level in %
int vbat_raw = 0; // ADC reading of Vbat
// define BLE Services
BLEDis bledis; // device information
BLEUart bleuart; // uart over ble
BLEBas blebas; // battery
// Set the analog reference to 3.0V (default = 3.6V)
analogReference(AR_INTERNAL_3_0);
// Set the resolution to 12-bit (0..4095)
analogReadResolution(12); // Can be 8, 10, 12 or 14
while ( !Serial ) delay(10); // for nrf52840 with native usb
Serial.println("nrf52 _ BNO080 IMU 9DOF");
Serial.println("---------------------------");
// pin definitions
digitalWrite(N_RST, LOW); // Reset pulse active low
pinMode(N_RST, OUTPUT);
delay(100); // not clear how long this must be. reset probably not needed at all
digitalWrite(N_RST, HIGH);
digitalWrite(Led,LOW); // initial state of LED = off
pinMode(Led, OUTPUT);
Wire.begin(); // start I2C communication pins are defined in variants
//Wire.setClock(400000); // select 400 kbps (100, 250) not needed because 400kHz is default
// Setup the BLE LED to be enabled on CONNECT
// Note: This is actually the default behaviour, but provided
// here in case you want to control this LED manually via PIN 19
Bluefruit.autoConnLed(true);
// Config the peripheral connection with maximum bandwidth
// more SRAM required by SoftDevice
// Note: All config***() function must be called before begin()
Bluefruit.configPrphBandwidth(BANDWIDTH_MAX);
Bluefruit.begin();
// Set power. Accepted values are: -40, -30, -20, -16, -12, -8, -4, 0, 3, 4 (5,6,7,8, nrf52840 only)
Bluefruit.setTxPower(4);
Bluefruit.setName(NAME);
//Bluefruit.setName(getMcuUniqueID()); // useful testing with multiple central connections
Bluefruit.Periph.setConnectCallback(connect_callback);
Bluefruit.Periph.setDisconnectCallback(disconnect_callback);
// Configure and Start Device Information Service
bledis.setManufacturer("JPS2000");
bledis.setModel("Lab 0");
bledis.begin();
// Configure and Start BLE Uart Service
bleuart.begin();
// Start BLE Battery Service
blebas.begin();
// Convert from raw mv to percentage (based on LIPO chemistry)
vbat_raw = analogRead(VBAT_PIN);
battery_level= vbat_raw * VBAT_MV_PER_LSB / VBAT_DIVIDER; //convert to mV
battery_percent = map(battery_level,3400,4200,0,100); // linear approximation mV to %
blebas.write(battery_percent);
// Set up and start advertising
startAdv();
Serial.print("Battery ");
Serial.print(vbat_raw * VBAT_MV_PER_LSB / VBAT_DIVIDER );
Serial.println(" mV");
timer_timeout = millis(); // set timeout timer
Bluefruit.printInfo(); // print SoftDevice Config and BLE Settings
// BNO settings
Wire.beginTransmission(BNO_ADDRESS);
while (Wire.endTransmission() != 0); //wait until device is responding (32 kHz XTO running)
Serial.println("BNO found");
delay(200); //needed to accept feature command; minimum not tested
set_feature_cmd_QUAT(); // set the required feature report data rate are generated at preset report interva
save_periodic_DCD(); // saves DCD every 5 minutes ( only if cal = 3)
ME_cal(1,1,1,0); // switch autocal on @ booting (otherwise gyro is not on)
get_QUAT();
// Forward sensor data to serial
#ifdef serial_out
if (millis() - timer_data1 > serial_interval)
Serial.print ("S "); Serial.print (stat_);
Serial.print ("; E "); Serial.print (H_est + 0.05f,1); // including rounding
Serial.print ("; q0 "); Serial.print (Q0 + 0.00005f,4);
Serial.print ("; q1 "); Serial.print (Q1 + 0.0005f,3);
Serial.print ("; q2 "); Serial.print (Q2 + 0.0005f,3);
Serial.print ("; q3 "); Serial.println (Q3 + 0.0005f,3);
Serial.print ("ROLL = "); Serial.println (roll,1);
Serial.print ("PITCH = "); Serial.println (pitch,1);
Serial.print ("YAW = "); Serial.println (yaw,1);
Serial.print ("STAT = "); Serial.println (stat_);
timer_data1 = millis();
//Forward sensor data to BLE
if ((millis() - timer_data) > ble_interval) // send data in defined interval
#ifdef quaternions
bleuart.print (Q0);
bleuart.print (" "); bleuart.print (Q1);
bleuart.print (" "); bleuart.print (Q2);
bleuart.print (" "); bleuart.println (Q3);
#ifdef euler
bleuart.print ("S "); bleuart.print (stat_);
bleuart.print (" H "); bleuart.print (yaw,1);
