Page 3 of 3 FirstFirst 1 2 3
Results 51 to 71 of 71
Thread: Teensy 4.1 NTP server
  1. #51
    Jan 2021
    17
    Some initial results
    Good afternoon all,
    Some early results:
Name:	Screenshot 2021-05-21 160138.jpg
Name:	Screenshot 2021-05-21 160202.jpg
    And the stats from the bottom:
    PPS To GPS: 107 ms
    millis() at PPS: 9376.972
    millis() at GPS Timestamp: 9377079
    millis() now: 9377.766
    NTP time: 3830619824
    IEEE 1588 counter at PPS: 2463559265
    Offset between NTP/GPS times: 0.000000029 s
    Estimate of NTP clock freq: 0.000009757 s/s
    ChiSq fit of freq measure: 1.678
    PID output: 9760 ns/s (ppb)
    GPS lock Status: 3D
    GPS Strong signals (> 25db): 14, Weak Signals (10db-24db): 0, No Signal (0db-9db): 1
    GPS pdop=1.6, hdop=0.8, vdop=1.4
    And Meinberg shows it as a valid peer available for synchronization.
Name:	Screenshot 2021-05-21 160454.jpg
    I should note that:
    192.168.4.66 is the Teensy.
    192.168.4.65 is a Chinese NTP server from the ePlace.
    192.168.4.50 is an RPi NTP server.
    192.168.4.57 is an RPi NTPSec server.
    Why do I have four GPS NTP servers on my local network? Why not? hahaha
    Thanks much,
    Ben
  2. #52
    Jan 2021
    17
    Quote Originally Posted by ddrown View Post
    I'd love to see your enclosure design, that sounds neat. I've been meaning to design a "shield" with a GPS module and an ethernet connector built in, but keep on getting distracted with other projects.
    The enclosure is actually a recycled extruded aluminum enclosure from the ePlace that held a previous, failed project. The 3D printed part was a piece to hold the Teeny ethernet jack board - nothing really special, but here's a quick screen-grab just for giggles:
Name:	Screenshot 2021-05-21 161028.jpg
    If anyone desires, I'll upload the source files. I can do STL, STEP, IGES, et cetera, just let me know.
    The jack mounts with two screws into a 1" hole. I can drill nice round holes; squares are a lot more difficult.
    Thanks much,
    ben
  3. #53
    Quote Originally Posted by kd5byb View Post
    Those are some good GPS signals
    Interesting that .65 claims a round trip time of 59 microseconds. I wonder if it's lying about the transmit time on the response. The RPIs and the Teensy seem to agree to the time within 100 microseconds and were all polled at around a minute of each other. Using a 1024 second interval, it's hard to tell if the .65 server is off by 500 microseconds or if the local time had just drifted by that much in 10 minutes.
    I agree, I think there should be more GPS NTP servers.
  4. #54
    Jan 2021
    17
    The antenna I'm using is a cheap, magnetic-mount eBay special on a groundplane about a foot square, inside the house. I do have an external amplified GPS antenna that I split 8-ways with a non-amplified splitter, it's both better (better view of the sky) and worse (the splitter adds a lot of loss). In the past, the receiver that feeds the outdoor antenna with +5VDC for power failed, which took down *everything*, so I now keep two of the NTP servers on dedicated, magnetic-mount antennas.
    I have my doubts about the Chinese NTP server. Apparently, it's a Telit GPS module feeding a fairly low-cost TI microcontroller based on a Cortex M4. There are a couple of photos of the unit opened up here: https://fc-ntp-100.toimii.fi/ It would not surprise me if the Chinese NTP server was doing something funky such as lying about transmit time. I've been keeping my eyes open for a "real" NTP server by Endrun, Brandywine, Spectracom, etc., but so far, none have come up at a price I'm willing to pay. My thought is that a "real" NTP server would be the reference to which I could compare all the others.
    Totally in agreement - with GPS NTP being so low cost these days, there should be more of them out there.
    Thanks much,
    Ben
  5. #55
    Jan 2021
    17
    Cool And some additional results!
