I'm new to Teensy and wonder if anyone can help me by suggesting any way forward to this problem?
I'm using a Teensy 4.1 and the new Audio Board for the 4.
Background
I have always wanted to build a synth and have been following Notes and Volts series on YouTube. I've reached episode 9 (https://www.youtube.com/watch?v=l34CNfwfuIY&t=328s ) where you build a 5 pin DIN traditional midi-input circuit. Everything was going well!
Problem
When I play notes, the synth plays the right sounds but they are accompanied by a slight crackling sound (only when the notes are triggered).
What I have tried so far:
So I am thinking - it can only be the code (see below) or the boards?
The code? - Lots of people seem to have completed the Notes and Volts Teensy Synth and I haven't seen any mention in the comments on YouTube of the issue.
The board? The examples (e.g. guitar, PlaySynthMusic) all work fine, although of course they don't need any midi notes. And the MidiSynth examples are not compatible with Teensy 4 so I can't test it with those. Might it be that the Notes and Volts code, which was designed for Teensy 3.2 is not able to run properly on Teensy 4 even though it compiles and loads OK?
I also thought maybe it's my soldering? But I have checked all the solder joints with a magnifying glass and they're all good.
And now I am stumped!
Any advice much appreciated.
Thanks in advance.
Background
Problem
- I swapped the midi keyboard for another one - no change.
- I found a post on this forum suggesting using the pjrc midi input circuit rather than the Notes and Volts one (there is an additional 1uf capacitor on the pjrc version). I fitted capacitor - no change.
- I've downloaded a trial version of Ableton Live and set it up so that it provides the USB midi notes (instead of a physical keyboard) - the notes sound, but so does the crackling.
Thanks in advance.
// Teensy-Synth Part 9
// 5-PIN MIDI INPUT
// By Notes and Volts
// www.notesandvolts.com
#include <SerialFlash.h>
#include <MIDI.h>
AudioSynthWaveform waveform2; //xy=382,453
AudioSynthWaveform waveform1; //xy=386,394
AudioSynthNoisePink pink1; //xy=394,504
AudioMixer4 mixer1; //xy=577,454
AudioFilterStateVariable filter1; //xy=725,457
AudioEffectEnvelope envelope1; //xy=888,458
AudioOutputI2S i2s1; //xy=1049,465
AudioConnection patchCord1(waveform2, 0, mixer1, 1);
AudioConnection patchCord2(waveform1, 0, mixer1, 0);
AudioConnection patchCord3(pink1, 0, mixer1, 2);
AudioConnection patchCord4(mixer1, 0, filter1, 0);
AudioConnection patchCord5(filter1, 0, envelope1, 0);
AudioConnection patchCord6(envelope1, 0, i2s1, 0);
AudioConnection patchCord7(envelope1, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=565,556
// GLOBAL VARIABLES
const byte BUFFER = 8; //Size of keyboard buffer
