Hi all, I am new to the forum and new to coding and using teensyduino.
Bought a midi controller recently and wanting to control to guitar Strymon pedals. The code I have its for only 1 set of bank preset. I manage to add an extra MIDI channel for TRS MIDI
How do I send 2 separate set of PC to 2 different device?
Advice needed. Thanks!
//************LIBRARIES USED**************
// 'include the Bounce library for 'de-bouncing' switches -- removing electrical chatter as contacts settle'
#include <MIDI.h>
#include <Bounce.h>
//'usbMIDI.h library is added automatically when code is compiled as a MIDI device'
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
// ******CONSTANT VALUES********
//********** PIN DEFINITIONS
const int D_PINS = 5; // number of Digital PINS in main group (excl tap/bank)
const int DIGITAL_PINS[D_PINS] = {0,1,2,3,4}; // pins to switchs
const int RED_LED_PINS[D_PINS] = {6,22,10,17,19};
const int GREEN_LED_PINS[D_PINS] = {24,9,16,18,20};
const int MODE_TAP_PIN = 5; // momentary switch to set tempo and select bank
const int MODE_TAP_LED_PIN = 15; // pin to LED for tempo/bank indicator
//********** MIDI DEFINITIONS*************
// MODIFY THIS SECTION TO CUSTOMISE YOUR MIDISTOMP SIX
//const int firstchannel = 0; // MIDI channel for USB MIDI
const int secondchannel = 1; // MIDI channel for TRS MIDI
const int thirdchannel = 2; // MIDI channel for TRS MIDI
const int MODE_COUNT = 2; // number of rows of banks
//CC configuration matrix!!
const int MIDI_PC_NUMS[MODE_COUNT][D_PINS] = { //rows are banks up to MODE_COUNT
{0,1,2,3,4},
{5,6,7,8,9}
const int TAP_CC = 93;
const int ON_Value = 127; // note-one velocity sent from buttons (should be 65 to 127)
//********** PHYSICAL DEFINITIONS
const int BOUNCE_TIME = 30; // 5 ms is usually sufficient
const int modeThreshold = 800; // how long to hold before mode changes
const int flashOnTime = 150; // how long flashed LED is on
const int flashOffTime = 250; // how long flashed LED is off
const bool LED_ON = LOW; // LOW for active LOW wiring
const bool LED_OFF = HIGH; // HIGH for active LOW wiring
const int onClocks = 4; // number of clock messages with LED on for tempo flash
const int waitflash = 2; // number of dark flash cylces after bank change before tempo flash resumes
//******VARIABLES***********
// a data array to remember the current state of each switch
boolean state[MODE_COUNT][D_PINS];
elapsedMillis modeTimer,flashTimer;
boolean modeSelectActive = false;
int bank = 0 ;
int flashcount= (-1*waitflash); // default is effective sequence stop of flash counter
int shiftUp; // keeps track of whether the mode change needs to be handled (true) or was (false)
int modeLED; // keeps track of whether LED is on without testing it..
