I have built a 32x32 LEB Dit matrix BI Color display. The code used for that display will run on ATmel328P ro Mega 2560. Well, that is not fast enough, and the NodeMCU is 80 Mhz, I wanted to port the code over to the Teensy 3.x or Teensy 4.x. The code is defined below:
Please ignore the Pin numbers for the time being, I am try to Compile the Code I am getting the following error Message and would like to know if there is an work around to get the code to work on Teensy.
NODEMCU_RAINBOW_BICOLOR_MATRIX_8x32_wemos:149: error: 'timer1_isr_init' was not declared in this scope
timer1_isr_init();
NODEMCU_RAINBOW_BICOLOR_MATRIX_8x32_wemos:150: error: 'timer1_attachInterrupt' was not declared in this scope
timer1_attachInterrupt(timer1_ISR);
NODEMCU_RAINBOW_BICOLOR_MATRIX_8x32_wemos:151: error: 'TIM_DIV16' was not declared in this scope
timer1_enable(TIM_DIV16, TIM_EDGE, TIM_SINGLE);
NODEMCU_RAINBOW_BICOLOR_MATRIX_8x32_wemos:151: error: 'TIM_EDGE' was not declared in this scope
NODEMCU_RAINBOW_BICOLOR_MATRIX_8x32_wemos:151: error: 'TIM_SINGLE' was not declared in this scope
NODEMCU_RAINBOW_BICOLOR_MATRIX_8x32_wemos:151: error: 'timer1_enable' was not declared in this scope
NODEMCU_RAINBOW_BICOLOR_MATRIX_8x32_wemos:152: error: 'timer1_write' was not declared in this scope
timer1_write(60);
D:\Aduino software\HC595 Projects\32x32_Bi_color_led_matrix\NODEMCU-WITH-32x32-BICOLOR-LED-BOARD-master\NODEMCU_RAINBOW_BICOLOR_MATRIX_32x32_wemos\NODEMCU_RAINBOW_BICOLOR_MATRIX_8x32_wemos\NODEMCU_RAINBOW_BICOLOR_MATRIX_8x32_wemos.ino: At global scope:
NODEMCU_RAINBOW_BICOLOR_MATRIX_8x32_wemos:413: error: expected initializer before 'timer1_ISR'
void ICACHE_RAM_ATTR timer1_ISR()
//*********************** NODEMCU ESP8266 WITH THE 32x32 BICOLOR MATRIX USING B.A.M METHOD *******************//
#include <Arduino.h>
#include "bitmap.h"
#include "font8x8.h"
#include "font8x16.h"
#include "vnfont8x16.h"
// REAL PIN ON NODEMCU
#define blank_pin 15 // BLANK PIN - 74HC595 (13)
#define latch_pin 2 // LATCH PIN - 74HC595 (12)
#define clock_pin 14 // CLOCK PIN - 74HC595 (11)
#define data_pin 13 // DATA PIN - 74HC595 (14)
#define RowA_Pin 16 // A PIN - 74HC238
#define RowB_Pin 5 // B PIN - 74HC238
#define RowC_Pin 4 // C PIN - 74HC238
#define RowD_Pin 0 // D PIN - 74HC238
#define OE_Pin 15 // ENABLE OUTPUT PIN - 74HC238 (Connect to blank_pin).