const float noteFreqs[128] = {8.176, 8.662, 9.177, 9.723, 10.301, 10.913, 11.562, 12.25, 12.978, 13.75, 14.568, 15.434, 16.352, 17.324, 18.354, 19.445, 20.602, 21.827, 23.125, 24.5, 25.957, 27.5, 29.135, 30.868, 32.703, 34.648, 36.708, 38.891, 41.203, 43.654, 46.249, 48.999, 51.913, 55, 58.27, 61.735, 65.406, 69.296, 73.416, 77.782, 82.407, 87.307, 92.499, 97.999, 103.826, 110, 116.541, 123.471, 130.813, 138.591, 146.832, 155.563, 164.814, 174.614, 184.997, 195.998, 207.652, 220, 233.082, 246.942, 261.626, 277.183, 293.665, 311.127, 329.628, 349.228, 369.994, 391.995, 415.305, 440, 466.164, 493.883, 523.251, 554.365, 587.33, 622.254, 659.255, 698.456, 739.989, 783.991, 830.609, 880, 932.328, 987.767, 1046.502, 1108.731, 1174.659, 1244.508, 1318.51, 1396.913, 1479.978, 1567.982, 1661.219, 1760, 1864.655, 1975.533, 2093.005, 2217.461, 2349.318, 2489.016, 2637.02, 2793.826, 2959.955, 3135.963, 3322.438, 3520, 3729.31, 3951.066, 4186.009, 4434.922, 4698.636, 4978.032, 5274.041, 5587.652, 5919.911, 6271.927, 6644.875, 7040, 7458.62, 7902.133, 8372.018, 8869.844, 9397.273, 9956.063, 10548.08, 11175.3, 11839.82, 12543.85};
byte globalNote = 0;
byte globalVelocity = 0;
int octave = 0;
const float DIV127 = (1.0 / 127.0);
float detuneFactor = 1;
float bendFactor = 1;
int bendRange = 12;
unsigned int LFOspeed = 2000;
float LFOpitch = 1;
float LFOdepth = 0;
byte LFOmodeSelect = 0;
int FILfreq = 10000;
float FILfactor = 1;
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
AudioMemory(30);
usbMIDI.setHandleControlChange(myControlChange);
usbMIDI.setHandleNoteOff(myNoteOff);
usbMIDI.setHandleNoteOn(myNoteOn);
usbMIDI.setHandlePitchChange(myPitchBend);
MIDI.begin();
MIDI.setHandlePitchBend(myPitchBend);
sgtl5000_1.enable();
sgtl5000_1.volume(0.32);
waveform1.begin(WAVEFORM_SAWTOOTH);
waveform1.amplitude(0.75);
waveform1.frequency(82.41);
waveform1.pulseWidth(0.15);
waveform2.begin(WAVEFORM_SAWTOOTH);
waveform2.amplitude(0.75);
waveform2.frequency(123);
waveform2.pulseWidth(0.15);
pink1.amplitude(1.0);
mixer1.gain(0, 1.0);
mixer1.gain(1, 1.0);
mixer1.gain(2, 0.0);
envelope1.attack(0);
envelope1.decay(0);
envelope1.sustain(1);
envelope1.release(500);
usbMIDI.read();
MIDI.read();
LFOupdate(false, LFOmodeSelect, FILfactor, LFOdepth);
void myNoteOn(byte channel, byte note, byte velocity) {
if ( note > 23 && note < 108 ) {
globalNote = note;
globalVelocity = velocity;
keyBuff(note, true);
LFOupdate(true, LFOmodeSelect, FILfactor, LFOdepth);
void myNoteOff(byte channel, byte note, byte velocity) {
keyBuff(note, false);
void myPitchBend(byte channel, int bend) {
float bendF = bend;
bendF = bendF / 8192;
bendF = bendF * bendRange;
bendF = bendF / 12;
bendFactor = pow(2, bendF);
oscSet();
void keyBuff(byte note, bool playNote) {
static byte buff[BUFFER];
static byte buffSize = 0;
// Add Note
if (playNote == true && (buffSize < BUFFER) ) {
oscPlay(note);
buff[buffSize] = note;
buffSize++;
return;
// Remove Note
else if (playNote == false && buffSize != 0) {
for (byte found = 0; found < buffSize; found++) {
if (buff[found] == note) {
for (byte gap = found; gap < (buffSize - 1); gap++) {
buff[gap] = buff[gap + 1];
buffSize--;
buff[buffSize] = 255;
if (buffSize != 0) {
oscPlay(buff[buffSize - 1]);
return;
else {
oscStop();
return;
void oscPlay(byte note) {
waveform1.frequency(noteFreqs[note] * bendFactor * LFOpitch);
waveform2.frequency(noteFreqs[note + octave] * detuneFactor * bendFactor * LFOpitch);
float velo = (globalVelocity * DIV127);
waveform1.amplitude(velo);
waveform2.amplitude(velo);
pink1.amplitude(velo);
envelope1.noteOn();