int ClockCount; // for tempo tracking
boolean tempoFlashOn = true;// tempo flash defaults to on
//************INITIALIZE LIBRARY OBJECTS**************
// initialize the bounce objects
Bounce digital[] = {
Bounce(DIGITAL_PINS[0],BOUNCE_TIME),
Bounce(DIGITAL_PINS[1], BOUNCE_TIME),
Bounce(DIGITAL_PINS[2], BOUNCE_TIME),
Bounce(DIGITAL_PINS[3], BOUNCE_TIME),
Bounce(DIGITAL_PINS[4], BOUNCE_TIME)
Bounce modeTap = Bounce(MODE_TAP_PIN, BOUNCE_TIME);
//************SETUP**************
MIDI.begin(MIDI_CHANNEL_OMNI);
//'set a handle for returning control change messages'
// usbMIDI.setHandleProgramChange(OnProgramChange);
usbMIDI.setHandleSongPosition(onSongPosition);
usbMIDI.setHandleClock(onClock);
usbMIDI.setHandleStart(onStart);
//'loop to configure input pins and internal pullup resisters for digital section'
for (int i=0;i<D_PINS;i++){
pinMode(DIGITAL_PINS[i], INPUT_PULLUP);
pinMode(RED_LED_PINS[i], OUTPUT);
pinMode(GREEN_LED_PINS[i], OUTPUT);
pinMode(MODE_TAP_PIN, INPUT_PULLUP);
pinMode(MODE_TAP_LED_PIN, OUTPUT);
digitalWrite(MODE_TAP_LED_PIN, LED_OFF);
digitalWrite(GREEN_LED_PINS[i], LED_OFF); // - GREEN OFF
digitalWrite(RED_LED_PINS[i], LED_ON); // - RED ON
//************LOOP**************
getMain();
getModeTap();
flasher();
while (usbMIDI.read()) {
//' controllers must call .read() to keep the queue clear even if they are not responding to MIDI'
while (MIDI.read()){
//************DIGITAL SECTION**************
void getMain(){
digital[i].update();
if (digital[i].fallingEdge() || digital[i].risingEdge()) {
if (state[bank][i]) {
// usbMIDI.sendProgramChange(MIDI_PC_NUMS[bank][i], firstchannel);
MIDI.sendProgramChange(MIDI_PC_NUMS[bank][i], secondchannel);
MIDI.sendProgramChange(MIDI_PC_NUMS[bank][i], thirdchannel);
}else{
//usbMIDI.sendProgramChange(MIDI_PC_NUMS[bank][i], firstchannel);
digitalWrite(RED_LED_PINS[i], LED_OFF);
digitalWrite(GREEN_LED_PINS[i], LED_ON);
state[bank][i] = !state[bank][i] ;
//************MODE/TAP SECTION**************
void getModeTap(){
modeTap.update();
if (modeTap.fallingEdge()) {
// usbMIDI.sendControlChange(TAP_CC, ON_Value, firstchannel);
MIDI.sendControlChange(TAP_CC, ON_Value, secondchannel);
// MIDI.sendControlChange(TAP_CC, ON_Value, thirdchannel);
modeTimer = 0;
shiftUp = true;
tempoFlashOn = false;
flashcount = 0; // is this error or magic?
Serial.println("suspend tempo on tap");
if (modeTap.risingEdge()){
shiftUp = false;
if (modeTimer<modeThreshold){
Serial.println("resume tempo no mode change");
if (modeTimer>modeThreshold && shiftUp) {
shiftUp = false;
bank++;
bank = bank%MODE_COUNT;
for (int i = 0; i < D_PINS ; i++){
digitalWrite(GREEN_LED_PINS[i], !state[bank][i]);
digitalWrite(RED_LED_PINS[i], state[bank][i]);
// set counter of flashes 'owed' -- count them down after main part
flashcount = bank + 1;
flashTimer = 0 ; // is this needed?
void flasher(){
if (flashcount>= -1*waitflash){
if (flashcount> 0){
if (flashTimer>(flashOnTime+flashOffTime)){
flashcount-- ;// decrement flashcount
flashTimer = 0;
if (modeLED){
modeLED = false;
}else{
if (modeLED == false && flashTimer>flashOnTime){
modeLED = true;
digitalWrite(MODE_TAP_LED_PIN, LED_ON);
}else{
flashTimer = 0;
}else{
if (!tempoFlashOn){
Serial.println(flashcount);
Serial.println("resume tempo after bank select");
void OnProgramChange(byte rcvChannel, byte controller, byte value) {
if (rcvChannel == secondchannel){
if (MIDI_PC_NUMS[bank][i] == controller) {
if (value >= 64) {
digitalWrite(RED_LED_PINS[i], LED_OFF); //'receiving >64 turns green on and red off'
state[bank][i] = true;
}else{
digitalWrite(RED_LED_PINS[i], LED_ON); //'receiving <64 turns red on and green off'
state[bank][i] = false;
} // 'if not the controller for i then skip this loop'
void onClock() {
if (tempoFlashOn){
if (ClockCount<=onClocks){
}else{
ClockCount = (ClockCount+1)%24;
void onStart(){
ClockCount = 0;
void onSongPosition(uint16_t semiQ){
ClockCount= semiQ*6 ;
