Page 2 of 2 FirstFirst 1 2
Results 26 to 48 of 48
Thread: Teensy 4.1 NTP server
  1. #26
    Oct 2012
    Portland OR
    706
    With more data, I see my wild surmise about my GPSDO was wrong, and your more obvious suggestion was correct. Almost all the variation I saw was explained by air movement over the T4.1 PCB, as well as the ambient temperature. When I left the office with the door closed overnight, the error was a mostly a regular low-pass-filtered square wave tracking the 23-minute HVAC on/off cycle. This morning, after I sealed the T4.1 into an 8 inch cinderblock to remove drafts and stabilize its temperature, the chi-squared value is often less than 1 and rarely exceeds 5, and the offset rarely exceeds 30 ns, so the performance is quite different from before.
    count       offset      frequency   chisq      ppb  ntpseconds
    1723630418 0.000000013 0.000007707 0.333104610 7708 3805121064
    1798629840 0.000000009 0.000007707 0.333148301 7707 3805121067
    1823629647 0.000000023 0.000007707 0.638458192 7709 3805121068
    1898629069 0.000000020 0.000007707 0.305683136 7709 3805121071
    1998628298 0.000000026 0.000007707 0.437653899 7710 3805121075
    2073627720 0.000000018 0.000007708 0.405045867 7709 3805121078
    2148627142 0.000000010 0.000007708 0.337020397 7709 3805121081
    2248626371 0.000000016 0.000007708 0.325883627 7709 3805121085
    2323625793 0.000000010 0.000007708 0.257352889 7709 3805121088
    2348625600 0.000000022 0.000007708 0.275229812 7710 3805121089
    2423625022 0.000000014 0.000007708 0.226483017 7709 3805121092
    2523624251 0.000000017 0.000007708 0.229082704 7710 3805121096
    2598623673 0.000000010 0.000007709 0.233526707 7709 3805121099
    2698622902 0.000000014 0.000007709 0.233599454 7710 3805121103
    2723622709 0.000000024 0.000007709 0.321402192 7711 3805121104
    2823621938 0.000000023 0.000007709 0.375832856 7711 3805121108
    2898621360 0.000000010 0.000007709 0.377925456 7710 3805121111
    2998620589 0.000000010 0.000007709 0.421401381 7710 3805121115
    3023620396 0.000000020 0.000007709 0.451219887 7711 3805121116
    3123619625 0.000000020 0.000007710 0.515136003 7711 3805121120
    3198619047 0.000000007 0.000007710 0.347284496 7710 3805121123
    3298618276 0.000000007 0.000007710 0.274755895 7710 3805121127
    3323618083 0.000000017 0.000007710 0.437681466 7712 3805121128
    3423617312 0.000000014 0.000007710 0.339892298 7711 3805121132
    3523616541 0.000000010 0.000007710 0.339898229 7711 3805121136
  2. #27
    Nice! Good idea with the cinderblock, that should add a lot of thermal mass
  3. #28
    Oct 2012
    Portland OR
    706
    After a few days of sitting in a concrete block, which is in turn inside a large styrofoam box, the T4.1 temperature and frequency drift has mostly stabilized. Its reported CPU temperature is around 61.2 C and the frequency drift is near +8.612 ppm, with stability near 0.005 ppm in one hour. Based on the crude reported CPU temperature, this particular T4.1 frequency tempco is +0.195 ppm/C so it appears that the oscillator temperature is not drifting more than 25 milli-degrees in that time period. Not too bad!
  4. #29
    My two have a tempco of 0.154ppm/C and 0.206ppm/C, so that fits with your 0.195ppm/C.
    Wander being 0.005 ppm in an hour is pretty impressive.