void oscStop() {
envelope1.noteOff();
void oscSet() {
waveform1.frequency(noteFreqs[globalNote] * bendFactor * LFOpitch);
waveform2.frequency(noteFreqs[globalNote + octave] * detuneFactor * bendFactor * LFOpitch);
void myControlChange(byte channel, byte control, byte value) {
switch (control) {
case 100:
mixer1.gain(0, (value * DIV127));
case 101:
mixer1.gain(1, (value * DIV127));
case 102:
mixer1.gain(2, (value * DIV127));
case 103:
switch (value) {
case 0:
octave = 24;
case 1:
octave = 12;
case 2:
octave = 0;
case 3:
octave = -12;
case 4:
octave = -24;
oscSet();
case 104:
envelope1.attack(3000 * (value * DIV127));
case 105:
envelope1.decay(3000 * (value * DIV127));
case 106:
envelope1.sustain(value * DIV127);
case 107:
envelope1.release(3000 * (value * DIV127));
case 108:
switch (value) {
case 0:
case 1:
waveform1.begin(WAVEFORM_TRIANGLE);
case 2:
case 3:
waveform1.begin(WAVEFORM_PULSE);
case 109:
switch (value) {
case 0:
waveform2.begin(WAVEFORM_SINE);
case 1:
waveform2.begin(WAVEFORM_TRIANGLE);
case 2:
case 3:
waveform2.begin(WAVEFORM_PULSE);
case 110:
detuneFactor = 1 - (0.05 * (value * DIV127));
oscSet();
case 111:
FILfactor = value * DIV127;
FILfreq = 10000 * (value * DIV127);
if (LFOmodeSelect < 1 || LFOmodeSelect > 5)filter1.frequency(FILfreq);
case 112:
filter1.resonance((4.3 * (value * DIV127)) + 0.7);
case 113:
if (value <= 12 && value > 0) bendRange = value;
case 114:
float xSpeed = value * DIV127;
xSpeed = pow(100, (xSpeed - 1));
LFOspeed = (70000 * xSpeed);
case 115:
LFOdepth = value * DIV127;
case 116:
LFOmodeSelect = value;
void LFOupdate(bool retrig, byte mode, float FILtop, float FILbottom) {
static float LFO = 0;
static unsigned long LFOtime = 0;
static bool LFOdirection = false;
unsigned long currentMicros = micros();
static bool LFOstop = false;
static float LFOrange = 0;
static byte oldMode = 0;
static bool retriggered = false;
if (retrig == true) retriggered = true;
if (currentMicros - LFOtime >= LFOspeed) {
LFOtime = currentMicros;
if (mode != oldMode) {
if (mode == 0 || mode == 8) {
LFOpitch = 1;
oscSet();
else if (mode >= 1 || mode <= 7) {
LFOpitch = 1;
oscSet();
else if (mode >= 9 || mode <= 13) {
oldMode = mode;
LFOrange = FILtop - FILbottom;
if (LFOrange < 0) LFOrange = 0;
// LFO Modes
switch (mode) {
case 0: //Filter OFF
return;
case 1: //Filter FREE
filter1.frequency(10000 * ((LFOrange * LFO) + LFOdepth));
case 2: //Filter DOWN
if (retriggered == true) {
LFOdirection = true;
LFO = 1.0;
case 3: //Filter UP
LFO = 0;
case 4: //Filter 1-DN
LFOstop = false;
LFO = 1.0;
if (LFOstop == false) filter1.frequency(10000 * ((LFOrange * LFO) + LFOdepth));
case 5: //Filter 1-UP
LFOstop = false;
LFO = 0;
case 8: //Pitch OFF
return;
case 9: //Pitch FREE
LFOpitch = (LFO * LFOdepth) + 1;
oscSet();
case 10: //Pitch DOWN
LFO = 1.0;
oscSet();
case 11: //Pitch UP
LFO = 0;
oscSet();
case 12: //Pitch 1-DN
LFOstop = false;
LFO = 1.0;
if (LFOstop == false) {
oscSet();
case 13: //Pitch 1-UP
LFOstop = false;
LFO = 0;
oscSet();
// Update LFO
if (LFOdirection == false) { //UP
LFO = (LFO + 0.01);
if (LFO >= 1) {
LFOstop = true;
if (LFOdirection == true) { //Down
LFO = (LFO - 0.01);
if (LFO <= 0) {
LFOstop = true;