    Figured I'd follow up now that the Teensy NTP has had some time in its new enclosure. PLUS, I powered down the Chinese NTP Server (192.168.4.65) just for kicks. I do think it was somehow lying to me.
Name:	Screenshot 2021-05-24 172628.jpg
Name:	Screenshot 2021-05-24 172651.jpg
Name:	Screenshot 2021-05-24 172714.jpg
    PPS To GPS: 104 ms
    millis() at PPS: 273805.386
    millis() at GPS Timestamp: 273805490
    millis() now: 273805.702
    NTP time: 3830884255
    IEEE 1588 counter at PPS: 3169238425
    Offset between NTP/GPS times: -0.000000025 s
    Estimate of NTP clock freq: 0.00001024 s/s
    ChiSq fit of freq measure: 3.940
    PID output: 10237 ns/s (ppb)
    GPS lock Status: 3D
    GPS Strong signals (> 25db): 13, Weak Signals (10db-24db): 0, No Signal (0db-9db): 1
    GPS pdop=2, hdop=0.9, vdop=1.7
    I'm pretty happy! Fairly good agreement between the Teensy and the two RPi GPS/NTP servers.
    Thanks much,
    ben
  6. #56
    May 2015
    USA
    1,084
    Nice work.
    Somewhat off topic, but if a PC is left connected and the goal is just an accurate teensy clock, then one can simplify with the use of the PC (with a ntp client on it) as an accurate timing source. For example, I use a once per second single byte from the PC to adjust the teensy audio clock. Which eliminates some obnoxious audio artifacts and buffer xruns.
  7. #57
    Jan 2021
    17
    Greetings all - dumb question time: on y'alls Teensy 4.1 NTP servers, does the RJ45 jack LED light up? (assuming you're using the PJRC ribbon header / RJ45 jack board) Mine does not and I'm wondering if I've got a cold solder joint or something like that...
    thanks,
    ben
  8. #58
    Yeah, I'm also using the magnetic-mount antennas on a windowsill.
    LeoNTP is another low cost NTP server, and I've seen some good results from other people's tests of them.
    Quote Originally Posted by jonr
    Yup, NTP client will meet most everyone's needs these days. Of course, those NTP clients need to get time from somewhere, which is why I created an NTP server I'm also using it as one of the upstream sources of my cloud VMs which are part of the NTP pool, which serves time to everything from android phones, to other people's servers.
    yeah, I get the green link LED that blinks on activity
  9. #59
    Jan 2021
    17
    Red face
    Very good. Just pulled my 4.1 out of the case and the green LED lights from an external supply when powered thru the Teensy end of the cable. Reflowed the solder joints on the pins and measured 150 ohms from the LED pin to the other side of the 150 ohm resistor (which was super hard to do, those resistors are tiny). Still doesn't work. Probably needs a reflow on the ethernet chip, but that's above my skill level so I'm just going to leave it alone and call it good as-is.
    Thanks much,
    ben
  10. #60
    Dec 2015
    LA
    230
    Awesome project!
    Thanks for making it available. I've finally gotten it running with a ublox NEO-M8N-0-10 module and active antenna.
    In settings.h
    uncomment the #define GPS_USES_RMC
    change the baud rate to GPS_BAUD 9600
    and in GPS.cpp
    change:
    #define GPS_CODE_RMC "GPRMC"
    #define GPS_CODE_GGA "GPGGA"
    to:
    #define GPS_CODE_RMC "GNRMC"
    #define GPS_CODE_GGA "GNGGA"
    Curious that the GPS_CODE... needed to be changed. Didn't see that posted by others using M8N? Maybe the modules 2.x firmware should be updated to 3.x?
    Not sure why but my Clock Sync count settles to 26.xxx ppm rather than others posted 8.xxx. As noted temperature is a big factor.
    As you are no doubt aware the Teensy4.1 can be run at many CPU speeds. Your program seems to run fine even at the lowest 24MHz speed. Not sure what all the effects are but the PID seems to work just fine, maybe a little more overshoot. Probably the ntp responses will be worse.