  5. #30
    Oct 2012
    Portland OR
    706
    Well, I am cherry-picking the best few hours I've seen so far, but the concrete block is pretty effective in slowing down temperature changes. It appears to me if I had a high-resolution temperature sensor, and the temperature gradients and rate of change with time are low enough, that it may be possible to compensate the drift for that sort of stability over the medium term (at least for many hours). I don't know about temperature hysteresis and no doubt there is also an aging component longer-term, but so far in this experiment, I don't see much variation that isn't explained by temperature. I don't actually have a need for that level of performance, but it's interesting how stable it seems to be. If you maintained a constant error of 5 ppb for one year, it would add up to 0.16 seconds.
  6. #31
    2,616
    @ddrown, your isr in examples/lwip_1588_input/ needs asm volatile ("dsb");, otherwise the ISR fires twice for each PPS.
    https://github.com/ddrown/teensy41_ethernet
  7. #32
    You're correct, I've updated that example.
  8. #33
    Jan 2021
    10
    Very neat!
    Good morning all,
    Just put one of these together with a uBlox M8N and it seems like it is working just fine:
    eticks offset drift chisq drift secs
    2548391359 0.000000037 0.000007600 4.000188351 7604 3819280163
    2623390789 0.000000025 0.000007600 4.000512123 7603 3819280166
    2698390219 0.000000016 0.000007600 3.999779940 7602 3819280169
    2773389649 0.000000010 0.000007600 3.999139786 7601 3819280172
    2848389079 0.000000007 0.000007600 3.937441349 7601 3819280175
    2898388699 0.000000006 0.000007600 3.749967575 7601 3819280177
    2998387939 0.000000003 0.000007600 3.437464237 7600 3819280181
    3073387369 0.000000003 0.000007600 3.000012875 7600 3819280184
    I did add it as a server to my ntp.conf here on my Win10 box and it isn't using it yet even after an NTP stop / start using services.msc:
    remote refid st t when poll reach delay offset jitter
    *192.168.4.50 .PPS. 1 u 59 128 377 0.946 -0.054 0.221
    +192.168.4.57 .PPS. 1 u 73 128 377 0.869 +0.075 2.552
    74.208.235.60 .INIT. 16 u - 1024 0 0.000 +0.000 0.000
    172.86.179.86 .INIT. 16 u - 1024 0 0.000 +0.000 0.000
    192.168.4.50 is an RPi GPS NTP server with standard NTP, and 192.168.4.57 is another RPi GPS NTP server built around NTP-Sec. Yes, I really have no need for a total of three NTP servers...but all this got started when the original RPi GPS NTP server died...I rebuilt it...and it didn't seem to be working so I then built the NTP-Sec version and ordered up the Teensy 4.1 parts...and then while the Teensy 4.1 shipped out to me...both the original GPS NTP server and the GPS NTP-Sec servers both started working just fine.
    Just thought I'd post my results and send a nice thank you to ddrown for posting his code and doing the work in the first place to port it to the Teensy 4.1.
    thanks much and 73,
    ben, kd5byb
  9. #34
    Jan 2021
    10
    RPi Likes It!
    Good morning again all,
    So I fired up another RPi, added the Teensy 4.1 NTP server along with the addresses of my other NTP servers to ntp.conf...and it's clear that the Teensy 4.1 NTP server (192.168.4.66) is working fine and that the RPi is quite happy to use it as it's NTP source:
    *192.168.4.66    .PPS.            1 u   17   64    1    0.071    1.193   0.085
    +192.168.4.50    .PPS.            1 u   16   64    1    0.387    1.165   0.182
    +192.168.4.57    .PPS.            1 u   15   64    1    0.299    1.115   0.191
     108.61.73.244   .INIT.          16 u    -   64    0    0.000    0.000   0.000
     test.diarizer.c .INIT.          16 u    -   64    0    0.000    0.000   0.000
     lithium.constan .INIT.          16 u    -   64    0    0.000    0.000   0.000
     time.cloudflare .INIT.          16 u    -   64    0    0.000    0.000   0.000
    I used the code block as I can't seem to find a fixed-width font in the font choices? Probably a PEBCAK on my part.
