iamtritium
New member
hello, new to all this and i have been poking around.
Initially Arduino IDE was not showing teensy boards even after installing Teensyduino.
Deleted everything and started from scratch. everything is peachy.
I have the soldering down, but im new to coding.
Downloaded two codes and tested them separately. they both work exactly how i wanted them to.
i am using two slide switches and one potentiometer. however i have tried to combine them and im not having luck.
i am posting them separately...
can someone help me combine them properly.
first switch sends signal CH05.CC.01 which is what i wanted. it only outputs one signal. so in the program i am using. i have it mapped to two buttons with an invert on the second so it acts like a toggle between the two. (so wheres CH05.CC.02?)
if i flip the second switch it changes the output of the first switch to NOTEs. however i would like for the second switch to work like the first and send CH05CC.02
the potentiometer works perfect when that code alone is in the teensy.
i want to fix and combine both codes.
at least combine them.. i can work with the second output being notes if anything.
thank you for any help and encouragement.
#include <ResponsiveAnalogRead.h> const int pot_pin = A0; // pot input int potValue; // Stores Pot State int potMidiValue; // Stores Pot State devided by 8 for MIDI int conNum; // midi cc control number int carryVal = 0; ResponsiveAnalogRead analog(pot_pin, true); void setup() { Serial.begin(9600); } void loop() { analog.update(); //update the analouge reading in each pass potValue = analog.getValue(); // store current state in variable potMidiValue = potValue / 8; // Makes potVale in to MIDI friendly code if ((analog.hasChanged()) && (potMidiValue != carryVal)){ usbMIDI.sendControlChange(conNum, potMidiValue, 5); Serial.println(potMidiValue); } carryVal = potMidiValue; while (usbMIDI.read()) { } delay(5); } |
..................................................................... #include <Bounce.h> const int NUM_OF_BUTTONS = 2; const int MIDI_CHAN = 5; const int DEBOUNCE_TIME = 5; Bounce buttons[NUM_OF_BUTTONS] = { Bounce (0, DEBOUNCE_TIME), Bounce (1, DEBOUNCE_TIME) }; const int MIDI_MODE_NOTES = 0; const int MIDI_MODE_CCS = 1; int midiMode = MIDI_MODE_NOTES; const int MIDI_NOTE_NUMS[NUM_OF_BUTTONS] = {40, 41}; const int MIDI_NOTE_VELS[NUM_OF_BUTTONS] = {110, 110}; const int MIDI_CC_NUMS[NUM_OF_BUTTONS] = {01, 02}; const int MIDI_CC_VALS[NUM_OF_BUTTONS] = {127, 127}; void setup() { for (int i = 0; i < NUM_OF_BUTTONS + 1; i++) { pinMode (i, INPUT_PULLUP); } } void loop() { for (int i = 0; i < NUM_OF_BUTTONS + 1; i++) { buttons.update(); } for (int i = 0; i < NUM_OF_BUTTONS; i++) { if (buttons[i + 1].fallingEdge()) { if (midiMode == MIDI_MODE_NOTES) usbMIDI.sendNoteOn (MIDI_NOTE_NUMS, MIDI_NOTE_VELS, MIDI_CHAN); else usbMIDI.sendControlChange (MIDI_CC_NUMS, MIDI_CC_VALS, MIDI_CHAN); } else if (buttons[i + 1].risingEdge()) { if (midiMode == MIDI_MODE_NOTES) usbMIDI.sendNoteOff (MIDI_NOTE_NUMS, 0, MIDI_CHAN); else usbMIDI.sendControlChange (MIDI_CC_NUMS, 0, MIDI_CHAN); } } if (buttons[0].fallingEdge()) { midiMode = MIDI_MODE_NOTES; } else if (buttons[0].risingEdge()) { midiMode = MIDI_MODE_CCS; } while (usbMIDI.read()) { } } |
