Memotech-Bill
New member
As a result of a project I have been working on, I uncovered a couple of issues with the USB code for Teensy 3 in Teensyduino 1.52.
In routine usb_init(), file "cores/teensy3/usb_dev.c", lines 1172 to 1176 are:
However, the loop should be:
The existing code leaves the last three buffer descriptor table entries undefined. This results in invalid pointer values being passed to usb_free() when a USB set configuration event occurs. Fortunately, usb_free() is (mostly) protected against invalid pointer values.
Secondly, in file "cores/teensy3/yield.c", line 41:
It is assumed that the first USB serial interface is always defined. This should be surrounded by conditional compilation directives:
Finally, in file "cores/teensy3/usb_dev.c", lines 1073 to 1076, there is the comment:
Just to confirm that I have encountered this issue. The solution I adopted for my project was to create separate packet pools for each USB endpoint. There may be better ways of dealing with this.
for (i=0; i <= NUM_ENDPOINTS*4; i++) {
table[i].desc = 0;
table[i].addr = 0;
for (i=0; i < (NUM_ENDPOINTS+1)*4; i++) {
table[i].desc = 0;
table[i].addr = 0;
if (Serial.available()) serialEvent();
#if defined(USB_SERIAL) || (USB_DUAL_SERIAL) || defined(USB_TRIPLE_SERIAL)
// TODO: implement a per-endpoint maximum # of allocated
// packets, so a flood of incoming data on 1 endpoint
// doesn't starve the others if the user isn't reading
// it regularly