//MAPPING TO PORT
#define Blank_Pin_Bit 15 // GPIO15 D8
#define Latch_Pin_Bit 2 // GPIO2 D4
#define Clock_Pin_Bit 14 // GPIO14 D5
#define Data_Pin_Bit 13 // GPIO13 D7
#define RowA_Pin_Bit 16 // GPIO16 D0
#define RowB_Pin_Bit 5 // GPIO5 D1
#define RowC_Pin_Bit 4 // GPIO4 D2
#define RowD_Pin_Bit 0 // GPIO0 D3
#define OE_Pin_Bit 15 // GPIO15 D8
//***************************************************CONST************************************************//
#define myPI 3.14159265358979323846
#define myDPI 1.2732395
#define myDPI2 0.40528473
#define dist(a, b, c, d) sqrt(double((a - c) * (a - c) + (b - d) * (b - d)))
#ifndef _swap_int16_t
#define _swap_int16_t(a, b) { int16_t t = a; a = b; b = t; }
//*************************************************ColorWheel******************************************//
#define COLOUR_WHEEL_LENGTH 128
uint8_t colourR[COLOUR_WHEEL_LENGTH];
uint8_t colourG[COLOUR_WHEEL_LENGTH];
int16_t ColPos = 0;
uint16_t colourPos;
uint8_t R, G;
//***************************************************B.A.M**************************************************//
#define BAM_RESOLUTION 4 // EG 4 bit colour = 15 variation of R, G (256 colours)
const byte Size_Y = 32; //Number of LEDS in Y axis (Top to Bottom)
const byte Size_X = 32; //Number of LEDs in X axis (Left to Right)
//const byte Size_Y = 1;
//const byte Size_X = 1;
byte red[4][128];
byte green[4][128];
int level=0; //Keeps tracking of which level we are shifting data to
int row=0;
int BAM_Bit, BAM_Counter=0; // Bit Angle Modulation variables to keep track of things
/********************************************* AN RG COLOR TEMPLATE **********************************************/
struct Color
unsigned char red, green;
Color(int r, int g) : red(r), green(g) {}
Color() : red(0), green(0) {}
const Color redcolor = Color(0x0F,0x00);
const Color orangecolor = Color(0x0F,0x0F);
const Color yellowcolor = Color(0x0F,0x09);
const Color greencolor = Color(0x00,0x0F);
const Color clearcolor = Color(0x00,0x00);
#define RED 0x0F,0x00
#define ORANGE 0x0F,0x04
#define YELLOW 0x0F,0x09
#define GREEN 0x00,0x0F
#define CLEAR 0x00,0x00
//*************************************************ALL FUNNCTIONS******************************************//
void LED(int X, int Y, int R, int G);
void timer1_ISR();
void clearfast();
void fill_colour_wheel(void);
void get_colour(int16_t p, uint8_t *R, uint8_t *G);
void get_next_colour(uint8_t *R, uint8_t *G);
void increment_colour_pos(uint8_t i);
void hScroll(uint8_t y, Color For_color, Color Bk_color, wchar_t *mystring, uint8_t font, uint8_t delaytime, uint8_t times, uint8_t dir);
void hScroll_colorwheel(uint8_t y, Color Bk_color, wchar_t *mystring, uint8_t font, uint8_t delaytime, uint8_t times, uint8_t dir);
void HScrollBigImageL(uint16_t xoffset, uint16_t yoffset, uint16_t width, uint16_t height, const uint8_t *image, Color For_color, Color Bk_color, uint16_t delaytime );
void HScrollBigImageL_colorwheel(uint16_t xoffset, uint16_t yoffset, uint16_t width, uint16_t height, const uint8_t *image, uint16_t delaytime );
void drawImage(uint16_t xoffset, uint16_t yoffset, uint16_t width, uint16_t height, const uint8_t *image, Color For_color, Color Bk_color);
void drawImage_colorwheel(uint16_t xoffset, uint16_t yoffset, uint16_t width, uint16_t height, const uint8_t *image);
void drawImage_colorwheelX(uint16_t xoffset, uint16_t yoffset, uint16_t width, uint16_t height, const uint8_t *image);
