Results 1 to 25 of 25
Thread: CAN bus write
    CAN bus write
    Is there a very basic example of a CAN bus write program somewhere for the teensy 3.6
    I found this on the sparkfun examples and i have made it work with the sparkfun can bus shield and uno.
    but i need to move over to the teensy 3.6 and run the same code on it and i am not sure what all i need to change to make it work correctly.
    and i like to run at 1M not 500 kbps, I found that the sparkfun can bus shield has no library to allow it to run at 1M on 500 kbps.
    thanks!
    CAN Write Demo for the SparkFun CAN Bus Shield.
    Written by Stephen McCoy.
    Original tutorial available here: http://www.instructables.com/id/CAN-...g-with-Arduino
    Used with permission 2016. License CC By SA.
    Distributed as-is; no warranty is given.
    #include <Canbus.h>
    #include <defaults.h>
    #include <global.h>
    #include <mcp2515.h>
    #include <mcp2515_defs.h>
    //********************************Setup Loop*********************************//
    Serial.println("CAN Write - Testing transmission of CAN Bus messages");
    if(Canbus.init(CANSPEED_500)) //Initialise MCP2515 CAN controller at the specified speed
    Serial.println("CAN Init ok");
    Serial.println("Can't init CAN");
    //********************************Main Loop*********************************//
    tCAN message;
    message.id = 0x640; //formatted in HEX
    message.header.rtr = 0;
    message.header.length = 8; //formatted in DEC
    message.data[0] = 0x3e;
    message.data[1] = 0xfe;
    message.data[2] = 0x7a;
    message.data[3] = 0x00; //formatted in HEX
    message.data[4] = 0x37;
    message.data[5] = 0x00;
    message.data[6] = 0x00;
    message.data[7] = 0x00;
    mcp2515_bit_modify(CANCTRL, (1<<REQOP2)|(1<<REQOP1)|(1<<REQOP0), 0);
    mcp2515_send_message(&message);
    maybe if i ask like this, I'd like to be able to send messages in hex like the code on the right. does anyone know the line command to be able to do this with flexcan? the code on the left is from flexcan example, the code on the right is the mcp2515 example. the code on the left i am not sure what the data value is its not hex though
    New York
    5,361
    Not sure which library you want to use with the T3.6. If you tell us maybe we can help better. I am not really familiar with the library used in the instructable you referenced
    If you use IFCT think you will be better off which pretty much looks like the code on the left.
    I have ifct downloaded. Can you describe how to transmit the values in the right side of the pic using ifct?
    New York
    5,361
    Actually was just reviewing @tonton81's FlexCan_t4 library and looks like that's a replacement for IFCT. But if you want to give IFCT a try:
    #include <IFCT.h>
      pinMode(2, OUTPUT); // for the transceiver enable pin, use the pin for your transceiver
      Can0.setBaudRate(1000000);
      Can0.enableFIFO();
      CAN_message_t msg;
      if ( Can0.read(msg) ) canSniff(msg);
      msg.flags.extended = 0;
      msg.flags.remote = 0;
      msg.len = 8;
      msg.id = 0x351;   //your other example had 0x640
      msg.buf[0] = random(0, 255);
      msg.buf[1] = random(0, 255);
      msg.buf[2] = random(0, 255);
      msg.buf[3] = random(0, 255);
      msg.buf[4] = random(0, 255);
      msg.buf[5] = random(0, 255);
      msg.buf[6] = random(0, 255);
      msg.buf[7] = random(0, 255);
      CAN.write(msg);
    void canSniff(const CAN_message_t &msg) {
      Serial.print("MB "); Serial.print(msg.mb);
      Serial.print("  LEN: "); Serial.print(msg.len);
      Serial.print(" EXT: "); Serial.print(msg.flags.extended);
      Serial.print(" REMOTE: "); Serial.print(msg.rtr);
      Serial.print(" TS: "); Serial.print(msg.timestamp);
      Serial.print(" ID: "); Serial.print(msg.id, HEX);
      Serial.print(" Buffer: ");
      for ( uint8_t i = 0; i < msg.len; i++ ) {
