Results 1 to 6 of 6
Thread: Problem changing AUDIO_BLOCK_SAMPLES
    Feb 2020
    Dublin, Ireland
    55
    I had reduced AUDIO_BLOCK_SAMPLES to 32 previously to reduce latency in an audio project and it worked perfectly (and significantly reduced the latency). That was using a Teensy 4.0 with audio shield using the latest version of Teensyduino available in September 2019. There were no problems. I've now done the same thing using version 1.52 (Arduino with a Teensy 4.1 with USB audio output and it is not working. This shows what is happening to a 220 Hz sine wave - the frequency is correct.
    I don't have access to the other hardware to test it. The problem is happening with all audio source types. You can test it with the simplest code:
    AudioSynthWaveformSine   sine1;          //xy=235,197
    AudioOutputI2S           i2s1;           //xy=405,161
    AudioOutputUSB           usb1;           //xy=427,231
    AudioConnection          patchCord1(sine1, 0, i2s1, 1);
    AudioConnection          patchCord2(sine1, 0, i2s1, 0);
    AudioConnection          patchCord3(sine1, 0, usb1, 0);
    AudioConnection          patchCord4(sine1, 0, usb1, 1);
    AudioMemory(20);
    sine1.frequency(220);
    Feb 2020
    Dublin, Ireland
    55
    Could the fixing of USB Audio for Teensy 4.x have introduced a problem when
    AUDIO_BLOCK_SAMPLES is changed?
    23,994
    Quote Originally Posted by AlanK View Post
    I don't see how you could have run this program last year, since AudioOutputUSB has only existed for the last few months.
    Feb 2020
    Dublin, Ireland
    55
    Hi Paul,
    I didn't - it was working with AUDIO_BLOCK_SAMPLES set to 32 on a 4.0 using an audio shield for output. I've been working on other aspects of my software, and have moved to a 4.1 - currently the only audio output I have is USB audio. I've just changed AUDIO_BLOCK_SAMPLES again from 128 to 32 and encountered this problem.
    This seems to be the same problem - raised in November:
    https://forum.pjrc.com/threads/58322...causes-problem
    23,994
    Sadly, USB audio does not work with smaller block sizes. Other parts of the audio library also depend on 128 sample block size and do not work properly when it's changed to 32.
    But I2S does work, and so does do the waveform synths. I'm pretty sure the code you tried on Teensy 4.0 last year using only I2S output will still work properly.
    I tried your USB+I2S example with block size 32 and the audio shield. The proper waveform does appear on the output. The problem is only that USB doesn't support different block sizes. It must be 128 for USB to work.
    AudioControlSGTL5000     sgtl5000_1;
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.75);
      AudioMemory(20);
    Feb 2020
    Dublin, Ireland
    55
    Hi Paul,
    Thanks for clarifying that,
    All the best,
    Alan