void drawImage_colorwheelY(uint16_t xoffset, uint16_t yoffset, uint16_t width, uint16_t height, const uint8_t *image);
void drawImage_inv_colorwheel(uint16_t xoffset, uint16_t yoffset, uint16_t width, uint16_t height, const uint8_t *image);
void drawImage_inv_colorwheelY(uint16_t xoffset, uint16_t yoffset, uint16_t width, uint16_t height, const uint8_t *image);
void EffectMarquee(uint8_t y, wchar_t *mystring);
byte getPixelHString(uint16_t x, uint16_t y, wchar_t *p,uint8_t font);
unsigned int lenString(wchar_t *p);
void fillTable(byte R, byte G);
void fillTable_colorwheel();
void fillTable_colorwheelXY();
float mySin(float x);
float myCos(float x);
float myTan(float x);
float mySqrt(float in);
float myMap(float in, float inMin, float inMax, float outMin, float outMax);
int16_t myRound(float in);
float myAbs(float in);
void drawVLine(uint16_t x, uint16_t y1, uint16_t y2, Color color);
void drawHLine(uint16_t x1, uint16_t x2, uint16_t y, Color color);
void drawFastVLine(int16_t x, int16_t y,int16_t h, Color color);
void drawFastHLine(int16_t x, int16_t y,int16_t w, Color color);
void drawLine_colorwheel(int16_t x0, int16_t y0, int16_t x1, int16_t y1);
void drawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, Color color);
void drawRectangle(uint16_t x1, uint16_t y1, uint16_t x2, uint16_t y2, Color color);
void fillRectangle(uint16_t x1, uint16_t y1, uint16_t x2, uint16_t y2, Color color);
void drawCircle(int xCenter, int yCenter, int radius, Color color);
SPI.setDataMode(SPI_MODE0);
SPI.setBitOrder(MSBFIRST);
SPI.setFrequency(4000000);
noInterrupts();
timer1_isr_init();
timer1_write(60);
pinMode(latch_pin, OUTPUT);
//pinMode(blank_pin, OUTPUT);
pinMode(data_pin, OUTPUT);
pinMode(clock_pin, OUTPUT);
pinMode(RowA_Pin, OUTPUT);
pinMode(RowB_Pin, OUTPUT);
pinMode(RowC_Pin, OUTPUT);
pinMode(RowD_Pin, OUTPUT);
digitalWrite(blank_pin, HIGH); // commented out
interrupts();
SPI.begin();
fill_colour_wheel();
wchar_t scrolltext_1[]=L" * WELCOME TO BICOLOR LED MATRIX 32x32-B.A.M 4 BIT WITH NODEMCU ESP8266, 74HC595 & 74HC238* ";
wchar_t scrolltext_2[]=L" * Welcome to TUENHIDIY doityourself channel * ";
wchar_t scrolltext_3[]=L" * Red Green ~ Colorwheel Matrix ~ Testing ! * ";
clearfast();
HScrollBigImageL_colorwheel(0, 0, 400, 32, INSTRUCTABLES, 20);
clearfast();
drawImage_inv_colorwheel(0, 0, 32, 32, BUG) ;
delay(5000);
clearfast();
hScroll_colorwheel(7, clearcolor, scrolltext_1, 0, 50, 1, 1);
clearfast();
drawImage_inv_colorwheel(0, 0, 32, 32, Facebook) ;
delay(5000);
clearfast();
hScroll_colorwheel(7, clearcolor, scrolltext_3, 0, 40, 1, 1);
clearfast();
for(int i=0; i<50; i++)
drawImage_colorwheelX(0, 0, 32, 32, TIGER01);
delay(110-2*i);
drawImage_colorwheelX(0, 0, 32, 32, TIGER02);
delay(110-2*i);
drawImage_colorwheelX(0, 0, 32, 32, TIGER03);
delay(110-2*i);
drawImage_colorwheelX(0, 0, 32, 32, TIGER04);
delay(110-2*i);
drawImage_colorwheelX(0, 0, 32, 32, TIGER05);
delay(110-2*i);
drawImage_colorwheelX(0, 0, 32, 32, TIGER06);
delay(110-2*i);
clearfast();
drawImage_colorwheel(0, 0, 32, 32, Git_Hub);
delay(5000);
clearfast();
drawImage(0, 0, 32, 32, Whatsapp, yellowcolor, greencolor);
delay(5000);
clearfast();
drawImage(0, 0, 32, 32, Twitter, greencolor, orangecolor) ;
delay(5000);
clearfast();
drawImage(0, 0, 32, 32, Apple, greencolor, orangecolor);
delay(5000);
clearfast();
drawImage(0, 0, 32, 32, Git_Hub, redcolor, clearcolor) ;
delay(5000);