        Serial.print(msg.buf[i], HEX); Serial.print(" ");
      } Serial.println();
    Its been quite a while since i played with FlexCan. Will have to redo the setup with a T3.x and give it a try
    New York
    5,361
    Just looking at FlexCAN_t4 and looks like this might work for you as well - haven't tested it yet so no gurantees
    // CANtest for Teensy 4.0 using CAN2 and CAN2 bus
    #include <FlexCAN_T4.h>
    #define debug(msg) Serial.print("["); Serial.print(__FILE__); Serial.print("::"); Serial.print(__LINE__);  Serial.print("::"); Serial.print(msg); Serial.println("]");
    void debug_pause(void)
      Serial.print("Paused...");
      while (!Serial.available());
      while (Serial.available()) Serial.read();
      Serial.println("Restarted.");
    FlexCAN_T4<CAN0, RX_SIZE_256, TX_SIZE_16> Can0;
    static CAN_message_t msg;
    static uint8_t hex[17] = "0123456789abcdef";
    static void hexDump(uint8_t dumpLen, uint8_t *bytePtr)
      uint8_t working;
      while( dumpLen-- ) {
        working = *bytePtr++;
        Serial.write( hex[ working>>4 ] );
        Serial.write( hex[ working&15 ] );
      Serial.write('\r');
      Serial.write('\n');
    void setup(void)
      int iSerialTimeout = 1000000;
      while (!Serial && (iSerialTimeout-- != 0));
      debug (F("start setup"));
      Can0.begin();
      Can0.setBaudRate(1000000);   // I like to set the baud rates just to be on the safe side
      // t4 missing msg.ext = 0;
      msg.id = 0x100;  //pick one
      msg.len = 8;
      msg.flags.overrun  = 0;
      msg.flags.reserved = 0;
      msg.buf[0] = 10;
      msg.buf[1] = 20;
      msg.buf[2] = 0;
      msg.buf[3] = 100;
      msg.buf[4] = 128;
      msg.buf[5] = 64;
      msg.buf[6] = 32;
      msg.buf[7] = 16;
      debug (F("setup complete"));
      //debug_pause();
    void loop(void)
      msg.buf[0]++;       //since you are in a loop i just incremented each time in stead of doing it 5 times
      Can0.write(msg);    //you could do it your way as well
      //Serial.println("cantest - Repeat: Read bus0, Write bus1");
      CAN_message_t inMsg;
      if (Can0.read(inMsg)!=0)
        Serial.print("W RD bus 0: "); hexDump(8, inMsg.buf);
      delay(20);
    the values circled in the pic taken from your examples are not hex. I do not know what they are or where they come from.
    so can you tell me how to modify that code to simply transmit hex values?
    the hex values i need to transmit are:
    [0] = 0x38;
    [1] = 0xfe;
    [2] = 0x7a;
    [3] = 0x00;
    [4] = 0x37;
    [5] = 0x00;
    [6] = 0x00;
    [7] = 0x00;
    on address 0x640
    that's all i need to do, nothing else, just transmit those values.
    New York
    5,361
    Ok obvious answer just change the message id to what you want and message to the hex values that you want instead of ints, thats it. Here you go:
    #include <IFCT.h>
      Can0.enableFIFO();
      CAN_message_t msg;
      msg.len = 8;
      msg.id = 0x640;   //changed ID to 0x640
      msg.buf[1] = 0xfe;
      msg.buf[2] = 0x7a;
      msg.buf[3] = 0x00;
      msg.buf[4] = 0x37;
      msg.buf[5] = 0x00;
      msg.buf[6] = 0x00;
      msg.buf[7] = 0x00;
      CAN.write(msg);
      } Serial.println();
    I left the cansniff their in case you wanted to try receiving messages. otherwise you can delete it.
    #include <IFCT.h>
      Can0.enableFIFO();
      CAN_message_t msg;
      msg.len = 8;
      msg.buf[1] = 0xfe;
      msg.buf[2] = 0x7a;
      msg.buf[3] = 0x00;
      msg.buf[4] = 0x37;
      msg.buf[5] = 0x00;
      msg.buf[6] = 0x00;
      msg.buf[7] = 0x00;
      CAN.write(msg);
      } Serial.println();
    it errors when compiling:
    the line: CAN.write (msg); is the error line and says 'CAN' was not declared in this scope
    Quote Originally Posted by Fox95 View Post
    i figured it out it needs to be this:
    Can0.write(msg);
    and now it works correctly! thank you for the help this is just what i needed, perfect!
