Results 1 to 1 of 1
Thread: Teensy 4.0 - synchronizing PWMs and left/center/right-aligned configurations
    Aug 2019
    12
    Greetings All!
    Using the Teensy 4.0 with a PWM switching output of 25kHz for an AC-DC boost converter. I am using an external parallel interface ADC to simultaneously sample input voltage, input current, and output voltage at the same 25kHz rate.
    --> In terms of the Teensy 4.0, I'm using:
    1 analogWrite PWM to trigger the external ADC conversions (constant duty cycle, let's say 50%)
    1 PWM to switch the switching transistor (variable duty cycle - this is the output of the control law on the Teensy)
    I want:
    The switching transistor PWM to be center-aligned
    The ADC trigger PWM to be left-aligned
    Both PWMs to be synchronized to the same clock.
    Is this possible?
    Diagram here to illustrate what I'm looking for (external ADC "conversion start" is triggered by a positive edge).
