Results 1 to 4 of 4
Thread: adjustTime(number) problem when adding seconds
    Jul 2020
    Netherlands
    3
    As you can see, I added some test code to the existing example TimeTeensy3. With test set to HIGH you can see that the clock doesn't advance beyond 5 minutes or so.
    With test set to LOW the clock advances OKE.
    Seems that there is a problem with adjustTime?
ID:	20834 Click image for larger version.
    >>> Added code <<<<
    boolean test=HIGH;
    if (test) {
    adjustTime(120); // Does not work beyond 5 min. when test=HIGH
    setTime(now()+120); // Works perfect when test=LOW
    Jul 2020
    Netherlands
    3
    I forgot to tell that this is done on a Teensy 3.6.
    The example sourcecode is on Github examples/TimeTeensy3/TimeTeensy3.ino
    May 2017
    106
    with adjusttime() you set timelib object but not the RTC on Tennsy 3.x.
    In setup() you have set syncronisation of timelib with teensy-RTC by "setSyncProvider(getTeensy3Time)". Default time for sync is 300 seconds (5 minutes). You can change this by "setSyncInterval(seconds)".
    So after 5 minutes your before adjusted time in timelib (+120) ist resyncronised with RTC an set with value of RTC.
    Bear in mind timelib and RTC are two independent objects.
    Of course you can also adjust RTC with "Teensy3Clock.set(t)".
    Jul 2020
    Netherlands
    3
    Thanks for the great and quick reply.
    That explains a lot!!