    New York
    5,361
    Can0.write(msg);
    Good glad it worked. Thats was my fault - thats what happens when you do copy and pastes.
    i need to ask one more question, i need to apply the above can transmit to a code file that runs a IMU but i am unsure where to put it in the file, i pasted it into the main loop but its not sending out any CAN data. could you look at this and tell me if its in the correct spot to transmit?
                    INCLUDES
    #include <IFCT.h>
                    DEFINITIONS
    #define nrf52
    //#define Simblee
    //#define Nano
    #define Led                       13              // Led  (Arduino nano = 13) to measure loop duration (10) nrf52 = 17
    #define btn_TARE                  A1              // input pin for button TARE
    #define btn_CAL                   6               // input pin for button TARE
    int plot_interval                 = 1000;         // plot interval in ms
    unsigned long plot_timer          = 0;
    #define BNO_ADDRESS               0x4A            // Device address when SA0 Pin 17 = GND; 0x4B SA0 Pin 17 = VDD
    uint8_t cargo[25];
    float Q0,Q1,Q2,Q3,H_est;
    uint8_t stat_;                                     // Status (0-3)
    float yaw,pitch,roll;
    const uint8_t quat_report        = 0x05;          // defines kind of rotation vector (0x05), geomagnetic (0x09), AR/VR (0x28)
                                                      // without magnetometer : game rotation vector (0x08), AR/VR Game (0x29)
    const int reporting_frequency    = 400;           // reporting frequency in Hz  // note that serial output strongly reduces data rate
    uint32_t rate              = 1000000 / reporting_frequency;
    uint8_t B0_rate            = rate & 0xFF;                       //calculates LSB (byte 0)
    uint8_t B1_rate            = (rate >> 8) & 0xFF;
    uint8_t B2_rate            = (rate >> 16) & 0xFF;
    uint8_t B3_rate            = rate >> 24;                        //calculates MSB (byte 3)
    /******* Conversions *************/
    #define QP(n)                       (1.0f / (1 << n))                   // 1 << n ==  2^-n
    #define radtodeg                    (180.0f / PI)
                     SETUP
    // pin definitions
      pinMode(Led, OUTPUT);
      digitalWrite(Led, HIGH);               // initial state of LED = on
      pinMode(btn_TARE, INPUT_PULLUP);
      pinMode(btn_CAL, INPUT_PULLUP);
      //pinMode(2, OUTPUT); // for the transceiver enable pin, use the pin for your transceiver
      Can0.enableFIFO();
    // communication
      Serial.begin(115200);                  // 115200 baud
      #ifdef Simblee
      Wire.speed = 400;  // select 400 kbps (100, 250)   //
      Wire.beginOnPins(5,6);                 // (SCLpin,SDApin)
      #ifdef nrf52
      Wire.begin();                          // no need to define pins. they are declared in variants.h
      Wire.setClock(400000L);
      #ifdef Nano
      Wire.begin();                          // start I2C communication
      Wire.setClock(400000L);                // set I2C to 400kHz
      Serial.println ("*********************************************************************");
      Serial.println (" Rock bottom code for  BNO080 on Atmega 328p; Cortex M0 (Simblee) and M4 (nrf52)  V1.1 2018-12-30");
    // BNO settings
      Wire.beginTransmission(BNO_ADDRESS);
      while (Wire.endTransmission() != 0);         //wait until device is responding (32 kHz XTO running)
      Serial.println("BNO found");
      for (byte i = 8; i < 120; i++)              //I2C Scanner for debug purpose
        Wire.beginTransmission (i);
        if (Wire.endTransmission () == 0)
          Serial.print ("Found address: ");
          Serial.print (i, DEC);
          Serial.print (" (0x");
          Serial.print (i, HEX);
          Serial.println (")");
      // On system startup, the SHTP control application sends its full advertisement response, unsolicited, to the host (chapter 5.1ff SHTP v1.7)
      // remark: commands are only accepted after that  alternatively add a delay(200);
      Serial.print("SHTP advertising: ");