    Very cool.
    thanks much,
    ben
  10. #35
    Excellent, glad to hear it is working for you. Those are low delay and jitter numbers, I like to see that.
  11. #36
    Jan 2021
    10
    Very glad to hear that I'm getting low delay / jitter numbers - that's excellent.
    Next up on my to-do list for this unit is an enclosure, as I do want to make it a permanent installation. I'm in process of looking at your code to see if there are some status variables used that I could then use to light LED's on a front panel display to "LED it up" a bit.
    Very likely one of those will be PPS. I'll buffer the PPS output from the GPS unit and make that one of the front panel LED's. I've got several GPS units for various things here and when one is having an issue (like it's antenna plug coming loose) it's easy to see because it's PPS gets out of sync with the other units.
    Thanks much,
    ben
  12. #37
    Jan 2021
    10
    Quick update - Teensy 4.1 NTP continues to work great. The Win10 box is now using it for time sync after I removed "iburst" from ntp.conf.
    Very neat!
    thanks much,
    ben
  13. #38
    Quote Originally Posted by kd5byb View Post
    That's interesting, the teensy should be more than able to keep up with an iburst.
    PPS would be able to tell you a lot at a glance
    Some other ideas for LED indication:
    * offset between local clock and GPS under a threshold (say 100ns)
    * GPS in 3D lock
    * GPS has >3 satellites with >20db SNR
    * GPS has a valid year (after cold reset, most GPS modules start with a year in the past)
  14. #39
    Jan 2021
    10
    Quote Originally Posted by ddrown View Post
    I'll try adding it back into Win10 Meinberg NTP ntp.conf and see what happens. It may have been just a coincidence that it "got happy" right after I removed it (and restarted the service with services.msc).
    * GPS in 3D lock
    Excellent suggestions! At the moment another project has grabbed my attention, but when I get back working on this I will definitely consider all of those.
    Thanks much,
    ben
  15. #40
    I've added a webserver to the code to make it easier to get data from the NTP server. /state.json from the teensy returns the following structure:
    "ppsToGPS": 396, // milliseconds between PPS timestamp and GPS's uart message showing the date
    "ppsMillis": 177223, // local millis() counter at PPS
    "curMillis": 178286, // current millis() counter
    "gpstime": 3820102515, // seconds since 01-01-1900 from GPS, aka NTP time
    "counterPPS": 53101544, // IEEE 1588 counter value at PPS
    "offsetHuman": 0.000000032, // offset between local clock and GPS, in seconds
    "pidD": 0.000010763, // Theil-Sen estimate of local clock's error, this is 10.763ppm
    "dChiSq": 5.998106956, // chi sq fit of local clock error estimate
    "clockPpb": 10760 // PID output
  16. #41
    Building on the JSON data, I added a webpage that will poll /state.json and build graphs. You can reach the web page by putting your teensy's IP address in your web browser.
    As well as general stats:
    PPS To GPS: 405 ms
    millis() at PPS: 902.225
    millis() at GPS Timestamp: 903689
    millis() now: 903.693
    NTP time: 3820194785
    IEEE 1588 counter at PPS: 1073301322
    Offset between NTP/GPS times: 0.000000008 s
    Estimate of NTP clock freq: 0.000010612 s/s
    ChiSq fit of freq measure: 2.924
    PID output: 10613 ns/s (ppb)
    GPS lock Status: 3D
    GPS Strong signals (> 25db): 3, Weak Signals (10db-24db): 6, No Signal (0db-9db): 2
    The index.html and index.js files take awhile to load (around 100ms), but the state.json file is taking 3-7ms. This shouldn't affect the NTP timestamp quality, as the 1588 hardware takes those independently from the main processor. My tests comparing one Teensy with the new webserver code and one without it show no difference in the round trip time or the offset.
  17. #42
    2,616
    Nice. Here is graphic data from T4.1 connected to sparkfun GNSS NEO-M9N with external antenna mounted on windowsill. M9N can use up to 4 constellations (GPS, GLONASS, Galileo, BEIDOU).
