Results 1 to 3 of 3
Thread: MicroE-506 with AudioControlWM8731master Problem
    Mar 2020
    Italy
    17
    Hi guys, i'm trying to setup my new buy. MicroE-506 With Teensy 4.0 (or Teensy 3.2).
    I'm having some problem with easy examples so probably there's something that I dont understand.
    I'm trying to connect my poket operator (PO-16) in (mic-in jack) and my headpohones (in output jack) to make some real time effect.
    If I connect just AudioInputI2S in a AudioOutputI2S everything seems to work and i can hear the sound in my headphones.
    But if I use some effect like Filter or Delay I have problem.
    if I use Filter -> I can hear just a strong white noise
    if I use a Delay -> I can hear PO input but everything is distorted (like clipping)
    I have follow wiring instruction in the WM8731MikroSine Example.
    This the code of filter test
    AudioInputI2S            i2s1;           //xy=99,60
    AudioFilterBiquad        biquad1;        //xy=257,60
    AudioOutputI2S           i2s2;           //xy=416,60
    AudioConnection          patchCord1(i2s1, 0, biquad1, 0);
    AudioConnection          patchCord2(biquad1, 0, i2s2, 0);
    AudioConnection          patchCord3(biquad1, 0, i2s2, 1);
    AudioControlWM8731master wm8731m1;       //xy=526.0104370117188,988.0103330612183
      delay(1000); // allow the WM7831 extra time to power up
      wm8731m1.enable();
      AudioMemory(15);
      wm8731m1.volume(0.50);
      wm8731m1.inputSelect(AUDIO_INPUT_MIC);
      // wm8731m1.inputSelect(AUDIO_INPUT_LINEIN); // not connected on MikroE-506
      // Butterworth filter, 12 db/octave
      biquad1.setLowpass(0, 1000, 0.707);
      // Linkwitz-Riley filter, 48 dB/octave
      //biquad1.setLowpass(0, 800, 0.54);
      //biquad1.setLowpass(1, 800, 1.3);
      //biquad1.setLowpass(2, 800, 0.54);
      //biquad1.setLowpass(3, 800, 1.3);
    Can anyone help me.
    Thank
    Andrea
    22,272
    If you configure the WM8731 with AudioControlWM8731master, then you need to use AudioInputI2Sslave and/or AudioOutputI2Sslave to communicate with it.
    Using AudioControlWM8731master together with AudioInputI2S & AudioOutputI2S will cause both Teensy and the WM8731 to attempt to drive BCLK and LRCLK. Not good...
    Mar 2020
    Italy
    17
    Ok, now it's working! :-)
    Thank you very much for your help.