      cargo[0] = 1;                                       // start condition
      while (cargo[0] != 0)                               // repeat if length is still > 0
        Wire.requestFrom(BNO_ADDRESS,32);
        int i=0;
          while (Wire.available())
          cargo[i] = Wire.read();
          i++;
          for(int j = 4 ; j <33; j++)  // skip first 4 bytes
          Serial.print (cargo[j],HEX);
          Serial.print(",");
      get_Product_ID();
      set_feature_cmd_QUAT();                // set the required feature report data rate  are generated  at preset report interval
      delay(200);
      save_periodic_DCD();                   // saves DCD every 5 minutes ( only if cal = 3)
      ME_cal(1,1,1,0);                       // default after reset is (1,0,1,0); switch autocal on @ booting (otherwise gyro is not on)
                         LOOP
     get_QUAT();                           // get actual QUAT data (if new are available)
     if (millis() - plot_timer > plot_interval){
            plot_timer = millis();
            Serial.print ("S "); Serial.print (stat_);
            Serial.print ("; E "); Serial.print (H_est + 0.05f,1);                   // including rounding
            Serial.print ("; q0 "); Serial.print (Q0 + 0.00005f,4);                  // = qw (more digits to find out north direction (y axis N --> q0 = 1)
            Serial.print ("; q1 "); Serial.print (Q1 + 0.0005f,3);
            Serial.print ("; q2 "); Serial.print (Q2 + 0.0005f,3);
            Serial.print ("; q3 "); Serial.println (Q3 + 0.0005f,3);
            Serial.print ("ROLL = "); Serial.println (roll,1);
            Serial.print ("PITCH = "); Serial.println (pitch,1);
            Serial.print ("YAW = "); Serial.println (yaw,1);
            Serial.print ("STAT = "); Serial.println (stat_);
      //if (stat_ == 3)  digitalWrite(Led,HIGH);                              // indicate cal status 3
      if (stat_ == 3)  digitalWrite(Led, !digitalRead(Led));                  // blink Led every loop run (--> to measure loop duration);
      else digitalWrite(Led, LOW);                                            // status Led
    // *************  buttons *******************************
      if(digitalRead(btn_TARE) == LOW ){                        // button pressed  stores actual phi as mean value and saves actual calibration to flash
        delay(200);
        while(digitalRead(btn_TARE) == LOW);                    // wait for button release
        //actions follow  here
        TARE();
       if(digitalRead(btn_CAL) == LOW){
         delay(200);
         while(digitalRead(btn_CAL) == LOW );            // wait for button release
         save_DCD();                                     // store cal in flash
         delay(200);
        // ME_cal(0,0,1,0);                              //autocal acc + gyro stop; magnetometer  cal continues
    }                                                    // loop ends here
                 Subroutines
    /* This code reads quaternions
     * kind of reporting (quat_report) is defined above
    void get_QUAT(){
     int16_t q0,q1,q2,q3,h_est;                        // quaternions q0 = qw 1 = i; 2 = j; 3 = k;  h_est = heading accurracy estimation
     float a,b,c,d,norm;
     if (quat_report == 0x08 || quat_report == 0x29){
        Wire.requestFrom(BNO_ADDRESS,21);
        int i=0;
        while (Wire.available()){
          i++;
      else{
        Wire.requestFrom(BNO_ADDRESS,23);
        int i=0;
          i++;
          if(cargo[9] == quat_report)                                             // check for report
            q1 = (((int16_t)cargo[14] << 8) | cargo[13] );
            q2 = (((int16_t)cargo[16] << 8) | cargo[15] );
            q3 = (((int16_t)cargo[18] << 8) | cargo[17] );
            q0 = (((int16_t)cargo[20] << 8) | cargo[19] );
         // patch for  rarely occurring wrong data from BNO of unknown reasons. --> Check if q(0,1,2,3) is not a unity vector
            a = q0 * QP(14); b = q1 * QP(14); c = q2 * QP(14); d = q3 * QP(14);    // apply Q point (quats are already unity vector)
