Results 1 to 2 of 2
Thread: teensy_loader_cli with multiple devices connected
    Apr 2020
    3
    I have a system that has multiple (at this time 2) Teensy 3.2s attached via USB to a raspberry pi. I have udev rules to label the serial ports presented by each so I know which is which when they enumerate so I talk to the right one.
    Initially I had just one device and I was using teensy_loader_cli to push updates to the device, now I've added the second I can't find a way to distinguish between them when I want to update new sketches?
    At the moment it's always picking the last one to enumerate which is making life difficult...
    Apr 2020
    3
    In case anybody else stumbles on this needing the same.
    I took the patch from here and paired it with:
    udevadm info /dev/ttyACM0 | awk -F "[ =]" '/ID_SERIAL_SHORT/ { print $3 }'
    which will grab the serial number for the matching Serial port device.