clearfast();
drawImage(0, 0, 32, 32, Facebook, yellowcolor, greencolor) ;
delay(5000);
clearfast();
drawImage(0, 0, 32, 32, Instagram, greencolor, orangecolor) ;
delay(5000);
clearfast();
for(int i=0; i<20; i++){
get_colour(colourPos + 10*i, &R, &G);
drawImage(0, 0, 32, 32, ROT01, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT02, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT03, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT04, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT05, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT06, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT07, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT08, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT09, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT10, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT11, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT12, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT13, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT14, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT15, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT16, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT17, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT18, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT19, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT20, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT21, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT22, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT23, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT24, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT25, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT26, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT27, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT28, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT29, clearcolor, Color(R,G));
delay(10);
drawImage(0, 0, 32, 32, ROT30, clearcolor, Color(R,G));
delay(10);
clearfast();
for(int i=0; i<10; i++){
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE00);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE01);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE02);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE03);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE04);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE05);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE06);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE07);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE08);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE09);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE10);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE11);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE12);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE13);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE14);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE15);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE16);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE17);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE18);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE19);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE20);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE21);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE22);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE23);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE24);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE25);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE26);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE27);
delay(20);
drawImage_inv_colorwheelY(0, 0, 32, 32, FACE28);
delay(20);
clearfast();
HScrollBigImageL_colorwheel(0, 0, 576, 32, CALL, 30);
clearfast();
HScrollBigImageL_colorwheel(0, 0, 624, 32, YOUTUBE, 30);
clearfast();
EffectMarquee(7, scrolltext_1);
clearfast();
fillTable(2,6);
hScroll_colorwheel(7, Color(2,6), scrolltext_2, 0, 40, 1, 1);
clearfast();
drawImage(0, 0, 32, 32, BLACK_TREE, greencolor, orangecolor);
delay(5000);
clearfast();
drawImage(0, 0, 32, 32, DARK_SKULL, greencolor, orangecolor);
delay(5000);
clearfast();
drawImage(0, 0, 32, 32, WHITE_HOME, greencolor, orangecolor);
delay(5000);
clearfast();
drawImage(0, 0, 32, 32, BOOK, greencolor, orangecolor);
delay(5000);
clearfast();
drawImage(0, 0, 32, 32, CHAIR, greencolor, orangecolor);
delay(5000);
clearfast();
drawImage(0, 0, 32, 32, INSTAGRAMM, greencolor, orangecolor);
delay(5000);
clearfast();
drawImage(0, 0, 32, 32, TRASH, greencolor, orangecolor);
delay(5000);
clearfast();
X = constrain(X, 0, Size_X - 1);
Y = constrain(Y, 0, Size_Y - 1);
R = constrain(R, 0, (1 << BAM_RESOLUTION) - 1);
G = constrain(G, 0, (1 << BAM_RESOLUTION) - 1);
int WhichByte = int(Y*4+ X/8);
int WhichBit = 7-(X%8);
for (byte BAM = 0; BAM < BAM_RESOLUTION; BAM++)
bitWrite(red[BAM][WhichByte], WhichBit, bitRead(R, BAM));
bitWrite(green[BAM][WhichByte], WhichBit, bitRead(G, BAM));
void rowScan(byte row)
if (row & 0x01) digitalWrite(RowA_Pin,HIGH);
else digitalWrite(RowA_Pin,LOW);
if (row & 0x02) digitalWrite(RowB_Pin,HIGH);
else digitalWrite(RowB_Pin,LOW);
if (row & 0x04) digitalWrite(RowC_Pin,HIGH);
else digitalWrite(RowC_Pin,LOW);
if (row & 0x08) digitalWrite(RowD_Pin,HIGH);
else digitalWrite(RowD_Pin,LOW);
digitalWrite(blank_pin, HIGH); // Set BLANK PIN high - 74HC595 & 74HC238
if(BAM_Counter==6) // Bit weight 2^0 of BAM_Bit, lasting time = 6 ticks x interrupt interval time
BAM_Bit++;
if(BAM_Counter==18) // Bit weight 2^1 of BAM_Bit, lasting time = 18 ticks x interrupt interval time
BAM_Bit++;
if(BAM_Counter==42) // Bit weight 2^3 of BAM_Bit, lasting time = 42 ticks x interrupt interval time
BAM_Bit++;
BAM_Counter++;
switch (BAM_Bit)
case 0:
//Red
SPI.transfer(red[0][level + 0]);
SPI.transfer(red[0][level + 1]);
SPI.transfer(red[0][level + 2]);
SPI.transfer(red[0][level + 3]);
SPI.transfer(red[0][level + 64]);
SPI.transfer(red[0][level + 65]);
SPI.transfer(red[0][level + 66]);
SPI.transfer(red[0][level + 67]);
//Green
SPI.transfer(green[0][level + 0]);
SPI.transfer(green[0][level + 1]);
SPI.transfer(green[0][level + 2]);
SPI.transfer(green[0][level + 3]);
SPI.transfer(green[0][level + 64]);
SPI.transfer(green[0][level + 65]);
SPI.transfer(green[0][level + 66]);
SPI.transfer(green[0][level + 67]);
case 1:
//Red
SPI.transfer(red[1][level + 0]);
SPI.transfer(red[1][level + 1]);
SPI.transfer(red[1][level + 2]);
SPI.transfer(red[1][level + 3]);
SPI.transfer(red[1][level + 64]);
SPI.transfer(red[1][level + 65]);
SPI.transfer(red[1][level + 66]);
SPI.transfer(red[1][level + 67]);
//Green
SPI.transfer(green[1][level + 0]);
SPI.transfer(green[1][level + 1]);
SPI.transfer(green[1][level + 2]);
SPI.transfer(green[1][level + 3]);
SPI.transfer(green[1][level + 64]);
SPI.transfer(green[1][level + 65]);