            norm = sqrtf(a * a + b * b + c * c + d * d);
            if(abs(norm - 1.0f) > 0.0015) return;                                   // skip faulty quats
            Q0 = a; Q1 = b; Q2 = c; Q3 = d;                                        // here orientation may be changed b=x; c=y, d = z
           stat_ = cargo[11] & 0x03;                                               // bits 1:0 contain the status (0,1,2,3)
           if (quat_report == 0x05 || quat_report == 0x09 || quat_report == 0x28 ){  // heading accurracy only in some reports available
            h_est = (((int16_t)cargo[22] << 8) | cargo[21] );                        // heading accurracy estimation
            H_est = h_est * QP(12);                                                  // apply Q point this is 12  not 14
            H_est *= radtodeg;                                                       // convert to degrees
             // calculate euler angles
            yaw   =  atan2f(Q1 * Q2 + Q0 * Q3, Q0 * Q0 + Q1 * Q1 - 0.5f);
            float argument = 2.0f * (Q1 * Q3 - Q0 * Q2);                               // may be > 1 due to rounding errors --> undefined
            if(abs(argument) > 1.0f) argument = 1.0f;
            pitch =  asinf(argument);
            roll  =  atan2f(Q0 * Q1 + Q2 * Q3, Q0 * Q0 + Q3 * Q3 - 0.5f);
            yaw += PI * 0.5f; // correction of the y axis direction
            if(yaw < 0) yaw += 2.0f * PI;
            if(yaw > 2.0f *PI) yaw -= 2.0f * PI;
            yaw   *= radtodeg;
            yaw    = 360.0f - yaw;
            pitch *= radtodeg;
            roll  *= radtodeg;
            CAN_message_t msg;
            msg.len = 8;
            msg.buf[0] = 0x3e;
            msg.buf[1] = 0xfe;
            msg.buf[2] = 0x7a;
            msg.buf[3] = 0x00;
            msg.buf[4] = 0x37;
            msg.buf[5] = 0x00;
            msg.buf[6] = 0x00;
            msg.buf[7] = 0x00;
            Can0.write(msg);
    //                COMMANDS
    // This code activates quaternion output  at defined rate
    void set_feature_cmd_QUAT(){                                 // quat_report determines the kind of quaternions (see data sheets)
      uint8_t quat_setup[21] = {21,0,2,0,0xFD,quat_report,0,0,0,B0_rate,B1_rate,B2_rate,B3_rate,0,0,0,0,0,0,0,0};
       Wire.write(quat_setup, sizeof(quat_setup));
       Wire.endTransmission();
    /* This code tares  and stores results in flash after correct positioning and calibration (follow Tare procedure Hillcrest BNO080 Tare function Usage Guide 1000-4045)
    * Make sure to run  rotation vector (0x05) and watch h_est and stat (should be << 10 deg and 3 respectively)
    * NOTE: tare and calibration are different things
    * NOTE: to undo tare persist requires calibration of the device followed by another tare persist with the device oriented y = north bfz = vertical before.
    void TARE(){
      uint8_t RV;               // rotation vector used to tare defined in quat_report
      if(quat_report == 0x05) RV = 0x00;
      if(quat_report == 0x08) RV = 0x01;
      if(quat_report == 0x09) RV = 0x02;
      uint8_t tare_now[16] = {16,0,2,0,0xF2,0,0x03,0,0x07,RV,0,0,0,0,0,0};                //0x07 means all axes 0x04 = Z axis only; based on rotation vector
      uint8_t tare_persist[16] = {16,0,2,0,0xF2,0,0x03,0x01,RV,0,0,0,0,0,0,0};
      Wire.write(tare_now, sizeof(tare_now));
      //Wire.write(tare_persist, sizeof(tare_persist));                                  // uncomment  for tare persist;
    /* The calibration data in RAM is always updated in background. 'Save DCD'  push the RAM record into the FLASH for reload @ next boot.
       The algorithm will only update the calibration data when it feels the current accuracy is good. You don't need to care about the status or heading error.
       Save  before power off or whenever you would like to do. (Hillcrest information)
    void save_DCD(){
      uint8_t save_dcd[16] = {16,0,2,0,0xF2,0,0x06,0,0,0,0,0,0,0,0,0};
      Wire.write(save_dcd, sizeof(save_dcd));
    /* This code disables the calibration running in the background of the accelerometer gyro and magnetometer.