    PPS To GPS: 134 ms
    millis() at PPS: 3105.912
    millis() at GPS Timestamp: 3106046
    millis() now: 3106.625
    NTP time: 3820244653
    IEEE 1588 counter at PPS: 255890795
    Offset between NTP/GPS times: 0.000000012 s
    Estimate of NTP clock freq: 0.000007667 s/s
    ChiSq fit of freq measure: 1.667
    PID output: 7668 ns/s (ppb)
    GPS lock Status: 3D
    GPS Strong signals (> 25db): 25, Weak Signals (10db-24db): 5, No Signal (0db-9db): 8
    Can you report HDOP in your textual summary?
  18. #43
    Wow, you have a very strong signal there. It should be easy to pull HDOP out of GSA, it's already parsing that message.
  19. #44
    2,616
    Maybe not. the multiple satellites are from different constellations, i think the gps solution probably uses no more than 12 satellites, though it's able to choose from a larger collection of strong signals.
  20. #45
    Ok, updated the code with the *dop data:
    GPS pdop=1.8, hdop=1.5, vdop=0.9
  21. #46
    Mar 2018
    17
    Not familiar with the M9N. Is it a dual frequency unit, similar to the ublox F9P? If not, I have one of those working right beside my desk as we speak. I could run some of those tests for you as a comparison, with or with ntrip, as you prefer. But I only have a Teensy 4, not a 4.1 (yet.)
  22. #47
    2,616
    Thanks! Not a lot of variation in dop values, maybe needs two decimal places. Here is data for 3 different GPS units with external antenna.
    Adafruit ultimate, 1 constellation
       GPS Strong signals (> 25db): 10, Weak Signals (10db-24db): 2, No Signal (0db-9db): 0
       GPS pdop=1.35, hdop=0.77, vdop=1.11
    NEO-M8U, 2 constellations
       GPS Strong signals (> 25db): 15, Weak Signals (10db-24db): 3, No Signal (0db-9db): 3
       GPS pdop=1.55, hdop=0.7, vdop=1.39
    NEO-M9N, 4 constellations
       GPS Strong signals (> 25db): 20, Weak Signals (10db-24db): 7, No Signal (0db-9db): 3
       GPS pdop=1.1, hdop=0.6, vdop=0.9
    Variations on a theme:
    Just because I could, I hacked your library to use GPT2@24mhz on pin 15 instead of the 1588 timer @25mhz. One could add precision by running GPT @150mhz. And then based on that experiment, I made another version of the library that could do the PID tuning on a Teensy 4.0 (no Ethernet) using GPT2 capture.
  23. #48
    May 2015
    USA
    840
    A feature request - discipline the audio clock to the GPS with small tweaks to the rate and this code:
    // set audio rate in Hz
    void ClockSkew::setAudioRate(double fs)
      // !!! you must change avr/libraries/Audio/avr/libraries/Audio/output_XXX.cpp
      // to be "int c2 = 10000000;"     Not 10000.
      Serial.printf("abs rate: %.10f\n", fs);
      assert(CCM_ANALOG_PLL_AUDIO_DENOM >= 1000000);     // has user changed this for more resolution?
      // calc new audio clock rate
      // this block from teensy code
      // PLL between 27*24 = 648MHz und 54*24=1296MHz
      // n1, n2 choosen for compatibility with I2S (same PLL frequency) :
      int n1 = 4; //SAI prescaler 4 => (n1*n2) = multiple of 4
      int n2 = 1 + (24000000 * 27) / (fs * 256 * n1);
      double C = ((double)fs * 256 * n1 * n2) / 24000000;
      int c0 = C;
      int c2 = CCM_ANALOG_PLL_AUDIO_DENOM;
      int c1 = C * c2 - (c0 * c2);
      CCM_ANALOG_PLL_AUDIO_NUM = c1;   // set rate
    }  // setAudioRate()