bleuart.print (" P "); bleuart.print (pitch,1);
bleuart.print (" R "); bleuart.println (roll,1);
#ifdef plotter
// Having everything in one string leads to much faster data transfer --> check with nrf logger and toolbox
bleuart.print((String)"-200,360," + String(yaw,0) +"," + String(pitch,0) +"," + String(roll,0) + "\r\n"); //println does require an additional transfer
// bleuart.print(-200); bleuart.print(" "); bleuart.print(360); bleuart.print(" "); // set limits for plot to override autoscale in app
// bleuart.print(roll,0);bleuart.print(" ");
// bleuart.print(pitch,0);bleuart.print(" ");
// bleuart.println(yaw,0);
timer_data = millis();
if (stat_ == 3) digitalWrite(Led,HIGH); // status Led
else digitalWrite(Led, LOW);
// get data from BLEUART
while ( bleuart.available() )
readbuf = bleuart.read(); // as read clears also the buffer it can be read only once
if(readbuf == 't') // button pressed stores actual orientation as q(1,0,0,0)
TARE();
readbuf = 0; // clear readbuffer
for(int i=0; i<2;i++){digitalWrite (Led,LOW); delay(200);digitalWrite (Led,HIGH);delay(200);} // acqknowledge blink 2x
if(readbuf == 'c')
save_DCD(); // store cal in flash
delay(200);
// ME_cal(0,0,1,0); //autocal acc + gyro stop; magnetometer cal continues
} // loop ends here
//************ BLE code *****************************************************************
// callback invoked when central connects
void connect_callback(uint16_t conn_handle)
// Get the reference to current connection
BLEConnection* connection = Bluefruit.Connection(conn_handle);
char central_name[32] = { 0 };
connection->getPeerName(central_name, sizeof(central_name));
Serial.print("Connected to ");
Serial.println(central_name);
//conn = true; // for auto shutdown
//digitalWrite(19,LOW); //switch off led optionally
* Callback invoked when a connection is dropped
* @param conn_handle connection where this event happens
* @param reason is a BLE_HCI_STATUS_CODE which can be found in ble_hci.h
void disconnect_callback(uint16_t conn_handle, uint8_t reason)
(void) conn_handle;
(void) reason;
Serial.println("Disconnected");
void startAdv(void)
// Advertising packet
Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE);
Bluefruit.Advertising.addTxPower();
// Include bleuart 128-bit uuid
Bluefruit.Advertising.addService(bleuart);
// Secondary Scan Response packet (optional)
// Since there is no room for 'Name' in Advertising packet
Bluefruit.ScanResponse.addName();
/* Start Advertising
* - Enable auto advertising if disconnected
* - Interval: fast mode = 20 ms, slow mode = 152.5 ms (244 x 0.625)
* - Timeout for fast mode is 30 seconds
* - Start(timeout) with timeout = 0 will advertise forever (until connected)
* For recommended advertising interval
* https://developer.apple.com/library/content/qa/qa1931/_index.html
Bluefruit.Advertising.restartOnDisconnect(true);
Bluefruit.Advertising.setInterval(32, 244); // (fastmode, slow mode) in unit of 0.625 ms
Bluefruit.Advertising.setFastTimeout(30); // number of seconds in fast mode
Bluefruit.Advertising.start(0); // 0 = Don't stop advertising after n seconds
//************** BNO080 code *************************************************************************
void get_QUAT()
int16_t q0,q1,q2,q3,h_est; // quaternions q0 = qw 1 = i; 2 = j; 3 = k;
float a,b,c,d,norm;
if (quat_report == 0x08 || quat_report == 0x29)
Wire.requestFrom(BNO_ADDRESS,21); //21
int i=0;
while (Wire.available())
cargo = Wire.read();
i++;
Wire.requestFrom(BNO_ADDRESS,23); //23
int i=0;
i++;
if((cargo[9] == quat_report) )
q1 = (((int16_t)cargo[14] << 8) | cargo[13] );
q2 = (((int16_t)cargo[16] << 8) | cargo[15] );
q3 = (((int16_t)cargo[18] << 8) | cargo[17] );
q0 = (((int16_t)cargo[20] << 8) | cargo[19] );
// patch for rarely occurring wrong data from BNO of unknown reasons. --> Check if q(0,1,2,3) is not unity vector
a = q0 * QP(14); b = q1 * QP(14); c = q2 * QP(14); d = q3 * QP(14); // apply Q point (quats are already unity vector)
norm = sqrtf(a * a + b * b + c * c + d * d);