     * sensors can be set individually on and off (chapter 6.4.7.1)
     * P0 = accelerometer, P1 = gyro; P2 =magnetometer; P4 = planar accelerometer (without Z axis)
     * 0 = disable; 1 = enable
    void ME_cal(uint8_t P0, uint8_t P1, uint8_t P2, uint8_t P4){
      uint8_t me_cal[16] = {16,0,2,0,0xF2,0,0x07,P0,P1,P2,0,P4,0,0,0,0};
      Wire.write(me_cal, sizeof(me_cal));
    // Saves dynamic cal data periodically every 5 minutes (default)
    void save_periodic_DCD(){
      uint8_t periodic_dcd[16] = {16,0,2,0,0xF2,0,0x09,0,0,0,0,0,0,0,0,0};
      Wire.write(periodic_dcd, sizeof(periodic_dcd));
    /* This code reads  the product ID
    void get_Product_ID(){
      uint8_t get_PID[6] = {6,0,2,0,0xF9,0};
      //uint8_t get_PID[6] = {6,0,2,0,0xF9,0};
      Wire.beginTransmission(BNO_ADDRESS);                         // requesting product ID (chapter 6.3.1)
      Wire.write(get_PID, sizeof(get_PID));
      delay(200);                                                  // wait until response is available
       while (cargo[4] != 0xF8)                            // wait for command response
        Wire.requestFrom(BNO_ADDRESS,25);                 // fetching response(chapter 6.4.7.3)
        int i=0;
          i++;
            Serial.print ("Product ID response: ");
            Serial.print ("Reset cause: ");
            Serial.print (cargo[5],HEX);
            Serial.print (" SW Major: ");
            Serial.print (cargo[6],HEX);
            Serial.print (" SW Minor: ");
            Serial.println (cargo[7],HEX);
    /* Utilities (Quaternion mathematics)
      q0 * q0 + q1 * q1 + q2 * q2 + q3 * q3  = 1
     // Gravity vector from quaternion
      gx = q1 * q3 - q0 * q2;
      gy = q0 * q1 + q2 * q3;
      gz = q0 * q0 + q3 * q3 -0.5f;
      norm = sqrtf(gx * gx + gy * gy + gz * gz);
      norm = 1.0f / norm;
      gx *= norm; gy *= norm; gz *= norm;
     # Rotation matrix (half)
      (R00 R10 R20)
     =(R01 R11 R21)
      (R02 R12 R22)
     R00 = q0 * q0 + q1 * q1 -0.5f; // = 0.5f - q2 * q2 - q3 * q3;
     R01 = q1 * q2 - q0 * q3;
     R02 = q1 * q3 + q0 * q2;
     R10 = q1 * q2 + q0 * q3;
     R11 = q0 * q0 + q2 * q2 -0.5; // = 0.5f - q1 * q1 - q3 * q3;
     R12 = q2 * q3 - q0 * q1;
     R20 = q1 * q3 - q0 * q2;
     R21 = q2 * q3 + q0 * q1;
     R22 = q0 * q0 + q3 * q3 -0.5f; // = 0.5f -q1 * q1 -q2 * q2;
     To rotate a vector V = (vx,vx,vz) in quaternion frame
     W = (wx,wy,wz)
     wx = 2.0f * ( R00 * vx + R10 * vy + R20 * vz);
     wy = 2.0f * ( R01 * vx + R11 * vy + R21 * vz):
     wz = 2.0f * ( R02 * vx + R12 * vy + R22 * vz):
     For example gravity vector  g = (0,0,1)  --> G = (gx,gy,gz) = (R20, R21, R22)
     # Euler angles from rotation matrix:
     yaw   =  atan2f(R10 , R00);                    // heading
     pitch =  -  asinf(R20); =  -  asinf(gx);
     roll  =  atan2f(R21 , R22); = atan2f(gy , gz);
     # Euler angles from quaternions
     yaw   =  atan2f(Q1 * Q2 + Q0 * Q3, Q0 * Q0 + Q1 * Q1 - 0.5f);   // heading
     pitch =  -  asinf(2.0f * (Q1 * Q3 - Q0 * Q2));
     yaw += PI * 0.5f;                                               // correction of the y axis direction if needed
     yaw   *= radtodeg;
     yaw    = 360.0f - yaw;                         // correction of the y axis direction if needed; apply location offset also here
     pitch *= radtodeg;
     roll  *= radtodeg;
    TARE (to make qt = 1,0,0,0) from q = (q0,q1,q2,q3)
    //store  konjugate komplex quat  (*-1 of i, j, k) at the moment of TARE
        t0 = q0;
        t1 = -q1;
        t2 = -q2;
        t3 = -q3;
      // qt are then the tared coefficients
      qt0 = q0 * t0 - q1 * t1 - q2 * t2 - q3 * t3;      // multiplication matrix
      qt1 = q0 * t1 + q1 * t0 + q2 * t3 - q3 * t2;
      qt2 = q0 * t2 - q1 * t3 + q2 * t0 + q3 * t1;
