Results 1 to 6 of 6
Thread: Live music performance with 5x Teensy 4.1 & 1x Tsunami
    Hey all!
    Here is a live video I put together using my Teensy setup:
    https://www.facebook.com/swingbassev...7298702181930/
    And here are some pics of the build:
    https://photos.app.goo.gl/rpHvsoQe4LVXHFLn8
    I am now working on getting it all running on a rpi as the SD library is too much of a bottleneck on the Teensy.
    Happy tweaking
    A
    there is actually an issue with the video! the host is taking it down and it will be going back online tomorrow! : o
    Few pics from the build!
    Very cool build. Could you outline a bit what is going on here?
    Ta recursinging!
    4 of the Teenys have loops loaded into them which can be triggered together using the buttons which are conneted via the keypad library. I have stereo outputs for Drums, Risers, Side chain trigger and then various ways of trigging bass using MIDI. Everything is summed in analog and run through the filter. The bass is run through the stereo side chain.
    The 5th teensy is controlling a tsunami wav trigger which can pitch samples so lends itself to the move greasy reese bass noises in the video : )
    It's been a much longer project than I though at the start (of course) hopefully I can see the light at the end of the tunnel now, looking forward to its first outing.