if(abs(norm - 1.0f) > 0.0015) return; // skip faulty quats; margin is empirically determined
Q0 = a; Q1 = b; Q2 = c; Q3 = d; // update quaternions
stat_ = cargo[11] & 0x03; // bits 1:0 contain the status (0,1,2,3)
if (quat_report == 0x05 || quat_report == 0x09 || quat_report == 0x28 ) // heading accurracy only in some reports available
h_est = (((int16_t)cargo[22] << 8) | cargo[21] ); // heading accurracy estimation
H_est = h_est * QP(12); // apply Q point
H_est *= radtodeg; // convert to degrees
// calculate euler angles
yaw = atan2f(Q1 * Q2 + Q0 * Q3, Q0 * Q0 + Q1 * Q1 - 0.5f);
float argument = 2.0f * (Q1 * Q3 - Q0 * Q2); // may be > 1 due to rounding errors --> undefined
if(abs(argument) > 1.0f) argument = 1.0f;
pitch = asinf(argument);
roll = atan2f(Q0 * Q1 + Q2 * Q3, Q0 * Q0 + Q3 * Q3 - 0.5f);
yaw += PI * 0.5f; // correction of the y axis direction
if(yaw < 0) yaw += 2.0f * PI;
if(yaw > 2.0f *PI) yaw -= 2.0f * PI;
yaw *= radtodeg;
yaw = 360.0f - yaw;
pitch *= radtodeg;
roll *= radtodeg;
// COMMANDS
// This code activates quaternion output at defined rate
void set_feature_cmd_QUAT() // quat_report determines the kind of quaternions (see data sheets)
uint8_t quat_setup[21] = {21,0,2,0,0xFD,quat_report,0,0,0,B0_rate,B1_rate,0,0,0,0,0,0,0,0,0,0};
Wire.write(quat_setup, sizeof(quat_setup));
Wire.endTransmission();
/* This code tares and stores results in flash after correct positioning and calibration (follow Tare procedure Hillcrest BNO080 Tare function Usage Guide 1000-4045)
* Make sure to run rotation vector (0x05) and watch h_est and stat (should be << 10 deg and 3 respectively)
* NOTE: tare and calibration are different things
* NOTE: to undo tare persist requires calibration of the device followed by another tare persist with the device oriented y = north bfz = vertical before.
void TARE()
uint8_t RV; // rotation vector used to tare defined in quat_report
if(quat_report == 0x05) RV = 0x00;
if(quat_report == 0x08) RV = 0x01;
if(quat_report == 0x09) RV = 0x02;
uint8_t tare_now[16] = {16,0,2,0,0xF2,0,0x03,0,0x07,RV,0,0,0,0,0,0}; //0x07 means all axes 0x04 = Z axis only; based on rotation vector
uint8_t tare_persist[16] = {16,0,2,0,0xF2,0,0x03,0x01,RV,0,0,0,0,0,0,0};
Wire.write(tare_now, sizeof(tare_now));
//Wire.write(tare_persist, sizeof(tare_persist)); // uncomment for tare persist;
/* The calibration data in RAM is always updated in background. 'Save DCD' push the RAM record into the FLASH for reload @ next boot.
The algorithm will only update the calibration data when it feels the current accuracy is good. You don't need to care about the status or heading error.
Save before power off or whenever you would like to do. (Hillcrest information)
void save_DCD()
uint8_t save_dcd[16] = {16,0,2,0,0xF2,0,0x06,0,0,0,0,0,0,0,0,0};
Wire.write(save_dcd, sizeof(save_dcd));
/* This code disables the calibration running in the background of the accelerometer gyro and magnetometer.
* sensors can be set individually on and off (chapter 6.4.7.1)
* P0 = accelerometer, P1 = gyro; P2 =magnetometer; P4 = planar accelerometer (without Z axis)
* 0 = disable; 1 = enable
void ME_cal(uint8_t P0, uint8_t P1, uint8_t P2, uint8_t P4)
uint8_t me_cal[16] = {16,0,2,0,0xF2,0,0x07,P0,P1,P2,0,P4,0,0,0,0};
Wire.write(me_cal, sizeof(me_cal));
// Saves dynamic cal data periodically every 5 minutes (default)
void save_periodic_DCD(){
uint8_t periodic_dcd[16] = {16,0,2,0,0xF2,0,0x09,0,0,0,0,0,0,0,0,0};
Wire.write(periodic_dcd, sizeof(periodic_dcd));
any redistribution.
Features
3V3
GND
INCLUDES
DEFINITIONS
uint8_t cargo[23];
// pin definitions
Bluefruit.begin();
bledis.begin();
bleuart.begin();
blebas.begin();
startAdv();
// BNO settings
get_QUAT();
#ifdef serial_out
#ifdef quaternions
bleuart.print (Q0);
#ifdef euler
#ifdef plotter
TARE();
if(readbuf == 'c')
delay(200);
} // loop ends here
(void) conn_handle;
(void) reason;
void startAdv(void)
void get_QUAT()
float a,b,c,d,norm;
int i=0;
i++;
int i=0;
i++;
yaw *= radtodeg;
yaw = 360.0f - yaw;
pitch *= radtodeg;
roll *= radtodeg;
// COMMANDS
void TARE()
void save_DCD()
