Results 1 to 7 of 7
Thread: Teensy 3.6: interrupt configured for falling edges fires on both edges
    May 2017
    14
    I'm working with Teensy 3.6 and I set the interrupt function with the following simple code:
    attachInterrupt(digitalPinToInterrupt(RPM_Pin), RPM_PulseTimeDifference, FALLING);
    I'm using a signal generator to send a square wave to the RPM_Pin, and check it with the oscilloscope. I found that the interrupt on that pin, fires on both the rising and falling edges, as if I had set the interrupt with the CHANGE option instead of FALLING.
    Am I missing some info about the interrupts on Teensy 3.6?
    1,376
    That "shouldn't happen", but how do you know it is also triggering on the rising edge?
    Post some demo code.
    Pete
    May 2017
    14
    Pete
    I check the time differences with arduino micros function and compare with the oscilloscope's signal
    1,376
    I'd still like to see the code you are using to compute the time differences.
    Pete
    2,560
    does the tick count from this sketch increase by 1000 each second? (jumper pin 12 to pin 23)
    volatile uint32_t ticks;
    void ding() {
      ticks++;
      while (!Serial);
      analogWriteFrequency(23, 1000);    //jumper 23 to 12
      analogWrite(23, 128);
      attachInterrupt(12, ding, FALLING);
      Serial.println(ticks);
    try counting ticks with your signal generator.
    22,279
    I'm running that test here. Indeed it is incrementing 1000 times per second, so only 1 interrupt per cycle.
    May 2017
    14
    I found that there is a systematic jitter on the signal; this is why I'm counting two falling fronts instead of one
