Page 2 of 2 FirstFirst 1 2
Results 26 to 31 of 31
Thread: Teensy 4.1 Based CNC Controller
  1. #26
    Germany
    1,115
    I had a look at the grblHAL repositiory. It indeed has much improved lathe support. Looks like I have a nice winter project :-)
  2. #27
    Apr 2019
    6
    I've built up one of these boards as a replacement for for a g2core based CNC setup on a mill. I had been using ChiliPeppr to control it, and was pretty happy with that setup partly because it's one of the few controller setups that runs on a Macintosh. I've got an old Mac laptop that I'd like to continue using for this. My initial testing showed that ChiliPeppr grbl 1.1 doesn't work well with grblHAL. It'll run the motors, but the position counters and 3d preview don't update.
    I have a Windows PC in my home office that I use for computer graphics, and I have been testing the board with that running the Universal Code Sender GrblHAL fork, and that works, but I'd rather not have to get another windows PC just to run it.
    Anyone know of a Gcode sender that runs on a Macintosh that will play nicely with this controller?
  3. #28
    Mar 2016
    211
    Hi John. Have you tried grblHAL with compatibility settings? It takes a recompile though I have prebuilt 3, 4 and 5 axis versions on the github page. Or, you can build it yourself from the grblHAL github site. Follow the instructions in the wiki. The recently introduced changes to the build system make it easy to configure.
    On senders - UGS and bCNC work with grblHAL built with compatibility settings as well. Most java based senders work though you might have to play with the compatibility settings. (I think a section in the wiki needs to be created.)
    If you use a Windows PC, your best bet is the CGode Sender built for grblHAL. It truly is the best one out there. Even though it is in a "pre-release" state, beta 6 is very stable. I have been using it for a while now. Just recently I used it to make quite a few signs for a recent wedding and they all came out great. Visualizations are realtime. It's grbl config section is head and shoulders above the other senders. It's probing capabilities are outstanding - especially height map probing to mill/route uneven surfaces. Great for engravings and PCB milling. Works with simple contact probes as well as 3D probes. If you use it, be sure to check the site regularly - Terje, the developer, is actively adding features as well as fixing bugs.
  4. #29
    Apr 2019
    6
    Ah, I didn't know about the compatibility setting builds. I'll give that a try, thanks.
    I hear you on using the forked grblHAL Universal Gcode Sender. It does look like the best option. I was just trying to avoid getting another Windows PC to install in the garage when I already have an old Mac that's been doing the job for a few years now.
    I figure these grblHAL controllers are likely the future of hobby cnc work, given that grbl on 8bit avr micro controllers is at a dead end. These faster and more capable controllers have so much more headroom for improved features and are getting to be so inexpensive these days that I've gotta imagine they'll be everywhere soon.
  5. #30
    Mar 2016
    211
    I'm hoping that the UGC and bCNC folks get grblHAL religion. It is capable of taking significant share from both grbl "classic" and LinuxCNC.
    But, to be honest, java based GCode Senders have their limitations. It would be great to get a native IOS app but, since there isn't one for grbl classic, I won't hold my breath.
    If you are going to be doing a lot of CNC work, it's probably worth getting a cheap/old Win PC (even win7) to run the sender I linked to previously. It supports ethernet which is highly preferable to USB. My BoB also supports ethernet, by the way, just add the magjack.