SPI.transfer(green[1][level + 66]);
SPI.transfer(green[1][level + 67]);
case 2:
//Red
SPI.transfer(red[2][level + 0]);
SPI.transfer(red[2][level + 1]);
SPI.transfer(red[2][level + 2]);
SPI.transfer(red[2][level + 3]);
SPI.transfer(red[2][level + 64]);
SPI.transfer(red[2][level + 65]);
SPI.transfer(red[2][level + 66]);
SPI.transfer(red[2][level + 67]);
//Green
SPI.transfer(green[2][level + 0]);
SPI.transfer(green[2][level + 1]);
SPI.transfer(green[2][level + 2]);
SPI.transfer(green[2][level + 3]);
SPI.transfer(green[2][level + 64]);
SPI.transfer(green[2][level + 65]);
SPI.transfer(green[2][level + 66]);
SPI.transfer(green[2][level + 67]);
case 3:
//Red
SPI.transfer(red[3][level + 0]);
SPI.transfer(red[3][level + 1]);
SPI.transfer(red[3][level + 2]);
SPI.transfer(red[3][level + 3]);
SPI.transfer(red[3][level + 64]);
SPI.transfer(red[3][level + 65]);
SPI.transfer(red[3][level + 66]);
SPI.transfer(red[3][level + 67]);
//Green
SPI.transfer(green[3][level + 0]);
SPI.transfer(green[3][level + 1]);
SPI.transfer(green[3][level + 2]);
SPI.transfer(green[3][level + 3]);
SPI.transfer(green[3][level + 64]);
SPI.transfer(green[3][level + 65]);
SPI.transfer(green[3][level + 66]);
SPI.transfer(green[3][level + 67]);
if(BAM_Counter==90) //Bit weight 2^3 of BAM_Bit, lasting time = 90 ticks x interrupt interval time
BAM_Counter=0;
BAM_Bit=0;
rowScan(row);
digitalWrite(latch_pin, HIGH); // Set LATCH PIN low - 74HC595
digitalWrite(latch_pin, LOW); // Set LATCH PIN low - 74HC595
digitalWrite(blank_pin, LOW); // Set BLANK PIN low - 74HC595 & 74HC238
row++;
level = row<<2;
if(row==16)
row=0;
if(level==64)
level=0;
timer1_write(60); //Interrupt will be called every 60 x 0.2us = 12us
void clearfast ()
memset(red, 0, sizeof(red[0][0]) * 4 * 128);
memset(green, 0, sizeof(green[0][0]) * 4 * 128);
for (byte x=0; x<32; x++)
for (byte y=0; y<32; y++)
LED(x, y, R, G);
// FONT 8x8
for (int offset=0; offset <((lenString(mystring)-8)*8-1); offset++)
for (byte xx=0; xx<32; xx++)
for (byte yy=0; yy<16; yy++)
Color setcolor, For_color=clearcolor, Bk_color;
get_colour(colourPos + 2*(xx+yy), &Bk_color.red, &Bk_color.green);
if (getPixelHString(xx+offset, yy, mystring,0))
setcolor = For_color;
else setcolor = Bk_color;
LED(xx, (yy+y), setcolor.red, setcolor.green);
increment_colour_pos(1);
delay(50);
byte getPixelChar(uint8_t x, uint8_t y, wchar_t ch,uint8_t font)
if (font==0)
//ch = ch-32;
if (x > 7) return 0; // 4 = font Width -1
if ((ch >=32) && (ch <= 127))
return bitRead(pgm_read_byte(&font8x16[ch-32][y]),7-x);
if ((ch >=192) && (ch <= 273))
return bitRead(pgm_read_byte(&font8x16[ch-96][y]),7-x);
if ((ch >=296) && (ch <= 297))
return bitRead(pgm_read_byte(&font8x16[ch-118][y]),7-x);
if ((ch >=360) && (ch <= 361))
return bitRead(pgm_read_byte(&font8x16[ch-180][y]),7-x);
if ((ch >=416) && (ch <= 417))
return bitRead(pgm_read_byte(&font8x16[ch-234][y]),7-x);
if ((ch >=431) && (ch <= 432))
return bitRead(pgm_read_byte(&font8x16[ch-247][y]),7-x);
if ((ch >=7840) && (ch <= 7929))
return bitRead(pgm_read_byte(&vnfont8x16[ch-7840][y]),7-x);
else if (font==1)
//ch = ch-32;
return bitRead(pgm_read_byte(&font8x8[ch-32][y]),7-x);
else if (font==2)
//ch = ch-32;
if (font==0)
p=p+x/8;
return getPixelChar(x%8,y,*p,0);
else if (font==1)
p=p+x/7;
return getPixelChar(x%7,y,*p,1);
else if (font==2)
p=p+x/8;
return getPixelChar(x%8,y,*p,2);
unsigned int retVal=0;
while(*p!='\0')
retVal++;
p++;