    With the lower speed -> power dissipation -> lower temperature variation, I have noticed a quieter Clock Sync count
    600Mhz mine settles to 27 +-.020
    24MHz 26 +-.005
    In an unrelated program found that when the CPU speed speed is changed on the fly the internal temp sensor response tc is < .5 sec. Haven't tried yet on this program but I will and post some plots if anyone is interested. Perhaps the Clock cycle count could be smoothed by changing the CPU speed?
    I would like to get a 10MHz signal output. Any thoughts on the best way to do this?
  11. #61
    2,663
    Every crystal is likely to have a different frequency offset (drift,ppm). The spec for the crystal specifies the expected range, e.g. +-20 ppm. FWIW, for my various Teensy 4s, here are measured drift values. As you noted, frequency can vary with temperature (post #15).
    The Teensy 4 can generate 10mhz PWM (analogWriteFrequency()), but the accuracy will reflect the drift offset of the 24 MHz crystal. Here is a thread that discusses dithering the PWM compare register to "tune" the PWM frequency. You might also search forum for GPSDO. There is also a windows program (u-center) that configures u-blox GPSs and you can configure the GPS PPS output to run at 10MHz (GPS accurate).
  12. #62
    Oct 2012
    Portland OR
    712
    I had not been keeping track of developments; I only just saw the T4.1 NTP server code was updated to include the webserver with some plots and numbers. In case of interest here are my current results, with a rooftop antenna. My receiver is limited to the original US GPS constellation only, but the antenna position allows for reasonably good signal reception.
    PPS To GPS: 347 ms
    millis() at PPS: 2225.722
    millis() at GPS Timestamp: 2226069
    millis() now: 2227.004
    NTP time: 3842900464
    IEEE 1588 counter at PPS: 3955615440
    Offset between NTP/GPS times: 0.000000012 s
    Estimate of NTP clock freq: 0.000008906 s/s
    ChiSq fit of freq measure: 0.224
    PID output: 8907 ns/s (ppb)
    GPS lock Status: 3D
    GPS Strong signals (> 25db): 10, Weak Signals (10db-24db): 1, No Signal (0db-9db): 0
    GPS pdop=1.8, hdop=1, vdop=1.5
ID:	26144   Click image for larger version.
  13. #63
    Jan 2015
    UK
    179
    I'm trying to get the teensy-ntp.ino example to work with the Adafruit Ultimate GPS V3. The PPS is connected to T4.1 D35 but I can't get any coordinates on the output.
    I've tried changing the setting as in msg #60 but still nothing.
    On the CLI I get this :
    Ethernet 1588 NTP Server
    netif status changed: ip 0.0.0.0, mask 0.0.0.0, gw 0.0.0.0
    waiting for link
    enet link status: up
    netif status changed: ip 192.168.1.87, mask 255.255.255.0, gw 192.168.1.1
    On the browser after a few seconds the GPS lock Status changes to 3D so I assume the Tx and Rx is wired correctly but everything else is blank.
    Any idea on how to fix this ?
  14. #64
    2,663
    here is minimal GPS test sketch running with T4.1 and adafruit ultimate v3 GPS
    // GPS Tx to  T4 pin 0 Rx,  PPS to T4 pin 35, 3v3 to Vin, GND to GND
    void ding() {
      Serial.println("\nPPS");
      while (!Serial);
      attachInterrupt(35, ding, RISING);
      Serial1.begin(9600);
      while (Serial1.available()) Serial1.read();
      while (Serial1.available()) {
        char c = Serial1.read();
        Serial.print(c);
    you may need external antenna to establish and maintain fix.