      qt3 = q0 * t3 + q1 * t2 - q2 * t1 + q3 * t0;
    alternative:
    //store quats at the moment of TARE
        t0 = q0;
        t1 = q1;
        t2 = q2;
        t3 = q3;
      // qt are the tared coefficients
      qt0 =  q0 * t0 + q1 * t1 + q2 * t2 + q3 * t3;    // konjugated multiplication matrix t1, t2, t3 negative sign
      qt1 = -q0 * t1 + q1 * t0 - q2 * t3 + q3 * t2;
      qt2 = -q0 * t2 + q1 * t3 + q2 * t0 - q3 * t1;
      qt3 = -q0 * t3 - q1 * t2 + q2 * t1 + q3 * t0;
     // Quaternion Qt(1,0,0,0) leads to gravity G = (0, 0, 1) (see formula for gravity)
     // Hence the angle of the sensor  to gravity after tare (any orientation) is the dot product between the unity
     // vectors (0,0,1) and (gx,gy,gz) which is
      PHI = acos(gz);       //  angle of the cone
      PHI *= 180.0f / PI;
    //Angle between quaternions
    float dotproduct = Q0 * q0 + Q1 * q1 + Q2 * q2 + Q3 * q3;
    float angle = radtodeg * 2.0f * acos(dotproduct);
    //*************************************************************************************Jizhong XiaoJizhong Xiao
         //**************** dphi calculation************
          float argument = (QT0 * Q0 + QT1 * Q1 + QT2 * Q2 + QT3 * Q3);  // calculate delta angle to previous sample
          if (abs(argument) > 1) argument = 1.0f;                        // check for N/A
          if(asin(argument) > 0) dphi = 2.0f * acos(argument);
          else dphi = 2.0f * (PI - acos(argument));                      // in case rotation is >360 deg  ( quat flip signs)
          dphi *= radtodeg;                                              // conversion to deg
          if(dphi < 1.4f) dphi = 0.0f;                                   // Noise cancelling (empirical value)
    Last edited by defragster; 06-17-2020 at 06:19 PM. Reason: Added hashtag # / CODE marking to see indenting
    New York
    5,361
    First is anything printing from get_Quant? Only thing that I see is that if this criteria is never met:
    nothing will be sent via Can bus, i.e.:
          if(cargo[9] == quat_report)   <====== probably not met
            CAN_message_t msg;
            msg.len = 8;
            msg.buf[0] = 0x3e;
            msg.buf[1] = 0xfe;
            msg.buf[2] = 0x7a;
            msg.buf[3] = 0x00;
            msg.buf[4] = 0x37;
            msg.buf[5] = 0x00;
            msg.buf[6] = 0x00;
            msg.buf[7] = 0x00;
            Can0.write(msg);
    yes, it currently prints out that values of roll pitch yaw etc...
            CAN_message_t msg;
            msg.len = 8;
            msg.buf[0] = 0x3e;
            msg.buf[1] = 0xfe;
            msg.buf[2] = 0x7a;
            msg.buf[3] = 0x00;
            msg.buf[4] = 0x37;
            msg.buf[5] = 0x00;
            msg.buf[6] = 0x00;
            msg.buf[7] = 0x00;
            Can0.write(msg);
    i moved the CAN transmit block of code up into the area right under where it prints the values for the imu and this does not work either
    as you can see it prints the values of the imu out correctly, but CAN values are not being transmitted, please note that the CAN message is being sent to another device and it is not expected to be seen in the serial monitor. the can device is out of the picture and not getting the values
    New York
    5,361
    It should work. Two things:
    1. Do you have to enable your transceiver? You never did say what transceiver you are using
    2. Are still wired correctly with CAN bus?
    its a waveshare sn65hvd230
    i didnt think they had enable pins?
    but it worked fine in before when it was just runing that very simply code of transmit only, it transmitted properly
    New York
    5,361
    That particular one doesn't have an enable pin - some of the transceivers do.
