Results 1 to 3 of 3
Thread: Teensy 4.1 USB HOST GND & Shield
    For a new PCB design, I'm adding an onboard USB-A connector for the Teensy 4.1.
    From the bottom of the Teensy 4.1, the pinouts are GND, GND, D+, D-, 5v. Hence, looks like there are two GND pins.
    Should one of the GND pins be connected to Shield?
    14,426
    Indeed two GND - AFAIK just to accommodate typical 5 pin connector - with two GND's as was done on the T_3.6. Both are the same GND - so yes GND to shield so everything has a common reference
    Great, thank you @defragster