    PPS
    $GPGGA,221016.000,xx01.3036,N,0xx12.4109,W,2,5,1.34,202.1,M,-32.1,M,0000,0000*65
    $GPGSA,A,3,16,26,31,04,32,,,,,,,,1.61,1.34,0.90*0F
    $GPRMC,221016.000,A,xx01.3036,N,0xx12.4109,W,0.70,154.20,031121,,,D*7B
    $GPVTG,154.20,T,,M,0.70,N,1.30,K,D*3F
    PPS
    $GPGGA,221017.000,xx01.3036,N,0xx12.4107,W,2,5,1.34,202.3,M,-32.1,M,0000,0000*68
    $GPRMC,221017.000,A,xx01.3036,N,0xx12.4107,W,0.65,154.66,031121,,,D*72
    $GPVTG,154.66,T,,M,0.65,N,1.21,K,D*39
  15. #65
    Jan 2015
    UK
    179
    Thanks for the code. The ding() is called.
    I get the output ok.
    PPS
    $GPGGA,221922.000,51xx.2695,N,00004.5937,E,2,8,0.9 8,75.8,M,47.0,M,0000,0000*66
    $GPGSA,A,3,29,25,12,31,32,04,02,26,,,,,1.55,0.98,1 .21*0E
    $GPGSV,3,1,11,29,81,137,31,31,62,276,49,25,55,094, 32,49,30,173,28*7C
    $GPGSV,3,2,11,02,27,048,22,26,27,283,43,12,22,093, 23,32,10,222,38*7D
    $GPGSV,3,3,11,18,10,170,20,04,06,339,25,20,06,072, 16*4F
    $GPRMC,221922.000,A,51xx.2695,N,00004.5937,E,0.02, 55.24,031121,,,D*56
    $GPVTG,55.24,T,,M,0.02,N,0.03,K,D*0F
    PPS
    $GPGGA,221923.000,51xx.2695,N,00004.5937,E,2,8,0.9 8,75.8,M,47.0,M,0000,0000*67
    $GPGSA,A,3,29,25,12,31,32,04,02,26,,,,,1.55,0.98,1 .20*0F
    $GPRMC,221923.000,A,51xx.2695,N,00004.5937,E,0.02, 55.24,031121,,,D*57
    $GPVTG,55.24,T,,M,0.02,N,0.04,K,D*08
    PPS
    $GPGGA,221924.000,51xx.2695,N,00004.5937,E,2,8,0.9 8,75.8,M,47.0,M,0000,0000*60
    $GPRMC,221924.000,A,51xx.2695,N,00004.5937,E,0.01, 55.24,031121,,,D*53
    $GPVTG,55.24,T,,M,0.01,N,0.03,K,D*0C
    PPS
    $GPGGA,221925.000,51xx.2695,N,00004.5937,E,2,8,0.9 8,75.8,M,47.0,M,0000,0000*61
    $GPRMC,221925.000,A,51xx.2695,N,00004.5937,E,0.01, 55.24,031121,,,D*52
  16. #66
    2,663
    Hmm, the simple test looks OK. What i have seen if you don't have an external antenna, when you power up the T4.1 ethernet, the adafruit GPS loses fix. With no fix, you get the web page that you illustrated --- mosly 0s, and nothing printing on the serial monitor after the initial ether setup. Do you have an external antenna attached to adafruit GPS?
  17. #67
    Jan 2015
    UK
    179
    Yes, I've got an external antenna connected. At power up the LED blink about once per second and after a few seconds when it gets the lock the LED flash once every few seconds.
  18. #68
    2,663
    confirm settings.h has
    #define GPS_BAUD 9600
    #define GPS_SERIAL Serial1
    #define DHCP_HOSTNAME "teensy-1"
  19. #69
    Jan 2015
    UK
    179
    Yes, I've changed the settings in settings.h
    Also I've tried to change:
    GPS.cpp
    to:
    I think I need to put more debug msg in the code.
  20. #70
    2,663
    Quote Originally Posted by skpang View Post
    GPS.cpp
    to:
    I've made NO changes to GPS.cpp. and you are not getting GNRMC sentences, you're getting GPRMC
  21. #71
    Jan 2015
    UK
    179
    Wow, got it working now.
    I only need to make changes to settings.h and not the GPS.cpp
    Thanks for your help manitou.