return retVal;
//int offset =0;
// FONT 5x7
int offset;
Color color;
if (font == 0)
while (times)
for ((dir) ? offset=0 : offset=((lenString(mystring)-8)*8-1) ; (dir) ? offset <((lenString(mystring)-8)*8-1) : offset >0; (dir) ? offset++ : offset--)
if (getPixelHString(xx+offset,yy,mystring,0))
color = For_color;
color=Bk_color;
LED(xx,(yy+y),color.red, color.green);
delay(delaytime);
times--;
// FONT 8x8
else if (font == 1)
while (times)
for ((dir) ? offset=0 : offset=((lenString(mystring)-8)*7-1); (dir) ? offset <((lenString(mystring)-8)*7-1): offset >0; (dir) ? offset++ : offset--)
for (byte yy=0; yy<8; yy++)
if (getPixelHString(xx+offset,yy,mystring,1))
color = For_color;
color = Bk_color;
delay(delaytime);
times--;
// FONT 8x16
else if (font == 2)
while (times)
for ((dir) ? offset=0 : offset=((lenString(mystring)-8)*8-1); (dir) ? offset <((lenString(mystring)-8)*8-1) : offset >0; (dir) ? offset++ : offset--)
if (getPixelHString(xx+offset,yy,mystring,2))
color = For_color;
color=Bk_color;
delay(delaytime);
times--;
//int offset =0;
// FONT 5x7
int offset;
Color setcolor, For_color;
if (font == 0)
while (times)
get_colour(colourPos + 3*(xx), &For_color.red, &For_color.green);
setcolor=Bk_color;
LED(xx,(yy+y),setcolor.red, setcolor.green);
delay(delaytime);
times--;
// FONT 8x8
else if (font == 1)
while (times)
get_colour(colourPos + 8*(xx), &For_color.red, &For_color.green);
LED(xx,(yy+y), setcolor.red, setcolor.green);
delay(delaytime);
times--;
// FONT 8x16
else if (font == 2)
while (times)
setcolor=Bk_color;
delay(delaytime);
times--;
for (uint16_t i= 0; i < width-32; i++)
for (uint16_t y = 0; y < height; y++)
for (uint16_t x = 0; x < 32; x++)
uint16_t myindex = (i+x)/8 + y * (width / 8);
uint16_t mybitmask = 7-((i+x) % 8);
uint16_t colorImage = bitRead(pgm_read_byte(&image[myindex]), mybitmask) & 1;
if (colorImage)
LED(x+xoffset, (y+yoffset), For_color.red, For_color.green);
LED(x+xoffset, (y+yoffset), Bk_color.red, Bk_color.green);
delay(delaytime);
Color For_color;
if (colorImage)
get_colour(colourPos + 2*(x+y), &For_color.red, &For_color.green);
LED(x+xoffset, (y+yoffset), 0, 0);
delay(delaytime);
for (uint16_t x = 0; x < width; x++)
uint16_t myindex = x/8 + y*4;
uint8_t mybitmask = 7-(x % 8);
uint8_t colorImage = bitRead(pgm_read_byte(&image[myindex]),mybitmask) & 1;
if (colorImage)
LED(x+xoffset,y+yoffset,For_color.red, For_color.green);
LED(x+xoffset,y+yoffset,Bk_color.red, Bk_color.green);
Color For_color;
if (colorImage)
get_colour(colourPos + 2*(x + y), &For_color.red, &For_color.green);
LED(x+xoffset,y+yoffset,0, 0);
Color For_color;
if (colorImage)
LED(x+xoffset,y+yoffset, 0, 0);
LED(x+xoffset, y+yoffset, For_color.red, For_color.green);
Color For_color;
if (colorImage)
get_colour(colourPos + 2*x, &For_color.red, &For_color.green);
Color For_color;
if (colorImage)
get_colour(colourPos + 2*y, &For_color.red, &For_color.green);
Color For_color;
if (colorImage)
uint8_t R, G, B;
get_colour(colourPos + x + y, &R, &G);
LED(x, y, R, G);
uint8_t R, G, B;
for (byte inter=0; inter<10; inter++)
LED(x, y, R, G);
delay(30);
get_colour(colourPos - 2*y +x, &R, &G);
LED(x, y, R, G);
delay(45);
//*******************************************************MK4*****************************************************//
//FAST SINE APPROX
float mySin(float x){
float sinr = 0;
uint8_t g = 0;
while(x > myPI){
x -= 2*myPI;
g = 1;
while(!g&(x < -myPI)){
x += 2*myPI;
