Results 1 to 12 of 12
Thread: (another) Animated GIF player
    Jun 2020
    Rome, Italy
    16
    Long ago, in a job far far way, I wrote optimized image codecs for all standard image types. I've been slowly porting them to be compatible with Arduinos and today I got my old GIF player to run on the Teensy4. It still needs some cleanup before it can be released as an Arduino library, but today I got it running reliably.
    https://youtu.be/Bmqrxzmw30s
    It currently uses a lot of RAM and doesn't optimize the display writes, but I will get there in stages. Hopefully this will make it easier to use animated images on the Teensy when I finish it.
    Oct 2019
    285
    That looks quick!
    So you’re going to build a new library to play back the GIFs, or will it be an extension library that utilizes the APIs from display driver libraries such as ILI9341_t3n?
    Jun 2020
    Rome, Italy
    16
    Quote Originally Posted by Rezo View Post
    That looks quick!
    It's going to use my bb_spi_lcd library to draw on LCDs. It should be easy to modify it to use any other LCD library from there.
    I maintain this AnimatedGIFs "sketch", originally written for Teensy/SmartMatrix Library/SD card, but easily adaptable to other platforms: https://github.com/pixelmatix/AnimatedGIFs
    Adafruit adapted the sketch into an Adafruit Arcada specific library: https://github.com/adafruit/Adafruit_Arcada_GifDecoder
    I've forked their library to make it generic again, and it's now available here: https://github.com/pixelmatix/GifDecoder
    It sounds like you're coding your library from scratch, but I'm sharing anyway in case it helps. Looking forward to seeing your library!
    Jun 2020
    Rome, Italy
    16
    I've done some cleanup and testing. Here's the status so far:
    1) Written for any C compiler (no dependency on Arduino or anything else)
    2) Static GIF structure uses 22k of RAM; no other buffers needed and no use of malloc/free or any dynamic structures
    3) Can play files from memory (internal FLASH) or SD cards (seek and read callbacks)
    4) Uses a smart buffering system that de-chunks a few blocks of GIF data and doesn't have to constantly check for needing more data at each decode step
    5) Can display much quicker on systems with enough RAM to hold the destination image (transparent pixel rendering in memory versus moving the LCD write cursor)
    I'll share it soon; I'm still fleshing out the parts and I need to document it and provide examples.
    Jun 2020
    Rome, Italy
    16
    I finally got time today to work on this. I've been coding the SD card support and it basically works, but I've run into an odd problem. My code tries to read a fixed amount of data (2K) to parse the GIF header of each frame instead of calling read() tons of times with tiny buffers. The problem occurs when it reaches the end of the file. If the file position is at filesize-1k and I try to read 2K, it will correctly read 1k, but from that point on, seek() has no effect and the file is 'stuck' at the end. Has anyone seen this?
    Update:
    If found an ugly workaround - if I read up to, but not including the last byte of the file, seek() continues to work.
    https://youtu.be/8psIzfY2Ick
    Jun 2020
    Rome, Italy
    16
    I finished the code - please have a look and let me know what you think:
    https://github.com/bitbank2/AnimatedGIF
    Oct 2021
    19
    Teensy 3.1 Animated GIFs sketch not working...
    Quote Originally Posted by bitbank View Post
    I am having compile issues with AnimatedGIFs sketch for my Teensy 3.1 & SmartMatrix board. I got it all working in the middle of last year but now, using the exact same sketch and no changes, I only get errors that I don't understand. Is there an update that addresses these issues? I would like to get back my SmartMatrix screen display working properly.
    Here is the verbose output while trying to compile:
    /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware -hardware /Users/alfredolivas/Library/Arduino15/packages -tools /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/tools-builder -tools /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/alfredolivas/Library/Arduino15/packages -built-in-libraries /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/libraries -libraries /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=96,opt=o 2std,keys=en-us -ide-version=10813 -build-path /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_632896 -warnings=none -build-cache /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_cache_60728 -verbose /Users/alfredolivas/Desktop/Arduino/Sketchbook/TeensyGIFs_2022/TeensyGIFs_2022.ino
    /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware -hardware /Users/alfredolivas/Library/Arduino15/packages -tools /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/tools-builder -tools /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/alfredolivas/Library/Arduino15/packages -built-in-libraries /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/libraries -libraries /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=96,opt=o 2std,keys=en-us -ide-version=10813 -build-path /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_632896 -warnings=none -build-cache /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_cache_60728 -verbose /Users/alfredolivas/Desktop/Arduino/Sketchbook/TeensyGIFs_2022/TeensyGIFs_2022.ino
    Using board 'teensy31' from platform in folder: /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware/teensy/avr
    Using core 'teensy3' from platform in folder: /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware/teensy/avr
    Detecting libraries used...
