Results 1 to 3 of 3
Thread: Serial communication between instrument and PC through teensy 3.6
    Jun 2020
    4
    Hello everyone,
    I am fairly new to this world and need some guidance for a project I have. The current setup I have might seem dumb but it's not permanent. It's just a step for me to learn how to establish communication between an instrument, a teensy board and my laptop.
    Here's the setup... I have an optical particle counter with a 3 pin rs232 serial port sending data at a 9600 baud rate. I have connected this port to a max3232 transceiver breakout (for rs232 to ttl conversion) which is then in turn connected to the serial port #2 on my teensy (pins 9 and 10). The teensy is then connected to my laptop with the USB cable.
    I have looked at different examples and the serial library but I am a bit lost at the moment. How do I make my teensy read the incoming data on serial port 2 and then send it directly to my computer so I can read it on the serial monitor?
    I hope my explanation is clear. Thank you very much for any help!
    Cheers,
    Roman
    Oct 2015
    Roma (IT, EU)
    339
    Assuming you're using Arduino IDE 1.8.12 with Teensyduino 1.52 installed, you could use the example:
    "Examples->04.Communication->Serial.passthrough"
    as a base, replacing "Serial1" with "Serial2".
    Jun 2020
    4
    Thank you very much XFer!
    It worked perfectly!