sinr = myDPI*x - myDPI2*x*myAbs(x);
sinr = 0.225*(sinr*myAbs(sinr)-sinr)+sinr;
return sinr;
//FAST COSINE APPROX
float myCos(float x){
return mySin(x+myPI/2);
float myTan(float x){
return mySin(x)/myCos(x);
//SQUARE ROOT APPROX
float mySqrt(float in){
int16_t d = 0;
int16_t in_ = in;
float result = 2;
for(d = 0; in_ > 0; in_ >>= 1){
d++;
for(int16_t i = 0; i < d/2; i++){
result = result*2;
for(int16_t i = 0; i < 3; i++){
result = 0.5*(in/result + result);
return result;
//MAP NUMBERS TO NEW RANGE
float myMap(float in, float inMin, float inMax, float outMin, float outMax){
float out;
out = (in-inMin)/(inMax-inMin)*(outMax-outMin) + outMin;
return out;
//ROUND A NUMBER
int16_t myRound(float in){
int8_t s = in/myAbs(in);
return (int16_t)(s*(myAbs(in) + 0.5));
//ABSOLUTE VALUE
float myAbs(float in){
return (in)>0?(in):-(in);
float red, green;
float c, s;
int32_t phase = 0;
int16_t I = 0;
while (phase < COLOUR_WHEEL_LENGTH)
s = (1 << BAM_RESOLUTION)*mySin(myPI*(3 * phase - I*COLOUR_WHEEL_LENGTH) / (2 * COLOUR_WHEEL_LENGTH));
c = (1 << BAM_RESOLUTION)*myCos(myPI*(3 * phase - I*COLOUR_WHEEL_LENGTH) / (2 * COLOUR_WHEEL_LENGTH));
red = (I == 0 ? 1 : 0)*s + (I == 1 ? 1 : 0)*c;
green = (I == 1 ? 1 : 0)*s + (I == 2 ? 1 : 0)*c;
colourR[phase] = red;
colourG[phase] = green;
if (++phase >= (1 + I)*COLOUR_WHEEL_LENGTH / 3)
I++;
if (p >= (COLOUR_WHEEL_LENGTH-1))
p -= ((p-= (COLOUR_WHEEL_LENGTH-1)==0) ? COLOUR_WHEEL_LENGTH-3 : COLOUR_WHEEL_LENGTH-1);
*R = colourR[p];
*G = colourG[p];
if (++ColPos >= (COLOUR_WHEEL_LENGTH))
ColPos -= (COLOUR_WHEEL_LENGTH);
*R = colourR[ColPos];
*G = colourG[ColPos];
colourPos += i;
while (colourPos >= (COLOUR_WHEEL_LENGTH))
colourPos -= (COLOUR_WHEEL_LENGTH);
Draw or clear a line (horizontal and vertical line) from x1, y1 to x2, y2
for (uint16_t y = y1; y <= y2; y++) {
LED(x, y, color.red, color.green);
for (uint16_t x = x1; x <= x2; x++) {
LED(x,y, color.red, color.green);
// Update in subclasses if desired!
drawLine(x, y, x, y+h-1, color);
drawLine(x, y, x+w-1, y, color);
int16_t steep = abs(y1 - y0) > abs(x1 - x0);
if (steep)
_swap_int16_t(x0, y0);
_swap_int16_t(x1, y1);
if (x0 > x1)
_swap_int16_t(x0, x1);
_swap_int16_t(y0, y1);
int16_t dx, dy;
dx = x1 - x0;
dy = abs(y1 - y0);
int16_t err = dx / 2;
int16_t ystep;
if (y0 < y1)
ystep = 1;
} else
ystep = -1;
for (; x0<=x1; x0++)
if (steep)
LED(y0, x0, color.red, color.green);
LED(x0, y0, color.red, color.green);
err -= dy;
if (err < 0)
y0 += ystep;
err += dx;
drawHLine(x1,x2,y1,color);
drawHLine(x1,x2,y2,color);
drawVLine(x1,y1,y2,color);
drawVLine(x2,y1,y2,color);
if (steep)
if (x0 > x1)
int16_t dx, dy;
dx = x1 - x0;
dy = abs(y1 - y0);
int16_t ystep;
if (y0 < y1)
ystep = 1;
} else
ystep = -1;
if (steep)
get_colour(colourPos+ 3*x0, &R, &G);
LED(y0, x0, R, G);
get_colour(colourPos+63+(x0+y0), &R, &G);
LED(x0, y0, R, G);
err -= dy;
if (err < 0)
y0 += ystep;
err += dx;
//increment_colour_pos(1);
Draw or clear a circle of radius r at x,y centre
// Bresenham's circle drawing algorithm
int x = -radius;
int y = 0;
int error = 2-2*radius;
while(x < 0) {
LED(xCenter-x, yCenter+y, color.red, color.green);
LED(xCenter-y, yCenter-x, color.red, color.green);
LED(xCenter+x, yCenter-y, color.red, color.green);
LED(xCenter+y, yCenter+x, color.red, color.green);
radius = error;
if (radius <= y) error += ++y*2+1;
if (radius > x || error > y) error += ++x*2+1;
timer1_isr_init();
timer1_write(60);