    "/Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=155 -DARDUINO=10813 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_632896/sketch/TeensyGIFs_2022.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
    Alternatives for MatrixHardware_Teensy3_ShieldV1toV3.h: [SmartMatrix-4.0.3@4.0.3]
    ResolveLibrary(MatrixHardware_Teensy3_ShieldV1toV3 .h)
    -> candidates: [SmartMatrix-4.0.3@4.0.3]
    "/Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=155 -DARDUINO=10813 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/SmartMatrix-4.0.3/src /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_632896/sketch/TeensyGIFs_2022.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
    Alternatives for MatrixHardware_T4Adapter.h: []
    ResolveLibrary(MatrixHardware_T4Adapter.h)
    -> candidates: []
    /Users/alfredolivas/Desktop/Arduino/Sketchbook/TeensyGIFs_2022/TeensyGIFs_2022.ino:76:38: fatal error: MatrixHardware_T4Adapter.h: No such file or directory
    compilation terminated.
    Using library SmartMatrix-4.0.3 at version 4.0.3 in folder: /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/SmartMatrix-4.0.3
    Error compiling for board Teensy 3.2 / 3.1.
    Thanks in advance.
    Last edited by FredEBear; 02-09-2022 at 07:21 PM. Reason: Included verbose output from IDE
    Jun 2020
    Rome, Italy
    16
    Quote Originally Posted by FredEBear View Post
    Thanks in advance.
    Please post the error msgs; AnimatedGIF is working on my setups; I can't fix what I can't reproduce.
    The error is here (and unrelated to the AnimatedGIF)
    The file is now named `MatrixHardware_Teensy4_ShieldV4Adapter.h`. It was renamed as part of the SmartMatrix Library 4.0 release, you must have been using an older version.
    Feb 2022
    16
    Quote Originally Posted by embedded-creations View Post
    NOPE - Tried the changes here as suggested and still get the same error.
    Arduino: 1.8.13 (Mac OS X), TD: 1.55, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz (overclock), Faster, US English"
    /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware -hardware /Users/alfredolivas/Library/Arduino15/packages -tools /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/tools-builder -tools /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/alfredolivas/Library/Arduino15/packages -built-in-libraries /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/libraries -libraries /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=96,opt=o 2std,keys=en-us -ide-version=10813 -build-path /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_411163 -warnings=none -build-cache /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_cache_339882 -verbose /Users/alfredolivas/Desktop/Arduino/Sketchbook/TeensyGIFs_2022/TeensyGIFs_2022.ino
    /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware -hardware /Users/alfredolivas/Library/Arduino15/packages -tools /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/tools-builder -tools /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/alfredolivas/Library/Arduino15/packages -built-in-libraries /Users/alfredolivas/Desktop/Desktop - Alfred’s iMac - 1/Arduino/Arduino.app/Contents/Java/libraries -libraries /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=96,opt=o 2std,keys=en-us -ide-version=10813 -build-path /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_411163 -warnings=none -build-cache /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_cache_339882 -verbose /Users/alfredolivas/Desktop/Arduino/Sketchbook/TeensyGIFs_2022/TeensyGIFs_2022.ino
    Please post the full (not truncated) compilation log and your full sketch. Use gist.github.com or another text sharing service if it doesn't fit within a post
    Also, MatrixHardware_T4Adapter.h and MatrixHardware_Teensy4_ShieldV4Adapter.h are meant for use with a Teensy 4 (with an adapter to connect to a SmartLED Shield for Teensy 3). You're compiling for a Teensy 3. Something's wrong there.