    I would move the can transmit to the main loop for a test. If it still doesn't work then it has to be the wiring.
    i have a scope on pins 3, 4 on the teeensy board, this pic shows what they are putting out, does it look normal?Click image for larger version.
Name:	pin 5 6 .jpg
ID:	20628 the waveshare board was working earlier
    there's a bigger problem here. is there anyone here that works for teensy?
    when i upload one program it will work fine, but when i upload another program its like it wont initiliaze the CAN pins on the teensy board.
    id like to know what pins 3 4 should look like on the scope so i can determine if its a problem with the wave share CAN transceiver, i have two of them and tried them both and now both do not work. They WERE working yesterday and transmitting can just fine. so i can't believe that both failed at this point when all i tried to do was import some CAN code into the IMU code and upload it
    is it possible there is a conflict between pins 3 4 CAN0 and pins 19 18 SCL SDA? when trying to use the board to do can and i2c at the same time?
    New York
    5,361
    Well I don't work for Teensy but i can tell you that using CAN0 on pins 3 and 4 I have had a IMU (MPU-9350) attached to I2C pins 18,19 and a GPS attached to Serial1 (pins 0,1) without any issues.
    As for the Waveshare Transceivers I used them all the time with a T3.2, T3.5, T3.6 and on a T4.x for the CAN2.0 pins, again without any problem.
    the only time you would run into an issue with the transceivers is when you have hooked them up wrong, thats why I asked you to check your wiring again as you had that problem before and if you changed setups..:
    Transceiver    Teensy Pin
    3.3v ----------- 3.3v pin
    RX ------------- pin 4 on the T3.6
    TX ------------- pin 3 on the T3.6
    GND ------------ GND
    And you connect CANH to CANH and CANL to CANL.
    As for your CAN2.0 waveform if you do a search on web you will find a couple of things:
    https://www.youtube.com/watch?v=fwPG0mxqK9M
    the wiring is good, it was working yesterday sending CAN messages just fine.
    the issue arose when i tried to merge the two sets of code where the imu was connected the same time as the wave share
    I know what a CAN bus should look like. the PINS i showed on my scope pic are BEFORE the wave share. there is nothing obviously coming out of the waveshare at this point. I want to know what the signal looks like coming out of pins 3 4 before it goes through the waveshare to understand if its correct.
    i understand I had wiring issues earlier and that was a board problem and it has been replaced, the wiring connections are good and they are conected properly as I said I was getting CAN messages BEFORE and it worked great.
    the scope pattern pic on pins 3 4 BEFORE the wave share should tell whats going on if a proper signal is making out of the board, if it is then somehow TWO waveshare boards failed at the same time which is doubtful.
    side note: i dont believe a square wave would be transmitted from pins 3 4 before the waveshare, the waveshare board should be what converts it to a square wave so it will look like your scope pic AFTER the waveshare board (but this is what i want to confirm with someone who's scoped the pins before....)
    Dec 2016
    Montreal, Canada
    3,379
    the pins won't communicate if flexcan went into error passive state, it practically sits dormant till another node on the bus starts talking. this happens when it's trying to transmit and not getting a response (single node, or transceiver issue)
    New York
    5,361
    Thanks for jumping in @tonton81. I did put a scope on the pins a long time ago but unfortunately don't have them anymore and dont have access to my scope for a few days.
    EDIT: Just a couple of questions until you get your wave form answer:
    1. Does the CAN example sketch still run and are you seeing data on the receiving node?
    2. When you are doing your testing do you have both nodes powered up as @tonton81 mentioned - think the answer is yes to this one from your comments.
    3. Add back in the code for receiving messages that you took out - cansniff stuff. Just out of curiosity.
    as an update for anyone who may read this in the future, as unlikely as it sounds, i had two bad waveshare CAN boards. ordering new ones solved the above issues. thanks to everyone who responded here. i was out of town for the last week so this was off my plate for awhile.
